Fill the Big Brain - Page 37 — Parallax Forums
Fill the Big Brain
1343537394059
    edited 2011-07-05 05:19
    Multiple PST Instances
    There's a useful thread about running multiple instances of the Propeller Tool Software and the PST.
    http://forums.parallax.com/showthread.php?132744-multiple-PSTs
    This function can attach to specific Propeller chips and act as virtual reporting screens, take the place of output LEDs, serving as LCD and TV monitor replacements, and other useful functions in a multi-chip Propeller machine.
    edited 2011-07-05 05:25
    12Blocks with Multiple Props?
    12Blocks now has a Mac version. Has anyone tried programming multiple props with it?
    http://12blocks.com/download.php
    It has a trial version, and after that:
    $49 - Lite (no function or arrays)
    $79 - Standard (limited time offer- normally $99)
    http://12blocks.com/resources.php comprehensive resources
    http://forums.parallax.com/showthread.php?132724-12Blocks
    http://onerobot.org/education.html 25page+19page downloads+video written by post-doc
    http://12blocks.com/tutorial.pdf 35 pages with >20 activities
    http://12blocks.com/videos.php several videos
    http://12blocks.com/manual.pdf 29 page manual- yes, this is outdated...
    Edit: refer to post 1095
  • HannoHanno Posts: 1,130
    edited 2011-07-05 14:23
    Yes, 12Blocks now runs on Linux and Mac!
    Here's a picture of a class using 12Blocks on Macs to program TBots:
    What do you mean "programming multiple propellers"? As long as you just want to program one at a time you're fine: 12Blocks has a nice "port chooser"- that either automatically connects to a Propeller- or let's you manually specify which port to use. In demos I frequently show 12Blocks connecting to multiple bots/projects.
    Hanno
    960 x 720 - 259K
    edited 2011-07-05 14:25
    How incredibly odd- the photo was right side up on my pc- the forum software rotated it!
    edited 2011-07-05 23:22
    Hanno: what about the mixing of languages? On a piece of Spin code, can it embed 12blocks code, or you will probably say it's just the other way around..
    :In the case of the rotated picture - no problem with a Snow Leopard Mac. Just drag it to the desktop and turn it.
    edited 2011-07-06 05:58
    Big Brain Reduction Interface RI
    The Big Brain has a HYBRID interface under development for some time which includes various circuits: examples are Serial Communications, Daisy Chain, Token Ring Topology, Prop to Prop, and Parallel.
    Definition
    Reduction Interface RI - the simplification and combining of wire interfaces to achieve one interface that can handle the functions of several
    HYBRID Interface - several interfaces mixed together, not necessarily reduced
    This post introduces the Reduction Interface RI. The implementation of RI will reduce the number of prop wires by combining several interfaces together and mutualizing various functions.
    edited 2011-07-06 09:07
    A Smaller 800-Cogger Machine
    This week sees the reassembly of the first two Partition arrays for 800 cogs after moving to the larger containment rack. A cog testing program is needed and suggested. Pseudo code below.
    Loader ' loads code into 2 Partitions of 100 prop chips in Cog 0
    Cog Loader ' loads code into all Cogs
    Test Cog 0 through 7
    Result to LEDn
    Repeat
    This makes a new smaller machine of 100 props with 800 cogs. Partitions were built at 50 props each, however since the introduction of the Filter, it is likely the number of props per Partition could double (perhaps a future consideration) and continue to work reliably.
    edited 2011-07-06 09:23
    Instructions on Using a Multi Array ParaP System
    POa1 { Loadn [ParaP = Partition1]} + POa2 { Loadn [ParaP = Partition2]} + POa3 { Loadn [ParaP = Partition3]}
    PO - Power On
    Loadn
    ParaP
    Partition
    a0...an - array 0 through n
    POa1 + POa2 + POa3 = ||
    Loadn ~ EEPROM ~ Partition1 + Partition2 + Partition3
    = ParaP1 + ParaP2 + ParaP3
    (continued)
    edited 2011-07-06 16:08
    Hi Humanoido,
    12Blocks let's you "inline" pure spin with the "code" block. You can also type any valid expression or condition into appropriate parameters. If you want to reuse existing spin objects you can "file>import" them and 12Blocks will create blocks for your public functions. Do you have a usb connection to each of your props? Or are you loading one and telling it to copy to others?
    Hanno
    edited 2011-07-06 17:45
    Hanno: It's good to know Spin code ports to 12blocks. I'm more interested in knowing if anyone has multiple props connected together with various routines already developed in 12blocks.
    edited 2011-07-06 18:03
    Correct me if I'm wrong Hanno, but I thought 12Blocks was designed to make programming the Prop a lot easier, especially for non programmers.
    I haven't used 12Blocks but I'm guessing it's kind of like the interface to program Lego MindStorms. You arrange the graphical blocks to indicate what you want your robot to do and in what order.
    I doubt it's the best programming environment for programming unusually behavior like multiple Propeller communication protocols.
    I'd think programming directly in Spin and PASM would be easier than trying to bend 12Blocks into doing things for which it wasn't intended.
    Duane
    edited 2011-07-06 18:50
    Hi Duane,
    You're right, I initially designed 12Blocks to simplify programming the Propeller so my 5 year old daughter could do it. It takes away most of the hard things: syntax, grammar, and vocabulary to let users focus on the logic of what they're trying to do. It adds a bunch of features that I initially developed for ViewPort to simplify debugging- graphing variable values, seeing pin states, and changing program parameters while your program runs. While it started as a simple project- it's now very complete- even letting you create stand-alone "exe" files similar to the PropScope application- with bundled firmware, graphical gui and communication stack.
    Think of 12Blocks as a hybrid- easy to use, visual, with nice integrated tools calling into low level drivers written in spin/pasm. As such, I
    think a high-level interface to the "Big Brain" is a very valid use case. While I continue to develop low-level drivers in pasm/spin, I prefer to program in 12Blocks- especially when I want to demonstrate how to do something...
    Hanno
    edited 2011-07-06 18:56
    Duane, I see your point. However, the ad says it was programmed by a 6-year old. But you never know. It can draw vector graphics, do color, play WAV files, handle TV, VGA, do sprites, create tones, synthesize speech, record sounds, handle mouse, keyboard and terminal events, graph variables - handle plotting and functions, control 32 servos, broadcast messages, handle a receiver block, access a terminal, use functions and calls, variables, arrays, access to VARS library, toggle pins, send and receive data with RS232, shift data, measure frequencies, count edges, and measure duration of discharge in an RC circuit, includes graphical tools, function parameters, can create State Machines... It sounds like the 6-year old in all of us could enjoy.
    edited 2011-07-06 19:39
    12 Blocks & Propeller - Front End?
    Hanno wrote: »
    I initially designed 12Blocks ... to let users focus on the logic of what they're trying to do ... a high-level interface to the "Big Brain" is a very valid use case. While I continue to develop low-level drivers in pasm/spin, I prefer to program in 12Blocks- especially when I want to demonstrate how to do something...Hanno
    I can see the potential of programming it to make a Big Brain front end - making complex Brain things very simple to handle and program. It reminds me somewhat of Odesta software - I'm very fond of the iconix method of programming having spent years with a Double Helix programming environment. http://en.wikipedia.org/wiki/Helix_(database)
    http://letsmakerobots.com/node/22528
    http://www.instructables.com/id/Program-a-microcontroller-With-12Blocks/
    http://hannoware.com/
    http://blog.hannoware.com/
    http://forums.parallax.com/showthread.php?114059-12Blocks-v1.2-launched!
    www.12blocks.com/tutorial.pdf
    http://12blocks.com/cheatsheet.pdf
    http://forums.hannoware.com/
    edited 2011-07-06 20:36
    Hanno wrote: »
    Thanks for clarifying what 12Blocks can do. I keep wondering about holding a "Robot Summer School". I ought to investigate 12Blocks better to see if I could use with the school.
    Duane
    edited 2011-07-06 21:05
    Hi Duane,
    Good timing! I just posted a link to a talk I recently gave about Robots and Education- it's here:
    http://forums.parallax.com/showthread.php?132806-Hanno-s-latest-Google-Tech-Talk-quot-Robots-and-Education-Bridging-the-Gap-quot
    Quite a few schools are now using 12Blocks- I'm even working with a university to develop an official curriculum to bring 12Blocks and TBot into classrooms. Let me know if you need any help...
    Here are links to everything related to 12Blocks: http://12blocks.com/resources.php
    Hanno
    edited 2011-07-07 06:19
    SpotLite Index - Propeller & AMD
    Introducing various SpotLite Indices
    This introduces SpotLite Index, to save time and accumulate a sub index of information for ongoing study, research and project development about specified subject matter. The topic of this SpotLite is AMD and the range is from pages 1 through 55 inclusive.
    The AMD project is to connect 720 GPU's to the Propeller Array and for over a 100 props of over 16,000 theoretical MIPS it adds over a TeraFLOP of computing power and numerous resources.
    The full Index is found here:
    http://forums.parallax.com/showthrea...l=1#post977025
    Page 33
    650 Apple AMD Radeon HD 6750M Graphics Card 480 Stream Processors
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page33
    Page 46
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page46
    910 Merging Technologies - Big Brain with AMD
    912 AMD Sources
    Page 47
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page47
    923 Developing AMD for Parallax Propellers
    924 AMD (to Parallax Propeller) Development Boards Source
    925 AMD’s Software Kit Source
    929 More about AMD GPUs
    Page 51
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page51
    1004 Big Brain's AMD Radeon HD
    Page 52
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page52
    1023 Big Brain Expansion with AMD Radeon HD, High Speed Streaming GPUs
    Definition
    SpotLite Index
    - a small sub index designed to save time and accumulate information for ongoing study, research and project development about specified subject matter. Includes the main topic, links, pages, posts, post titles, and the range of posts.
    edited 2011-07-07 07:06
    Designing a Big Robotic Brain Stub
    Discovery post
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain&p=982979&viewfull=1#post982979
    The study and design of Brain Stubs is progressing. The project will also require, in addition to technical merit, some art and imagination. Unfortunately there were no suggestions for the shape of a Brain Stub so the project is progressing slowly. Apparently the right side of the gray matter is mute.
    The Investigation
    The investigation begins with weight and mass. Since the stub will be servo driven with props, it must not have too much mass. Although Wonder-Board is extremely light weight, it still has mass under consideration and appreciable weight in large sizes at various extended positions.
    Determining Mass and weight
    Both are determined by shape, and shape must adhere to the requirements set in the previous Brain Stub post. For mass, the formula F = (M)(A) is utilized. The servo has ramping and can therefore control inertia.
    Control
    Control will be under the Brain Stem as previously planned. This allows many functions of programming for the servo(s).
    DOF
    Now under consideration are two degrees of freedom but it is not known where these will locate. Enough parts exist to do 2 DOF and this is in compliance with the Brain Stem. The board can immediately handle 2 servos.
    Brain Stub Design
    This week the trial period was up on the CAD design program. Today, the program was purchased and the Brain Stub design can resume.
    Quantity of Stubs
    Do we go with a quantity of redundant Octopus-like stubs or could the Brain could get by with one stub? Two stubs open up some possibility of grasping. One stub would be faster, cheaper, lighter, and easier to construct. It would consume less power, and remain easier to program.
    Stub Focus
    Focus is now on designing the shape of one Brain Stub.
    Hardware
    The current idea is to use a PING))) kit for the interface connection to a constructed Wonder-Board Giant Brain Arm run by the large servo.
    Dimensions
    It's possible the Giant Brain Stub Arm could be 4-feet long and 1 or 2 feet in diameter. This is however subjective until the design is more solidified.
    Shape
    The shape is estimated to be grotesquely large, overbearing, ungainly, shocking, and with an appearance never before seen. It could have a very large hand at the end of the arm. But the hand would not be fully articulated. It must however meet the minimal requirements set forth in the previous Brain Stub post.
    Servos
    Should these servos mount standard or should they be continuous rotation servos? Maybe one of each - the large had could continuously rotate at the wrist (for some special functions) while the globby arm could dangle in varying degrees at the lumpy shoulder.
    Possible Conclusions & Suggestions
    • A single Brain Stub
    • A blobbed shape never before seen
    • Made from manufactured WonderBoard
    • Interfaced with Parallax PING)))
    • Two degrees of freedom
    • Servo driven
    • A massively large hand
    • Side mounted
    • Articulation at the shoulder or elbow
    • Articulation at the hand wrist
    • Extremely large overall size ~ Four Foot extent
    • Grotesquely appearing
    • Light weight to minimize inertia
    • Programmed/Operated by the Brain Stem
    • Employing one continuous rotation servo at the hand wrist
    • One standard servo at the shoulder or elbow
    387 x 461 - 57K
    edited 2011-07-07 10:09
    Humanoido,
    Do you know about the "servos" Dynamixel makes?
    FRS-B-AX-12A-a.jpg&lr=t&bw=300&w=300&bh=300&h=300
    This is the AX-12A which replaces their earlier AX12+.
    I have a robot arm with some AX-12+ controllers (servos). The controller are really cool because you can position them like a standard servo (but not using the same communication protocol) and they can also rotate continuously. They have a 60 degree "blind spot" were they wont know their location but for 300 degrees they'll tell you what their position is as they rotate.
    One of (the many) cool things about Dynamixel controllers is the communication protocol. It uses a serial communication protocol that includes the controllers ID so they can be daisy chained together and you can control a whole bunch (256) of them with one IO pin (and two resistors).
    The AX-12As have pretty good torque 16.5kg*cm (@12V). If you want a real heavy lifter, you could move up to a EX-106+ with torque of 106kg*cm (@18.5V). These will break finger bones if you're not careful. They cost $499! You would also need a RS-485 chip in order let a Prop communicate with the EX-106+.
    I'm guessing you already have the servos you're going to use but you might want to keep the Dynamixels in mind for a future project.
    Duane
    edited 2011-07-07 15:42
    WOW. Duane, you MUST be rich to afford all those fancy schmancy Dynamixel servos. So you're the second rich guy I know who lives in Idaho. Caleb Chung, of Furby and Pleo fame, also lives there.
    Caleb, is it you posing as Duane? Remember Letterman? ;)
    edited 2011-07-07 17:03
    Erco, Shush!
    Now you know why I don't have my picture for an avatar (or anything else for that matter(yet)).
    I once heard that Idaho has more millionaires per capita than California (It might have even been per capita of all 50 states (we don't have a lot of capita here so it would not take many millionaires). This was about 25 years ago. I don't know if it's still true or not. (I don't know if it was true 25 years ago either, but I heard it from a friend.)
    Just because I posted a picture of the EX-106+ doesn't mean I own one. I don't.
    I do have a relatively good number of AX-12+ servos. They're really nice to use. I think I have enough to make a humanoid robot if I took all the AX-12+s out of their current projects.
    P.S. I missed the last decade of Letterman shows. I have no idea who Caleb is.
    edited 2011-07-07 17:09
    Several of us were on Letterman way back in Dec 1988 and Dec 1989. Still gotta dig out those VHS tapes & Youtube 'em.
    edited 2011-07-08 22:31
    Duane: the Dynamixel servo has good specs and is a good suggestion - it appears they would work well for the Brain Stub project. Having a servo that can double as both standard and continuous rotation, plus report position, is a good feature. I have Parallax / Futaba standard and continuous rotation servos on hand. It appears the 43.1 oz./in rating will be sufficient to move each stub section. The board is really light weight - lighter than expected. But tests are needed with all three sections connected together. The inertial result can be minimized by moving it more slowly, plus it only needs 2 DOF.
    edited 2011-07-09 03:30
    LED Brain Application Chronicles - Part 1
    What can it do?
    One of the best devices deep inside the Big Brain is the simple and inexpensive LED. While most people appreciate its significance as a diagnostic tool, others may or may not realize it has many more functions and is both versatile and multipurpose.
    While LEDs are easily simulated on monitors and displays, it's preferable in this project to put at least one LED on each Propeller chip. The physical positional relationship is a help during design work and pacing the machine.
    The proverbial LED can function as both an input and an output device. This opens up a gamut of possibilities.
    LED Functions
    Light detection as a photodetector
    Debugging Tool
    Experimenting with Tri-States
    Output, input
    Propeller Partition talk
    Display
    Alerts
    CPU variable reporting
    Prop Enumeration Indicator
    Comparing props
    Communicator
    Actual Data out
    Signaling and Signing
    Conveying timing
    Cog identification
    EOPs and SBs (End Of Programs & Stop Blocks)
    Indicate data presence
    Work Tasking identifications
    Sequential Identifier
    Task Exampling
    Binary device
    Parallel demonstrations
    Syncing Illustrations
    Other Possible Functions
    Touch Pad
    Matrix
    Talk on a Light Beam
    Flood Communicator
    Group Functions
    Upcoming Part 2
    In Part 2 of LED Brain Application Chronicles, we'll cover an idea for adding over a hundred LEDs to the machine and keep the power draw down to an essential minimum.
    edited 2011-07-09 03:41
    Erco, what type of servos would you recommend for this very large lightweight robot arm (Brain Stub), standard servos or continuous rotation? You can get a general idea of the range of motions in the diagram at the post.
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain&p=1015760&viewfull=1#post1015760
    edited 2011-07-09 10:54
    To Simulate or Not To Simulate
    In response to the possibility of doing this project as one big simulation on a computer...
    "Great ideas.... All the fun (to me) is in building the real machine and interfacing it and actually programming it - not simulating it on a PC. It's like simulating a fine dinner on a PC, you just don't get the same satisfaction as the real thing."
    http://forums.parallaxinc.com/forums/default.aspx?f=25&m=475282
    Humanoido
    In another spinoff in the opposite direction, a simulation project is started. A lot of what's being done with hardware can be accomplished with simulated software on a very powerful platform. But there is a twist..
    edited 2011-07-09 19:56
    Can Your Machine Brain Pass the China Test?
    In this interesting China brain project, PDF linked below, they quote one important criteria.
    If the average person can remain intrigued for half an hour by such a robot and the A-Brain that controls it, then we state that the A-Brain has passed the “China Test”.
    http://www.agiri.org/docs/China-BrainProject.pdf
    Hugo de Garis at Wuhan University (Wikipedia) - in 2008 awarded a ~$450,000 grant to build an artificial brain for China.
    http://en.wikipedia.org/wiki/Hugo_de_Garis
    Book to be published in November 2010: Artificial Brains - An Evolved Neural Net Module Approach (Amazon).
    http://www.worldscibooks.com/compsci/7713.html
    edited 2011-07-09 20:23
    The Ultimate AI Challenge - the Artificial Brain
    The document is still open source but the project has moved to closed source. Contains unique perspectives of artificial brains.
    http://theartificialbrain.com/Data/The%20Artificial%20Brain.pdf
    http://theartificialbrain.com/ArtBr.htm
    Table of content
    (Download the document to get access to the content)
    Preface
    It’s all about linking and comparison
    __Warming Up
    __Linking, comparison and decisions
    __Neural Networks
    Procedural or not ?
    __Introduction
    __Thanks time and space !
    __Scripting is the answer !
    ____Other advantages of scripting
    The main protector
    __Introduction
    __The amygdala
    Emotions and feelings
    __Some free thoughts on emotions
    __Fear
    __Feelings, the derivatives of fear
    __Disgust and surprise
    __Curiosity and acceptance
    __Pain
    __Aggression
    Believe, the driving force !
    __Introduction
    __Believe, always believe …
    __The three states of believe and doubt
    The diverse forms of consciousness
    __Introduction
    __Consciousness
    ____Some free thoughts
    ____Another approach towards answers
    __Conscious versus subconscious
    __Self-awareness (self-conscious)
    __Creativity, dreams, imagination and thinking
    __Impact on the digital brain
    Unexpected processes of the subconscious
    __Intuition or following the own instincts
    __Imitation and insight
    What about hormones ?
    __Introduction
    __Hormones
    __An odd question : is puberty required ?
    __The impact on the digital brain
    ____The hormone part
    ____The pre-juvenile phase
    ____The juvenile phase
    Deeper thoughts
    __'I think, therefore I am ...'
    __The buzzword 'perception'
    Values and ego
    __Introduction
    __Relativity
    __Standard of values
    __The world turns around you !
    __Self-interest, always !
    __Altruism …
    A number of important actors
    __Motivation
    __Appreciation versus punishment
    __Instincts
    Memory
    __Introduction
    __What about synapses ?
    __Storing information
    __The inner voice
    __The principles behind belief and fear
    __The ‘play-zone’
    __The long-term memory
    __Visualization
    __Fragmentation
    __Mirror neurons
    __What types of memory are needed ?
    Attention
    __Introduction
    __Concentration
    Appendix 1 : A sample diagram
    __Introduction
    __The diagram
    __Explanation
    ____Digital Cerebellum (A) and the Play-zone (B)
    ____Pain (C)
    ____Surprise (F)
    ____Attention (E)
    ____Curiosity (G)
    ____Digidala (J)
    ____Labeling (L)
    ____Data Temp (M)
    ____Digi LTP (Long Term Potentiation) (N)
    ____Main Data (O)
    ____Acceptance (I)
    ____Rewarding (K) and Punishment (D)
    ____Instincts (P)
    ____Conscious versus subconscious
    Epilog
    edited 2011-07-10 01:33
    Parallel Schematic
    This is a parallel schematic sketch designed for brain testing. Some ideas for use: The parallel circuit can open up eight channels of communication in true parallel. It can also serve out an eight bit byte. It double duties as a serial interface. It can open up packets of send and receive. One or eight can talk while hundred(s) of others listen. Not shown are typical protection resistors across each pin.
    552 x 300 - 59K
This discussion has been closed.
