Free KISS OS to Current Customers - Page 5 — Parallax Forums
1235711
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-08-16 10:35
    OK, I have read the manual.
    I couldn't find anything that sounded like "teach", "learn", "recognition", "intelligence" etc.
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
    edited 2009-08-16 11:00
    To me it had shades of BASIC52 about it.
    Good to see some written clues, now we wait for those existing customers to put their head over the parrapet, and give a report.
    Style and grace : Nil point
    edited 2009-08-16 18:24
    I am inpressed! Nice manuel, care to define CRAM, ERAM, and DRAM?
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    But you·can·call me micro.
    If it's not Parallax then don't even bother.
    I have changed my avatar so that I will no longer be confused with others who use generic avatars (and I'm more of a Prop head then a BS2 nut, anyway)
    edited 2009-08-16 18:35
    If memory serves me well:
    CRAM = COG-RAM
    ERAM = External RAM
    DRAM = HUB-RAM
    Nick
    YADRO
    edited 2009-08-16 19:01
    ERAM, would you CRAM the DRAM please?
    B)
    Chat in real time with other Propellerheads on IRC #propeller @ freenode.net
    edited 2009-08-16 19:51
    Hi Mark,
    I am very happy to see some documentation start to appear, it actually helps me to understand what direction Dr. Jim is going in.
    ERAM = thumb drive Flash memory
    MRAM = hub memory
    CRAM = cog memory
    Correct?
    The listing of kernel functions helps a bit, however it does not show how the virtual memory works. It implies that the kernel provides the means to copy data to/from the three different types of memory, but that managing it is left up to the code running in the cogs. Is this correct?
    Will there be additional kernel calls that implement virtual memory and hide the differences between ERAM and MRAM (to use your terminology)?
    64 longs for the kernel seems too little to implement all the kernel functions. Are you using the LMM technique to execute code from the hub?
    Is there some locking mechanism to prevent user programs from trying to access "ERAM" at the same time?
    Bill
    mallred said...
    KISS OS has been released as an alpha version to our current customers. The beginnings of documentation are on the website. Also of note, for those of you who just need to be connected, we have a Wiffiti screen live on our homepage. The question to answer is "What is machine intelligence?" We look forward to your answers on our Wiffiti screen. Directions to text your answers is given on the website. See you soon.
    Mark Allred
    Machine Intelligence Technologies
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
  • mallredmallred Posts: 122
    edited 2009-08-17 00:11
    @Bill,
    Not sure about virtual memory, would have to ask Dr. Jim.
    The four types of memory.
    VRAM - thumb drive
    ERAM - extended RAM (our 2MB boards)
    MRAM - main RAM (32K Propeller Hub RAM)
    CRAM - 2K COG RAM
    Not sure what DRAM is.· Mabe a typo, or I would have to ask.
    About the access issue, Dr. Jim has said that only one ERAM chip will be active at any given time, so that probably takes care of any overlap issues.
    Mark
    edited 2009-08-17 00:21
    Mark,
    Bill was referring to the multiprogramming nature of the Propeller where you can have multiple processors all accessing the same I/O at the same time. There is built-in locking capability to make one processor wait until it's "safe" for it to access either a hub ram location (MRAM) or an extended RAM chip (ERAM), but you have to make use of it. It doesn't work by itself. Even if you have a single cog accessing the extended RAM at all times, multiple cogs could be making a request of some sort for access to the extended RAM and someone somewhere has to do the negotiating somehow.
    edited 2009-08-17 00:30
    @Mike
    Gotcha, probably handled in programming then. I'm sure Dr. Jim could elaborate.
    Mark
  • pmrobertpmrobert Posts: 677
    edited 2009-08-17 02:13
    Mark, it would be exceptionally helpful to have Dr. Jim spend five or ten minutes each day directly answering the technical questions.
    edited 2009-08-17 05:30
    seems that DR. Jim don't want to share technical details with mark
    I can't help myself: there are so many things mysterious about this project
    My doubts about seriosity stay and won't go away with what mark is posting here
  • Agent420Agent420 Posts: 439
    edited 2009-08-17 10:12
    Nick Mueller said...
    Not only is there no mention of the most hyped features of this "OS", but...
    MIT said...
    Known bugs
    2. the "RUN" command does not work properly. A new OS kernel will be sent as soon as this is fixed
    It doesn't even run a program?· What was the point of releasing this?
    Post Edited (Agent420) : 8/17/2009 10:58:43 AM GMT
  • PraxisPraxis Posts: 333
    edited 2009-08-17 10:44
    Agent420 said...
    It doesn't even run a program? What was the point of releasing this?
    None that I have been able to discern.
    Houston we have a problem.................
    Caelum videre iussit, et erectos ad sidera tollere vultus
    Certe, toto, sentio nos in kansate non iam adesse
    edited 2009-08-17 13:12
    Naa, that's OK! As long as there is no documentation how such a program should look like, where the hooks are to access the shades of xRAM, etc.
    mallred is the VP and COO. I've never seen a president making such a dis-service to his own company.
    Nick
    YADRO
  • LeonLeon Posts: 7,620
    edited 2009-08-17 14:06
    Mrs Allred is President. She ought to sack him.
    Leon
    Amateur radio callsign: G1HSM
    Suzuki SV1000S motorcycle
    Post Edited (Leon) : 8/17/2009 2:12:59 PM GMT
    edited 2009-08-17 15:47
    Just bought a new car and the salesman says we have a slight problem. The car doesn't start - LOL
    · Home of the MultiBladeProps: TriBladeProp, RamBlade, TwinBlade,·SixBlade, website
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index) ZiCog (Z80), MoCog (6809)
    edited 2009-08-17 19:45
    Mark,
    think about this:
    to avoid further damage to the image of your company you should consider a radical step
    take the whole KISS and AI thing out of your website, concentrate on developing it until it works properly
    and then come back and put it online again.
    If your AI modul is able to do just a bit more than
    nderwater Robots Work Together Without Human Input
    and you can show it IN PUBLIC You will get a lot of attention
    If you need money in the meantime - work as a millionaire or a dishwasher or whatever suits to you inbetween. (Except as a KISS AI-purchaser)
    I guess the earning will be bigger then selling 1 or 2 ExtRAM-boards to people who have fun on testing all kind of equipement
    and post critical reviews about it.
    best regards
    Stefan
    edited 2009-08-17 20:13
    Post as a blog, not a store. Show the current development status and update your site daily with what you accomplished on your debugger and OS. You can even post pictures to show what you are doing. If you didn't get anything major done just post "Standard Programming". This way your fans could keep track of your project on a day to day basis. You could even still sell your boards but keeping a log would encourage more people to buy them becouse they could see your current progress.
  • jazzedjazzed Posts: 11,803
    edited 2009-08-17 21:42
    Agent420 said...
    Hmm, maybe it just thinks about running programs.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-08-18 00:14
    Guys, machine intelligence is wide open. I invite any of you to invent your own version of machine intelligence and compete directly with us.
    As far as I know, we are the only ones claiming anything of substance that is workable. We will continue our work until we are done. When we are done, you will see videos on our blog of our machine learning. Even then I know we will be recieved skeptically. That's ok, because we are doing something worthwhile.
    Mabe we roll things out too early. That's probably true. So what. That only gives our followers a heads up and the ability to work with our products early. What's the harm in that, (other than you did not create it)?
    We will continue what we are doing at our own pace and eventually we will get there. In the end, our "vaporware" will be very real indeed.
    Mark
    edited 2009-08-18 00:39
    Mallred, allow me to introduce you to someone who claims something of substance that is workable:· http://en.wikipedia.org/wiki/Ben_Goertzel
    I hope you will notice that much of Ben's plan sounds exactly like yours.· He favors a learning approach, has had early and commercially viable succeses, has focused early on natural language, and believes that AI will arise by training itself by interacting with an appropriate environment.· He differs in having driven the focus artifically toward natural language for his early work and favoring artificial environments like Second Life instead of real robots to accommodate the learning process.
    He also has a real company (http://www.novamente.net/)·funded by non-trivial investors and is using real computers.· In fact his early efforts were focused on using the entire internet, showing that he does have a feel for the scale of the problem he is attacking.· And oh yes one other thing -- despite ten years of extremely well funded work, his creations have yet to use natural language to ask him a sensible spontaneous question.
  • SRLMSRLM Posts: 5,045
    edited 2009-08-18 00:54
    mallred said...
    Mabe we roll things out too early. .... What's the harm in that...?
    It's how people perceive your company. Right now, Kiss OS looks like the hobby of some college kid who doesn't want to share his secrets, but wants everybody to know how smart he is. It lacks professionalism.
    Post Edited (SRLM) : 8/18/2009 4:51:51 AM GMT
    edited 2009-08-18 01:11
    When the thing is working, we will have lots of offers. I'm not worried about that. They will have tons of money and polish it for us. Who cares about polish right now? We are eight months into our company and put out products on average once every two months. We are in the creative zone right now. Polish can come later. Same for professionalism. Let them do the TV commercials and packaging. We are concentrating on building the platform which will house our technology.
    At least no one is paying for the KISS OS right now.· It's free.· Our customers can play with it and get free updates for life.· Nothing wrong with that.
    Post Edited (mallred) : 8/18/2009 1:17:57 AM GMT
    edited 2009-08-18 01:35
    I have a new water run car for sale. Get in early and buy now, only $1,000,000. Engine, batteries, wheels, tyres etc will be free later. LOL
  • RossHRossH Posts: 5,645
    edited 2009-08-18 02:19
    ... must ... resist ... temptation ... to ... post ... DAMN!
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-08-18 02:29
    mallred said...
    And No Worky
    But No, Worky?
    Where be Run Command ?
    Why No Worky?
    Dis looky QUIRKY!
    YES, I buy now! ... but wait...·you say boat have BIG HOLE in it?!
    edited 2009-08-18 02:31
    By the way, it took a whole day to get the RUN command working. It's working now. Geez Dr. Jim is fast.
    edited 2009-08-18 02:41
    Howard, I think "water run car" was a reference to Brown's Gas, the water carburetor, or the H2O hydrogen fuel MPG booster [noparse]:)[/noparse]
    Ross? Ross? are you Ok Ross? I thought they got rid of you [noparse]:)[/noparse] Entertaining isn't it?
    If Dr. Jim looked at the OBEX, the run command would have worked last year! [noparse]:)[/noparse]
    --Steve
    mallred said...
    I can't believe that anyone who's serious about making a mark in their field would ever utter such tripe! It's never too soon to demonstrate — nay, exude — professionalism if you want anyone to take you seriously! Otherwise, you come off as two-bit hacks. No one forgets a first impression! I certainly won't forget this one!
    Post Edited (Phil Pilgrim (PhiPi)) : 8/18/2009 2:50:37 AM GMT
  • mparkmpark Posts: 1,322
    edited 2009-08-18 04:58
    Wait... if KISS OS is going to include voice recognition, shouldn't the hardware platform at least have some sort of microphone input?
