Wall-E Robot - Page 3 — Parallax Forums
Wall-E Robot
13
  • StampNut2StampNut2 Posts: 224
    edited 2008-03-16 03:02
    Here is a short video of Wall-E's eyes when the lights go out or when he approaches a dark area. he also has ping in both eyes, these had to be modified to fit one in each eye.
    www.youtube.com/watch?v=GM0EwTtUZQQ
    Never give up when things go wrong, Just work them out.
    robosapienv2-4mem8.page.tl/
    Post Edited (StampNut2) : 3/16/2008 3:08:22 AM GMT
  • UghaUgha Posts: 543
    edited 2008-03-16 04:11
    Hey StampNut2... I got a quick question about Wall-E's Ping eyes.
    Did remounting the Ping transmitter and receiver further apart affect the readings you got?
    If so in what way?
    edited 2008-03-16 04:21
    Ugha That side of it I have not yet had the chance to test maybe next week when I will have more time to experiment with this. Hopefully it shouldn't have to much effect.
  • WhitWhit Posts: 4,194
    edited 2008-03-16 12:45
    Hey All,
    The Radio Shack experiment worked! Four days after walking in the local Radio Shack and placing the order, a pair (one left and one right) of Mattracks arrived at my front door. The total price was $30.67 and might not go up much or at all for multiple pairs - the box was really big and could hold at least four pair with packing protection.
    Catalog numbers are as listed above (the order did not include the matching tires for the Hummer).
    Order away! StampNut2 - want me to check on some for you (though I may have to wait till after Easter) ?
    Whit+
    edited 2008-03-17 05:29
    Whit: Yes please if you wold not mind. I can pay you by PayPal. Thanks.
    edited 2008-03-17 14:16
    I would kill for a set.
    But I'd have to wait two months before I can afford them... living on a farm sucks.
    You should consider buying up a bunch and selling them to forum members for a small
    markup.
  • jbodjbod Posts: 46
    edited 2008-03-17 15:08
    Mine are on the way ... now to figure out a nice easy way to mount ... Don't have a mill and not planning to run over rough ground .. just indoor ... so not to concerned mounting them with shocks/pivot.
    edited 2008-03-18 08:18
    Ugha I have checked my ping Which is 60mm apart in Wall-E's head against the normal 25mm ping setup, And there is absolutely no difference in distance measurements from ping to object measuring with a tape and comparing with debug terminal. Hope this helps out.
    edited 2008-03-19 01:39
    Great news on the Ping)))!
    Whit+
    edited 2008-03-19 08:27
    Yeah, I was pleased that it worked without any hiccups, Now to make that H bridge for Wall-E,Next step in the process.
    edited 2008-03-21 03:43
    OK, I am now starting to build my H bridge for Wall-E, I will have to substitute the Tip: 120 and 125 for the ones that I have Tip: 121 and 126 Darlington. They are similar specs.
    Post Edited (StampNut2) : 3/21/2008 3:48:41 AM GMT
    519 x 355 - 27K
    600 x 450 - 31K
    edited 2008-03-22 20:51
    Ok, Have now bread boarded my H bridge system for Wall-E, Had a problem to start with, it did not work. I got out the logic probe and started checking and found that I had two 2N2222 transistors faulty. Replaced and works fine. However I have a problem in that the Tip 121 and 126 which I substituted for the ones shown in the schematic 120 and 125 seem to have a continuious voltage across the collectors even when the A+B and A+B [noparse][[/noparse]this is for two H bridges] are NOT tied to VDD. I would have thought that when either A+A or B+B or B+A or A+B were floating there would be no voltage across the collectors only when tied to VDD, Or am I reading this wrong.
    600 x 450 - 72K
    600 x 450 - 78K
    600 x 450 - 76K
    edited 2008-03-29 19:33
    Ok, I have found the problem and this system runs an active high to operate all functions NOT active low like the stamp puts out. So ithe program will be changed by GWjax so that it runs an active high output. Will test today. if all ok I will build the circuit.
    edited 2008-04-01 17:48
    We may be inserting 4n32/33 darlington opto couplers on the input lines to the H-bridge to stop any interference by back emf, although the diodes across the motors should stop this.
    edited 2008-04-01 18:02
    Thanks for the update StampNut2. The movie is coming soon!
    Whit+
  • David H.David H. Posts: 78
    edited 2008-05-20 18:41
    StampNut2, Whit, or ??
    Do you know the best way for connecting the Mattracks to the Boe-Bot? Do they have some connections our there to combine these, or is it the "makeyourown" brand? I looked on other posts, and have an idea how to connect them, but haven't seen a good picture of the missing link. I have the tracks and just starting to get time to combine them. Any words of wisdom?
    David
    There are 10 types of people in this world,...
    Those that understand binary numbers, and those that don't!!!
    edited 2008-05-21 03:12
    If you follow some of the links on the earlier posts in this thread, I think you will see several options. It is a make your own kinda deal, unless you contact TOm and by his attachment.
    See my post to Jbod on page three.
    This is TOm connector from the servo to the Mattracks - the rest is a question of fixed or movable mounting.
    [url=:void(null)]027f_12.JPG[/url]
    Whit+
    Post Edited (Whit) : 5/21/2008 3:19:09 AM GMT
  • iDaveiDave Posts: 252
    edited 2008-05-21 03:48
    I used erector parts to mount the mattracks. Here is some pics. Nothing custom or machine made..except for $15 worth of erector parts off ebay. I've ran old huey around for 2 months now and only had to re-tighten one nut. Here some pics:
    "THE ONLY TRUE WISDOM IS IN KNOWING YOU KNOW NOTHING." - SOCRATES
    480 x 640 - 86K
    480 x 640 - 86K
    480 x 640 - 79K
    480 x 640 - 77K
    edited 2008-05-21 13:29
    Thanks!
    I'll have to dive back into this and get these hooked up.
    StampNut2: Looking at the pictures of your fine work, it's almost like you're the one would designed the movie version of Wall-E. I've seen a couple pictures, and a movie trailer. Your version seems right on the money. Keep up the excellent work.
    David
    edited 2008-05-23 11:47
    David H: Many thanks for your comments, very much appreciated. Here are a few more up to date pics.
    Post Edited (StampNut2) : 5/23/2008 11:55:02 AM GMT
    446 x 334 - 38K
    446 x 334 - 44K
    446 x 334 - 40K
    446 x 334 - 44K
    446 x 334 - 48K
    edited 2008-05-23 11:59
    Also a few more here.
    Post Edited (StampNut2) : 5/23/2008 12:05:11 PM GMT
    446 x 334 - 47K
    446 x 334 - 45K
    446 x 334 - 42K
    446 x 334 - 45K
    edited 2008-05-24 09:26
    Here are a few Wall-E pics of his eyes lit up.
    Post Edited (StampNut2) : 5/24/2008 9:31:36 AM GMT
    446 x 334 - 47K
    446 x 334 - 43K
    446 x 334 - 44K
    edited 2008-05-24 15:16
    The lighted eyes really make it come alive.
    Whit+
    edited 2008-05-24 17:44
    Hey Whit+, Yeah I agree, starting to take on a character now.
    edited 2008-05-27 13:13
    StampNut2:
    Thanks for the updated pics. I think it's turning out great. Very impressive work.
    David
    edited 2008-05-27 18:26
    David H. Thanks for your comments, It's a huge project and getting closer to completion,will keep you guys informed of progress.
    edited 2008-06-07 03:57
    Hey guys i have just received this via email, Great news for Wall-E and a surprise for us 4mem8 and GWJax
    www.engadget.com/2008/06/06/diy-wall-e-bot-sweeps-our-heart-up-into-his-cute-little-storage/
    edited 2008-06-07 05:28
    Congrats StampNut2.·· I actually caught wind of this on 2 of my rss feeds(Make: & engadget). I just knew it had to be you even before I clicked on the link! And there she was.· Very thurow and complete documentation. Your energy has no bounds. Now all anyone needs is your years of experience.
    Dave
    edited 2008-06-07 07:43
    iDave: Hey, Thanks for your comments, There are only 50 pics of 350 that I have documented, When Wall-E is finished it will be an article on Robocommunity where I first started this project, I am committed to robocommunity to do the article there first. it will be a complete how to.
    www.robocommunity.com
    Post Edited (StampNut2) : 6/7/2008 7:50:25 AM GMT
    edited 2008-06-08 07:03
    Here is the latest update to Wall-E's motor driver. using the l298 driver.
    446 x 334 - 36K
    446 x 334 - 41K
    446 x 334 - 39K
    446 x 334 - 38K
    446 x 334 - 36K
