Index Test
Update (September 2, 2019): Apparently most of the links listed below are broken. I'll attempt to fix as I have time.
I don't like relying on my "Favorites" to find threads here on the forum.
I'm making an index of threads, I frequently link to or use, here.
Thanks to Humanoido for the idea of using a Test Forum post as an index.
This first post with be an index to the index.
Post #2: Personal Projects Index
Post #3: FAQ
Post #4: Machine Vision, Video Overlay, Fonts
Post #5: Miscellaneous and Unsorted Posts Including:
Tools for Prop Programming
Prop to Prop Communication
Prop Lab Equipment
Thermistor
Air Quality
Encoder
PWM
Wireless
Spinnerete/Ethernet
GPS
Auto Pilot
Gyro
Display Drivers
Sound with the Propeller
Enclosures
Batteries
PCBs
Electronics Information
Best Practices
Other
Prop Plug with Enclosure Ideas
Math
DIY Prop Plug
Medical Links
Pulse Oximetry
Post #6: AVR Stuff
Post #7: Displays
Post #8: Boards of Interest
Post #9: Items of Interest
Post #10: Servo Info., Say It Info. and Quadcopter Information.
Post #11: E-Books
Post #12: Robots and Robot Controllers Index
(Updated: February 15, 2020) Below is some information about nRF24L01+ module. These modules are often very inexpensive. Don't pay more than $2 for the simple module.
I have on occasion received a transceiver that didn't work. If you're going to buy nRF24L01+ modules, I'd suggest getting at least three modules in case one of the modules is DOA.
(8/6/13) Added eBay Nordic module schematic and PCB layout.
(8/18/13) Here's a datasheet to the Nordic nRF24L01+ chip. (Datasheet hosted on SparkFun's server.)
(8/18/13) My Propeller driver for these modules (new driver coming soon).
(8/18/13) Ron Czapala's driver for BS2.
(2/14/13) I'm now including dates of when a link is added. Hopefully this will make it easier for forum members to find new links.
Post #3: FAQ
Prop Lab Equipment
Thermistor
Air Quality
Encoder
PWM
Wireless
Spinnerete/Ethernet
GPS
Auto Pilot
Gyro
Display Drivers
Enclosures
Batteries
PCBs
Best Practices
Other
Math
DIY Prop Plug
Medical Links
Pulse Oximetry
Post #6: AVR Stuff
Post #7: Displays
Post #11: E-Books
Projects by Duane Degn
Omni Wheeled Plywood Base Bot (in Retrobot thread)
Mecanum Wheeled Robot with Machine Vision (Video)
The above includes my LED array
__Same Robot on Lets Make Robots
Stack of 23K256 SRAM chips with 8-bit bus
QuickStart Roomba
QuickStart Demos and Projects
Modifications to Tim Moore's four port serial object
__Improved version by Tracy Allen (Use this object when you want flow control or more than one port.)
____OBEX Version (fullDuplexSerial4port)
Lab data logging
Nordic nRF24L01+ driver
_Mark_T's Audio Streaming Object
Panic Buttons
Say It bridge program for Propeller
Relay powered cell phone dialer
Buffered 4x4 Keypad Object (I don't really trust this object)
Wearable Keypad Object
Serial port merger
Universe Remote (Using Rayman's PTP, just a picture)
QuickStart Servo Tester (Video)
Scribbler 2 Enhanced Obstacle Avoidance (Video)*
LED Flasher
Serial Barcode Reader
Propeller Driving 32 Servos (Video)
6-Digit 6.5" 7-Segment Display (Clock) (Video)
Popsicle Stick Hexapod (Video)
AS5055 Magnetic Encoders (now with software) (Video)
**Encoder PCB Designs
****(11/3/13) Mounting Encoder Inside Servo
**Encoder with Prop and Sigma-Delta
PropBOE Bot (Video)
**(11/3/13) Record and Playback of Path
Hexapod Build
PlayStation 2 With Analog Buttons
Pulse Oximeter Attempt (Video (poor quality))
Simple 74HC165 Object
8x8 RGB LED Array (Video)
Receive Six RC RX Signals on Any Pins (I only programmed the "any pins" part)
Polymorph Tutorial (Video)
(2/14/13)Rover 5 Thread *
__Same Robot on Lets Make Robots (Link Broken | Robot Shop Destroyed Let's Make Robots)
(2/25/13)Spark Fun (Fun with a Spark Gap Igniter)
(2/27/13)CheapBot (an Inexpensive BSA Robotics Merit Badge Bot)
(8/1/13) Mood Enhancing LEDs
(8/23/13) Using Variable Acceleration in Motion Algorithm
(10/16/13) NeoPixel Rings (WS2812/WS2811)
(10/16/13) Vex Tank Treads / Treaded Robot Idea
(11/2/13) Robot Remote
(11/3/13) P5587 Optical Encoders Inside a Servo
(11/18/13) Quadrature Encoders for the ActivityBot (Fixed Link 3/7/20)
(11/18/13) Search For an Avatar
(12/24/13) Investigating Stack Space
(12/28/13) Quadrature Encoder Software with PWM Included (4-channel and 2-channel)
(12/29/13) Power/Data Transfer Rings
(12/29/13) Object to Control LED Arrays with MAX7219
__Related Thread about Cheap 8x8 Arrays
(1/09/14) CNC Controller (just some starting questions)
(3/11/14) Piezo Speaker Music
(4/18/14) MFRC522 RFID Reader
(5/12/14) HMC5883L Compass Object with Demo
(10/3/14) Halloween Hex
(12/9/14)PING))) Object with Temperature Compensation
(12/9/14)Open Propeller Project #8 Eddie Firmware
(3/4/20)Eddie Firmware Used with Arlo Hardware
(12/9/14)Nona Prop (Nine Propeller on One PCB)
(1/12/15)Object to Test SF02 Serial Interface
(1/12/15)Open Propeller Project #4 ESC Programmer
(10/28/15)How to Use a L298N H-Bridge with a Microcontroller
(1/8/16)F32 as an EEPROM Cogject
(1/8/16)Four Port Serial as an EEPROM
Cogject
(7/12/16)F32 with Locks
(11/23/20)Sine Table Test aka MathTestSine.
*Listed in other places in the index.
How do I learn to program the Propeller chip?
(Broken Link)Propeller Education Kit (Also in "Help" menu of Propeller Tool)
This is probably the best place to start. Mostly Spin.
Propeller Resource Index (This is a stickie in the Propeller Forum.)
A lot of the the links in above index are also listed here.
Learn.Parallax.Com
This is another good place to start learning about programming the Propeller in Spin. These tutorials use the Propeller Board of Education.
Here's direct link to Spin tutorials on Learn.
Propeller Manual v1.0 (older version)
The older version of the manual include a section on learning to use Spin. This is the way I learned Spin.
Corrections to the v1.0 Manual.
Propeller AppNotes Lots of great information. Make sure and take a look a them. Spin and PASM.
(6/16/14) AN001 Propeller P8X23A Counters
(6/16/14) AN002 Real-time GPS Data Reception and Parsing
(6/16/14) AN003 Implementing Abstract Data Structures with Spin Objects
(6/16/14) AN004 GUI & Graphics Series – Getting Started with VGA and Terminal Output
(6/16/14) AN005 GUI & Graphics Series – Simple VGA Menus
(6/16/14) AN006 FAT16-FAT32 Full File System Driver Documentation
(6/16/14) AN007 Soft-loading an Application Image into the Propeller P8X32A via XBee Transceivers
(6/16/14) AN008 Sigma-delta Analog to Digital Conversion
(6/16/14) AN009 Code Execution Time on the P8X32A
(6/17/14) AN010 Low-cost Bidirectional Mixed-voltage Interfacing
(6/17/14) AN011 Simple Multicore Template for the Propeller P8X32A
(6/17/14) AN012 Interfacing the Propeller to External SRAM with SPI
(6/17/14) AN013 GUI & Graphics Series – Menus and Messaging with the Propeller Window Manager Framework
(6/17/14) AN014 Coroutines in Propeller Assembly Language
(6/17/14) AN015 Creating Schmitt-Triggered Inputs on the P8X32A Propeller Microcontroller
(6/17/14) AN018 Communication with a PC Application
(6/17/14) AN019 Measuring Stack Space for Parallel Processes
The Spin Zone: Adventures in Propeller Programming
Nuts & Volts articles by Jon Williams (JonnyMac) I finally figured out how to program with PASM from these.
(These also include lots of good information about programming in Spin.)
Programming and Customizing the Muticore Propeller Microcontroller
Not really an absolute beginner's book, but lots of good stuff. (Mostly Spin IIRC.)
(10/30/14) Jeff Ledger's Propeller Cookbook (Spin)
deSilva's Tutorial
This a good one for learning PASM. Potatohead's tutorial is also here.
Graham Stabler's Tutorials PASM
I personally haven't read these but they are recommended by others and Graham is a smart guy so they should be good.
The Hydra Book (Direct link to pdf (warning large file).)
This is a great book. It has lot of information about the Propeller video capabilities.
Propeller Wiki
Both Spin and PASM information.
Propeller Downloads
(1/12/14) PASM 101 - Manipulation Input and Output Pins
Tutorial by MJHanagan (A very useful guide dealing with controlling pin states with PASM.)
How do I use a SD card with the Propeller?
(3/26/14) Simple example of using uSD card with PropBOE
How can I tell if my EEPROM is 32K or 64K?
Use the program attached to post #24 in this thread.
More explaination.
(8/25/13) What EEPROM chips will work with the Propeller (booting from EEPROM)?
The datasheet for EEPROM chips apply to both surface mount parts and DIP packages.
32K EEPROM (link to datasheet)
64K EEPROM (link to datasheet)
128K EEPROM (no link yet)
Apparently there are several different 128K EEPROM chips which may be used with the Propeller. The upper 64K of the 128K EEPROM chips are accessed differently depending on the specific chip's protocol. Mike Green discusses this a bit in this post.
(1/9/14) Is there an ANDN equivalent in Spin?
How can I interface the Prop with a file on my computer?
Use Phil's program to read a write to Windows cvs files.
Also see AppNote #AN018.
How do I learn to build a robot?
Robotics with the Boe-Bot (Link to the book is near the bottom of the page, under "Downloads & Resources")
I like this book but I'm not a fan of Basic Stamps (Propeller are so much better).
The book still teach a lot about electronics which may be applied to a robot controlled by a Propeller chip.
If you need help converting any of the lessons to use with a Propeller, just ask on the Propeller Forum.
I understand Parallax is working on a Prop-Bot. I look forward to it.
Gordon McComb's Robot Builder's Bonanza 4th Ed.
Robot Forum
The Robot Forum is also a good place to learn about robots.
(3/11/13) Another great resource is the Society of Robots.
(3/18/13) Great robotics video found on LMR.
(3/18/13) If you haven't seen Let's Make Robots, go there!
(6/7/15) Chris the Carpenter's "Want to Build a Robot Video." These are great videos for someone deciding if they want to build a robot.
What are the requirements for the Boy Scouts of America Robotics Merit Badge?
Merit Badge Wiki
Forum Questions
How do I post code in the forum?
How do I add large inline pictures?
My method in post #15
Phil's method in post #7
How do I make a word or words a hyperlink?
My tutorial
(6/29/14) How do I get the Parallax corporate discount at Rocklin StayBridge Hotel?
(6/29/14) Ken's post on the topic
Placeholder
Machine Vision
Hanno's tutorial on machine vision
_SteveWoodrough's line follower using Hanno's method
_My example of using Hanno's method (also listed on post #2)
Gareth's "Halo" laser with Wii-mote project
Gareth's Wii-mote LIDAR
Phil's NTSC B&W capture
Phil's NTSC color capture
Phil's color imaging with line scan sensor
Using Parallax's Laser Range Finder as a camera
CMUcam4(forum discussion)
CMUcam4 for sale at SparkFun
(3/18/13)CMUcam4 GUI for PC
(3/20/13)Laser Range Finder Thread (About speeding up sample rate.)
(8/23/13) Another thread about speeding up sample rate.
(8/17/14) PropCAM Product Page
(8/17/14) PropCAM Image Processing Thread
Video Overlay
Propeller Backpack Custom Character Overlay
Fonts
(2/20/13) Reduced Size Propeller Font
Robot Navigation
(Not all navigation related links are here. Also check in post #5.)
(1/12/14) Laser Triangulation
(8/22/14) Distance Measurements
(8/22/14) Laser Range Finders
(8/22/14) Parallax's Laser Range Finder Product Page (designed by Joe Grand)
(There are additional links to the LRF elsewhere in the index.)
(8/22/14) SF02 Laser Rangefinder Product Page
(8/22/14) Ken Gracey's C Code for the SF02
(8/22/14) prof_braino's discussion of the SF02 (before it was carried in the Parallax store)
(8/22/14) Parallax Has a New Toy (started by idbruce)
(8/22/14) Original thread by Laser Developer about creating the rangefinder.
placeholder (otherwise the above link will merge with the next entry)
Tool for Prop Programming
PreSpin
Using eBay USB to Serial Boards as a Prop Plug (Broken Link)
Cheap Prop Plug Alternative
Prop OS
(3/20/13)Cluso99's OS
Prop to Prop communication
https://forums.parallax.com/discussion/127983/55-parallax-propellers-parallells-processing-of-permanent-perturbations.
https://forums.parallax.com/discussion/134641/demo-high-speed-multi-prop-to-prop-communication/p1
Prop Lab Equipment
Poor Man's Oscilloscope
EasyADC
Propalyzer
Beau's TV Oscilloscope
(9/22/13) Ahle2's Signal Generator
Thermistor
https://forums.parallax.com/discussion/129684/thermistor-cable-harness-tester
Thermal Imaging
Phil's Prop Thermal Imager
Air Quality
Chris Nafis Compares Two Particle Counters
Radon Detector Hack
Encoder
https://forums.parallax.com/discussion/134278/mysterious-rotation-sensor-disk
Graham Stabler's Magnetic Encoder Object
My AS5055 Project (Including Object)
Forum Links Below Broken
(4/13/13)Quadrature Encoder Tip/Walk Through at LMR
(9/29/13) Encoder Noise Picked up by Counters
(11/8/13) erco's P5587 Optical Encoders
(11/8/13) Phil's Refrigerator Magnet Encoder
CNC
(8/23/13) Don Starkey's CNC Object (forum discussion)
(9/10/13) TV and VGA for CNC Terminal
(4/15/14) Stepper Question
(4/15/14) Step Direction Generator
(4/15/14) Why Parallel
PWM
PWM With or Without Counters?
Hard Drive Motor Control
Wireless
http://forums.parallax.com/discussion/127780/Upload-Prop-programs-via-XBee
http://forums.parallax.com/discussion/113062/Radio-activated-voice-output-anemometer&p=809389
Martin_H's Wireless Programming Propellers with Wixel (Fixed Link)
BlueTooth
Ron Czapala's BS2 Code for Nordic nRF24L01+ Modules
Recover a Bricked XBee
OpenBeacon (uses nRF24L01+ transceiver)
Spinneret/Ethernet
Javalin's Fix to W5100_Indirect_Driver.spin
Mike G's Spinneret Manual
GPS
Andrew Williams' Propeller Based Handheld GPS with Full Code
Paul_H's Propeller GPS Datalogger
Chris Savage's BS2 GPS Datalogger
(5/30/13) Ragtop's GPS Logger
Auto Pilot Stuff
http://forums.parallax.com/discussion/131022/Propeller-DCM-Now-with-source
Gyro
lisy300
Display Drivers
http://forums.parallax.com/discussion/130531/jazzed-inspired-NTSC-PAL-Driver.
(2/20/13)HDTV Format Information
(7/25/13) Clock Loop's BlackBox (with digital audio SPDIF)
SIDcog - The sound of the Commodore 64 ! (forum)
__(OBEX)
Phil's Simple Class D Speaker Amp Using a MOSFET Driver
Phil's Who needs a speaker amplifier when you have a spare H-bridge?
Tracy Allen's Search for Loud but Small, Thin Audio Speaker
C3 Audio Concerns I
C3 Audio Concerns II
Veho 360 speaker
Phil's Audio Frequency Shifter
(11/11/13) Kye's Wave Player V2 (forum)
__(2/22/14) OBEX
(1/14/14) Tracy Allen takes apart a Veho 360
(5/3/14) Propeller Audio Links at Propeller Powered
FTDI Reset Issue
http://forums.parallax.com/discussion/143212/Play-simple-sound-files-from-an-SD-chip-using-the-Prop-BOE&p=1136037&viewfull=1#post1136037
(3/20/13)Kye's wav Recorder (OBEX)
(3/20/13)Kye's wav Player (OBEX)
(3/20/13)Phil's Goertzel Object with CTMF Decoding
(3/20/13)Color Organ Thread
(11/7/13) Retronitus
Ultrasound
(3/20/13)Shared Echo Pins of Multiple Sensors
Additional links which had originally been included in this post are now located in this post.
I thought I'd list some fo the useful sites I've found here.
Arduino
Derek Malloy's Intro to Arduino
Malloy's Arduino on a breadboard tutorial (video)
Malloy's AVR Dragon Intro (video)
AVR Freaks
Programing Propeller with ATtiny84
AVR ATtiny84 (Small Chip with lots of Memory)
AVR ATtiny2313 (Small Chip with UART)
Propeller Plus Arduino
(9/26/13) Propeller Shield Idea (Fixed Link 3/4/20)
(9/26/13) When the Propeller met the Arduino (Fixed Link 3/4/20)
Displays
Rayman's 3.5" LCD touchscreens
Rayman's Propeller Touchscreen Platform (rayslogic.com)
Rayman's 4.3" LCD touchscreens
Rayman's 4.3" LCD touchscreens (rayslogic.com)
Rayman's 4.3" LCD touchscreens low pins on PP
2.5" NTSC display ($10)
More info about 2.5" screen
2.4" TFT displays (from eBay)
(9/26/13) SDRAM Video Driver
Terminal Info
(9/26/13) VT100 on Wikipedia
(9/26/13) VT100 User Guide
(9/26/13) XTerm Control Sequences
LEDs
JonnyMac's WS2801 Driver (Fixed Link 3/4/20)
(7/1/13) tonyp12's 17-segment driver PCBs
_(7/1/13) Three Pin Version
_(7/1/13) One Pin Version
(9/2/13) SimplyTronics RGB 8x8 Array
_(9/2/13) Forum Sneak Peak
_(9/2/13) Forum Demo Code
_(9/2/13) Forum Tom Crawford's Demo Video
__(9/2/13) Includes Schematic in Post #13
(11/11/13) GE G35 Christmas Lights
(11/11/13) WS2801 Mood Enhancing LEDs Project (Fixed Link 3/4/20)
(11/11/13) Fun with NeoPixels Project (WS2812)
(Mostly Propeller Boards)
Tubular's Und3rb3lly
Tubular's Telit Board
Jazzed's TetraProp
Jazzed's SDRAM
Cluso's Cheap and Tiny Prop Boards
Cluso's Stackable Boards
Smorgasboard
Propeller Backpack (Product Page)
Propeller Backpack (Overlay Forum Post)
Items I own:
(Just some I want to be able to find quickly)
Parallax:
Propeller Boards
Propeller Protoboards
USB Propeller Protoboards
Propeller Professional Development Board
Propeller Demo Board
Propeller Backpack
QuickStart
C3 Full Kit
Hydra
Spinneret
Parallax Laser Range Finder
PropBOE
Ping
PIR Sensor
Ultrasound Transducers
SparkFun:
Nordic FOB
nRF24L01+ chip antenna
nRF24L01+ RP-SMA
nRF2401A chip antenna
XBee XSC wire antenna
XBee XSC RP-SMA
XBee ZigBee Pro wire antenna
XBee ZigBee Pro RP-SMA
XBee ZigBee wire antenna
XBee ZigBee RP-SMA
MicroMag 3-Axis Magnetometer
SoftPot Rotary
SoftPot 500mm
Dual Gearbox
Rover 5
Tank Treads
Mecanum Wheels (Vex Mecanum Wheels a lot better than these.)
Mouse Sensor (Parallax's version is better)
LinkSprite JPEG Color Camera
DealExtreme
6mm 5mW Laser Module
Electronic Goldmine
(4/26/14) 140:1 Gear Motors (Thread)
__(4/26/14) RobotRoom Info about Motors
Items I'm thinking about:
Holder for 5 AA Batteries
Futurlec beakout boards for smt parts
(5/11/14) Laser Scanner
Things Erco made me buy:
Ultrasound sensors
Purple batteries
Li Ion batteries (AA size)
Roomba
Roboni-I
Vex Mecanum Wheels
Switching Regulator
L298N Motor Controllers
(7/21/13) LiPo Battery Voltmeter/Alarm
(12/24/13) 10 x Red 8x8 LED Arrays
(12/24/13) Red 8x8 LED Array with MAX7219 Chip
(12/24/13) P5587 IR Encoders (he also gave me some)
(12/29/13) More Regulators
(5/11/14) Aluminum Wallets
(5/31/14) I2C RTC
(6/28/14) Sharp IR Sensors
Part Sources
TNC Scooter
Electric Scooter Parts
Micro Fasteners
Shopping List
Digi-Key To Buy List (updated 10/11/12)
74HC573 IO expanders for 144 servo driver
ATtiny2313
2.6V regulator
camera
grid_eye
smt ATtiny84 with leads
optoisolators
DC to DC chip
(6/19/13) +/- 30A Current Sensor
(6/19/13) Also +30A, 20A, 5A
(8/6/13) DC to DC again
Mouser To Buy List (updated 5/7/12)
1mm pitch, 10-wire ribbon cable (to use with 2mm IDC)
Pololu To Buy (and Already Purchased) List (updated 1/22/13)
Pololu Motors
37Dx54L 67:1 Gearbox Motor with Encoder
37D Motor Brackets
Mounting Hubs 6mm
MC33926 H-Bridge
MC33926 at Digi-Key
SN75HC165PWR at Digi-Key
Mdfly.com (updated 7/4/12)
MP3 Player with SD card holder
Pogo Pins
10mm Standoff
30mm Standoff
Other Prototyping Stuff
LED Heatsink
IR LED 1W
http://www.mdfly.com/index.php?main_page=product_info&cPath=87&products_id=483
Beau's 144 servo controller
Rayman's Servo Hack
Rayman's Serial Servo Attempt
Open Servo
ZoSuper Modified Servos
$3 Servo Tester
Hobby King HX12K Metal Geared Servo
Hobby King Vigor VS-11 Large Servo
Hobby King HXT900 Micro Servo
__LMR HXT CR Tutorial
Metal Gear 180 Degree Servo
My Servo Projects (Listed Previously)
QuickStart Controlling 32 Servos
Say It Stuff:
Martin_H's Robot
SayIt GUI and Example BS2 Code
SayIt Bridge Program for Propeller
Prop Voice Recognition
Chips to use with the Propeller
TC4427
QuadCopter Stuff
(9/18/14) ELEV-8 Tutorials on Learn.Parallax.com ****** Start Here ******
Forum Threads
Jason Dorie's QuadX
ELEV-8 Build Log
(5/25/13)Jason Dorie's Code for the HoverFly Sport See Jason's Thread listed below
ELEV-8 Assembly and Flight
ELEV-8 Cameras
ELEV-8 Connector Questions
ELEV-8 Radio Setup Questions
ELEV-8 Flight Simulators
ELEV-8 Batteries
Another Build Log (by CowboyCoder)
HackAWeek (MakerDino) Build Log Videos
(5/25/13) Competing Quadcopter Solutions
(5/25/13) Parallax and HoverFly: Relationship and Future Plans! (Ken Gracey)
(5/25/13) Jason Dorie's QuadX Open Source Quadcopter Firmware (Thank you Jason)
Related Links of Personal Interest
(5/27/13) HMC5883L 3-Axis Compass at HobbyKing
(5/27/13) ITG-3205 3-Axis Gyro at HobbyKing
Airspeed Sensor at DigiKey
http://www.kkmulticopter.kr/index.html?modea=manual
http://rcexplorer.se/Educational/kkguide/kkguide/quadx.html
http://www.hobbyking.com/hobbycity/store/__21977__HobbyKing_Multi_Rotor_Control_Board_V3_0_Atmega328_PA_.html
MultiWii at HobbyKing
MultiWii.com
MultiWii Google Code
HobbyKing $100 QuadCopter
Forum Post about $100 Quadcopter
Large Quad Parts (One I'm slowly building testing)
Plush-60A
Turnigy Outrunner
ELEV-8
Turnigy 2217 860 kV Outrunner
Control Board
PinOuts
Back
Hacking Spektrum and Orange Radios
rcgroup hacking Spektrum remote receiver
rcgroup hacking Spektrum telemetry
rcgroup BLDC controller
rcgroup Flyduino
Robot Builder's Bonaza 4th Edition
Forum
Amazon Link
Programming and Customizing the Multicore Propeller Microcontroller
Ebook
Intruder Alarms, 2nd Edition, by Gerald Honey
This ebooks will be here temporarily.
This book was deleted on March 5, 2012.
I had uploaded this ebook in response to this thread.
http://www.scoutstuff.org/bsa/uniforms-insignia/belts-buckles/belts/new-tiger-cub-web-belt.html
Robots:
Scribbler 2:
(2/22/14) Early Design Notes
Parallax's S2 Product Page
Parallax's Information and Downloads Page
Black Masking Tape
Sneak Peek
Pen Lifter
Internal Pen Lifter
Alphabet for S2”: A Collaborative Project
XBee Remote
Early S2 Thread
Reveals Soul (draws Propeller beanie)
S2 on Sale
Expansion Board
S2 Sound: Audio "Loudness" and Dynamic Range Compression
(2/14/13)Gwolfe's Custom S2 Software
PropBOE-Bot:
Product Page
Downloard Page
Learn.Parallax (tutorials on using a PropBOE-Bot)
Jose's QuickStart BOE-Bot
ActivityBot
(9/26/13) Any plans for Non-C-quot support for the ActivityBot?
(9/26/13) ActivityBot Encoder Resolution
(9/26/13) Boe-Bot Encoders (I think ActivityBot encoders cost the same.)
(9/26/13) Calibration failure
Rover 5:
SparkFun Product Page
(2/14/13)My Rover 5 Thread in the Robot Forum*
Roomba:
Magician Chassis:
Forum Post
Robot Parts:
Dual Gearbox with Motors
Cheap Omni Wheels
Treads
Lynxmotion Tread
Vex Tank Tread Kit
Tamiya Tank Tread
BOE-Bot Tread Kit
Rover 5 Treaded Robot
Bicycle chain tread
Mattracks (for trucks and ATVs)
(3/13/13)Thread about Treads on Let's Make Robots
Robot Controllers:
PJ's Cypherbot with Controller
Microcontrolled's Stingray Remote
Microcontrolled's Remote, Version 2
Propeller Wireless Intelligent Terminal (PWIT) (S2 Remote)
Paul K's XBee Robot Controller
TheGrue's Robot Remote
Robot Navigation:
Robot Location Thread
Compass Accuracy & Dead Reckoning
Autonomous robot's navigation
6DOF IMU
(9/26/13) Magnetic Tape Following Robot
(9/26/13) A* (A star) Algorithm on Wikipedia
(9/16/13) Wavefront Algorithm at Society of Robots
Bots to Find Again (robots I want to be able to find again)
Erco's Trash Bot
Erco's Retro Bot
Sphere Robot by Zenta
Prospero
(9/26/13) Dragon Robot
Sensors:
Ultrasound:
IR-augmented Echo-location with the Ping)))
IR:
IR Compound Eye
(1/15/14) IR Remote Projects:
(1/15/14) Ragtop's Project
(1/15/14) Podion's Project
(1/15/14) Beau's IR Remote Object in OBEX
IK:
Martin_H's Arm
IK thread in Robot Forum
* Listed in other places in index.
Have you to thank for the idea of using a test forum post as an index. (I just added a line to my first post about this.)
I considered use the blog area as an index but I like the way forum posts display better than the way blog posts display.
You also have to add some code to get links to show up in blogs.
I have a bunch of projects I haven't documented yet. Hopefully I'll have more to add to my personal project index soon.
Duane
(4/11/13) Some links I'd like to find again.
Robot Balances on Ball
Sea Water Antenna
Dead Reckoning Robot
Light Field Display
SLAM
Arduino IMU Code
LED Sensors
High Altitude Balloon Transmitter
(4/13/13)LMR Posting Suggestions
Placeholder
uSD cards from OBC
Tilt Compensation
(1/9/14) What are your 2014 projects?
(1/26/14) erco uses a Propeller
(4/23/14) 140:1 Inexpensive Gear Motors from Electronic Goldmine
(6/4/14) (130221 JBWolf) MPU6050 Thread
(6/4/14) (120925 StephenMoore) MPU6050 Thread
(6/4/14) MPU-6055 at Arduino Playground
(6/4/14) (120908 Kris Cardoen) Question about HMC5883L Compass
(6/4/14) (131219 Shawna) Tilt Compensation of HMC5883L (includes link to calibration information)
(6/4/14) USB in OBEX
(6/4/14) USB Thread
(6/4/14) USB Scanlime Website
(6/4/14) Cheap ($1.60) Bluetooth Dongle at DealExtreme
(6/17/14) BradC's USB Toys
(7/12/14) Ethernet and WiFi
(7/12/14) Bulk Buy #1 Purchasing WiFi Modules
(7/12/14) OBC's Webserver for Serial WiFi Module
Placeholder (otherwise links spill onto next line)
http://forums.parallax.com/showthread.php/158560-Propeller-controlled-Rover-5-bot
http://forums.parallax.com/showthread.php/158548-Old-Robots-and-Old-Guys
http://forums.parallax.com/showthread.php/154274-The-quot-Artist-quot-robot
http://forums.parallax.com/showthread.php/156644-Building-Arlo
http://forums.parallax.com/showthread.php/159608-Compact-use-of-gt-how-to
http://forums.parallax.com/discussion/144082/microsd-party-board-spi-widgets-for-microsd-enabled-prop-boards
Esp. "things erco made me buy"...
I know that list is woefully incomplete.
I'm hoping if I made an "erco deals I resisted" list, it would be longer than the "buy" list, but I'm not so sure it would be.
Thanks Whit.
I'm not as altruistic as this index may at first make me appear. I mainly made this index for my own use. I myself wanting to link to certain threads in my forum replies and I got tired of searching for these same threads over and over again. Most of the items in this index are things I'm very interested in myself. This index doesn't have much (if any) information I'm not personally interested in.
I also wanted a place to list my various projects.
Another forum member has made a similar sort of index. I thought I had a link to it somewhere in this thread but I couldn't find just now. This other index has a lot of great information. I'll try to find it again and made sure to add a link to it in post #1 of this index (I thought I had already done this).
As I've mentioned elsewhere in this thread/index, I got the idea of listing my projects in a test forum thread from Humanoido. I like many of Humanoido's threads listing threads on various topics (serial drivers, Propeller programming languages, multi-Propeller projects, etc.) and wanted to start some of my own lists on topics I'm interested in.
I don't mind at all. I got the idea from Humanoido.
I wish other forum members kept a list of their projects and forum threads they think are important or interesting. I think it would be fun to see what others have done and what they find interesting.
I use Rich's search page (linked to at the top of post #1) a lot but there are lots of threads which are hard to find through Google or the forum search page. I've found this list of links has been extremely useful.
You are so great !
I got here by clicking the link in your signature over in the thread where you gave me some ideas about providing 5 volts for the project board. WOW - this is a great resource. Thanks
Thanks, I'm hope it helps you find things.
You're very welcome.
Thanks but I disagree about this being made a sticky. A few years ago the first page in the Propeller Forum was half filled with stickies. I was very glad when they merged the stickies into the Propeller Resource Index (there is also a link to the PRI in post #3).
Unfortunately with the recent change in Parallax's website, many of the links in PRI are broken. (I hate it when Parallax breaks links like this.) I've tried to fix all the broken links in this thread.
duane, you seem like you know your stuff. i am in need of some assistance maybe you can help or point me in the right direction. i work for a tv station making commercials and i am always doing something on a computer. i have carpal tunnel and i believe arthritis is setting in on most of my fingers. i have been trying to mod mice, keyboards, gamepads, and old video editing control panels for some time now with varying levels of success. nothing has turned out like i wanted so i decided to get into the micro controller scene which is something i have always wanted to do anyway. i started with two trinkets from adafruit but they would never connect to my pc, the software would not install. a few days ago in radioshack i purchased two propeller p8x32a quickstart boards, two five position switches, and a few spdt-submini lever switches. i have also been disassembling any human interface device and collecting every button i could find for a year now. i am trying to emulate a mouse and keyboard so i can program hot keys for various applications. i would like to use the 8 touch buttons and the items listed but i have no idea where to start and i cannot find a tutorial that fits my needs please help.
My wife has carpal tunnel syndrome also and I've been investigating ways of making a custom mouse. I don't know how to emulate a mouse right now but I'll share what I've learned so far. There was a recent thread on this topic. I'll find the thread and add to this reply in the other thread. Once I find the other thread, I'll add a link to it here. I might not have time to reply properly until tomorrow.
I had to reboot after installing in order for my camera to work again. It seems like it might work well in certain situations.
I started a thread in the projects forum and included some links to HID information. I haven't done much more than read about the topic so far.
I tried to fix some links which were broken in the last forum migration but after fixing the links I received the following error:
Here's the content of what had been part of post number 5 (I miss post numbers).
Enclosures
List of Enclosure Websites
Plastics
(3/20/13)Mold Making Smooth-On (I haven't used them myself.)
Batteries
Some Discussion about NiMH Charging
Prop on Single LiPo?
PCBs
Making your own PCBs and links to pro sites
(link fixed 6/14/13) Iteads Studio 4-Layer Service 5cm x 5cm
PCBCart
OSH Park
Why Parallax switched from Eagle to DipTrace
(10/4/13) OSH Stencils
(11/9/13) PCB Component Models for DipTrace
Soldering
(6/14/13) TonyP's Toaster Oven
Driving Motors with Transistors (off site)
Best Practices
NASA Workmanship Standards
NASA Perferred Practices for Design and Test
Other
http://forums.parallax.com/showthread.php?130126-Parallax-Propeller-WiiMote-White-Board
http://forums.parallax.com/showthread.php?134929-Could-you-use-a-study-motivation-partner-Ham-Radio-Study
http://forums.parallax.com/showthread.php?127233-Automatic-Spin-Program-Documenter-(Online-version-now-available)&highlight=s2.spin
http://forums.parallax.com/showthread.php?86311-Propeller-Loader
http://forums.parallax.com/showthread.php?139928-Batch-job-object
Panel Mount Header?
With Metal Enclosure Ideas
Sliding Drill Press Vice to help Cut Holes
Math
Display Pseudo Real
F32 in OBEX
uM-FPU64 64-Bit Coprocessor
(3/20/13)Math Section of Propeller Wiki(11/24/14) Subscription Expired (dead link)
(4/22/14)Phil's and Tracy's techniques For Using Multiply High
(11/24/14)Bean's Signed Multiply and Divide in PASM
(11/24/14)Phil's Computing Running Median Code (Basic Stamp)
Humidity
(3/20/13)Sensirion SHT1x & SHT7x Integer Math Object
(12/8/13) Home Automation
Theads I want to reply to sometime
http://forums.parallax.com/showthread.php?135369-Propeller-Starter-Kit-Questions
http://forums.parallax.com/showthread.php?137692-writing-an-auto-ranging-program
http://forums.parallax.com/showthread.php?137728-Using-the-Web-to-control-servo-at-home-ideas
http://forums.parallax.com/showthread.php?137656-Can-anyone-Help-With-Atlas-PH-stamp-on-propeller
http://forums.parallax.com/showthread.php?137729-This-Old-BOE-bot
http://forums.parallax.com/showthread.php?132766-2.46-Battery-Voltage-Digital-Readout
http://forums.parallax.com/showthread.php?132164-inverse-kinematics
http://forums.parallax.com/showthread.php?137355-Phil-s-veho360-Speaker-Mount-on-a-Propeller-BOE-Robot
http://forums.parallax.com/showthread.php?137572-Futaba-s9254-servos
http://forums.parallax.com/showthread.php?118634-Autonomous-robot-s-navigation
http://forums.parallax.com/showthread.php?137983-Giraffe-Gait-ATTN-Duane-amp-Martin_H!
http://forums.parallax.com/showthread.php?140579-Help-with-assembly-code-size&p=1104730#post1104730
(9/26/13) Complementary-filter-equation
Reply soon
(9/26/13) Got-Dynamixels?
(11/10/13) Toddler
(11/10/13) Amazing Spin
(11/10/13) Chinese Dropout
(11/10/13) Quadrature Encoders
(11/10/13) S2 Radio-Controlled
(11/10/13) EasyVR Question
Unsorted
(8/9/13)
Logitech Joystick Hack
Trace Antenna
Propeller Logo Vector Format
What's Next?
Two-Buck Ultrasound
D.A,I,R. Better
USB Power to QS
Constant Q Spectrum Analyzer
Robot Servos
NeoPixel Ring
eBay Lasers
Blue
RGB
ScanLime's Laser Scanner
(8/20/13) Newport Linear Stage
DIY Prop Plug
120321
120528
Medical Links
Pulse Oximetry
TI Site
http://www.oximeter.org/pulseox/principles.htm
http://pinouts.ru/PortableDevices/nellcore_pulse_pinout.shtml
Ohio State DIY Pulse Oximeter
Freescale AppNote
What you should know about LEDs and PDs
Ken's Request for SpO2 Code
Test Photodiode
LMR Pulse Oximetry
Photodiode Question
(7/9/13) Toot Toot (Tooting my own horn)
(7/9/13) Unsung Hero Contest
(7/9/13) Project of the Week (Fourth of July week 2013)
http://forums.parallax.com/showthread.php?141462-Suggestions-needed-for-parts-selection-on-a-high-speed-PIN-photodiode-circuit
