New 4.3" touchscreen LCD for Propeller: "used" screens almost free w/purchase. - Page 22 — Parallax Forums
11819202224
  • RaymanRayman Posts: 15,239
    edited 2010-06-14 23:53
    Take a look at the "PSB_VGA_DEMO" that you can download on this page:
    http://www.rayslogic.com/Propeller/Products/PSB/PSB.htm
    This is an example of how to modify a VGA app to use the 4.3" touchscreen...
    My Prop Apps:· http://www.rayslogic.com/propeller/Programming/Programming.htm
    My Prop Info: ·http://www.rayslogic.com/propeller/propeller.htm
    My Prop Products:· http://www.rayslogic.com/Propeller/Products/Products.htm
  • wjsteelewjsteele Posts: 697
    edited 2010-07-10 23:39
    Hey Ray,
    Have you, or anyone else done anything with the backlight so that it can be adjusted dynamically? Everytime I change the value (1-32) I have to reinitialize the display, which causes a very annoying screen flicker.
    I'd like to just change the value and have the display adjust the backlight only. That way, I could implment a software controlled ambient light sensor (with the user being able to set the gain.)
    Bill
  • HarleyHarley Posts: 997
    edited 2010-07-11 00:17
    I too searched the listing but it seemed fixed at the moment. Probably on a 'things to do' list?
    I don't need to adjust BL for now; but once I get on batteries (might be a while the way things are progressing for me), I'll sure want to conserve them. yeah.gif
    Harley Shanko
    edited 2010-07-11 22:33
    Bill, the backlight can be changed easily... The backlight level is a variable whose address is passed to the LCD driver. The driver checks this value very often and adjusts the backlight if changed. I don't think there should be any flicker when changing backlight level...
    edited 2010-07-11 23:15
    Ah, I found the problem. I'm using Andy Schenk's full screen driver, but he only updates the backlight in Spin during the Start method.
    I'll grab your code and add it to the backporch portion in his driver... that should do it.
    Bill
    edited 2010-07-11 23:36
    Ray,
    I forgot to mention - the PSB I bought at UPEW works great [noparse]:)[/noparse]
    I plugged in one of the "used" 4.3" displays I got from you earlier, and it fired up immediately!
    Now I will just have to measure the power consumption to see if I can get away with powering it from a USB port...
    Bill
    www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com
    My products: Morpheus / Mem+ / PropCade / FlexMem / VMCOG / Propteus / Proteus / SerPlug
    and 6.250MHz Crystals to run Propellers at 100MHz & 5.0" OEM TFT VGA LCD modules
    Las - Large model assembler Largos - upcoming nano operating system
    edited 2010-07-11 23:52
    Actually, I run the PSB off USB with no problem using Ray's 4.3" displays.
    Bill
  • AribaAriba Posts: 2,693
    edited 2010-07-12 00:16
    Bill (wjsteel)
    You can just move the Spin code that sets the brightness at the end of the start methode to it's own public methode. Then it will be possible to change this when ever you want by calling this methode.
    Bill (Henning)
    My Board draws ~150 mA and I power it always from an USB port. I think the PSB has a similar current consumption.
    Andy
    edited 2010-07-12 00:57
    Thanks Andy, wjsteele!
    Post Edited (Bill Henning) : 7/12/2010 1:28:29 AM GMT
    edited 2010-07-12 01:05
    The PSB draws about 400 mA at full brightness, just below the 500 mA, by the book, limit...
    Most of the 400 mA is the LCD backlight.· You can save a lot of power by turning it down...
    edited 2010-07-12 01:16
    I was wondering about how the backlight gets adjusted.
    This thread answered that question. So added a menu for the BL adjustment and it works great on the 3.5" LCD.
    Pic attached; the white text on blue is for debug purposes temporarily. yeah.gif
    Thanks for the info on BL.
    Harley Shanko
    640 x 480 - 40K
    edited 2010-07-12 01:27
    Ariba said...
    That was too easy!!! smile.gif Thanks Andy!!!
    Hey all, here is the simple method I added to Andy's Full Screen Graphics Driver to allow dynamic blacklighting adjustments.
    PUB AdjustBrightness(brightness) : okay
        repeat brightness
          outa[noparse][[/noparse]bl]  := 0
          outa[noparse][[/noparse]bl]  := 1
        return true
    Bill
    edited 2010-07-12 03:18
    @ rayman,
    On the LCD front surface is a film that is beginning to wrinkle and peel. Is this to be removed, or have I been too rough on it?
    I didn't want to peel it off if it shouldn't be done. Sorry to bother on this maybe trivial point.
    Harley Shanko
    edited 2010-07-12 12:28
    Harley, that's a screen protector that most new screens come with... Just peel it off and toss it...
    edited 2010-07-12 12:31
    Bill, I'm not sure Spin is fast enough to set the backlight correctly... The PSB and PTP assembly drivers set the backlight at assembly speed during the blanking period of the display. Your spin method may kinda work, but may not work exactly like you think... Anyway, that was my experience.
    edited 2010-07-12 13:24
    Ray,
    Doing some tests, it works perfectly. I built a slider that allows the user to drag a thumb across the screen. I used the TouchX value divided by 100. I then trimmed that to 1-32 to fit the parameter range. I found that if I didn't trim it, it would cause the display to shut down.
    Now, when I drag the thumb, it does a beautiful job of changing it depending on where you drag the thumb.
    EDIT:· By the way, it works because the spin code is the only code that is twiddling the bits for the backlight pin, which is obviously on a different cog then the display driver itself.· Andy's driver doesn't do anything to that pin after the initial spin startup.
    Bill
    Post Edited (wjsteele) : 7/12/2010 2:28:13 PM GMT
    edited 2010-07-12 18:47
    Rayman said...
    Thanks. Wasn't sure. I'd thought some damage had been done to the front surface; thought it were extra 'soft' and easy to scuff or punch.
    Looks super with it off, shinier, clearer and feels like it is a tougher film.
    Harley Shanko
    edited 2010-11-21 17:51
    Ran out of breakout boards and decided to improve the layout before ordering more... Test run of new boards checks out (and on way to GadgetGangster.com) and so will be ordering a bunch more now.
    The only non-cosmetic change was to reduce the spacings between mounting holes. This is because the blade that I cut the boards apart with is much thicker than originally anticipated. Also, I've made a lot of cosmetic improvements. Here's a pic:
    1496 x 1122 - 582K
  • pgbpsupgbpsu Posts: 460
    edited 2010-11-23 17:10
    wjsteele wrote: »
    Ray,
    Bill
    Bill- are you willing/able to share your code for this? I have one of Rayman's touch-screen units and I'm having trouble getting off square one. I'm not very familiar with graphics and bitmaps but I'm working on it. Having an example that adjusts the brightness could be really educational.
    Peter
    edited 2010-11-23 18:13
    Peter,
    I don't know how you planned to change the brightness, but I played with both the 3.5 and 4.3" LCDs and used 'buttons' to change things.
    I used the textual '<' and '>' characters to decrease/increase brightness with 0 and 31 limits.
    If you're interested I can supply the source.
    edited 2010-11-23 18:33
    Harley wrote: »
    Harley-
    That would be great. I think I need another way of looking at things to help me understand what's going on. I have the PTP board from Rayman. If that's what you've got too, it should be as simple as downloading your code to the platform to see what it does. I can then work through the code to see how you manage it.
    The application I'd like to write is pretty straight forward. Just some menus (text based would be a fine first pass). But getting text boxes (or better yet) small buttons to go where I want and be the color I want AND respond to buttons hasn't worked so far.
    I have to admit that Bill's slider sounds pretty cool- downright iPhone like.
    Peter
    edited 2010-11-24 04:08
    pgbpsu wrote: »
    Sure, Peter.
    The following code is used to read the screen touch location... and if it is within the lower portion of the screen, then I display the text for the slider.
    The user slides their finger across the text and I simply read the position of their finger.
          'get current touch screen location and pressure
          touchx := i2c.gettouchx/16
          touchy := i2c.gettouchy/16
          touchz := i2c.gettouchz1/1000
          'if the pressure is greater than 10, then show slider
          if touchz>10
            gr.text(0, -25, string("<-- Brightness -->"))
            if touchY > 3000 'are they touching the bottom line?
                newBrightness := (touchx/100) 'set brightness to 1/100 scale of touch point
                if (newBrightness =< 0) 'make sure brightness stays within bounds
                  newBrightness := 1
                if (newBrightness => 33)
                  newBrightness := 32
                newBrightness := 33 - newBrightness
                oldBrightness := newBrightness 'store for future use
            ifnot (Brightness == newBrightness) 'if they changed... then change display
                lcd.AdjustBrightness(Brightness)
    This is the code for the "AdjustBrightness" method I added to the "TSD_GraphicsDriver" that Andy Schenk wrote for the 4.3" display.
        repeat brightness
          outa[bl]  := 0
          outa[bl]  := 1
        return true
    That's it!
    Bill
    edited 2010-11-24 06:08
    Bill-
    Thanks for sharing. That looks pretty straight forward. I'm supposed to be packing the van and 3 kids for a trip to grandma's. When I get back I'll test it out.
    Peter
    edited 2010-11-26 16:54
    pgbpsu.
    Sorry about the slowness on this matter. For some reason I am unable to transfer the archived file from Windows to my Mac. Wasted too much time trying to fix the problem, so decided I'd just copy from Prop tool to the Mac to let you access it.
    Hope this is useful. I was hoping to include Basic with the file but never got that far; thus the file name is a bit confusing.
      | Touch-sscreen Basic -TsB by hasdesignn  18 Sep.2010 | rev. 11:17 am 6 Oct.2010
    'PSB Graphics Demo (C) Copyright 2009 Rayslogic.com, LLC
    'Based on the Propeller Graphics and Paint ! demos adapted for the PSB Screen   }}
    CON
      _clkmode = xtal1+pll16x
      _clkfreq = 80_000_000
      QU = 34
    'LCD is 480x272 giving 30x17 tiles; divide by 16 for Parallax font)
      cols = 30
      rows = 17
      screensize = cols * rows      ' = 510 tiles
    'Constants for Graphics Demo
      _stack = ($3000 + 100) >> 2   'accomodate display memory and stack
      x_tiles = 30 '16
      y_tiles = 17 '12
      paramcount = 14
      bitmap_base = $5000           ' was $2000  no double buffer
      display_base = $5000
      lines = 5
      thickness = 2
      GraphicsXOffset=6                     ' NEEDED ???
      GraphicsYOffset=3
    VAR
      long  lcd_status      'status: off/visible/invisible  read-only       (5 contiguous longs)
      long  lcd_enable      'enable: off/on                 write-only
      long  lcd_videobase   'video base @word               write-only
      long  lcd_colorbase   'color base @long               write-only
      long  lcd_backlight   'Used to control LCD backlight
      long  col, row, color, tilex, tiley, colU, rowU
      long  boxcolor,ptr
    'vars for Graphics Demo
      long  mousex, mousey
      long  touchx, touchy
    '  long touchx0,touchdx,touchy0,touchdy   'cal factors
      long  CurrentColor, bLineMode, bStillDown, LastX, LastY
      word  screen[screensize]
    'for custom characters
      word  user_charbase
      byte  colorA, colorB, flagReg, Char, Indexx       ' lagReg: lsb = 'cap'key ON;
      byte  x[lines], y[lines], xs[lines], ys[lines]
    OBJ
      lcd  : "PSB_LcdDriver"  'Modified to drive 4.3" TFT
      i2c  : "PSB_i2cDriver"        ' Rokicki & Dummer's i2c
      gr   : "graphics"             ' Chip Graecey's object
    ' kbd  : "Keyboard"             ' Ps/2 keyboard
    '  mouse : "mouse"
      fsrw : "fsrw" '
    '  sd2 : "SD2.0_FATEngine"  'Kye's SD card engine
    PUB Main
    'Start up Display
    'clear screen
      print($100)                   ' show black on silver
    'start driver
      lcd_enable:=1
      lcd_videobase := @screen
      lcd_colorbase := @vgacolors
      lcd_backlight:= 22  '1=bright, 16=medium, 32=dark
      lcd.start(@lcd_status)
      i2c.initialize                'init touch controller                  ' TSC2003 touch IC
      repeat 20
        i2c.GetTouchX
      GraphicsDemo
    PUB GraphicsDemo|i,j,k,dx,dy, kk, pp, pq, rr, numx, numchr,GraphicsColor   ' modified
      repeat
        print($110)
        print($100)
        printStr(string("KeyBd,Color,Calibrate"))
        WaitStylusDown(true)
        if tiley < 3
          if tilex < 5
            TouchKeyBd
          if (tilex < 11) and (tilex > 5)
            ColorDial
          if (tilex < 21) and (tilex > 11)
            CalibrateTouchScreen
    PUB colorDial | i
      colorB := coloReg1
      colorA := coloReg1 >> 8
      repeat
        print($100)
        print($11F)
        row := 1
        repeat i from 0 to 7
          printStr(string("The Parallax PROPELLER is # 1  "))
        colorLong
        if ina[lcd#TouchIrqPin]==0
          UpdateColor
        WaitStylusUp
        Waitcnt(cnt+clkfreq/2)
    PUB UpdateColor
      if (Tilex < 8) and (tiley > 12)
        if tiley < 15
          if (tilex == 0)
            colorA := ColorA + $10
          if (tilex == 1)
            colorA := ColorA + 1
          if (tilex == 6)
            colorB := ColorB + $10
          if (tilex == 7)
            colorB := ColorB + 1
        else
          if (tilex == 0)
            colorA := ColorA - $10
          if (tilex == 1)
            colorA := ColorA - 1
          if (tilex == 6)
            colorB := ColorB - $10
          if (tilex == 7)
            colorB := ColorB - 1
        coloReg1 := colorA<<24 + colorB<<16 + colorA<<8 + colorB
        coloReg2 := colorA<<24 + colorA<<16 + colorB<<8 + colorB
        colorLong
    PUB colorLong
      print($110)
      col := 0
      row := 13
      hex (coloReg1,8)
      col := 0
      row := 15
      hex (coloReg2,8)
    PUB TouchKeyBd
    {{ (272 lines/16 =) 17 tiles high provides 2 data entry lines w/blue background,4 lines display
      standard ASCII keyboard layout black on silver, w/ spacebar,control keys in white on green
      except for 'cap' key in white on red when locked.  When 'cap' has green baclground keys are
      lower-case, capitaized when red background.  Touch 'sft' prior to each single capital letter;
      touch cap' for multiple capital letters. }}
      flagReg := 1
    '  repeat
        print($111)                 ' heading white/yellow on blue
        print($100)
        col :=0                      '
        row := 0
        colU :=0
        rowU :=0
        printStr(string("       Touchscreen Basic      "))
        printStr(string("           6 Oct.2019         "))
        printStr(string("                              "))
      repeat
        if ((tilex == 0) and (tiley==16))                   ' DEBUG control
          if (flagReg & $80) > 1
            flagReg := flagReg & $7F
          else
            flagReg := flagReg | $80
        if ((tilex >25) and (tiley==16))                    ' backlight control
          if (tilex < 28) and (lcd_backlight < 32)
            lcd_backlight := lcd_backlight + 1
          else
            if (tilex > 27) and (lcd_backlight > 1)
              lcd_backlight := lcd_backlight - 1
        ShowKeys
        DecodeKey
        if flagReg & $80 > 0
          print($114)                 ' white on black for DEBUG data
          col := 18
          row := 0
          PrintStr(string("Index=")) ' show pixel x,y of touch position
          hex(Indexx,2)
    {{      PrintStr(string("touchx=")) ' show pixel x,y of touch position
          dec(touchx)
          col := 18
          row := 2
          PrintStr(string("touchy="))
          dec(touchy)                      }}
          col := 18
          row := 4
          PrintStr(string("tilex="))  ' show Tile number
          dec(tilex)
          col := 18
          row := 6
          PrintStr(string("tiley="))
          dec(tiley)
          col := 18                 ' show flag register value
          row := 8
          PrintStr(string("flagReg="))
          hex(flagReg,2)
          col := 18                 ' show BL value
          row := 10
          PrintStr(string("BL="))
          dec(lcd_backlight)
          col := 18                 ' show 'Char' value
          row := 12
          PrintStr(string("Ch="))
          hex(Char,2)
          print($20)
          print(Char)
        WaitStylusUp
    PUB DecodeKey | Index
      Char := 0
      Index := -50
      if tiley == 7 or tiley == 8                           ' check top line - numbers, punctuation
        if tilex > 1 and tilex < 27
          Index := (tilex - 2)/2
        elseif tilex > 27                                   ' check if on BS
          Char := $1
          ' do BS
      if tiley == 9 or tiley == 10                          ' 2nd line - qwerty..
        if tilex > 2 and tilex < 28
          Index := (tilex - 3)/2 + 13
        elseif tilex < 2                                    ' check if on TAB
          Char := $2
          ' do TAB
      if tiley == 11 or tiley == 12                         ' 3rd line - asdfg..
        if tilex > 3 and tilex < 25
          Index := (tilex - 4)/2 + 26
        elseif tilex > 25                                   ' checkif on RET key
          Char := 3
          ' do RET
        elseif tilex < 3                                      ' check if 'cap' pressed
          if (flagReg & 1) == 1
            flagReg := flagReg & $FE
          else
            flagReg := flagReg | 1
      if tiley == 13 or tiley == 14                         ' 4th line - zxcv..
        if tilex > 3 and tilex < 24
          Index := (tilex - 5)/2 + 37
        elseif tilex < 3 or tilex > 25                      ' check if on Shift key
          Char := 4
          ' do single Shift
          FlagReg := FlagReg | 2                            ' set for single Shift action
          FlagReg := FlagReg & $FE
      if tiley == 15 or tiley == 16                         ' bottom line
        if (tilex > 8 and tilex < 21)                        ' if Spacebar
          Char := $20
          flagReg := flagReg | 4
    {{'      Index := 47  }}
        elseif (tilex > 3 and tilex < 6)                    ' check if 'cntl-c' key
          Char := 5
          ' do Cntl-z
        elseif (tilex > 6 and tilex < 9)                    ' check if 'cntl-z' key
          Char := 6
          ' do Cntl-c
        elseif tilex > 21 and tilex < 25                    ' check if ESC key
          Char := 7
          ' do ESC
      if (flagReg & 3 == 1)'' or (flagReg & 2 == 1)            ' check flags for Shift Lock or single Shift
        Index := Index + 48
      Indexx := Index
      if (Index > 0) and (FlagReg & 4 == 0)
        Char := LookUpZ(Index: "`","1","2","3","4","5","6","7","8","9","0","-","=",{{
        }} "q","w","e","r","t","y","u","i","o","p","[","]","\",  {{
        }}  "a","s","d","f","g","h","j","k","l",":","'",{{
        }}  "z","x","c","v","b","n","m",",",".","/"," ",  {{
        }}  "~","!","@","#","$","%","^","&","*","(",")","_","+", {{
        }}  "Q","W","E","R","T","Y","U","I","O","P","{","}","|",  {{
        }}  "A","S","D","F","G","H","J","K","L",":",QU,{{
        }}  "Z","X","C","V","B","N","M","<",">","?"," ")
      if Char => $20
        col:= colU                  ' restore last position used                    '
        row := rowU
        print(Char)                 ' show last typed character in upper area
        if col == cols              ' move down two tiles for next row
          col++
          row := row + 2
        colU := col                 ' save last position
        rowU := row
        FlagReg := FlagReg & $FD   ' restore single Shift
        print($110)                 ' black letters on silver
    PUB ShowKeys
      if (flagReg & 1 == 1) or (flagReg & 2 == 1)
        col := 0
        row := 7
        PrintStr(string("  ~ ! @ # $ % ^ & * ( ) _ + "))
        print($116)                 ' bs, tb, ret, sft, spacebar are white on green
        PrintStr(string("bs"))
        col := 0
        row := 9
        PrintStr(string("tb"))
        print($110)
        PrintStr(string(" Q W E R T Y U I O P { } |"))
        col := 0
        row := 11
        print($115)                 ' 'cap' is white on red if selected, else on green
        PrintStr(string("cap"))
        print($110)
        print($110)
        PrintStr(string(" A S D F G H J K L : " , QU," "))
        print($116)
        PrintStr(string("ret "))
        col := 0
        row := 13
        PrintStr(string("sft"))
        print($110)
        PrintStr(string("  Z X C V B N M < > ?  "))
      ELSE
        col := 2
        row := 7
        PrintStr(string("` 1 2 3 4 5 6 7 8 9 0 - = "))
        print($116)
        col := 0
        row := 9
        print($110)
        PrintStr(string(" q w e r t y u i o p [ ] \"))
        col := 0
        row := 11
        print($116)
        print($110)
        print($110)
        PrintStr(string(" a s d f g h j k l : ' "))
        print($116)
        col := 0
        row := 13
        print($110)
        PrintStr(string("  z x c v b n m , . /  "))
      print($116)
      PrintStr(string("sft "))
      col := 9
      row := 15
      PrintStr(string("[ spacebar ]"))     ' cntl opt cmd names/legends unused
      print($112)
      col := 0
      row := 15
      PrintStr(string("cntl-z -c"))
      col := 22
      row := 15
      PrintStr(string("esc"))
    '  col := 0
    '  row :=
    '  PrintStr(string(""))
    'PUB DUMMY
    PUB CalibrateTouchScreen|TLX,TLY,TRX,TRY,TBLX,TBLY,TBRX,TBRY  ' touch '+'s to calibrate
      repeat
        print($100)
        row:=6
        col:=4
        PrintStr(string("Calibrate Touch Screen"))
        row:=12
        col:=1
        PrintStr(string("(Tap and release each point)"))
        'Calibrate top-left corner
        WaitStylusUp
        Bitmap1Bit(@CalibrateCursor, 0, 0, 1, 1, 0)
        row:=0
        col:=3
        PrintStr(string(186,144,144,170," Press Here"))
        GetTouchCal
        TLX:=touchx
        TLY:=touchy
        'Calibrate top-right corner
        WaitStylusUp
        print($100)
        Bitmap1Bit(@CalibrateCursor, cols-1, 0, 1, 1, 0)
        row:=0
        col:=10
        PrintStr(string("Press Here ",169,144,144,187))
        GetTouchCal
        TRX:=touchx
        TRY:=touchy
        'Calibrate bottom-left corner
        WaitStylusUp
        print($100)
        Bitmap1Bit(@CalibrateCursor, 0, rows-2, 1, 1, 0)
        row:=rows-2
        col:=3
        GetTouchCal
        TBLX:=touchx
        TBLY:=touchy
        'Calibrate bottom-right corner
        WaitStylusUp
        print($100)
        Bitmap1Bit(@CalibrateCursor, cols-1, rows-2, 1, 1, 0)
        row:=rows-2
        col:=10
        PrintStr(string("Press Here ",169,144,144,187))     ' these are Parallax font characters
        GetTouchCal
        TBRX:=touchx
        TBRY:=touchy
        'Calculate touchscreen cal factors
        'horizontal pixels between touchpoints = 16*(cols-1)
        'vertical pixels between touchpoints=16*(rows-2)
        touchdx:=((TRX+TBRX)-(TLX+TBLX))/(32*(cols-1))
        touchdy:=((TBLY+TBRY)-(TLY+TRY))/(32*(rows-2))
        touchx0:=((TLX+TBLX)/2)-8*touchdx
        touchy0:=((TLY+TRY)/2)-16*touchdy
        'Now show cross in center and see if cal is good
        WaitStylusUp
        print($100)
        Bitmap1Bit(@CalibrateCursor, 15, 8, 1, 1, 0)
        row:=5
        col:=4
        PrintStr(string("Press Here ",5))                   ' '5' = Parallax font 'down arrow'
        GetTouchCal
        WaitStylusUp
    '    waitcnt(cnt+clkfreq/2)
        'Calculate if cal good
        'test x is at 15*16+7=247
        'test y is at 8*16+15=143
        if (||(((touchx-touchx0)/touchdx)-247)<5) and (||(((touchy-touchy0)/touchdy)-143)<5)
          'Good Cal
          if true
    '        WaitStylusUp
            print($100)
            row := 4
            col := 10
            PrintStr(string(" dx="))
            dec(touchdx)
            row := 6
            col := 10
            PrintStr(string(" dy="))
            dec(touchdy)
            row := 9
            col := 10
            PrintStr(string(" x0="))
            dec(touchx0)
            row := 11
            col := 10
            PrintStr(string(" y0="))
            dec(touchy0)
            Waitcnt(cnt+clkfreq)
             'repeat
    '      Return
        else
          print($100)
          row:=5
          col:=4
          PrintStr(string("Calibration Failed."))
          row:=15
          col:=0
          PrintStr(string(" X="))
          dec((touchx-touchx0)/touchdx)
          PrintStr(string(" Y="))
          dec((touchy-touchy0)/touchdy)
    PUB GetTouchCal|tx,ty  'take 5 samples and average
        tx~
        ty~
        repeat 5
          WaitStylusDown(false)
          tx+=touchx
          ty+=touchy
        touchx:=tx/5
        touchy:=ty/5
        WaitStylusUp
    PUB WaitStylusUp
      'Wait for stylus to be up
      repeat
        waitcnt(cnt+clkfreq/100)
        if ina[lcd#TouchIrqPin]<>0
        return
    PUB WaitStylusDown(bCalibrated)|tx,ty,z1,z2,tz
      'Wait for stylus to be down then update touchx, touchy and return
      repeat
        waitcnt(cnt+clkfreq/1000)
          tx:=i2c.GetTouchX
          ty:=i2c.GetTouchY
          z1:=i2c.GetTouchZ1
          z2:=i2c.GetTouchZ2
          'take another x,y reading and average
          tx+=i2c.GetTouchX
          ty+=i2c.GetTouchY
          tx>>=1                    ' divide by 2 using shift right
          ty>>=1
          tz:=tx*(z2-z1)/z1
          if (tz<90000) and (tz>10000) and (ina[lcd#TouchIrqPin]==0 )   'You might have to tweak these values for some LCDs...
            if bCalibrated==true
              'calculate calibrated pixel
              touchx:=(tx-touchx0)/touchdx
              touchy:=(ty-touchy0)/touchdy
            else
              'set uncalibrated data
              touchx:=tx
              touchy:=ty
            tilex := touchx/16      ' HASD - these two added to have 'tile' value too
            tiley := touchy/16
            return
          else
            bStillDown:=false
        else
          bStillDown:=false
    PRI Bitmap1Bit(pBitmap, xPos, yPos, xSize, ySize, clr)|c,i,j,BmpAddress
      row:=yPos
      col:=xPos
      c:=0
      BmpAddress:=pBitmap+user_charbase-@uchar
      repeat j from 0 to (ySize-1) step 2
        repeat i from 0 to (xSize-1)
          screen[row * cols + col] := (clr<<1+1) << 10 + BmpAddress>>6 +c
          screen[(row+1) * cols + col] := (clr<<1) << 10 + BmpAddress>>6 +c
          c++
          col++
        row+=2
        col:=xPos
    PRI Bitmap2Bit(pBitmap, xPos, yPos, xSize, ySize, clr)|c,i,j,BmpAddress
      row:=yPos
      col:=xPos
      c:=0
          screen[row * cols + col] := (clr) << 10 + BmpAddress>>6 +c
          'Print2Bit(c,clr,pBitmap)
          c++
          col++
        row++
        col:=xPos
    PUB box(left,top,width,height) | x, y, i
      ptr := top * cols + left
      boxchr($0)
      repeat i from 1 to width
        boxchr($C)
      boxchr($8)
      repeat i from 1 to height
        ptr := (top + i) * cols + left
        boxchr($A)
        ptr += width
        boxchr($B)
      ptr := (top + height + 1) * cols + left
      boxchr($1)
        boxchr($D)
      boxchr($9)
    PRI boxchr(c): i
      screen[ptr++] := boxcolor << 10 + $200 + c       }}   ' WHAT DOES $200 MEAN ???
    '' Print a character
    ''  $00..$FF = character
    ''      $100 = clear screen
    ''      $108 = backspace
    ''      $10D = new line
    ''$110..$11F = select color
    PRI PrintStr(stringptr)
    '' Print a zero-terminated string
      repeat strsize(stringptr)
        print(byte[stringptr++])
    PUB print(c) | i, k
      case c
        $00..$FF:           'character?
          k := color << 1 + c & 1
          i := k << 10 + $200 + c & $FE
          screen[row * cols + col] := i
          screen[(row + 1) * cols + col] := i | 1
          if ++col == cols
            newline
        $100:               'clear screen?
          wordfill(@screen, $220, screensize)      ' original    ' WHAT DOES $220 MEAN ???
          wordfill(@screen, $220, screensize)      ' hasd
          col := row := 0
        $108:               'backspace?
          if col
            col--
        $10D:               'return?
          newline
        $110..$11F:         'select color?
          color := c & $F
    ' New line
    PRI newline : i
      col := 0
      if (row += 2) == rows
        row -= 2
        'scroll lines
        repeat i from 0 to rows-3
    '      wordmove(@screen[i*cols], @screen[(i+2)*cols], cols)
        'clear new line
    '    wordfill(@screen[(rows-2)*cols], $200, cols<<1)
    PRI dec(value) | i
    '' Print a decimal number
      if value < 0
        -value
        print("-")
      i := 1_000_000_000
      repeat 10
        if value => i
          print(value / i + "0")
          value //= i
          result~~
        elseif result or i == 1
          print("0")
        i /= 10
    PRI hex(value, digits)
    '' Print a hexadecimal number
      value <<= (8 - digits) << 2
      repeat digits
        print(lookupz((value <-= 4) & $F : "0".."9", "A".."F"))
    DAT 'Default Touchscreen Calibrations; HASD using B1 LCD average - 5 readings, B2 - 8
    touchdx long 121     '  Rayman  123     hasd A  127   B1 123   B2  121
    touchdy long 209     '          206             209      208       208
    touchx0 long 3584    '         2713            2072     2906      3605
    touchy0 long 4531    '         4590            4046     4221      4569
    {{      RAM usage       TsB      lcd      i2c     gr     fsrw
            program         3774
            Variable         455
            Stack/free      3957                                        }}
    DAT  'Bitmap data
    padding LONG  7[16] 'alignment padding for the following user defined characters
    uchar long
    CalibrateCursor long
    file "calibrateCursor.dat"  '1 tile
    ColorButton long
    file "button1.dat"  '2x2=4 tiles
    LineButton long
    file "button2.dat"  '2x2=4 tiles
    DotsButton long
    file "button3.dat"  '2x2=4 tiles
    DAT
    vgacolors     long    ' 1st long pair determines fore-/back-ground after 'print($100)'
                            long    $00A800A8       '0 black on silver
                            long    $0000A8A8
                            long    $F00CF00C       '1 blue background with yellow letters
                            long    $F0F00C0C
                            long    $08A808A8       '2 blue on silver
                            long    $0808A8A8
                            long    $50005000       '3 green on black
                            long    $50500000
                            long    $FC00FC00       '4 white on black
                            long    $FCFC0000
                            long    $FF80FF80       '5 white on red
                            long    $FFFF8080
                            long    $FF20FF20       '6 white on green
                            long    $FFFF2020
                            long    $FF28FF28       '7 white on cyan
                            long    $FFFF2828
                            long    $70447044       '8 yellow on purple
                            long    $70704444
                            long    $E084E084       '9 orange on raspberry
                            long    $E0E08484
                            long    $60346034       '10 cranberry o pale yellow
                            long    $60603434
                            long    $F020F020       '11 yellow-orange on green
                            long    $F0F02020
                            long    $AC14AC14       '12 grey-blue on gray
                            long    $ACAC1414
                            long    $50E050E0       '13 green on orange
                            long    $5050E0E0
                            long    $6CB06CB0       '14 lt. blue on yellow
                            long    $6C6CB0B0
    coloReg1                long    $70007000       '15 for 'Color Dial' use;
    coloReg2                long    $70700000       '    initially yellow on black
    {{  Propeller I/O pin usage
       Prop I/O  Signal     Use     I/O  Signal     Use
            A00  DO  (    SD card)  A31* TX      (PropPlug)
            A01  CLK       "  SPI   A30* RX         "
            A02  DI        "        A29* SDA   (i2c EEPROM)
            A03  CS        "        A28* SCL    (and Touch)
            A04  BL/DON      (LCD)  A27*     (PS/2 kEYBOARD)
            A05  DE            "    A26*            "
            A06  PCLK          "    A25*       (PS/2 MOUSE)
            A07  IRQ           "    A24*               "
            A08       not used      A23  R1          (LCD)
            A09            "        A22  R0            "
            A10            "        A21  G1            "
            A11            "        A20  G0            "
            A12  1.1K         (TV)  A19  B1            "
            A13  560           "    A18  B0            "
            A14  270           "    A17  HSync         "
            A15  560 (audio)   "    A16  VSync         "
      * = Hard-wired on Parallax Prop ProtoBoard
    edited 2010-11-26 20:25
    pgbpsu,
    I tried to send the archived files from Windows website but for some reason I'm not allowed in. Yet, after dinner I tried again on the Mac and I was logged in, yet before dinner I couldn't get in.
    I was hoping I could get in but can't. Will try later on. May be Sat before that happens. Sorry
    edited 2010-11-27 07:06
    Harley-
    Thanks for all your effort. I'm out of town for the Thanksgiving holiday, but look forward to getting home and trying this.
    I really appreciate this.
    Peter
    edited 2010-11-27 09:03
    Harley,
    I've got your code running... however, I don't have the four dat files for the new characters you loaded.
    It actually revealed a problem with one of the touch screens I have and didn't even realize... I have a dead spot in it!
    Very nice work!
    Bill
    edited 2010-11-27 11:53
    wjsteele,
    Yes, Somewhere along while I was working on my code I noticed those files were gone. I think maybe they were the '+' symbols for the Calibration points. I tried until I got pretty good at guessing where the graphic which did show up should be. Thus was able to get cal data for my screens. Worked great for the 3.5" screen, but don't recall it was for the 4.3".
    I learned a lot with these touchscreens. Pretty neat not needing a keyboard or mouse, LCD has variable brightness backlighting, and found both the 3.5 and 4.3" LCDs to be adequate for many applications.
    I must of had the 4.3" LCDs for nearly a year, but when I got the 3.5" one after them I got onto a design displaying heart beat waveform. Still haven't gotten to the 'front end' sensor and amplifier part yet. Rayman's PTP board for the 3.5" was a great beginning to work with. Hardly had to any parts except for the sigma-delta A/D and my D/A (to simulate a heart pulse for developing the firmware). Battery operated makes for a handy system to use anywhere. I'm amazed how long the AAA's last for the PTP board and 3.5" LCD. That was what sold me on getting a 3.5" one when I'd not even run the 4.3" ones.
    My 4.3" is mounted on a Prop Protoboard along with a SD card board. Unfortunately I have another project to finish first before getting back to playing with these LCDs.
    edited 2010-12-09 18:36
    Harley and Bill-
    I finally found a few minutes after returning from the turkey holiday to test out what you posted.
    I wasn't paying close enough attention to this thread (which is for the 4.3" touch screens). Turns out the one I have is the 3.5" so it didn't work as expected. I only had a few minutes when I tried this. I'll need to sit down with the code (and this thread) to see if there's a way to convert it to work on my board. I get something on the screen, but what ever it is is clearly munched. No doubt it has to do with the different screen size/number of tiles on these two different screens.
    Nevertheless, this seems as good a place as any to cut my teeth on graphics. I've not worked with display (other than serial debug messages) features of the prop.
    Thanks again for the code, examples, and suggestions.
    Peter
  • HShankoHShanko Posts: 402
    edited 2010-12-10 09:58
    pgbpsu,
    If all you need is to change brightness, I also have a 3.5" LCD source which uses the same scheme. I use two tiles for 'buttons' with '<' and '>' characters for button legend for brightness 'down and 'up'. If you are interested I could get that source to you. Let me know if this would interest you. The purpose was to plot (heart) pulse data and I needed a few 'buttons' to control things. So without an A/D and the front end it would plot just a straight line most likely. I used a D/A to simulate a pulse during debug of the button and plot code.
