New SD mode P2 accessory board - Page 2 — Parallax Forums
2456736
  • evanhevanh Posts: 17,069
    edited 2022-11-14 10:33
    Hmm, yeah, that's about the only smartpin mode that does both input and output combined. And it was a late addition at that. JMG requested it I think.
  • Just messed with SMPS smartpin mode and got something experimentally working to light the activity LED (P38) in sympathy with the SD CS signal on another pin (P35) going low and turning off when high. Another small bonus is that its brightness when lit (or off) can also be controlled via a PWM value. :smile:
    This combination seemed to work:
        _dirl(38); // pin 38 = LED (active low), 35 = !SD_CS
        _wrpin(38, 0x0d000054); // A=pin B=inv(38-3=35), SMPS mode
        _wxpin(38, 0x01000010); // base = $10, period = $100
        _wypin(38, 0x100); // PWM level
        _drvl(38);  // enable smartpin
        while(1)
            _pinl(35);
            printf("%8x\n", inb);
            _waitMs(500);
            _pinh(35);
            _waitMs(500);
  • Your choice of MOSFET has a questionable gate cutoff voltage and Rds(on). A NTJD4152P will fit in the same footprint, but turns on at a significantly lower gate voltage, which should guarantee <250mOhm at 3.3v drive, while the UM6J1NTN only describes Rds(on) at 4v drive (with .75v potential offset) at 1.2ohms.
    Some inconsistent behavior may be fixed by changing it.
  • roglohrogloh Posts: 6,245
    edited 2022-11-15 08:35
    Yeah @Circuitsoft it's not necessarily the ideal part for the job and I wouldn't want to choose it for any production. I did notice the Rds was a little high as well at the time and the curve was not shown for -3.3Vgs, but for the smallish SD current draw and reservoir cap fitted on the output it might help form an RC filter for the SD supply to remove noise. Also the doubling up should actually help halve the Rds resistance. Certainly if I do see strange behavior I can try to replace it.
    EDIT: I should just throw a set 150mA current load on the SD power pin and see what drop I get across the pFET pair...
    EDIT2: Did just that. Voltage dropped from 3.32 to 3.13 with 22ohms put directly across the main capacitor (142mA load + few mA of power LED current). So not too bad under load and similar to some 5% power supply tolerance effect. It acts like a 1.3 ohm resistor at this current.
    EDIT3: Actually the above was with the SD card fitted too. When I removed the card and re-applied the 22ohm load resistor, the voltage only fell to 3.15V so it's more like 1.2 ohms at that load.
  • Had a quick play around tonight with the SD card's CMD signal and some SPIN2 test code and hit the first snag.
    I'm trying to generate a 48 bit command on the SD CMD pin using the sync tx smart pin mode and the SD CLK pin as the clock source, driven in a smart pin pulse mode by the P2 to control the clock cycles. I setup the sync tx to generate 24 bit data which I send twice to form the 48 bits. But I'm seeing the output clock lag by one data bit which is weird. The clock is started manually in pulse mode so I can send 24 clocks at a time.
    I want the clock to be idling high (active low) so the pullups can keep it under control if/when it's released, in reset etc. The pulse output mode normally idles low so I've inverted its output. I've also inverted the clock source input for the sync tx smart pin so the data bits change on the falling edge of the clock input.
    In my capture the data bits are changing on the falling edge of this clock which is good, but the problem is that everything looks to be off by one bit below. How can the data be getting generated before the clock pin actually transitions low and is detected by the sync tx smart pin? It's weird. Must be doing something wrong.
    Here's the sample test code and what I'm seeing on the two P2 IO pins (CMD and CLK).
    CON
     BAUD = 115200
     SD_CMD = 4
     SD_CLK = 5
    OBJ
        f:"ers_fmt"
        uart:"SmartSerial"
    PUB main() | x
        uart.start(BAUD)
        send:=@uart.tx
        send("Press a key to start SD test...")
        send(uart.rx(),13,10)
        send("Initializing pins",13,10)
        initpins()
        send("Sending command",13,10)
        sendcmd(3, $55)
        send("Done",13,10)
        repeat
    PUB initpins()
        ' setup the clock pin
        pinf(SD_CLK)
        wrpin(SD_CLK, P_INVERT_OUTPUT | P_OE | P_PULSE) ' want active low clock, idling high
        wxpin(SD_CLK, 500<<16 | 1000) ' 50% duty cycle, divide clock by 1000 for testing with logic analyzer
        pinh(SD_CLK) ' enable the clock smart pin
        akpin(SD_CLK)
    PUB sendcmd(cmd, arg) | crc7, a, b
        ' todo: compute crc7
        crc7 := 0
        send("cmd=",f.hex(cmd), ", arg=", f.hex(arg),13,10)
        send("cmd|arg|crc = ",f.hexn(cmd, 2),f.hexn(arg,8),f.hexn((crc7<<1)|1, 2),13,10)
        a := (cmd << 24 | arg >> 8) rev 31
        b := (((arg & $ffff) << 16) | (crc7 << 9) | $100) rev 31
        send("a=",f.hexn(a,6), ", b=", f.hexn(b,6),13,10)
        pinf(SD_CMD) ' reset smart pin
        wrpin(SD_CMD, P_INVERT_B | P_PLUS1_B | P_OE | P_SYNC_TX) ' sync tx mode, clk is pin+1 inverted
        wxpin(SD_CMD, %1_10111) ' will tx 24 bits twice
        wypin(SD_CMD, a) ' prepare first 24 bits
        pinh(SD_CMD)
        wypin(SD_CLK, 24)' send first 24 bit clocks
      ' send("1",13,10)
        repeat until pinread(SD_CLK) ' wait until all clocks are sent
        akpin(SD_CLK)
        wypin(SD_CMD, b) ' setup next 24 bits
        wypin(SD_CLK, 24) ' send second 24 bit clocks
      ' send("2",13,10)
      ' send("3",13,10)
        pinf(SD_CMD) ' reset smart pin once done
        akpin(SD_CLK)
    edited 2022-11-20 10:45
    You'll be getting some excess old bits left in the shifter. I had a horrible time trying to get consistency from the tx smartpin's "start-stop" mode. I found "continuous" mode far better to run smoothly. But continuous mode does, of course, requires a little more management with the DIR low/high start sequencing.
    Here's an example working SPI snippet from sdmm.cc:
    // Smartpin SPI transmitter using "continuous" mode and 32-bit word size
    //   NOTE: data out always has at least a 4 sysclock lag
        __asm const {       // "const" prevents use of FCACHE
            dirl    PIN_DI      // reset tx smartpin, clears excess data
            setq    #1
            rdlong  bc2, buff   // fetch first data
            rev bc2
            movbyts bc2, #0x1b  // endian swap
            wypin   bc2, PIN_DI // first data to tx shifter
            mov bc2, bc
            shr bc, #2  wz  // longword count (rounded down)
            shl bc2, #3     // bit count (exact)
            wypin   bc2, PIN_CLK    // begin SPI clocks
            dirh    PIN_DI      // liven tx buffer, continuous mode
            add buff, #8
            rev d
            movbyts d, #0x1b    // endian swap
    tx_loop
        if_nz   wypin   d, PIN_DI   // data to tx buffer
        if_nz   rdlong  d, buff     // fetch next data
        if_nz   add buff, #4
        if_nz   rev d
        if_nz   movbyts d, #0x1b    // endian swap
    tx_wait
        if_nz   testp   PIN_DI  wc  // wait for tx buffer empty
    if_nc_and_nz    jmp #tx_wait
        if_nz   djnz    bc, #tx_loop
    // Wait for completion
    tx_wait2
            testp   PIN_CLK  wc
        if_nc   jmp #tx_wait2
            dirl    PIN_DI      // reset tx smartpin to clear excess data
            wypin   ##-1, PIN_DI    // TX 0xFF, continuous mode
            dirh    PIN_DI
    PS: Variable "d" is located immediately after "bc2" in cogRAM. The SETQ/RDLONG fills both with the first 64 bits of data. It was a late change and I never commented on it in the source code.
  • Yes, I think what might be happening is that the LSB data bit0 is already in the shifter and when the first clock happens then bit1 is clocked out. I can probably fix this by shifting the 24 bits up one bit before writing the data with WYPIN...
    edited 2022-11-20 10:51
    Oh, you're actually using start-stop wrongly. You're meant to make DIR high before WYPIN. What you've done would suit continuous mode.
  • Well it's ugly but it works.
    I've set it up for transmitting 25 bits in each half of the 48 bits. I shift the first data half by a bit but I don't need to shift the second half. I've put one bits in the start and end of each half and it seems to be doing the right thing.
    Yeah I think I got that control bit the wrong way around. I'll have to try the other option out.
    edited 2022-11-20 10:58
    With receive on the CMD pin it'd be nice to be able to use async RX mode given that the response from the SD card starts with a zero bit. But we need to receive more than 32 bits. I wonder if there's some way to start out in async mode and then somehow switch on the fly into sync mode at some given boundary. Maybe by stopping the clock after the first bit arrives or something. I was also wondering if my LED pin could be used as a receiver helper by running it as another smartpin in sync rx mode somehow triggered after the async rx smartpin interrupts to get the remaining data....? The LED can still potentially be controlled by its OUT pin.
    edited 2022-11-20 11:20
    Yeah, I've not looked at SD rx timings at all yet. I fear using the streamer will result in needing a working buffer to extract the valid data from. On the other hand, if CRC is to be validated then such a working buffer will be needed anyway.
    Ie: I've not seen anything that states a particular number of clocks from command to response nor to rx data block start. It seems to be whatever the SD card feels like within the timeout limit. Up to 100 ms.
    edited 2022-11-20 11:18
    Yeah the streamer might not be a go for DAT pins. Because sector data appears to be sent MSB first, which doesn't make a lot of sense to me. I think what might make sense is to read nibbles synchronously and assemble bytes, compute CRCs and write to LUTRAM backwards, then write to HUB using setq2. But I need to look into that more.
    EDIT: CRCs seem to be done independently on each bit lane too!
    EDIT2: might be able to do 32 bits at a time on each bit lane and munge from there (with clock gaps perhaps)
    edited 2022-11-20 11:28
    Big-endian nibble order is handled by streamer no problem. I think the streamer is still the solution. Just it'll need two working buffers to hold maybe 700 bytes each - Provides a decent preamble space for delayed blocks. Not sure how much variability there will be.
    Hoping to process the previous read buffer while reading the next one. Probably won't be able to go as fast because of the processing but still should be relatively efficient.
    edited 2022-11-20 11:34
    You're right about the CRC though, it'll process much easier coming from serial smartpins pre-merging of data.
  • You only actually need to compute CRC for commands and write data. Checking the read CRC isn't enforced.
    It'd be great to use the streamer. But looking at some docs I think the highest bytes in the 512 byte sector appear to be transferred first (so it's not just the nibble order). Surely I have this wrong. All DMA stuff would get broken that way unless it reads memory backwards.
    Yeah we can probably gap the clock temporarily if required. Certainly not a problem for the CMD line performance in doing so, though commands will need extra clocks at the end to be able to completely transmit their response.
    Yeah. CMD CRC on the 48 bits is pretty easy to do as you can do it before you begin transmission and it covers so few bits, it'll take very little time really in PASM. The data CRCs written get tricky because there are 4 of them if 4 DAT lines are used. Maybe we can stream and compute CRCs in parallel by reading into LUT and serializing...
    edited 2022-11-20 12:27
    If the streamer is used we could compute the 4 DAT lane CRCs in parallel from a LUT RAM buffer. This takes ~ 2800 clocks per sector, so you could process ~100k sectors per second at 280MHz which is in the vicinity of 50MBps, and over 25MBps @ 50MHz SD clock. ie. it runs faster than the streamer needs to be clocking out its nibbles.
        setq2 #128-1 ' 512 bytes
        rdlong 0, databuf ' read from HUB to LUT
        rep #10, #128 ' repeat 128 times (@21 clocks per iteration = 2688 cycles)
        rdlut data, ptra++ ' get data
        setq data
        crcnib crc3, poly
        crcnib crc3, poly
        crcnib crc2, poly
        crcnib crc2, poly
        crcnib crc1, poly
        crcnib crc1, poly
        crcnib crc0, poly
        crcnib crc0, poly
  • You can leave off the SETQ, RDLUT already sets Q for you.
    LOL, Yeah I thought it might but your docs under RDLUT didn't show that when I just looked. I should have looked up the Q register instead.
    Yeah, RDLUT is just a stub rn.
    Cool! So that could be rdlut inb, ptra++
    BTW: That first RDLUT should be a RDLONG instead.
    edited 2022-11-20 22:03
    Yeah, noticed my typo and fixed it above.
    I think the DAT thing must be sent lowest byte of the sector first (but high nibble). If that's true we could use the streamer for writes, and hopefully reads also once we somehow detect the start bit. We don't have to check the read sector's CRC if we don't want to worry about possible corruption.
    Ah, the data order is just written as big-endian because SD is just following SPI convention. What data goes first is still a matter of interpretation. Big-endian says the first word is the most significant, but little-endian says the first word is least significant. That doesn't necessarily mean the data actually changes. The data can be the same order. IBM did a slightly weird trick just like this for its POWER ISA endianess. The labelling of significance swapped but the instruction encoding order actually stayed the same. At least on paper.
    edited 2022-11-20 13:35
    And really, that's exactly how a byte addressed true big-endian system works too. The lowest addressed byte goes first. That just happens to be deemed most significant.
    EDIT: It comes down to smallest address unit, which is usually the byte. Probably the only question is whether the first nibble is high order or low order of the first byte. My guess is it follows SPI again and the first nibble is the high order bits.
    Q Register instruction missing from your doc:
    • XORO32: Q is set to the XORO32 result.
  • Wuerfel_21Wuerfel_21 Posts: 5,794
    edited 2022-11-20 17:57
    Thank you, quality observation. Fixed.
    edited 2022-11-25 06:59
    Took some finagling but I think this CRC7 generator is right...
    PUB gencrc7(cmd, arg) : crc | poly
    asm
        mov poly, #$48      ' CCITT polynomial is x^7 + x^3 + 1 (bit reversed for P2 and aligned on "bit-1")
        mov crc, arg        ' prepare an initial CRC value in its 32 bit long
        shr crc, #8         ' using cmd & arg data
        setbyte crc, cmd, #3' prepare first byte with cmd bits
        rev crc             ' reverse CRC bits because P2 CRC HW shifts right
        shl arg, #24        ' align remaining 8 arg bits
        setq #0             ' setup remaining data for CRC
        rep #1, #8          ' CRC on 40 bits is 10 nibbles
        crcnib crc, poly    ' compute CRC
        setq arg            ' setup remaining data for CRC
        rev crc             ' reverse bits
        shr crc, #25        ' keep 7 top bits
    endasm
    compared with this:
    https://github.com/hazelnusse/crc7/blob/master/crc7.cc
    edited 2022-11-21 06:31
    Here's one from Ariba I found somewhere on the forum. It was likely wrapped in Spin2 code originally. I don't even remember if it was for SD cards or not. I think it was:
    uint32_t  crc7( uint8_t * buf, int len )
        uint32_t  val, crc = 0;
        __asm {
    // Reference code courtesy of Ariba
    cr7lp
            rdbyte  val, buf
            add buf, #1
            shl val, #24
            setq    val
            crcnib  crc, #$90>>1
            crcnib  crc, #$90>>1
            djnz    len, #cr7lp
            rev crc
            shr crc, #24
            or  crc, #1
        return crc;
    And the CRC16 one:
    uint32_t  crc16( uint32_t * buf, int len )
        uint32_t  val, crc = 0,
        polynomial = 0x8408;  // CRCNIB shifts right, therefore ordered from left: x0 + x5 + x12
        __asm volatile {    // disable optimising, and enforces Fcache use
    // Reference code is courtesy of Ariba
            rdfast  #0, buf
            mov ptra, #0
            rep @.rend, len
            rflong  val
            setq    val
            crcnib  crc, polynomial
    .rend
            rev crc
            shr crc, #16
        return crc;
