Propeller II: Emulation of the P2 on FPGA boards (Prop123-A7/A9, DE0-NANO, DE2-115, etc) - Page 16 — Parallax Forums
1131416181924
    edited 2012-12-30 18:30
    David,
    A command line version would be helpful (very helpful). Thank you!
  • David BetzDavid Betz Posts: 14,523
    edited 2012-12-30 18:48
    mindrobots wrote: »
    David,
    Okay, I'm building it now. However, it takes forever under Windows. Are you sure you guys wouldn't like to switch to Linux or the Mac? :-)
    edited 2012-12-30 19:00
    I can use it under any flavor OS. Whatever works best for you and the people doing real, productive P2 works opposed to my wanderings.
    edited 2012-12-30 19:02
    I love Linux, and I have a Mac running the version just before Lion. I may entertain that Mac in the near future too, but right now I need to run Windows. Got a lot going on and it's pretty heavy Windows-centric stuff. For me, it's about managing head space, and sadly that means running Windows a whole lot of the time, OS X some of it, and Linux only when I need to.
    Had you known me in the 90's, I would have been nearly all IRIX / Linux with just a smattering of Windows for similar reasons. That's how I manage my hobby / work time and avoid burnout. Consolidate. Hmmm... I still had SGI machines with Propeller early on and ditched them partially due to lack of tools. Could reverse that here in the near future... Good grief, a nice O2 and a Prop? (drool)
    Will I need make and friends, or what? It's been a while since I ran GCC on Windows. Steve's IDE kicks a lot of Smile and it just worked. Love it. I know we are not there right now, and it's not a worry for me. Just wondering what I need to work reasonably here, no frills, just a lean setup. I'll do that.
    Honestly, I found C a little big for the little P1, and preferred to just do it the way I had been. P2 is a different story. Kind of excited about that. :)
    edited 2012-12-30 19:09
    potatohead wrote: »
    Yes, I know many people either prefer Windows or must use it for some reason. I was just kidding about switching. I use all three operating systems myself but mostly the Mac. It's not so much the Mac GUI that I like, it's the fact that it's BSD Unix underneath. Anyway, the Windows built is in progress. I'm afraid it probably won't finish before I turn in for the night. I'll have to post it tomorrow. Sorry.
    edited 2012-12-30 19:19
    I like the Mac too, and for the same reason. No worries, no hurry. Appreciated. :)
    edited 2012-12-30 19:58
    David Betz wrote: »
    The build finished successfully. I'll do some sanity testing and add p2load.exe to it tomorrow morning and post it. Sorry for the delay!
    edited 2012-12-30 20:34
    How can you delay a gift we didn't know we were getting?
    Thank you!!
    edited 2012-12-30 23:19
    Out of curiosity I just grabbed the p2 test branch of propgcc, "hg update p2test", however I don't see a jbuild2.sh script in there.
    Errr....scratch that. It helps to do a "hg pull" first. I need more coffee.
    edited 2012-12-31 13:37
    David Betz wrote: »
    I've uploaded a very preliminary version here:
    http://code.google.com/p/propgcc/downloads/detail?name=prop2gcc-2012-12-31.zip&can=2&q=#makechanges
    This only does LMM but I'm working on COG mode as well. To get it to compile for P2 you need to use the -mp2 option. Check the propgcc/demos/fibo/p2 demo program to see how to use the P2 code generation. Also, this compiler should still work fine for P1 as well as long as you don't use the -mp2 option.
    edited 2013-01-01 17:20
    I've just pushed changes to Google Code to allow both LMM2 and COG2 programs to be built and run. I've also added a new demo, propgcc/demos/multi-cog, that will run on the DE2-115 board and start six COGs each blinking one of the LEDs at different rates. I'll make a new Windows version tomorrow if there is any interest.
    edited 2013-01-01 18:08
    By build a new version, do you mean one that will run the multi-cog demo code you just produced, or something else?
    edited 2013-01-01 18:10
    potatohead wrote: »
    One that supports both LMM and COG modes. The one I built before only supports LMM mode. Also, because it supports both LMM and COG modes, it will run the multi-cog demo. The demo is just to illustrate how to launch multiple COGs on the DE2-115 board. Unfortunately, it won't work on the DE0-Nano board because it only supports one COG. However, you should be able to run single-COG LMM and probably COG mode programs on the DE0-Nano as long as they fit in the 32k of hub memory.
    edited 2013-01-02 07:35
    David,
    (I started off simple because I can't do much more than simple)
    I loaded your prop2gcc package onto my Mac Parallels Win7 VM and tried compiling the hello.c demo that comes with SimpleIDE. This is the error I got:
    C:\demos\hello>propeller-elf-gcc -mp2 hello.c
    C:\Users\rapost\AppData\Local\Temp\ccAgkKIo.o: In function `_main':
    (.text+0x40): undefined reference to `CNT'
    collect2: ld returned 1 exit status
    I have a feeling this is more pilot error and not having everything I need on my Win7VM (yet). I'm going to try this again later today/tonight on my Win7 laptop which currently does run PropGCC from the command line and I'm also going to build Prop2GCC on my Mac which is also running the command line package of PropGCC. I'm afraid SimpleIDE has made me lazy and ignorant! :lol: (Thanks, Steve!!:smile:)
    I've never built this before, so we'll see how that goes!
    If you don't think it's pilot error, then by all means, let me know what you'd like me to try on the relatively clean VM to fix the problem.
    edited 2013-01-02 07:42
    mindrobots wrote: »
    David,
    This isn't pilot error. It's because there is no CNT register in P2. The low-level stuff needs to be redone for P2. I've started that by defining some inline functions and macros in propgcc/demos/multi-cog/propstuff.h but I haven't finished yet. There is a prop_getcnt() function in there though that you can use to replace the references to CNT. Actually, I'm not remembering that the multi-cog demo isn't in the Windows zip file that I posted the other day. Steve has promised to make a new zip file though and it will contain that as well as support for both LMM2 and COG2 memory models. I hope that will get posted later today.
    Thanks for trying this stuff out!
    David
    edited 2013-01-02 07:44
    David Betz wrote: »
    David
    Another thing, until Steve uploads a new release you can look at propgcc/demos/fibo/p2 for an example that will run on the P2.
    edited 2013-01-02 07:57
    Great! Thank you!
    After I posted, I started looking and wondering about the low level P2 stuff. I always assume pilot error first, though!
    edited 2013-01-02 07:59
    mindrobots wrote: »
    Great! Thank you!
    If you're running on a Mac and have Xcode and the command line tools installed you can build propgcc yourself. It only takes about 10 minutes to build this release since I've disabled the build of C++ and GDB.
    edited 2013-01-02 08:11
    That's my next project today as soon as I finish downloading a .zip of the p2test branch.
    I'm staying out of the repository so I don't mess anything up. I'm much safer on an isolated machine for now!
    edited 2013-01-02 08:23
    mindrobots wrote: »
    You won't mess anything up unless you do 'hg commit' and 'hg push'. Feel free to use the repository in read-only mode if you want.
    edited 2013-01-02 11:41
    David,
    I did the hg clone of the default and the p2test repositories on my Mac.
    I ran j2build.sh and it happily went along until it got this error:
    propeller-elf-gcc -Wall -g -Os -mfcache -fno-exceptions -mlmm -fno-rtti -o ../../../build/lib/obj/lmm/tiny/c++-alloc.o -c c++-alloc.cpp
    c++-alloc.cpp:1:19: fatal error: cstdlib: No such file or directory
    compilation terminated.
    make[2]: *** [../../../build/lib/obj/lmm/tiny/c++-alloc.o] Error 1
    make[1]: *** [../../build/lib/obj/lmm/libtiny.a] Error 2
    make: *** [tiny] Error 2
    tiny library build failed - make
    macdev:p2test rapost$
    It appears to have built new propeller-elf-xx executables in the /opt/parallax/bin directory - I don't think this error would cause what I'm seeing but I don't know for sure.
    I then tried the gastest.s file you provided with:
    propeller-elf-as -ahl -p2 gastest.s
    and was told that -p2 was an unrecognized option. This is the same command I can use with your Windows package to assemble P2 GAS.
    Any thoughts on where I went astray?
    I'll try the C compiler a bit later but I need to run to a meeting.
    edited 2013-01-02 11:45
    mindrobots wrote: »
    David,
    Oops, sorry. You need to do this first before attempting to build "hg checkout p2test". This switches to the p2test branch where all of my P2 changes are.
    Also, I've just uploaded a new Windows zip file that supports both LMM2 and COG2 memory models. It's in the propgcc repository on Google Code.
    edited 2013-01-02 17:37
    Ok, I've never done this before, so I'm guessing and floundering. Here's what I've done so far:
    Hg clone of default
    Hg clone of p2test
    Cd p2 test
    Hg update p2test
    sudo ./j2build.sh
    ..after build errored as above, I ran the newly created propeller-elf-as as above and got the message about the invalid -p2 option
    Tried hg checkout p2test
    ...all updates came back with 0 file indicators
    Ran the build again and got same errors
    Can you give me the steps I should need? I'm obviously missing something. I'll just wipe out what I have and start fresh.
    Thanks!!
    edited 2013-01-02 17:52
    mindrobots wrote: »
    Hg clone of default
    Hg clone of p2test
    Cd p2 test
    Hg update p2test
    sudo ./j2build.sh
    Thanks!!
    I'm not sure what you mean by "clone of p2test", it is a branch of the "propgcc" repository. You should do this:
    hg clone https://code.google.com/p/propgcc/
    cd propgcc
    hg checkout p2test
    ./jbuild2.sh
    That will check out the propgcc repository, switch to the "p2test" branch, and build it.
    edited 2013-01-02 18:29
    Thanks, I'll try that tomorrow morning.
    I bet I created a default clone in a directory named p2test and never got you p2 changes.
    edited 2013-01-03 06:28
    I'm sure everyone is looking for a program to flash the LEDs on their DE2-115 FPGA board, right? :-)
    I've attached a compiled version of my new multi-cog demo that will start a C program running on all 6 COGs on the DE2-115 board. The program just blinks 6 LEDs (one for each COG) at different rates. It illustrates using the LMM2 and COG2 memory models on the P2. The sources are also included in the attached zip file. After unzipping, you can run the demo by using the following commands:
    cd multi-cog
    .\p2load toggle.elf
    You should then see 6 LEDs blinking in a semi-random pattern.
    multi-cog.zip
    Note: This same program can be run on the P1 QuickStart board and will flash all 8 LEDs using 8 COGs. You just have to rebuild it commenting out the CHIP= definition at the start of the Makefile and load it, as is usual for P1, with propeller-load instead of p2load.
    edited 2013-01-03 07:47
    VICTORY!!
    David, thanks for your help!!
    The instructions you provided above worked for building the p2test PropGCC on my Mac (OSX 10.8.2). I just pulled the repository, so it should be David's latest and greatest.
    I also build a mac version of p2load and put it in the /opt/parallax/bin directory.
    I've ran code through propeller-elf-as and it generated the same code as the windows version.
    I build the p2 version of fibo and p2load was able to find my nano, load it and start the terminal program so I could watch fibo.
    If anyone is interested, I can package this up (probably just .zip the /opt/propeller directories) and put it on the PropGCC Google code site. If there's a better way to package this for a Mac, please let me know.
    edited 2013-01-03 07:49
    mindrobots wrote: »
    VICTORY!!
    Congratulations Rick! I'm glad you were able to build a working Mac version!
    edited 2013-01-06 16:30
    I just downloaded everything. It was not clear that I needed to just overlay the special p2 build on top of the latest prop-gcc version.
    Is that true?
    My installation steps were:
    1. Fetch propellergcc 0.3.5
    2. Fetch propellergcc demos 0.3.5
    3. Fetch multi-cog.zip
    4. Fetch prop2gcc 2013-01-02
    Unzip them all, then copy propgcc 0.35 to C:\, drop demos folder in under that, copy multi-cog into there, copy prop2gcc into c:\ to overlay everything.
    From there, a double click on propgcc.bat opened up a window, which would run make and friends.
    CD into \demos\multi-cog
    make all
    make run
    Microsoft Windows XP [Version 5.1.2600]
    (C) Copyright 1985-2001 Microsoft Corp.
    C:\propgcc>cd demos
    C:\propgcc\demos>cd multi-cog
    C:\propgcc\demos\multi-cog>dir
     Volume in drive C is SystemDisk
     Volume Serial Number is 00F7-C0BA
     Directory of C:\propgcc\demos\multi-cog
    01/06/2013  04:10 PM    <DIR>          .
    01/06/2013  04:10 PM    <DIR>          ..
    01/03/2013  09:20 AM               491 Makefile
    01/03/2013  09:20 AM            79,134 p2load.exe
    01/03/2013  09:20 AM             4,102 propstuff.h
    01/03/2013  09:20 AM             4,881 toggle.c
    01/06/2013  04:10 PM             9,279 toggle.elf
    01/03/2013  09:20 AM               200 toggle.h
    01/06/2013  04:10 PM            18,305 toggle.i
    01/06/2013  04:10 PM             5,368 toggle.o
    01/06/2013  04:10 PM             2,645 toggle.s
    01/03/2013  09:20 AM             2,433 toggle_fw.c
    01/06/2013  04:10 PM             3,264 toggle_fw.cog
    01/06/2013  04:10 PM             7,132 toggle_fw.i
    01/06/2013  04:10 PM             2,108 toggle_fw.o
    01/06/2013  04:10 PM               845 toggle_fw.s
                  14 File(s)        140,187 bytes
                   2 Dir(s)  23,904,686,080 bytes free
    C:\propgcc\demos\multi-cog>make
    make: Nothing to be done for `all'.
    C:\propgcc\demos\multi-cog>make clean
    rm -f *.o *.elf *.a *.cog *.ecog *.binary
    C:\propgcc\demos\multi-cog>make all
    propeller-elf-gcc -save-temps -Os -DPARALLAX_I2C_BUS -mlmm -o toggle.o -c toggle
    .c
    propeller-elf-gcc -mlmm -fno-exceptions -fno-rtti -o toggle.elf toggle.o toggle_
    fw.cog
    C:\propgcc\demos\multi-cog>make run
    propeller-load  toggle.elf -r -t
    Propeller Version 32 on COM8
    No value for __cfg_basepin in the configuration file
    Loading toggle.elf to hub memory
    3464 bytes sent
    Verifying RAM ... Timeout Error!
    error: load failed
    error: load failed
    make: *** [run] Error 1
    C:\propgcc\demos\multi-cog>pwd
    'pwd' is not recognized as an internal or external command,
    operable program or batch file.
    01/06/2013  04:18 PM    <DIR>          .
    01/06/2013  04:18 PM    <DIR>          ..
    01/06/2013  04:18 PM             9,279 toggle.elf
    01/06/2013  04:18 PM            18,305 toggle.i
    01/06/2013  04:18 PM             5,368 toggle.o
    01/06/2013  04:18 PM             2,645 toggle.s
                  13 File(s)        138,079 bytes
                   2 Dir(s)  23,904,636,928 bytes free
    C:\propgcc\demos\multi-cog>type Makefile
    # this makefile allows building and cleaning the toggle demo
    # Copyright (c) 2011 Steve Denson
    # MIT Licensed
    # Propeller Demo include
    PROPLIB = ../common
    CFLAGS = -save-temps -Os -DPARALLAX_I2C_BUS
    CHIP = -mp2
    # objects for this program
    NAME = toggle
    OBJS = \
    toggle.o \
    toggle_fw.cog
    all: $(NAME).elf
    include $(PROPLIB)/common.mk
    run2:
            p2load toggle.elf
    C:\propgcc\demos\multi-cog>make run2
    p2load toggle.elf
    Found propeller version 32
    Loading 'toggle.elf' on port COM8
    I'm not sure how things are setup from here to troubleshoot. I'll be digging around, but thought I would post up a successful load, even if it didn't work yet. Close!
    Looks to me like it built a p1 binary maybe? That's what I'm reading through to learn right now.
    edited 2013-01-06 18:06
    Try this on your .o file
    macdev:p2 rapost$ propeller-elf-objdump -f fibo.o
    fibo.o:     file format elf32-propeller
    architecture: prop2, flags 0x00000011:
    HAS_RELOC, HAS_SYMS
    start address 0x00000000
    If you have prop2 in the architecture, you probably got the right stuff.
    I built the P2 fibo demo to verify my toolchain - it's in the demos under fibo/p2
