Console Emulation - Page 76 — Parallax Forums
Console Emulation
1707172737476»
  • You're welcome!
    Just tested your "poc driver" on the "no signal" monitor used before.
    It works ... I also hear the sound.
  • Wuerfel_21Wuerfel_21 Posts: 5,844
    edited 2025-10-17 14:03
    @MXX said:
    You're welcome!
    Bravo! We got it! Treat yourself to one of those sugary italian cookies!
    Okay, I'll work on a modified NeoVGA driver that sends only 8 preamble clocks. I re-read the HDMI spec and CTS and it appears that elongating the preamble is not actually allowed (I don't remember where I got that one from?), so I'm trying that first.
    Should be ready later today.
    EDIT: ostensibly made it, but it's now more broken here, so I think I made a mistake, need to debug that first
  • okay @MXX can you try NeoYume with this patched driver (more spec-compliant preamble timing)
    Great, this works like a charm!
    Will try on a few more monitors I have around and let you know
  • Awesome awesome awsome
  • I also put the new driver version on NeoYume's git repos. Ought to try porting this to the other driver variants if we can confirm it's good.
    (Incidentally, for any testing, it's best (but certainly more annoying) to test all 3 drivers; old, new and the PoC thing from earlier - that way you can differentiate "it always worked" from "I just fixed it")
    edited 2025-10-18 23:20
    Other oddity: Apparently an old fix I did for Sonic 1 on MegaYume was left to rot on the dev branch. I noticed this because I just went to port the preamble fix and wanted to put it on dev first because I can't test it right now. Will have to re-test that one now, too. (both are on dev now)
    EDIT: Preliminary HDMI preamble fix on dev branch for MisoYume and P1CC, too. On plain video-nextgen branch for Tempest 2000. Still need to re-test all those myself, but they're open for trying as well. If you're confused on wether you're on a branch with the fix, the hsync_preamble symbol got added with the fix, so if you don't have it you're on the old/stable version.
    edited 2025-10-24 18:49
    Update: Despite best efforts by The MatrixTM or other higher powers to stop me by way of multiple cancelled trains and traffic jams, I have managed to travel back up to where the problem TV was and test my fix (of course I came just for that purpose, you know my dedication to the mission)
    It works now. Yay. 🎊
    (I also tested MegaYume, MisoYume, P1CC and Tempest 2000 with the fix applied, all works)
    So that settles the score, it was the preamble length thing.
    So, updated list of not-quite-obvious things that need to be done for universal HDMI compatibility:
    • Drive mode should be P_LOW_FAST|P_HIGH_1K5|P_SYNC_IO (Not sure about bitDAC, I abandoned that because I can't use REPO mode with that, but idk if that works at all with SYNC_IO)
    • Preambles need to be exactly 8 characters/cycles/pixels
    • There always needs to be at least one data packet sent regularly (otherwise you may see a pink bar on the left edge - video guard band becomes visible because sink switches into DVI mode)
    • Audio data needs a valid SPDIF channel status. The word length must be set to a non-zero value (I use 24 bit -> check the spec)
    • Audio clock packets need to be sent at particular intervals (check spec, the details elude me, but if done right this can be a simple "send one every N samples")
    • Audio data has a maximum amount of allowable jitter. Consecutive packets should never have differing sample population count by more than +/- 1. (so 1-1-2-1-1 is ok, 1-2-2-0-1 is bad)
  • evanhevanh Posts: 17,197
    edited 2025-10-24 19:36
    Cool, and quite the list.
    PS: I'm pretty sure the fast DAC is wired registered always. The function block has a clock input:
  • RaymanRayman Posts: 16,345
    @Wuerfel_21 Do you have something that could be turned into an HDMI .wav file player?
    good to know
    Not beyond the plain driver. If you have a regular program that does DAC audio, adding the digital audio mailbox thing is easy. Every time you write to the DAC pins, you also write a left/right packed sample into the HDMI basepin. The driver also needs to know the sampling period at startup. If you do that, it'll do the rest.
    Consider the following snipped grabbed from NeoYume's sound code
                  mov       opn_arg1,opn_dac_center
                  mov       opn_arg2,opn_dac_center
                  add       opn_arg1,opn_filter_left
                  add       opn_arg2,opn_filter_right
                  ' wait for DAC cycle
                  testp    #AUDIO_LEFT wc
      if_nc       jmp #$-1
                  wypin      opn_arg1,#AUDIO_LEFT
                  wypin      opn_arg2,#AUDIO_RIGHT
                  setword    opn_arg1,opn_filter_left,#0
                  setword    opn_arg1,opn_filter_right,#1
      if DIGITAL_BASEPIN >=0
            _ret_ wxpin      opn_arg1,#DIGITAL_BASEPIN
      else
                  ret
      end
    The audio sample starts out in opn_filter_left/opn_filter_right and this writes it to both the DAC pins (unsigned $0000..$FF00 each) and the HDMI mailbox (upper/lower packed signed words).
    Glad you found your fix and created the list above of important things to be considered. I still haven't tested any of your recent changes but if/once I do retry it on the Pioneer I'll be sure to let you know if there's any regression there for me (I'm basically assuming not for now).
    I think the Preamble was always specified as 8 pixels in the HDMI docs and after double checking the code I've already ensured sure my driver variant used that too.
    x1                          xcont   m_imm8, video_preamble  'send preamble before active video
    x2                          xcont   m_imm2, video_guard     'send video guard before active video
    m_imm8                      long    X_IMM_1X32_4DAC8 | X_PINS_ON | 8
    m_imm2                      long    X_IMM_1X32_4DAC8 | X_PINS_ON | 2
  • I've just bumped new versions of all the emulators that formally incorporate the HDMI preamble fix.
    This is MegaYume V1.5, NeoYume V1.5 and MisoYume beta12.
    Other included changes:
    • MegaYume: Fix Sonic 1 "SEGA" PCM sound distortion by applying extra slowdown to NOP+DBF loops (this change got lost on a dev branch a while ago)
    • NeoYume: updated SDSD driver
    edited 2026-04-22 22:01
    @Wuerfel_21 if there were two PSRAM interfaces….
    Could the second be used as a frame buffer instead of going to output device?
    Wondering if that would let these run on a ftdi eve based display….
    Might be a frame of lag though…
    You can do anything in the video driver as long as it maintains roughly appropriate timing.
    Replacing the video driver is actually not that hard. The one I wrtote is just complicated because it needs to be nice. But a quick and dirty job would work as well. Essentially it has 2 jobs: Scanning out pixels from the line buffer (for the emulators this is always in RGB32 format! Tempest is also RGB32, but classics collection is LUT8) and incrementing the line counter and frame counter variables with appropriate timing (~15.75kHz frequency. The sequence of numbers is also significant, this is slightly complex to explain, but just check how the actual driver does it
    Always when buffering a whole frame.
    Also I'm reminded I still didn't get to writing the driver for the latched LCD boards.
    Ok, maybe can just send directly to EVE to display then. That'd be nice...
