Prop2 Analog Test Chip Arrived! — Parallax Forums
We've got 100 of these:
I've been so busy struggling with the ROM code that I haven't made a board for these, yet. I'll make a board that will plug into the Prop123, so that these chips can be exercised as if they were part of the core logic.
«13456713
  • cgraceycgracey Posts: 14,289
    Here's how the bonding went:
    And here is the pinout, as if it had gone into the originally intended 80-pin package:
    1645 x 2559 - 2M
    854 x 852 - 24K
  • Looking good, some partial P2 silicon is always good. Which analog functions are you testing?
    Everything. All elements of the pad frame are in there. So, there are two I/O pins (4 fuses in each), the clock pads (RCFAST/RCSLOW/XTAL/PLL), and the RESn and TESn pads.
  • Fabulous! :)
  • Fantastic. Nice that its QFP rather than that strange double row qfn, too.
    Good luck with the testing.
    Yea ha! Real silicon.
    Starts biting finger nails, nervously waiting for test results...
    Woohoo ;)
    Fingers and toes crossed that all functions as expected!!!
    Chip,
    You might be able to buy a PLCC128 breakout board off the shelf to start some testing while you layout and wait for your own pcbs.
    BTW what is the pitch of these chips?
  • Great! That's good news. It seems that the P2 will be launched next year, if all goes well.
  • RaymanRayman Posts: 15,937
    Good luck! QFP is a lot easier...
  • Cluso99 wrote: »
    Looks like it's .5mm. Plenty of breakout boards for that footprint.
    It's a 20x20mm package with 0.5mm lead pitch.
  • If you want this board done quickly, feel free to ask Michael or David to just get it done for you, Chip. We're all interested in the results of your first look at this test chip.
  • Publison wrote: »
    Cluso99 wrote: »
    I had a quick look but didn't find much in square 128 pin 0.5mm. There were rectangular 128 pin qfp package breakouts (RE470), however I suspect the 144 pin breakouts would work as these are also designed for 20x20mm
    http://uk.rs-online.com/web/p/surface-mount-smt-to-through-hole-adapter-boards/3675219/
  • Awesome!
    Hey, will we be able to test DAC input?
    potatohead wrote: »
    Awesome!
    It has two instances of the I/O pad. So, we've got both DAC and ADC.
  • potatoheadpotatohead Posts: 10,265
    edited 2016-10-23 04:00
    :D Cool! And of course, I had a brain fart. ADC, it is.
  • Excellent!! looks great.
  • Hi Chip,
    Which foundry did you use? I expected to be ON Semi, and on a different package as well. Also, are those 180nm testchips?
    Kind regards, Samuel Lourenço
    samuell wrote: »
    Hi Chip,
    Yes, OnSemi made these and they use the ONC18 process.
  • Fingers crossed it all goes well :D looking good Chip!
  • Wow, my first week off work after a long year of critical path stuff, and Prop2 is on a chip! so here's hoping it goes well with the tests.
  • Baggers wrote: »
    Not quite. This is only the ring (analog, smart pins, etc), no cogs or hub memory.
    Can you do grayscale VGA with this?
    Seems like maybe it could...
  • jmgjmg Posts: 15,199
    Rayman wrote: »
    It certainly should be possible to confirm the DAC Drive, and Slew rates on changes (bandwidth), and create some test patterns, and test things like Sync-On-Green.
    Limited Colour VGA and Limited Colour Component Video should be possible with 2 DACs.
    The final change-rate will be dictated by how quickly the test interface can update the DACS, so it might not manage full VGA pixel-change-rates.
    Actually, I guess you need 3 I/O for VGA: Vsync, Hsync, Luma...
  • I think I remember someone here saying there's some trick to send VGA with only two I/O, by XORing the hsync and vsync together or something like that.
    Could you instead just use two chips to get 4 I/O?
    Rayman wrote: »
    Strictly, yes, but whatever is driving the test chip, I figured could easily manage H,V Syncs.
  • Well there are already signals including sync driving the THS8136 dac's on the P123 boards.
    You could just duplicate/divert the signals to the P2 test silicon and see how it looks, side by side.
    True. That should work.
