Propeller C3 update — Parallax Forums
Propeller C3 update
AndreLAndreL Posts: 1,004
edited 2011-01-31 07:29 in Propeller 1
As many of you know we have been working on a new "Credit Card Computer" Propeller application board called the C3. The product is complete and now in Parallax manufacturing. I wanted to post some pics of it, so you can take a look at the final product.
The specs once again are:
* Prop + 64K EEPROM with socketed XTAL.
* FTDI USB port for programming and serial.
* Dual 1.5A - 3.3/5V supplies with USB powered and external 2.1mm power jack.
* Micro VGA port along with composite A/V.
* 1 PS/2 port.
* 1 MB SPI FLASH.
* (2) 32Kx8 SPI SRAMS.
* 2-Channel MCP3202 A/D
* Micro SD card interface.
* Headers exporting out IO, Power, etc.
* 4 convenient "servo port" headers with heavy capping to support directly driving servos.
* SPI bus system to minimize IO usage on peripherals like SD, FLASH, A/D, and SRAMS.
The idea of the C3 is to be a really powerful application board for the Propeller, not so much a development board that you learn on, not to say this isn't great for learning. But, this is great since you can put it in an application, work with it on your laptop with no power supply (since its USB powered as well as external). And we are building a "shield" daughterboard as well that mounts on top of it to give you more room to put hardware and your own stuff.
Also, one of the pics shows the "break away" mounting tabs. Instead of making the board bigger to support mounting holes, we decided to give you the best of both worlds, keep the board small with tabs. If you want the mounting holes, use them, if not, you just snap them off -- regardless there is a central mounting hole in the middle of the board.
Andre'
«1345678
    edited 2010-10-04 12:29
    A few more details:
    - entire design to be open-sourced and double as a Propeller reference
    - includes customer requests for SRAM and SD card interface
    - I/O pin designation compatible with other Parallax designs
    - will supply with a Parallax laser-cut enclosure for stand-alone projects
    - priced between $49.99 and $79.99 depending on our internal labor/BOM costs
    - availability mid-November, early December
    The USB-powered aspect will be great for those who travel with Propellers - program it easily on an airplane, train, or wherever you're going without providing external power supplies. The very small size (credit card) really helps on the portability side of things. At last check it fit within an Altoids tin.
    Parallax Inc.
  • hover1hover1 Posts: 1,929
    edited 2010-10-04 12:40
    Thanks Andre and Ken! Impressive stats! I love the FLASH and SRAM.
    The Altiods fit is a deal breaker! :)
    Jim
    edited 2010-10-04 12:43
    Was it tested with the 6.25Mhz Xtal?
    I would have thought that was the norm now.
    Jim
  • max72max72 Posts: 1,155
    edited 2010-10-04 12:50
    Impressive specs!!
    The USB powered option is a great point.
    Do you plan to offer a half assembled board (with TH to be home soldered) or a to be assembled one?
    A hobbyist could enjoy the assy and save a little bit doing that..
    Massimo
    edited 2010-10-04 12:53
    Congratulations Andre!!!
    Looks like a great (and very small) board - I hope you sell a lot of them.
    FYI David added C3 drivers to my VMCOG, so C3 will be able to run ZOG, ZiCog and all future VMCOG compatible software, and as VMCOG is MIT licensed, feel free to distribute it with C3.
    Bill
    AndreL wrote: »
    * 1 PS/2 port.
    * 1 MB SPI FLASH.
    Andre'
    edited 2010-10-04 12:55
    Nice work Ken & Andre!
    I think this little board will be a winner!
    Bill
    p.s.
    Frankly, given distributor margins, I think you will be selling at $79 - unless you are doing it as a loss leader.
    A few more details:
    Parallax Inc.
  • KaosKiddKaosKidd Posts: 296
    edited 2010-10-04 13:05
    I project is so cool!
    I love it!
    KK
    PS: When it comes out, I know I'll be getting one sometime thereafter.
  • TubularTubular Posts: 4,773
    edited 2010-10-04 13:33
    This looks great and in time for Christmas too. The mounting tabs / holes are a great addition. Not sure what "Micro VGA port" is - it looks like the standard size, doesn't it?
  • jazzedjazzed Posts: 11,803
    edited 2010-10-04 13:38
    Warning to travelers: Never tell airport security you have a C3 in your Altoids tin.
    It's a very nice board. I wish Andre' and Parallax much success.
    edited 2010-10-04 13:43
    LOL!
    jazzed wrote: »
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-10-04 13:47
    Super cool!
    I'm impressed with your price point to. $49 for all of that is a deal.
    edited 2010-10-04 14:02
    Bill, you are so correct. Hopefully our customers will always be so understanding. Building products with components sourced from Digi-Key, Mouser, Future and whoever else has a high cost (and the very real benefit of consistency on subsequent builds). And nothing compares to California labor for manufacturing. Customers don't complain, but sometimes they don't buy because of costs. This product will have a high retail and for good reason. Since the product is open-sourced it might even be helpful for others on this forum to know about the real costs:
    Design/engineering: $ 20,000
    Bill of materials setup 5,000
    Documentation costs 10,000
    Prototype costs 3,000
    P&P programming/setup 2,000
    Total 40,000 and no product has even shipped
    Per unit BOM costs: 30
    Manufacturing labor/kitting 10
    Unit cost 40
    I didn't mention the initial inventory costs.
    Retail price may be $79, but the average selling price could be more about $55 given distributor discounts.
    You can figure out how many you need to sell in order to break-even and have a reasonable return on investment. Somewhere between 2-5K units sound about right?
    What about lowering costs by building this in China? Not a good idea with this particular design. The very specific choice of components and fairly low-volume dictate American-made manufacturing, not to mention other management costs.
    This isn't to say we (and you) shouldn't be involved in such designs. This is what we do at Parallax, and what many of you do for a living so you know the facts as well as we do. But for the newcomer it is so important to understand the details in learning how to make these products a business success.
    The above is a very calculated approach that could help with pricing a product like C3, but Parallax must also look carefully at our marketing intent with the design - to inspire customers to consider the Propeller for whole-system designs, or to sell hardware at a profit? The former is usually a loss-leader - something that excites all of us but ends up on the EOL radar too early in the life cycle. It's always best to make sure a product can have a reasonable return on investment unless it's a clear printer/inkjet refill nexus. Sure, this sells chips, but how many more are sold because our customers bought a C3? Answer this for me if you could, please.
    At least from my perspective . . .
    Parallax Inc.
  • Ahle2Ahle2 Posts: 1,179
    edited 2010-10-04 14:04
    Where can I pre-order? :)
    This is EXACTLY what I have been waiting for, and I have a great project for it that REALLY needs the additional ram.
  • SapiehaSapieha Posts: 2,964
    edited 2010-10-04 14:10
    Hi Ken Gracey (Parallax).
    WHY You not said You PAY so good for Design/engineering: $ 20,000
    In my opinion ---> It is to much ---
    Unit cost 40
    Parallax Inc.
    edited 2010-10-04 14:15
    Thanks Ken :-)
    I totally understand. Unfortunately, I have even lower volume, and higher BOM costs :(
    I am looking forward to playing with a C3!
    I think it will fit nicely in my netbook's case...
    Bill
    Unit cost 40
    Parallax Inc.
    edited 2010-10-04 14:22
    Sapieha wrote: »
    You are taking this out of context, Sapieha, and assuming we wrote Andre' a check for this amount. I'm sure Andre' would really like that, however. The engineering costs sometimes appear in the form of a check written to somebody else, or they're hidden in what's known as the burden cost (salary, health benefits, vacation costs, 401K matches, sabbaticals, software license fees!, etc) of our staff time (at least $100-150/hr). Because of your assumptions I am trying to share what's involved.
    $20,000 / $150/hr = 133 hours. Try to achieve what it takes to bring a product like this to manufacturing within 133 hours.
    This is what's involved in engineering costs for such a design:
    - administrative costs if designed outside, such as writing an agreement
    - specification prepared by Parallax and engineered by Andre'
    - block diagram preparation with consideration to mechanical layouts
    - schematic review and approval
    - design cycle (2-3 prototypes)
    - test procedure/hardware (ever thought about this one? - requires hardware, software, pas/fail)
    Engineering costs associated with bringing a product to production are much more significant than laying out a PCB over the weekend and sending it to PCBExpress. Come on, you already know this. . . you've designed many boards and they look great.
    When a product like this is ready to command the attention of a half-dozen manufacturing staff you better be sure that it is not only engineered completely, but that it's passed to them with significant support in terms of test procedure, hardware, etc.
    Parallax Inc.
    edited 2010-10-04 14:25
    NICE!!!
    edited 2010-10-04 14:30
    Sorry If That was disturbing You. I know it is maybe not so much in USA.
    And I know all that You write on design stages
    > BUT If You consider as I have about 1000$ in month = My Sickness Assurance money that maybe You understand my standpoint.
    Parallax Inc.
    edited 2010-10-04 14:41
    what are the dimensions of this board?
    edited 2010-10-04 14:42
    Sapieha wrote: »
    No disturbance caused here. That's one of my points - designing and manufacturing is expensive in the USA. And it's a big amount compared to what you live on every month. It's so much cost that I could loose sleep over it. It's a serious investment every time and one that we don't take lightly.
    Always write what you want on these forums and will try to do the same. It's much more difficult for me to convey my opinion because I have to uphold a position under the name of Parallax. But we're here for all of you, and this forum is an open place so your thoughts are appreciated regardless of how anybody feels about them (within forum guidelines, of course).
    Parallax Inc.
    edited 2010-10-04 14:51
    THANKS for answers.
    Next time think that maybe I can give You some DESIGN time on PCB's
    Ps. No problems for me to write secrecy document.
    Parallax Inc.
  • schillschill Posts: 741
    edited 2010-10-04 15:06
    Thanks for putting on the mounting tabs. So many small boards these days seem to be leaving out ways to mount them (or putting holes in really awkward locations that leave no room for hardware). At a hobbyist level, it's always nice to be able to stick things in a box without needing tape/etc. to hold them in place.
    Pricewise: At $79 I'll buy at least one. At $49 I'll probably buy more than two.
  • MacTuxLinMacTuxLin Posts: 821
    edited 2010-10-04 15:09
    Hello All,
    Is this cool C3's dimension about 3.38" x 2.13"?
  • AndreLAndreL Posts: 1,004
    edited 2010-10-04 15:47
    Also, of course, I have written 20-30 demos that show off all the sub-systems that run both in local keyboard as well as over serial terminal mode. That along with my usual manual on the product that covers the design, each of the sub-systems and each of the demos which I am writing right now -- I did everything in SPIN, short and sweet to get users up to speed with the A/D, FLASH, and SRAMS.
    * The dimensions of the board are: ~75x55mm
    * I tested it with 5 and 10mhz XTALs, its a propeller chip and none of the hardware relies on the clocking of the Prop, so you can put 6.25 or whatever else you want in there.
    * Also, one other little tidbit, I designed the board so that you could add the Parallax NES adapter to it and plug into the headers and plug NES controllers in if you like :) This way any games written for the Prop will work on here that require NES controllers -- nice little touch even though this is not a game machine.
    Andre'
    edited 2010-10-04 15:51
    Andre',
    Thanks for the answer on 6.25mhz support.
    Jim
    edited 2010-10-04 16:41
    Total [$]40,000 and no product has even shipped
    Thanks for releasing this info! It makes me feel much better (or worse depending) about spending over $1,000 on the Propeller ASC
    edited 2010-10-04 16:46
    BTW, Martin, I've had the Prop ASC hooked up today and I can see it also has some really nice features and non-threatening design. I'll get back to you shortly on your message, too.
    edited 2010-10-04 17:57
    And here's another couple pics to show dimensions with things plugged in including the NES adapter and the manufacturing board test that exercises the C3.
    Andre'
    1707 x 1200 - 226K
    800 x 598 - 148K
    edited 2010-10-04 17:59
    :rofl:
    The C3 looks really great! Just what the power user needs. Nice work.
  • blittledblittled Posts: 697
    edited 2010-10-04 18:00
    I have 50 Altoid cases looking for something to do.... :) Actually I probably buy one. It looks great Andre and Parallax. I'm sure it'll be a great deal at any cost knowing the quality and support Parallax puts behind a product.
