Fill the Big Brain - Page 6 — Parallax Forums
Fill the Big Brain
13468959
    edited 2011-01-10 05:44
    The 1st Propeller Desktop Brain
    Horizontal Computational Brain Machine
    1st Parallax Propeller Desktop Brain
    Computational Machine in horizontal
    configuration with display
    Currently undergoing heavy wiring, design and testing, this latest version of the Parallax Propeller desktop computational brain machine is being developed and expanded to a total of 121 processors. Not visible is a growing back stack of 48 more processors and the side boards. I'm not sure if it counts as a blob anymore as it has taken on different course.
    271 x 130 - 7K
  • WhitWhit Posts: 4,194
    edited 2011-01-10 07:44
    Humanoido, Your documentation of this is amazing. I always learn something reading this thread.
    edited 2011-01-10 12:31
    Whit wrote: »
    Whit, thank you! I hope the completed project will have enough information so you can build a brain for your robot. I'm following your posts too - keep up your excellent robotics work!
    edited 2011-01-10 12:41
    Brain Blob and BASIC Stamp Supercomputer Software
    Similarities are striking
    I loaded up the software from the BSS project to take
    a look at the LCD code and something shocking
    occurred to me. The code was exactly the same as
    the Propeller code, allowing for PBASIC vs SPIN
    programming. Somewhere in the back of my mind
    I had created exactly the same concept on two
    different platforms. This is good because the same
    tried and true principles can be used to drive the LCD
    that I have in mind for displaying the brain thoughts.
    The principle is a serial LCD that connects to the bus
    on the super net and eavesdrops on the traffic. The
    concept is a master/boss and a series of workers/
    helpers. The master talks to workers and workers
    respond. The LCD hears everything...
    edited 2011-01-10 12:53
    Utilizing Liquid Crystals - the LCD
    In the BSS, the LCD has two lines and no buffer. So a small subroutine
    was written to format the LCD and buffer over a couple lines. This is
    initially handled by the Master each time talking takes place. It expands
    the messages to two lines with 16 characters per line at a time.
    In the Propeller Brain, a display with four lines of 20 characters per
    line can be used. The #30058 LCD has automatic line wrapping and
    scrolling so this display can greatly simply the code. It jumps to 40mA
    current draw so it's best used when plugged into a power source
    other than batteries, or used sparingly for portable apps.
    Another idea is to simply unplug it for field operations.
    edited 2011-01-10 13:01
    The Dream World
    Four types of brain dreaming
    Displaying Graphical Dreams will be possible as images can display and play back on a TV. A card may be needed for this app. The small TV monitor can also become portable.
    Another more basic option is to use software to Vector Dream and draw dreaming as it happens in real time using Propeller LOGO language. For details about a Propeller-based LOGO, follow this link.
    The third dreaming option is called Text Dreaming. This is where the dream is composed of words to represent the story line of the dream. This technique is ideal for outputting on the 4-line auto scrolling LCD as previously mentioned.
    Are there other types of dreaming? Yes. Internal Dreaming takes place inside the program but does not get outputted, at least not immediately. It happens and either gets saved or does not get saved.
    Will the Brain dream in black & white or color? Only time will tell..
    edited 2011-01-11 09:54
    Multi-purposed Software
    Code will have several purposes. In one example,
    I want to recreate the BASIC Stamp Supercomputer
    using Propeller chips. In the next arrangement, code
    will enhance the machine so it runs closer to super
    computing stature. Another code project enables
    high speed. Perhaps the best project will be an AI
    program that hopefully will lead to a life form. It's
    a great expectation and a high goal, I think, but could
    definitely lead to greater things.
    edited 2011-01-11 09:58
    Case of the Missing Software
    I searched all over looking for code samples and examples to be used with the #30058 LCD 4x20 from Parallax. This was on the web at one time but now I find nothing!
    edited 2011-01-12 02:56
    The EXO: Exoskeleton Physical Form Factor Design
    Creating a new exo design
    For the reason of inability to easily access and rewire
    the inside row of PPPBs, the Exo is now redesigned.
    A middle "inside" row of boards is now deleted and the
    row moved to the outside of the form.
    In the new design, the form has three sides with six boards
    to a side. That makes 18 boards and 20 boards total with
    the two side boards.
    This creates a rectangular box with the open end
    becoming the bottom as it sets on a desk top. It opens
    up easy access to wire and rewire all boards. It places
    the components on the outside of the boards rectangular
    shaped exoskeleton.
    edited 2011-01-12 03:05
    Connecting EXO Boards
    Avoiding short circuits
    You can connect the EXO (Exoskeleton) boards by overlapping
    and bolting together at the corner holes. Unfortunately, the leading
    PPPB back side edge has some protrusions - mainly the solder legs
    from the switch and capacitors stick out too far.
    These solder points from the power switch
    and filtering capacitor on the power supply
    circuit stick out on the back side of all PPPBs
    and form short circuits from board to board
    The text describes a method to prevent short
    circuits.
    This has a tendency to short out the two connecting boards. There's
    a simple remedy and fix. Cut out strips of insulating dialectric material
    (mine came from a sack distributed by the China General Technology
    Group) and place it in between the board.
    It was purely coincidental that blue Tyvek sack material matched the
    color of the PPPB boards.
    299 x 169 - 10K
    edited 2011-01-12 03:08
    Solderless Breadboard Results
    Favorable results offer permanent solutions
    The fix of directly attaching solderless breadboards with
    their original sticky backs instead of rolled tape has solved
    the problem of these boards falling off when inverted or
    held sideways for extended time periods.
    edited 2011-01-12 03:13
    Solderless Breadboard Positioning
    The critical position is established
    The exact position of the solderless breadboard on the
    PPPB is critical. It fits (width-wise) in between the Prop
    plug connector pins (next to the power barrel jack) and
    the board's edge by the edge hole for bolting.
    Positioning too far to the left will block insertion and
    connection of the Prop Plug. Too far to the right and
    the mounting bolt will be blocked.
    I find that it will line up with the left edge of the white
    breadboard with/and covering the line of holes to the
    right of the printed white ink brackets in the USB2SER
    marker. Photos will be added to this post later to show
    the positioning.
    286 x 184 - 4K
    285 x 213 - 9K
    282 x 213 - 7K
    edited 2011-01-12 03:22
    Dialectric Insulating Strips Design
    These prevent short circuits
    As mentioned, dialectric insulating strips are cut
    and prevent short circuits from one board to the
    next.
    Scissor out these strips from a discarded Tyvek
    shopping bag and use as insulating strips to
    prevent short circuits from board to board.
    The design of the strip, for the long side of the
    PPPBs is as follows:
    Width = 1-inch
    Length = 3.25-inch
    For the short side of the boards, use 2.5
    inch long strips.
    Remember to meter the resistance of the strips
    to confirm it is indeed insulating rather than
    conducting.
    Strips are held in place by the forced contact
    of the two board surfaces.
    301 x 226 - 11K
    edited 2011-01-12 03:30
    Solderless Breadboard Inverted Testing
    Making sure the breadboards do not disengage
    Upside Down Test
    To perform this test, the board was held upside
    down for several days and nights in the rig. Some
    boards held components and wiring and some did
    not. The original sticky side held firm on all tested
    boards.
    Added Weight Test
    In the next test following the first test, boards were
    gripped with a several pound force. No boards
    moved in position.
    Inertial Motion Test
    Considering the brain is designed for robotics in
    motion, a test with inertia was designed. In the start
    and stop action of this test, no boards were dislodged
    in any amount.
    Conclusion
    In conclusion, the small white solderless breadboards
    are firmly attached and will not fall off when wired in
    full and changed in position, such as inverted or
    with 90 degree rotations. This facilitates great the hybrid
    function of the EXO, i.e. positioning as a desktop unit
    or positioning as a tower. It also indicates the EXO is
    ideal for motion robotics.
    edited 2011-01-12 03:38
    Standard Brain Topology
    One goal with this Big Brain project is to establish
    a criteria of standards. This would allow the open
    source distribution of the brain and the creation of
    a common platform. In terms of hardware configurations,
    this could result in the ease of creating multiple
    brains. More details on creating a standard will
    follow.
    edited 2011-01-12 03:54
    Time Table
    New time schedule in effect
    Due to the new EXO design, all boards were disassembled
    and are now waiting for reassembly with bolts, nuts, and
    angle brackets. Starting all over on the design will create
    a much better EXO that can serve multiple functions, such
    as placements and form factors in both horizontal and
    vertical positions.
    Breadboard positioning & attachment
    Breadboard tests
    Board disassemble
    Board configuration design
    Removal of spacers, bolts, nuts
    Locate dialectric
    Cut out strips to insulate boards
    Locate source of angle brackets
    Test angle brackets
    Mockup of form factor
    Wire length test
    Resistor source
    edited 2011-01-12 04:11
    Invention of Brain Wrap
    When parts of your brain stick out
    What do you do when parts of your brain stick out
    and you're moving around in public? Something can
    get caught on something or bumped and pulled out
    or damaged.
    To ensure the safety of all brain components that
    mount on the EXO, the technology used in the SEED
    Basic Stamp Supercomputer and the BSS will be used.
    Sort of like a brain on seran wrap,
    SEED Stamp Supercomputer was
    wrapped during transport to
    avoid a wire being pulled out.
    This involved a stretch plastic wrap to cover the
    machine and it ensured that no wires pulled out
    during transport. Use Seran Wrap or similar,
    available at grocery stores.
    Wrapped from top down, SEED is
    protected during transport.
    Clear plastic wrap has many advantaged. It
    weighs practically nothing. It's protectively strong.
    It costs almost nothing for a section this size.
    It's commonly available at a grocery store.
    214 x 287 - 10K
    215 x 286 - 11K
    edited 2011-01-12 04:23
    Design with Fewer Parts
    New design is more efficient
    Spacers are now obsolete in the new design
    and no longer needed. The simplicity of board
    to board connections on the EXO is accomplished
    with bolts, angle irons and nuts.
    298 x 225 - 9K
    edited 2011-01-12 05:38
    Optical Illusion
    One side appears space larger than the other
    If you put together a bunch of PPPB boards by spacers
    while overlapping one board to the next, an interesting
    optical illusion will be created. One side will appear with
    spacing between boards smaller that the opposite side.
    Measuring the distance between
    boards proved the spacing is the
    same
    227 x 297 - 6K
    edited 2011-01-12 06:05
    Round Robin Rings Schematic
    Showing the Brain Blob Basic New Design Connections
    Extend P8 to P20 and R2 to R21. Hand sketch
    illustrates the first hybrid interface with a round
    robin BUS and two wire serial full duplex
    connections can be made in an outer ring.
    Inner rings handle Vss and Vdd.
    This is your Propeller brain on the napkin
    sketch series of diagrams. Brain domains
    show as correct orientation connectivity in
    circular notation
    286 x 219 - 8K
    edited 2011-01-12 06:58
    EXO Board Rows
    Showing the assembly of one EXO side
    The EXO has three board rows assembled in a consistent
    overlapping mount held together with bolts and nuts.
    This is approximately 1/3rd of an EXO.
    295 x 225 - 10K
    edited 2011-01-13 04:10
    Brain Span
    Assembly challenge
    The Brain Spans make up the sides of the EXO. Their assembly is a little more challenging since they assemble at right angles from row to row. There are currently three rows of six boards to be assembled in this manner. The problem occurs when the small bolt on one board obstructs the small bolt on the other board at right angles. I switched from half inch bolts to quarter inch bolts but once again, when I tried to assemble it, the bolt and nut interfered with the fastening.
    The discovered the solution when examining the size of the bolt head and comparing it to the size of the nut. The nut is appreciable larger than the bolt's pan head. The solution is to use the smaller quarter inch bolt and place the nut on top of the board away from the fastening joint. Even when mounting the right angled hardware, the half inch bolt is not needed (use the 1/4th-inch bolt throughout).
    edited 2011-01-13 04:29
    Right Angle Hardware Selection
    Angle iron connects Brain Spans together
    It appears that the size of the mounting hardware, the right angle iron in particular, is also critical. I was lucky to have several variations of angle iron on hand. (lighter weight plastic is not usable due to being too flexible) As it turned out, the smallest angle iron is the best. I used a special 5/8ths to a side iron with varying slotted holes for adjustment.
    edited 2011-01-13 04:35
    Balance Focal Point
    How to balance three brain spans
    This has become an issue for solving. The weight distribution is best when the row of the heaviest component is counter balanced. This means varying the breadboard postions. However, to vary the breadboards would require repositioning the boards where wires will need to be 50 to 75% longer. This is undesirable as we expect to use overclocking in the future. So examination of balancing may involve flipping the board so breadboards are side by side and 90-degrees to each other with the third row at the farther distance for compensation. It could be a compromise and I will know more after assembly of the two remaining Spans.
    edited 2011-01-13 05:20
    Brain Span Analysis
    In terms of weight and wire length
    Maybe we can say there is no need to balance Brain Spans or the distance of connecting wires is relatively unimportant. But I think there is a great use for brains in robots. In a free wheeling robot, we don't want a lopsided brain shifting the weight to one side or the other. It would skew steering and navigation. For humanoid robots, the same applies. Even in humans, our brains are relatively symmetrical with left and right hemispheres of equal weight around a common axis. Our neck does not need to exert undue muscle to balance the head-brain combination. An unbalanced brain would throw the head out of sync and require special muscle to counterbalance the weight, obviously an undesirable situation.
    Wiring is also important. It's desirable to have minimal length wiring from board to board, from Brain Span to Brain Span. With minimal wiring, we can overclock and make things run faster, and have more accurate data transfers.
    So far, the weight and wiring distribution possibilities using three brain spans and end effectors is something like the examples below. Here we see an example from the end of the rectangle shape, represented by complete balance with no breadboards.
    | End view of three rectangular Brain Spans
    In the example below, we see the introduction of breadboards (represented by the capital letter O) on all three rows of PPPBs. This is a two at right angles and one at distance configuration. If we call the wiring distance between breadboards as X, this arrangement is 2X. In the nomenclature, we will identify the locations of the heavy breadboards and their positions on the PPPBs. We will try enough examples until finding both a minimal wiring condition and a point of greatest balance condition.
    For wiring and weight balance, we sum the number of point to point distances between breadboards. A larger X summation is best for balance. The smallest X summation is best for wiring.
    O
    O
    | | A) Top board left, left board top, right board bottom, 2X
    O
    O
    O
    | | B) Top board left, left board bottom, right board top, 2X
    O |
    O
    | | C) Top board left, left board bottom, right board bottom, 3X
    O
    O
    O
    | | D) Top board right, left board bottom, right board bottom, 3X
    O
    O
    O
    O
    O
    | | E) Top board right, left board top, right board top, 1X
    O
    O
    | | F) Top board right, left board bottom, right board top, 2X
    O |
    O
    O
    O
    | | G) Top board left, left board top, right board top, 1X
    In conclusion, the following is best for minimal wire length: E and G.
    The following are best for balance: C & D. The configuration condition must be resolved by assigning a weighted value to weight balance and wire distance. Perhaps an average of the two is best. Then we are looking at all the 2X conditions. This includes A, B, and F. Since we want wiring convenience at the forefront, throw out condition F. This leaves us with a decision of A and B. In looking at this further, we could say weighting more to the front or back is a better counter balance. If this is the case, then G would be acceptable for minimal wire length and a the most weight balance in one direction.
    Note: the post has changed some of the spacing in the figure.
    edited 2011-01-13 08:51
    Brain Span Configuration
    Making the decision to position weight and wiring
    After the Brain Span analysis, it is decided to go for shortest possible wire length for greatest computational speed and ability and reliability. The brain must be given the highest considerations. For robotic balance point, the overall weight will be shifted and oriented in the best position and direction.
    O
    O
    O
    edited 2011-01-13 08:58
    Powering up 5-volt sensors in the Brain
    You can still insert a barrel plug from a transformer
    according to the PPPB specs, and it will power
    up the 5-volt regulator for sensor operations.
    This is key as each prop's 32 pins will have
    purpose and ability to drive numerous input
    and output devices.
    edited 2011-01-13 09:07
    Brain Hybrid Form Factor
    Establishing a dual form factor brain
    The dual form factor is now established for the Brain Blob.
    Taking on the new shape that's more rectangular, it can
    now easily function as a vertical high rising tower sky-
    scraper or as a horizontal slug fit to the robotic platform
    of choice. For humanoid robotics, it's back-packable.
    For wheeled robots, the hybrid offers two orientations,
    one for smaller robots with limited cargo space (vertical)
    and one for larger platformed carriages (horizontal).
    The desktop config is for programming convenience
    at a desk where it can be removed from the robot to
    establish higher brain functions, add-ons, upgrades,
    service and other operations.
    edited 2011-01-13 09:53
    Brain Photos Showing Hybrid Exo Configs
    Days of experimenting result in various EXO configurations
    Several horizontal variations include rows from three Brain Spans
    coupled to extra frontal boards.
    Another variation
    is this horizontal
    stack.
    Powerful stacked, loaded, expanded high rise skyscraper versions are towers with various supporting boards attached.
    Another high rise vertical EXO version shows more symmetry.
    463 x 86 - 6K
    110 x 87 - 2K
    681 x 114 - 11K
    702 x 86 - 13K
    edited 2011-01-13 15:24
    Pyramid Brain - Just for Fun
    You knew I had to try this, especially since we were
    trying out different versions of EXOskeletons. It's a
    pyramid EXO made from multiple Brain Spans. Since
    we've established the need for three Brain Spans
    with six boards per span, it seemed fitting. The extra
    three boards would go under the pyramid when
    flipped into vertical.
    Just for fun, a tryout of a brain pyramid. The
    form factor is interesting but may limit the
    addition of more boards.
    298 x 226 - 10K
This discussion has been closed.
