propmod_us and propmod_1x1 are in stock. Only $30. PCB available for $5
Want to make projects and have Gadget Gangster sell them for you? propmod-us_ps_sd and propmod-1x1 are now available for use in your Gadget Gangster Projects.
Need to upload large images or movies for use in the forum. you can do so at uploader.propmodule.com for free.
It should contain an upload. If not there I will reupload.
thanks. Was never ment as my main computer. bought for the 9 hour battery life when in school. Now batery is good for 2 to 3 only and my main PC has died. It is only a 1.3GHz and is pretty slow.
I program on a souped-up Gateway 2000. It looks like it just got dumped out of the back of a truck while going down the interstate, but it is the fastest 266Mhz computer that I have ever seen!!
▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔ Toys are microcontroled.
Robots are microcontroled.
I am microcontroled.
If it's not Parallax then don't even bother. :-) · I have changed my avatar so that I will no longer be confused with others who use genaric avatars.
Mini-Din/PS2 connectors are for sale! 5 for $1! PM me if you wish to make an order. Cheap·shipping unless specified!··········150 left!!··
Convert it to robotic uses. I'm thinking about totally revamping my computer, changing the motherboard and everything in maybe a year and using the old one for robotics. Hey, that reminds me, mabe I should ask for that motherboard for christmass... lol
here you go. If anyone feels like running with it. as mentioned before a prop based OTP encrypted communication device would be cool. ucontroler.com makes a good Ethernet module that would allow for coms over internet.
if anyone wants to make a String to MCVBEET1 object here is a lookup table. It is not an exact duplication. UNICODE and caps has been removed with ASCII altered to make the max length fit in 16bits.
$AABBCCCC
A=ASCII Equivalent
B=Length-1
C=Bit Sequence shifted to align on least significant bit.
The first 3 are not true ASCII characters
MCVBEET1 takes a big hit when letters are capitalized but even with 2 caps it is 11bits shorter the terminator is 8 bits longer then ASCII string so it only saves 3 bits in this short example but with longer sentences it can save a lot.
I went through all the code and understand it better but one thing I was wondering about is if I create a file do I just treat it like a long and stick one number or string in it, or is there a way to lengthen it and choose what part of the file to access? Please explain, it is necessary for my projects.
PUB mount(basepin)
' Mount a volume. The address passed in is passed along to the block
' layer; see the currently used block layer for documentation. If the
' volume mounts, a 0 is returned, else abort is called.
___________
PUB pflush
' Call flush with the current data buffer location, and the flush
' metadata flag set.
___________
PUB pclose
' Flush and close the currently open file if any. Also reset the
' pointers to valid values. If there is no error, 0 will be returned.
' Get the current date and time, as a long, in the format required
' by FAT16. Right now it"s hardwired to return the date this
' software was created on (April 7, 2007). You can change this
' to return a valid date/time if you have access to this data in
' your setup.
___________________
PUB popen(s, mode)
' Close any currently open file, and open a new one with the given
' file name and mode. Mode can be "r" "w" "a" or "d" (delete).
' If the file is opened successfully, 0 will be returned. If the
' file did not exist, and the mode was not "w" or "a", -1 will be
' returned. Otherwise abort will be called with a negative error
' code.
_______________________
PUB pread(ubuf, count)
' Read count bytes into the buffer ubuf. Returns the number of bytes
' successfully read, or a negative number if there is an error.
' The buffer may be as large as you want.
__________
PUB pgetc
' Read and return a single character. If the end of file is
' reached, -1 will be returned. If an error occurs, a negative
' number will be returned.
________________________
PUB pwrite(ubuf, count)
' Write count bytes from the buffer ubuf. Returns the number of bytes
' successfully written, or a negative number if there is an error.
_____________
PUB pputc(c)
' Write a single character into the file open for write. Returns
' 0 if successful, or a negative number if some error occurred.
_______________
PUB SDStr(ptr)
' Addition by John Twomey AKA: QuattroRS4
' Routine added to write a string
' Use as follows in Program -
' sdfat.sdstr(string("this string will be written to SDcard"))
' can also do -
' sdfat.sdstr(string("this string will be written to SDcard",13,10))
' the above adds CR & LF (Carriage Return and Line Feed)
_________________
PUB SDdec(value)
' Routine added to write decimal values to SD Card
' sdfat.sddec(25) ' writes 25 to SDCard
_________________________
PUB SDhex(value, digits)
' Routine added to write hexadecimal values to SD Card
' sdfat.sdhex(25) 'this example writes 19 to SD card
PUB SDbin(value, digits)
' Routine added to write Binary number to SD Card
' sdfat.sdbin(254,8) 'this example writes 11111110 to SD card
____________
PUB opendir
' Close the currently open file, and set up the read buffer for
' calls to nextfile.
___________________
PUB nextfile(fbuf)
' Find the next file in the root directory and extract its
' (8.3) name into fbuf. Fbuf must be sized to hold at least
' 13 characters (8 + 1 + 3 + 1). If there is no next file,
' -1 will be returned. If there is, 0 will be returned.
hard to concentrate on that stuff since im tired and mad cuz i just put a hole in the chicken coop door with my robot. now i have to fix that tomorrow along with every other broken thing on my robot.
short answer you can read any part of a file seqentially.
the wav player will show you how to read values in a specific expected order. if you want random i would make different files.
what im thinking for my robot is to save files like phone numbers, such as 1000 could refer to blackfoot where i live and 100 could refer to my neighborhood and 10 refers to my home. For each of these locations i would save the gps coordinates x to x and y to y that specifies this area. when the bot starts up it finds the coordinates of its current location and checks 1000, 2000, et cettera to find a match and goes down the list. when it reaches the end I want it to be able to find the coordinates of the obstacles for that area, such as my house and chicken coop and all the fencing and trees, then use them to make a map of where it should go to get to its destination. once this is figured out, it will go ahead and go there.
for my gg project it won't be so complicated, so knowing how to do this will make the other project easy.
sounds like a cool project. don't forget gps is only accurate to 3m or so. you can make more accurate though by measuring distance to known obstacle and keeping track of your movements.
I was thinking of having something like a haze area or whtvr, which would just add a couple feet or so and mark it as an area to avoid or if necessary approach slowly and use sensors to find the obstacles actual loction. I'm also hoping to let it tell the difference from animals and objects using ir heat sensors.
PG
@micro...: Thats what I thought when I first saw the bs2. now I just expect it
PG
It seems that they take really big pictures of electronics.....
PG
Not the fish.
sites.google.com/site/bitwinproject/
PG
PG
PG
Page with OTP info
Post Edited (mctrivia) : 8/6/2009 12:52:01 AM GMT
$AABBCCCC
A=ASCII Equivalent
B=Length-1
$000F8001 - end
$010F8000 - ascii
$020B080E - shift
$0D0E4001
$20080102
$240D2002
$250D2003
$2C0B080F
$2E0B0802
$300A0406
$310D2004
$320D2005
$330D2006
$340D2007
$350D2001
$360D200C
$370D200D
$380D200E
$390D200F
$4103000B
$42050001
$43040009
$44040015
$45020007
$46040002
$47050023
$48030006
$4903000D
$4A090207
$4B060041
$4C040014
$4D040001
$4E03000C
$4F030009
$50050021
$51090202
$52030005
$53030007
$54020001
$55040008
$56050000
$57040003
$58090206
$59050022
$5A090201
Example:
String: Hello World
ASCII:
0100100001100101011011000110110001101111001000000101011101101111011100100110110001100100 00000000 (88+8 bits)
MCVBEET1:
10000000111001101111010010100100110000001010000000111000011100101011010010101 1000000000000001 (77+16bits)
PG
PUB mount(basepin) ' Mount a volume. The address passed in is passed along to the block ' layer; see the currently used block layer for documentation. If the ' volume mounts, a 0 is returned, else abort is called. ___________ PUB pflush ' Call flush with the current data buffer location, and the flush ' metadata flag set. ___________ PUB pclose ' Flush and close the currently open file if any. Also reset the ' pointers to valid values. If there is no error, 0 will be returned. ' Get the current date and time, as a long, in the format required ' by FAT16. Right now it"s hardwired to return the date this ' software was created on (April 7, 2007). You can change this ' to return a valid date/time if you have access to this data in ' your setup. ___________________ PUB popen(s, mode) ' Close any currently open file, and open a new one with the given ' file name and mode. Mode can be "r" "w" "a" or "d" (delete). ' If the file is opened successfully, 0 will be returned. If the ' file did not exist, and the mode was not "w" or "a", -1 will be ' returned. Otherwise abort will be called with a negative error ' code. _______________________ PUB pread(ubuf, count) ' Read count bytes into the buffer ubuf. Returns the number of bytes ' successfully read, or a negative number if there is an error. ' The buffer may be as large as you want. __________ PUB pgetc ' Read and return a single character. If the end of file is ' reached, -1 will be returned. If an error occurs, a negative ' number will be returned. ________________________ PUB pwrite(ubuf, count) ' Write count bytes from the buffer ubuf. Returns the number of bytes ' successfully written, or a negative number if there is an error. ' The buffer may be as large as you want. _____________ PUB pputc(c) ' Write a single character into the file open for write. Returns ' 0 if successful, or a negative number if some error occurred. _______________ PUB SDStr(ptr) ' Addition by John Twomey AKA: QuattroRS4 ' Routine added to write a string ' Use as follows in Program - ' sdfat.sdstr(string("this string will be written to SDcard")) ' ' can also do - ' sdfat.sdstr(string("this string will be written to SDcard",13,10)) ' the above adds CR & LF (Carriage Return and Line Feed) _________________ PUB SDdec(value) ' Addition by John Twomey AKA: QuattroRS4 ' Routine added to write decimal values to SD Card ' Use as follows in Program - ' sdfat.sddec(25) ' writes 25 to SDCard _________________________ PUB SDhex(value, digits) ' Addition by John Twomey AKA: QuattroRS4 ' Routine added to write hexadecimal values to SD Card ' Use as follows in Program - ' sdfat.sdhex(25) 'this example writes 19 to SD card _________________________ PUB SDbin(value, digits) ' Addition by John Twomey AKA: QuattroRS4 ' Routine added to write Binary number to SD Card ' Use as follows in Program - ' sdfat.sdbin(254,8) 'this example writes 11111110 to SD card ____________ PUB opendir ' Close the currently open file, and set up the read buffer for ' calls to nextfile. ___________________ PUB nextfile(fbuf) ' Find the next file in the root directory and extract its ' (8.3) name into fbuf. Fbuf must be sized to hold at least ' 13 characters (8 + 1 + 3 + 1). If there is no next file, ' -1 will be returned. If there is, 0 will be returned.▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
PG
PG
PG
http://obex.parallax.com/objects/324/
PG
j:=sd.pread(@buff1, buffSize*4)
is @buff1 the location in the file (1 to whtvr) and buffsize the amount of info to read at that location?
PG
