CMUcam4 Preliminary Feature List
Hey everyone,
I put this (attachment) together for the CMUcam4, enjoy!
Additionally, the preliminary command list is below:
Functionally Grouped Command Listing
- System Level Commands
- “GV” – Get Version
- “RS” – Reset System
- “SD” – Sleep Deeply
- “SL” – Sleep Lightly
- System Mode Commands
- “BM” – Baud Mode
- “DM” – Delay Mode
- “PM” – Poll Mode
- “LM” – Line Mode
- Auxiliary I/O Commands
- “PO” – Pan Output
- “TO” – Tilt Output
- “PI” – Pan Input
- “TI” – Tilt Input
- “GI” – Get Inputs
- “SO” – Set Outputs
- Button De-bouncer Commands
- “GB” – Get Button State
- “GD” – Get Button Duration In State
- “GP” – Get Button Pressed
- “GR” – Get Button Released
- LED Controller Commands
- “L0” – LED Off (0)
- “L1” – LED On (1)
- Servo Controller Commands
- “GS” – Get Servo Position
- “SS” – Set Servo Position
- “AP” – Automatic Pan
- “AT” – Automatic Tilt
- “PP” – Automatic Pan Parameters
- “TP” – Automatic Tilt Parameters
- Television Monitor Commands
- “M0” – Monitor Off (0)
- “M1” – Monitor On (1)
- “MF” – Monitor Freeze
- “MS” – Monitor Signal
- Camera Module Commands
- “CB” – Camera Brightness
- “CC” – Camera Contrast
- “CR” – Camera Register Read
- “CW” – Camera Register Write
- Camera Format Commands
- “BW” – Black and White Mode
- “HM” – Horizontal Mirror
- “NG” – Negative Mode
- “VF” – Vertical Flip
- Color Tracking Commands
- “GT” – Get Tracking Parameters
- “GW” – Get Tracking Window
- “ST” – Set Tracking Parameters
- “SW” – Set Tracking Window
- “TC” – Track Color
- “TW” – Track Window
- Color Statics Commands
- “GH” – Get Histogram
- “GM” – Get Mean
- “HT” – Histogram Tracking
- “MT” – Mean Tracking
- Image Filter Commands
- “IF” – Inverted Filter
- “NF” – Noise Filter
- Image Capture Commands
- “DB” – Dump Bitmap
- “DF” – Dump Frame
- “SB” – Send Bitmap
- “SF” – Send Frame
- File System Commands
- “CA” – Change Attributes
- “CD” – Change Directory
- “DI” – Disk Information
- “DS” – Disk Space
- “FM” – Format Disk
- “FR” – File Read
- “FW” – File Write
- “LS” – List Directory
- “MK” – Make Directory
- “MV” – Move Entry
- “RM” – Remove Entry
- “UM” – Un-mount Disk
