multi-thread use of W5100_Indirect_Driver.spin — Parallax Forums
JavalinJavalin Posts: 892
edited 2012-03-01 17:49 in Accessories
All,
I'd like to raise/highlight an issue in the W5100_Indirect_Driver.spin driver relating to use of the W5100 chip from multiple Propeller cog's. As Microsoft would say - its not "thread safe"....
The ReadIND and WriteIND functions don't wait for the cog to complete its current action before setting the command variable and waiting output. For example if you're using (as I am) 3 sockets for a web server in one cog, and one for a dedicated client socket in another, it all goes badly wrong when both access the W5100 at the same time.
"fixed" code below:
PUB readIND(_register, _dataPtr, _Numbytes)
'' High level access to Indirect/parallel routine for reading from the W5100.
'' Note for faster execution of functions code them in assembly routine like the examples of setting the MAC/IP addresses.
''  params:  _register is the 2 byte register address.  See the constant block with register definitions
''           _dataPtr is the place to return the byte(s) of data read from the W5100 (use the @ in front of the byte variable)
''           _Numbytes is the number of bytes to read
''  return:  none
  'If the ASM cog is running, execute the command
  if (W5100flags & _Flag_ASMstarted)
    ' wait for the current command to complete
    repeat while command
    'Send the command
    command := _readIND + @_register
    'wait for the command to complete
  return 'end of readIND
PUB writeIND(_block, _register, _dataPtr, _Numbytes)
'' High level access to Indirect/parallel routine for writing to the W5100.
''  params:  _block if true will wait for ASM routine to send before continuing
''           _register is the 2 byte register address. See the constant block with register definitions
''           _dataPtr is a pointer to the byte(s) of data to be written (use the @ in front of the byte variable)
''           _Numbytes is the number of bytes to write
''  return:  none
    'Send the command
    command := _writeIND + @_register
    'wait for the command to complete (forced - declaration left as is for compatibility)
    'if _block
  return 'end of writeIND
The writeIND function - i've commented out the if _block statement as the function always needs to wait.
James
  • JavalinJavalin Posts: 892
    edited 2012-03-01 04:10
    continuing this - I've found some more functions that need to be updated with a:
              'wait for PASM to be idle
    Before the command variable is set - i.e.
    PUB Initialize(_socket, _mode, _srcPort, _destPort, _destIP)
    '' Open the specified socket in the specified mode on the W5100.
    '' The mode can be either TCP or UDP.
    ''  params:  _socket is a value of 0 to 3 - only four sockets on the W5100
    ''           _mode is one of the constants specifing closed, TCP, UDP, IPRaw etc
    ''           _srcPort, _destPort are the ports to use in the connection pass by value
    ''           _destIP is a pointer to the destination IP byte array (use the @on the variable)
    ''  return:  none
        'If the socket has memory allocated, execute the command
        if (rx_mask_S[_socket] <> 0)
          'Send the command
          command := _Sopen + @_socket
      return 'end of SocketOpen
    This needs to be done in the following functions : Initialize, Disconnect and Close
    James
  • Mike GMike G Posts: 2,702
    Nice work Javalin
