CONTEST!!! Give the Parallax Robot Base Kit a REAL NAME
Hi Everybody!
I hereby create the "Give the Parallax Robot Base Kit a worthy name" CONTEST!!!
Rules are simple:
1) No Pllx employee can participate.
2) Prize to be determined by Me.
3) All entries must be posted on THIS Thread.
4) Our Marketing Team + Me will determine the Winner
5) erco is not allowed to participate.
6) Winner will be chosen on Monday @ 4:00pm Rocklin Time (unless we have really bad choices to choose from, then at my sole discretion I'll extend it until you guys (and gals!) come up with something Worthy!
Contest is NOW OPEN!!!
Oh, OK. erco YOU CAN PLAY TOO ;-)
-Matt
Rules are simple:
-Matt
Should have Googled first, ProBot is already taken, I'll let you guys look it up. Pro-Bot is also taken, it is a Logo based robot.
Rich H
Dancer Bot.
SpinDancer
Cuttingboardman?
Tupper?
Flathead?
Harry Donald Peter Eschelman? (HDPE)
Miller?
Plasty?
Cirq?
Disq?
Regrind?
FriskyDisk?
JAFRO?
BYOB BOB?
AnkleBlaster?
Spinner?
PlatterBot?
Platterpuss?
I've got more! Thanks a lot, you've been great. I'll be here all week, tip your waitresses please!
Parallax Maxi-Bot Pro 18" Platform
Parallax MegaBot Pro 18" Platform
Parallax MaxiBot Pro 18" Platform
Parallax Pro-Bot 18" Platform
This kit supplies nearly everything you would need to build a multi-directional robot, with enough PING))) modules to cover 360 degrees of object detection. All you need to supply is power, a brain of your choice, and programming to get it around. The Robot Base Full Kit is offered with a combined savings of $162.
The products in this kit are almost entirely Made in the USA in our SMT line, CNC router and CNC milling machines. Theyre fully tested and packaged with care. Weve spared no expense to provide the highest quality materials and fabrication processes.
Features:
- 18 diameter round robot base provides zero-turn radius
- Pre-drilled mounting locations for two motor bearing blocks
- Pre-drilled mounting locations for up to 10 Ping))) Ultrasonic Sensors and Protector Stands
- Pre-drilled mounting locations for two caster wheels
- Under-carriage battery pack mount location for 12V 7Ah batteries (designed for Power-Sonic PS-1270 or PS-1272 sealed lead-acid batteries)
Full Kit Contents:- (1) Motor Wheel Kit with Position Controller (#27971)
- (10) PING))) Ultrasonic Ranger Finder (#28015)
- (2) Caster Wheel Kit (#28971)
- (1) Robot Base Kit - Black (#28977)
- (2) HB-25 Motor Controller (#29144)
- (10) PING))) Protector Stand (#725-28015)
- (10) Servo Extension Cables (#805-00002)
Things You Supply:DISCover Robot Base Kit
DIYscbot
Ursprung (the Swedish word for origin). I use Swedish words for codenames for my projects. My datalogger is codenamed Skriva for example.
Diskovery sounds neat & kinda Russian, but the spelling would be nuttin' but trouble downstream.
Voyager is good, too. From the cartoon version of "Fantastic Voyage" with Buzby...
ROVER is good too, although mayhaps a bit too obvious.
Also Parallax Pathfinder.
Parallax Pingo... with 10 all Pings aboard, it's a natural. Kinda pithy, too.
Parallax Paramount
Parallax Paragon
Parallax Passage
Vector, Vectoria, Vektor (again, Russian but cool)
VectorBot
Where am I? How did I get here?
Radian
Pinger)))(((
Parallax Paradigm
Parallax Panache
Parallax Purveyor
Parallax Pursuit
Surveyor
Probe
POLYbot
Radius
Sensor
UltraBot
Warrior
Viking
Flex
Astro
Gemini
Ranger
Traveller
Fargo
Nova
Trooper
Explorer (yes, I was on the road a lot today, lots of car names)
foreign:
Avanti (forward)
Andiamo (Let's Go)
Forza (Strength)
Allez (Go!)
Allow me to enter this: Hyakume
Other alternatives would be like Argos, Panoptes, etc. Anything with lots of eyes.
Comet
-dan
Here you go...
RoBaKit - Robot Base Kit
P-Bot - Platform Bot
Debate Bot - Wood vs. HDPE
and the winner is...
MadeUSA or Madeusa or Madusa - take off of Medusa - because of all the Pings))) and the fact that it is Made in the USA
Sounds cool too! The Parallax Madusa...
DaVinci (it's a palette with which to paint your robotic masterpiece and write your DaVinci code)
Wayfarer
Flatform
Freeform
Freedom
Quest
Apollo
Delta
Geo
PRoP (Parallax Robot Platform, too bad you already have a product named Propeller)
PropBot
ProtoBot
BASIC Bot or BASICbot (you own BASIC Stamp, so own this too)
(it is also very Greek! )
This platform is certainly a beginning, and 10 Pings is eerily like 2 heads looking forward & back!
also:
MORPH
MORPHEUS
EVOLVE
EVOLUTION
REVOLUTION
I see erco is a nimble-fingered subscriber to the "Infinite Monkey Theorem".
So when Parallax gets around to building a kit that bangs on a typewriter 24/7, please put my suggestion in the hat with all the rest: The Ercobot.
My only question: can plywood take that kind of punishment?
Hey, that's it, name the robot AMIGO!
@Matt: BTW, what's the prize? An iRobot Create?
OMG, that's it! Kissyerbuttbot.
Can erco and I split the prize?
PINGuino - sadly exists already
P2-D2
ParBud - Parallax Buddy
Parallax Vivat BASE
That name MORPHEUS are already used by Bill Henning on one of his PCB's
propell-bot
base-bot
pro-base
Home-Base
