Propeller C3 update - Page 5 — Parallax Forums
Propeller C3 update
123578
  • Ahle2Ahle2 Posts: 1,179
    edited 2010-10-18 08:56
    There is a list?
    I thought You said there was no pre-order list?
    Put me on that list toooooo... :)
  • RavenkallenRavenkallen Posts: 1,057
    edited 2010-10-18 18:23
    Man, i am already thinking up applications for this and it hasn't even come out yet...I am thinking about a Prop Game Boy. It has a Megabyte of flash(which should be able to fit a decent sized game in it)....Ughh, so cool!!
  • AndreLAndreL Posts: 1,004
    edited 2010-10-18 18:42
    No, this isn't the pre-order list, but a list of demo coders that had to email me and give me their resume of sorts, and why they should be on the team. The prototypes are about $1500 each, so I can't just give them away :) Anyway, the list is closed Jeff LeDger was the last person on the prototype list and they have to be made by hand -- (sorry about the typo, all this handle stuff from the 80's -- I would just rather use names now...) Having handles is like wearing big bells these days :)
    Anyway, since the C3 is an application board, most of the demos etc. aren't going to do anything fun like the HYDRA stuff we did years ago when that came out -- these applications, tools, or languages are to do serious stuff hopefully, get work done, deploy in real world applications to solve real problems in your work, school, or hobby development.
    Andre'
    edited 2010-10-19 01:54
    I spoke to Ken G today and Parallax has most of the parts now for the C3 and is getting ready to start manufacturing, so we are getting close! The manual is about 2 weeks from my completion then I think it will take them 1-2 weeks to edit it, so that's about it on my end.
    Almost there :)
    Andre'
  • SapiehaSapieha Posts: 2,964
    edited 2010-10-19 05:50
    Hi AndreL.
    It was to much for me to BUY that for my speed tests on 15MHz/PLL8.
    As I know as many QFP Propellers can it if PCB are correct.
    AndreL wrote: »
    Andre'
  • jmspaggijmspaggi Posts: 629
    edited 2010-10-19 06:01
    jazzed wrote: »
    Which one? Getting RossH to sign on to "1000's of instructions per second ...." for Catalina seems difficult at best. I would be very surprised if ImageCraft is involved at all. Of course porting ZOG should be a snap by now.
    Hi Steve,
    And what's about the JVM on C3? ;)
    JM
  • jazzedjazzed Posts: 11,803
    edited 2010-10-19 08:36
    jmspaggi wrote: »
    Andre' never sent me a C3 for testing.
    edited 2010-10-19 08:38
    jazzed wrote: »
    Where can I download the current version of the Propeller JVM? I can try it on my C3.
    edited 2010-10-19 09:04
    David Betz wrote: »
    The latest version out of the box requires a 64KB+ EEPROM. I was going to port this to C3 for using either the Flash or the SRAM. We can continue the discussion in the Propeller JVM thread if you like.
    edited 2010-10-19 09:25
    Despite what Andre says about the C3 being perfect for the serious stuff, I think it will likely be a very solid platform for the "fun" stuff as well. I see tons of memory for "sprites", sound, and map data. :)
    Hope my homework assignment that comes with the C3 prototype isn't too serious. ;) I'm holding on other projects for now till I see what Andre has in mind.
    @handles: yes, I agree. I'm getting to the point that having an "alias" is somewhat painful, so I "might" switch to my own name sooner or later.
    OBC
    edited 2010-10-19 09:27
    jazzed wrote: »
    Can you point me to the JVM thread? I tried doing a forum search for "JVM" but was told that you can't search for three letter words.
  • hover1hover1 Posts: 1,929
    edited 2010-10-19 09:33
    David,
    The 3 letter limitation is a pain. Had the same problem searching for GPS. Try the wild card search: *JVM*. That brings up some hits.
    Jim
    David Betz wrote: »
    edited 2010-10-19 09:47
    David Betz wrote: »
    Sorry about that David.
    You can add * to any three letter word for good search.
    Look here: http://forums.parallax.com/showthread.php?t=110317
    The top post in the thread points to the HUB only version of JVM which should run on any Propeller.
    The latest version which I'll support runs from EEPROM and when ported potentially any board with external memory addressable storage like SRAM, Flash, or SDRAM. The latest package can be found near the bottom of page 13: http://forums.parallax.com/attachment.php?attachmentid=72019&d=1280310689
  • AribaAriba Posts: 2,693
    edited 2010-10-19 17:17
    A few more details:
    - entire design to be open-sourced and double as a Propeller reference
    Will the C3 design be as open as the Arduino? Can everybody make a clone of the board, or a modified version for special requirements?
    Why I ask:
    I have a board made some time ago which is in many aspects similar to the C3. This board needs a redesign and I ask myself if I should change the expansion connector to a C3 style header. So C3 daughterboards would work with it, and my AddOn-boards can also be used with the C3.
    The board will not be 100% software compatible, mainly because of a different SPI select logic, but close enough to be useful.
    Is there any problem with that, or is it even welcome if others make compatible boards?
    Andy
    edited 2010-10-19 17:29
    Ken has to respond to this --- but, yes, I believe we are doing something just like the Arduino, the design is open sourced and the idea is to have a reference that others can use. I think the only thing parallax will want to control are people using our product name "C3" as the name of the product. Just like Arduino, it can say "Arduino Compatible" and be a play on the word Arduino. Same idea with the C3, I would imagine parallax wants to control the copyright on the name of the product itself, so when a customer buys a "C3" they know its a real bonafide parallax C3, but other than that -- the idea was to be open source with this.
    But, again, let's see what parallax says about this specifically and Ken's response.
    Andre'
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2010-10-19 20:11
    AndreL wrote: »
    Andre'
    This is perhaps more open-source than Arduino. If you make - and sell - Arduino boards then you pay the Arduino developers 10% of your proceeds. You don't have to pay us a dime! And the Propeller is probably more open-source than the AVR, too, considering Chip shared the interpreter code.
    We would like to keep the name C3 reserved for the Parallax version just to protect the reputation of the product's high quality. C3 boards will be made on the finest equipment in the USA using only approved and qualified components from consistent sources. Every board will undergo a FULL test of all I/O features, too. Aside from creating your own name, you can make these, sell them, and do whatever you want.
    All of the design files will be posted if they have not already been put on the web site.
    edited 2010-10-19 21:22
    Don't you just love Parallax. Thanks Ken & AndreL.
    Also Beau is showing us how he is laying out the PropII prototype chip.
    And others wonder why we love the Prop and Parallax!
    edited 2010-10-19 22:20
    Thanks Andr
  • ForrestForrest Posts: 1,341
    edited 2010-10-20 01:41
    Ken,
    Could you post a picture of the Parallax laser-cut enclosure for stand-alone projects?
    Forrest
  • koehlerkoehler Posts: 598
    edited 2010-10-20 03:56
    Figure out a way to get a nice 3.5 - 4" LCD panel as a gfx shield accessory, and you will have struck gold.
    Or maybe platinum, as this looks like gold.
    AndreL wrote: »
    And finally "what is this really for" -- the idea of this is an "application" board. That means, its not for development/learning in that it only contains a single prop and regulation. This board is designed for high end projects and control where you need built in A/D, larger memory for recording, SRAMS maybe for buffers that hold data, code, whatever etc. So, the idea here is a "credit card computer" that has everything you need to build something rather complex without adding FLASH, SD, SRAM, A/D, etc. its all on the card. A lot of customers have been wanting something like this, so here it is.
    Andre'
  • schillschill Posts: 741
    edited 2010-10-20 05:11
    I have removed my previous comment from this thread. I started to have paranoid thoughts about what it might look like on a Google search.
    Let's just leave it at I'm really looking forward to getting a C3 or two (at something under $1500 each :) ).
    edited 2010-10-20 15:38
    Since I am the name maker upper around here and came up with "HYDRA" and "C3" :) I would say just take "C3" and put something cool in front or after it like "Mega C3" or "C3 Xtreme" -- things like that :)
    Anyway, back to writing the manual....
    Andre'
    edited 2010-10-31 20:28
    Well, it is november now, haha....Any news yet? Some of us can't wait to our hands on them..
    edited 2010-10-31 20:37
    @AndreL
    Fantastic! lots of nice features. It will sure be interesting to see what gets built with them.
    edited 2010-10-31 20:48
    Thanks -- we have some interesting programs being developed right now while the C3 is in manufacturing.
    Andre'
  • RoadsterRoadster Posts: 209
    edited 2010-11-12 18:41
    Well it's almost mid Nov. any new updates, or screen captures of any demos
    edited 2010-11-12 18:47
    Well, like I said, this is an app board, so demos are boring "work" stuff like moving servos, writing flash memory, etc. However, we have ported a bunch of HYDRA games and we are working on a couple C3 only games that use its abilities. I will see if we can get any screen shots of them :)
    But, the manual is done, everything is done, its in manufacturing out of my hands now --
    Andre'
    edited 2010-11-12 18:51
    Thanks for the update Andre'
  • RemzRemz Posts: 4
    edited 2010-11-12 22:49
    Hi everyone,
    here's a screenshot attached for "Project B", a side-scroller action game designed for the C3:
    The game is not done yet, but it should look like the screen shown.
    Lots of work to do!
    Remz
    256 x 192 - 9K
    edited 2010-11-13 07:03
    Looks great!
    Remz wrote: »
    Hi everyone,
    Lots of work to do!
    Remz
