Screen hackability? Yup.. - Page 3 — Parallax Forums
13
  • rjo_rjo_ Posts: 1,825
    edited 2008-02-07 03:38
    Absolutely sweet... now, let's consider those motors[noparse]:)[/noparse]
    Rich
    edited 2008-02-07 14:02
    Baggers said...
    Great hack OBC, I liked the demo you were using on the website lol [noparse]:D[/noparse] nice 1.
    Hey Baggers,
    The pic made hackday... [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook
    Got an SD card? - PropDOS
    A Living Propeller FAQ - The Propeller Wiki
    (Got the Knowledge? Got a Moment? Add something today!)
    edited 2008-02-07 14:28
    Well I forgot and left mine on the other night. With the DVD chip removed and the Propeller Proto Board running off a seperate supply the screen ran for about 12 hours. I didn't totaly discharge the battery so it can probably go a bit longer than that.
  • JT CookJT Cook Posts: 487
    edited 2008-02-07 15:02
    That is pretty awesome, I may have to pick on up! I do have a question though, would it be feasable to remove the top half/the screen, give it external power and video source and still get a picture?
    edited 2008-02-07 15:15
    By hooking to the data pin found on the back of the LCD board, I strongly suspect the only requirements left are power and ground. I'm heading this direction..
    (Why can't we have 36 hour days? More time for Propeller stuff...[noparse]:)[/noparse]
    OBC
  • RaymanRayman Posts: 15,955
    edited 2008-02-07 15:31
    My two units just arrived! I'm thinking about using the earphone jack as either video or keypad input... Definitely want to rip out the DVD reader (although it seems a shame...) and insert Prop. Maybe there's room to put the battery charger circuit in there too...
    Think we can connect the buttons to the Prop?
  • BaggersBaggers Posts: 3,019
    edited 2008-02-07 15:53
    rofl, it's getting about isn't it lol.
    Oldbitcollector said...
    Baggers said...
    Hey Baggers,
    OBC
  • HarleyHarley Posts: 997
    edited 2008-02-07 23:01
    OBC,
    Was looking at your 'dreaming_maybenot' picture and realized how small the unit is. The keypad measures about 3.8" Yeah, pretty small monitor screen for my ol' eyes.
    And what is 'hackday'? I googled but it took me to some strange place. Maybe the URL is more complex that what I imagine.
    Harley Shanko
  • Paul_HPaul_H Posts: 85
    edited 2008-02-07 23:04
    OBC,
    Nice plug for your hack on www.hackaday.com !
    BTW - I ordered mine yesterday. I'm planning to put it on my UAV as a local monitor before takeoff, though I'll need to see how far it can be stripped down for weight.
    Paul
    www.pnav.net
    edited 2008-02-08 00:05
    Little off topic,
    There is a very tiny 3v motor that moves the optics. Decent power too.
    It's the one connected to the red/white leds. (so cut them near the board)
    These might be interesting for bots later.. [noparse]:)[/noparse]
    OBC
    edited 2008-02-08 00:58
    Stage two:
    Turning it into a real microcomputer... [noparse]:)[/noparse]
    (I've got a little sanding to do yet... )
    Anyone see any problems with running the prop at 3.6v_dc 2.5a?
    OBC
    408 x 308 - 35K
    408 x 308 - 37K
    edited 2008-02-08 01:12
    That is a very interesting idea (chopping up the proto board)! Does the existing board really run at 3.6 V? I assumed there was a voltage regulator to 3.3V in there somewhere...
  • bambinobambino Posts: 789
    edited 2008-02-08 01:28
    Look at the pic of the hirose connector. There is a 3.3 and a 5V line. No idea what there running or how much juice can be pulled off of them.
    edited 2008-02-08 01:36
    The idea of using a spin stamp is starting to worry me. Would 3.6 be enough to keep its regulator happy, and for how long?
    edited 2008-02-08 01:37
    5v.. Where are they getting 5v from? Might be enough to support a PS2 keyboard jack somewhere.
    OBC
    edited 2008-02-08 01:54
    Found it also at capacitor BC11 just behind the DVD Data connector. Between it and the battery connector.
    If it's running the Backlight or the top side amp it could be risky hooking up to it.
    edited 2008-02-08 02:29
    OldBit, Datasheet says 3.6 OK. Absolute maximum of 4.0V.
    So what do you think about the regulator on the spin stamp, would 3.6 volts be enough to run it.
    I guess a better question would be does anybody know where I could find the datasheet for the reg on the spinstamp?
  • Jimmy W.Jimmy W. Posts: 112
    edited 2008-02-08 09:22
    @bambino the best 3.3v LDO regulator I know of still needs 4 volts, he is talking about running the prop straight off the 3.6v, which SHOULD be happy, waiting on my pcb to come in the mail
    Will have video, audio, SD, and interface the buttons, pics to follow
    Jimmy
    EDIT:
    Also seriously considering adding an av input somewhere with a voltage detector to switch input over, would be quite handy at times.
    Sigh, looks like I will have to order another PCB, only thing I didn't think of that I really want.
    Post Edited (Jimmy W.) : 2/8/2008 9:29:18 AM GMT
    edited 2008-02-08 10:51
    Thanks Jimmy, I guess I'll be dicing my proto board up too!
  • schillschill Posts: 741
    edited 2008-02-10 19:34
    Has anyone opened the half of the case containing the screen and taken pictures? How thick is that part of the case, anyway? I'm wondering how much room there is in there for something like a bluetooth or xbee board.
    I've got a couple on order that should arive in the next few days. I'd like to use the keys built into the screen half and maybe put some other electronics up there (inspired by a lot of the EEE PC hacks, I guess).
    edited 2008-02-10 19:46
    There isn't much room for additional parts. If you sacrificed one of the speakers, maybe, but it's a pretty thin (width wise) area.
    I've got hopes of getting buttons working myself. I think it should be doable from the connection on the bottom board.
    OBC
    edited 2008-02-10 19:51
    OBC, I updated that hirose connector shot. It now has the button lines and the spi lines marked!
    I don't now if my hands can stay steady long enough, but I also found the button lines on the pads where the chip was removed.
    The Wire wrap guage I have laying around is perfect for the pitch of those pads, but time will tell!
    edited 2008-02-11 00:47
    One Sunday, flux, soldier, magnifying glass, wire wrap, and a pack of cigarettes!
    $#!+ my nerves are shot!
    512 x 384 - 92K
    512 x 384 - 80K
    edited 2008-02-11 00:57
    bambino said...
    WOW!
    After a couple more cartons, would you mind posting a pinout for that? There's no way to see it any other way.
    OBC
    edited 2008-02-11 01:19
    That is possible, But let me get some more Pepsi&Pizza in me. Ran into one problem too that I'm going to need you to verify on your board. I found two pads that map out to the TV signal, most likely nothing, but possibly I've shorted something!
    Anyway, I'll have more later tonight!
  • RinksCustomsRinksCustoms Posts: 531
    edited 2008-02-11 01:21
    Did i hear notariaty of a Y/C signal? S-Video? sweet! do keep us posted!hop.gif
    E3 = Thought
    http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
    edited 2008-02-11 01:30
    I'm wondering if it might be easier to gently scrape the vias and solder to those points to prevent side-by-side shorting.
    Glad I own a magnification light on my workbench. [noparse]:)[/noparse]
    OBC
    edited 2008-02-11 01:51
    OK, I'm back, but I have a problem. I didn't take a picture of the pads before I soldiered and Like you said It's hard to see thru the nail hardener. Can anyone post a pic of the pads and I'll try and label them!
    edited 2008-02-11 02:06
    Due to the lack of a picture and the fact that I can't remember exactly where they all where here is a shot of the pin connector on the bottom.
    I used it with a continuity checker to locate the pad and then soldier!
    As far a cross shorting goes, Im hopeing the nail hardener will provide some insulation.
    Then thing I wanted you to verify is the signal pad, which I think you can see clear enough. I get continuity with the signal pin marked on the bottom30Pin shot as well as the pin to its left. If you can check this out on yours it would be a big help. Right now I'm afraid to power up and check anything!
    I did have a short, got lucky, it still runs! I had to take off every wire to find it though. I think I'll just use the wires from the connector next time.
    Post Edited (bambino) : 2/11/2008 6:27:04 PM GMT
    1024 x 768 - 101K
    512 x 384 - 103K
    edited 2008-02-11 02:14
    @RC
    Yes there is a y/c input and the directions for it is in the datasheet Mike got us. Haven't tried it and since I've allready got this one geared towards NTSC I doubt I can help you more!
    I do know that the pin we are sending the signal on becomes the luminence input!
