New 4.3" touchscreen LCD for Propeller: "used" screens almost free w/purchase. - Page 13 — Parallax Forums
1101113151624
  • AribaAriba Posts: 2,697
    edited 2009-12-04 02:41
    Rayman said...
    M.E.S.H.: Thanks for sharing that photo of your setup BTW... It's nice to hear of people getting it working!
    I have also received my Displays today (shipped to Switzerland).
    Here is a photo.
    Thanks Rayman for giving away such a nice display for so little money.
    Andy
    387 x 400 - 19K
  • RaymanRayman Posts: 16,238
    edited 2009-12-04 02:49
    tdeyle: it's all on my website www.rayslogic.com !
    Ariba: That's a·clean looking·setup! Is that your own custom Prop board?
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2009-12-04 03:53
    Rayman said...
    Ariba: That's a clean looking setup! Is that your own custom Prop board?
    Yes it's my universal Propeller test board. It has 7 equal connectors with 4 I/O pins, GND and 3.3V. The connectors are
    compatible to the Digilent PMOD modules (and also to the first 6 pins on each side on a Propeller Protoboard).
    I have made a lot of modules, some are in the attached photo: SD card, another LCD, Capacitive Buttons, VGA/TV/PS2 module which uses 3 of the connectors, Audio out ...
    Program interface is a PropPlug clone with additional 5V from USB brought to the Test board.
    EEPROM and Voltage regulators are under the DIP Propeller.
    I call it the Propeller Puzzle.
    Andy
    424 x 300 - 16K
  • M.E.S.HM.E.S.H Posts: 18
    edited 2009-12-04 10:12
    Really nice work! Do you have any RTC and something in the 433MHz range of tranceiver "bricks" yet?
    With all these break-out components, and the great obex, finally it's possible to within a few hours/days of work step right into the application's end users perspective of the wanted propeller system. I remember programming 8 bit for the MC68HC11 w. 256 bytes ram 512 bytes Eeprom or something in that size, one entire project had one goal, like "I now have a program that decodes a 4x3 keypad" and it outputs the debounced-pressed key to a 2x16 char lcd, wow!! no more resources though..
    Well,
    The VGA/LCD driver is great
    The graphics driver is great.
    Breakout boards and other puzzle bricks are just great.
    "Everything is great."
    So the only "problem" now, is to create a "mixed mode of everything"
    * Text
    * Custom graphics tiles (symbols)
    * Touch clickable buttons (text or tiles?)
    * On screen keyboard
    * Overview lists (text) (windows listbox w up down arrow)
    * Sliders / progressbar
    * Probably a smaller grahics area, to monitor time/value samples.
    * Enough system resources left to handle SD, servo etc.
    I have tried many tv drivers, some vga drivers and now the lcd driver, seems like the mix between text & graphics melded into something that could act as the foundation to a presentation layer would be something for the skilled programmer, a GUI layer so to say? To give a layer ontop of the lcd/touch layer that gives you screen areas, realtime graph, something similar to click events etc.. Anyone has any tips?
    Saw another member asking about the vga tiles etc:
    Check out Rayman's propeller software page!, 1 bit, and 2 bit "image-to-propeller-vga-tiles" windows based single .exe programs - great stuff).
    http://www.rayslogic.com/propeller/Programming/Programming.htm
    /Magnus
    edited 2009-12-04 20:46
    Think we've settled on $18 as the new, long term price for the bare "used" 4.3" TFT.
    I'll start taking orders again in the next couple days...
    Breakout boards will stay $30 (If I were saavy I'd reduce it to $29.99 [noparse]:)[/noparse]
  • tdeyletdeyle Posts: 85
    edited 2009-12-04 21:03
    So it looks like the Prop won't have enough memory to display AND calculate, measure all of the sensors, and control a DAC output. I might have to run a dedicated Display Prop that takes care of that.
  • Luis DigitalLuis Digital Posts: 371
    edited 2009-12-04 22:06
    Hello Ray,
    In "PSB Paint Demo" is a line that says:
    lcd_backlight:=3 '1=bright, 16=medium, 32=dark
    But I see no change nor code PWM.
    Is that implemented?
    I tried with the object PWM v2.0 (Author: Beau Schwabe), and it worked.
    Here some results (My tool of measurement is not accurate.):
    PWM = 1:1 490 mA
    PWM = 1:4 385 mA
    PWM = 1:6 220 mA (Good choice.)
    PWM = 1:8 170 mA (Audible Noise, low frequency)
    PWM = 1:16 90 mA
    PWM = 1:32 40 mA
    PWM = 1:64 30 mA
    PWM = 1:128 20 mA (And still visible, audible high frequency sound.)
    edited 2009-12-04 22:08
    If one could choose, I hope the prop can do this dance, but otherwise it would be nice with some options. The lcd is 100%, it's now only a pure ram problem.
    I'm asking as well since I have no clue yet, but I guess as long as the end result allows for a graphics area that doesn't need double-buffering and that can be really small. (also perhaps in one bit color).
    The rest of the screen is text and a few custom tiles.
    To use the entire screen and plot the gui w. graphics needs more memory tough.
    I don't need fast updates in the graphics in my application, as long as the click irq from the lcd doesn't delay so it gets missed.
    But does this exist?:
    * a graphics chip that could handle compact serial commands (not serial transfer of bitmaps) and then act as a graphics adapter and generate the bitmap & control the lcd? (could be done on a prop 2?)
    A command like syntax, like svg, or damn it in worst case something html like, which is more or less end screen resolution independent, it's just a meta language, the choosen chip that follows the syntax chip will convert it to bitmap to vga, hdmi, lcd, e-mail / web-upload .png or print it or whatever.
    All chips that can send serial data could use it, if the application allows us to have a "uncertain/unknown/depends on what" refresh screen time, it might be possible, might even exist already, perhaps the same chip that controls the Oled screens could work with lcd screens or, well, I'm a new to this, hope for some hints if anyone out there is designing that kind of output from a propeller.
    edited 2009-12-04 22:54
    A chip like that could be made. My ai platform I am working on uses 8mw external ram to double buffer a 16bit screen and 64 sprites.
    24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
    edited 2009-12-05 00:12
    Luis Digital said...
    Hello Ray,
    PWM = 1:1 490 mA
    PWM = 1:4 385 mA
    PWM = 1:16 90 mA
    PWM = 1:32 40 mA
    PWM = 1:64 30 mA
    This function is implemented. But it can only work, if you use a LT3593 (or something compatible) to generate the LED voltage.
    The brightness control is not done with PWM, but this chips have internal 32 step LED current control, which you can set by toggeling the BL pin.
    Andy
    edited 2009-12-05 00:32
    Ariba said...
    Hello Ray,
    PWM = 1:1 490 mA
    PWM = 1:4 385 mA
    PWM = 1:16 90 mA
    PWM = 1:32 40 mA
    PWM = 1:64 30 mA
    Andy
    Now I see that has a counter and DAC.
    Thanks Ariba.
    edited 2009-12-05 00:47
    Just spent 2 hours trying to compress the 6-bit image data so that three bytes held 4 pixels. But, it's ending in disaster because the assembly driver is just not fast enough to decompress the data... [noparse]:([/noparse]
    edited 2009-12-06 19:47
    I just stumbled upon this thread: http://forums.parallax.com/showthread.php?p=606957.
    It describes a 2 bit VGA graphics driver that uses the 512x384 object. I attached it below.
    I tried to convert it to the 4.3" LCD by replacing the timings and pixel information in the CON section, but it does not work.
    I read in the post that it doubles the horizontal and vertical pixels from 512x384 resolution to 1024x768, and if the monitor you are using does not handle this res, then it will not work. So I halved the pixel information to see if the driver would work.
    No dice.
    So I was wondering if it was possible to adapt it, since it was essentially a monochrome graphics driver and should be within the limits of the Prop's memory.
    edited 2009-12-06 21:03
    I have adapted this driver to the 4.3" LCD last night [noparse]:)[/noparse]
    I made 3 versions:
    480 x 272 1-bit pixels, uses 16 kByte of memory
    240 x 136 1-bit pixels, uses only 4 kByte
    240 x 136 2-bit pixels, uses 8 kByte memory
    Every pixel of the 240x136 modes spans 4 TFT pixels so it fills the whole screen.
    I find the 4 color 240 x 136 the most useful.
    I need to polish the code a little bit and make a demo.spin, so I will release the drivers maybe tomorrow.
    Andy
    edited 2009-12-06 21:21
    That's awesome! I am guessing from your post that it took more than just changing settings, more like rewriting the ASM section.
    Since I am trying to learn Propeller Assembly, I am excited to compare the changes that were made from the original driver!
    edited 2009-12-06 22:35
    No, this driver is very easy to understand, and requires only a few changes. Mainly the pixel clock output and DataEnable.
    The nice thing is that the display is not so timing sensitive as VGA Monitors, it works with Vertical and horizontal frequencies in a wide range.
    I have attached an early version of the 240x136x1 driver with the VGA Demo and graphics-driver you posted.
    This Bitmap driver version has the fewest changes, so it's the best to compare with the original. But the last rows do not work.
    The newer drivers, which I will post later allows to pass the Pin settings to the driver, so no constants in the driver must be changed.
    The driver has a little test code incorporated, so you can first try the TDS__.spin file alone. Then try it with the demo.spin.
    Andy
    edited 2009-12-07 13:57
    Ariba said...
    I made 3 versions:
    Ariba:· I would love to see the 480x272 version!· Can different rows have different colors?
    edited 2009-12-07 14:03
    I spent hours yesterday doing everything I could think of to increase the framerate of the 6-bit fullscreen driver, but can't get much past 11 fps.
    It's not too bad, considering, but the flicker is still noticeable...
    Think I'll wrap that up and try a new version with the graphics limited to a 320x240 area. That should let me up the rate.
    Think I need about 20 fps to reduce the flicker to acceptable levels...
    I originally though I had no flicker with much lower fps, but I was duped by a bug in the Parallax VGA code that doesn't do the pixel clock correctly when it's below 4_000_000...
    edited 2009-12-07 16:02
    Rayman said...
    Ariba: I would love to see the 480x272 version! Can different rows have different colors?
    The colors are now settable for every 32x32 pixel tile, like in the VGA original driver.
    But I can make a version with 1 color per row (=272 words for the colors).
    It would also be possible to change it only every n rows, i.e 8 rows for text lines. Just say what you need [noparse];)[/noparse]
    Andy
    edited 2009-12-07 16:21
    Per tile coloring is perfect... Does it have to be full screen? I can see cases where you only need 1-bit graphics in a less than a fullscreen window...
    edited 2009-12-07 17:44
    You can change some constants for pixel width and height, to get a lesser size, but the window is then always top left placed.
    It would be possible to add a left and top margin, but the current driver hasn't that implemented.
    It is really only a bitmap driver, and you can't use the remaining part outside the window for anything other.
    The tiles are only for defining the colors.
    edited 2009-12-07 17:57
    Can the 240 x 136 modes be double buffered?
    I wonder if there's a way to use the SD card or EEPROM as the second buffer for a 480x272 mode...
    edited 2009-12-07 18:13
    Double buffering with 2 buffers in RAM is certainly possible. It has a sync indicator to know when to switch the buffers.
    I don't know if SD as double buffer will be fast enough...
    It's the best I release the code now....
    edited 2009-12-07 18:14
    OK, here are my Bitmap drivers for the 4.3" LCD.
    There are 1 bit per pixel drivers in HiRes- and LowRes versions (480x272 and 240x136 pixels).
    The color is definable per 32x32 pixel tile.
    HiRes is usefull when you will draw a lot on the screen, but needs 16 kByte memory.
    LowRes is mainly for application which has not much RAM free for the screen, LowRes needs only 4.2 kByte.
    Then there is also a 2 bit per pixel driver with 240x136 pixels. Every pixel can have 1 of 4 colors. Individual 4 colors
    are definable per 48x32 pixel tiles. This gives 5 x 5 tiles, which is a good size for touch buttons. The first line of tiles
    is only 10 pixels in height, this can be used for a Titlebar with its own colors.
    A demo code is included in the ZIP, which works for all drivers. You just need to change the driver in the OBJ section.
    The demo shows the color tiles, and draws pixels and lines. I've tried to make a photo, but my camera is not good
    enough, to show details sharp, so perhaps somebody else can make a screenshot.
    Andy
    Edit: Updated also the comments and description to the right version.
    Post Edited (Ariba) : 12/7/2009 6:53:39 PM GMT
    edited 2009-12-07 20:05
    I'll take a photo when I get home, if no one beats me to it...
    edited 2009-12-08 00:59
    Here's a couple·photos and a·little video of it running in high-res, 1-bit mode...
    Post Edited (Rayman) : 12/8/2009 1:07:38 AM GMT
    1496 x 1122 - 553K
    1496 x 1122 - 483K
    edited 2009-12-08 02:19
    Here's a new screenshot and latest (final?) version of the fullscreen 6-bit driver.
    It's at 11 Hz refresh, which gives a noticeable flicker to the eye, but looks great on camera!
    edited 2009-12-08 02:26
    In case anybody is brave enough to try this themselves...· Here's how I prepared the image in Photoshop:
    1.· Resize to 480x272
    2.··Image-->Mode-->Indexed Color
    and then choose the settings as shown in this photo.
    Save as .png and then use that with the 6Bit dat generating app, I posted earlier...
    773 x 517 - 119K
    edited 2009-12-09 05:03
    Rayman
    I tried your 6 bit driver, but my SD card is to slow (a 512MB older card). I get only the half buffer filled for every
    16 lines.
    I tried to slow down your video driver, but as you say before, the pixel clock seems not to work under 4 MHz.
    So I decided to reprogram a 6 bit Fullscreen driver starting from my Bitmap drivers. And it was not very hard.
    I have attached the result in the ZIP. It contains only the changed files (demo-code and driver) the other objects
    are in your PSB_6bitDemo Archive.
    This driver allows to adjust the Pixelclock in 0.3 MHz steps (5/16 MHz). And I also found that it's the best when the
    Sync Signal for buffer filling comes after a 1/4 of the buffer is outputed by the driver.
    I have the feeling that the flickering is lower, but I can't really say, because I see only the half picture and some
    changing lines with your driver.
    It's very easy to change the driver to 480x136, and I also have tried a 240x272 version which is not so bad, perhaps
    for a movie player with higher frame rate.
    I hope this will be usful for you
    Andy
    edited 2009-12-09 12:46
    Great!· More the merrier...
    I'm surprised your SD would be slower, mines a very old 256 MB card...· Maybe it's fragged...
    Anyway, you could have also used this parameter to slow down the refresh rate in my driver:
    _hd                     long     1200'512'512       '1+             read-only
