64 MB PSRAM module using 16 pins? --> 96 MB w/16 pins or 24 MB w/8 pins - Page 14 — Parallax Forums
11214161718
  • Any 1 bit PSRAM mode is going to be really slow as the address needs to be single bit serially clocked as well as the data. We're already talking 80 P2 clocks for transferring a single byte, and 16 P2 clocks for each additional byte after that. Not sure what it gains apart from a 4 pin minimum count vs 6 pins, which provides ~4x the performance with those 2 extra pins. A really pin constrained environment might find some use I guess. Not for emulators or much video (though 4bpp VGA resolution could possibly use it). Maybe you could share some of its pins with SPI SD or other flash devices...
  • @rogloh said:
    Hey @Wuerfel_21 I'm interested to know did you ever try out the sysclk/3 read rate idea in your code?
    No, never got around to that.
  • Got the delay test working with sysclk/2 writes and sysclk/3 reads with Rayman's 24MB board in 4 bit mode. The acceptable delay range widens with this change which is good.
    Will try the 96MB board next.
    PSRAM 4 bit memory read delay test over frequency, ESC exits
    Enter the base pin number for your PSRAM (0,4,8...52) [40]: 48
    Enter the chip enable pin number for your PSRAM [57]: 53
    Enter the clock pin number for your PSRAM [56]: 52
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 54
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 55
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 56
    Enter a starting frequency to test in MHz (100-350) : [100] 300
    Enter the ending frequency to test in MHz (300-350) : [300] 350
    Enter 1 to use the automatic delay value only, or 0 to test over the delay range : [0] 0
    Enter 1 to display the first error encountered, or 0 to not display error details : [0] 0
    Testing P2 from 300000000 - 350000000 Hz
                            Successful data reads from 100 block transfers of 8192 random bytes
    Frequency      Delay    3       4       5       6       7       8       9       10      11      12      13      14
    300000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    301000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    302000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    303000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    304000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    305000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    306000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    307000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    308000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    309000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    310000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    311000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    312000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    313000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    314000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    315000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    316000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    317000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    318000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    319000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    320000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    321000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%      0%
    322000000        (11)   0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    99%     0%
    323000000        (11)   0%      0%      0%      0%      0%      99%     100%    100%    100%    100%    100%    0%
    324000000        (11)   0%      0%      0%      0%      0%      74%     100%    100%    100%    100%    100%    0%
    325000000        (11)   0%      0%      0%      0%      0%      16%     100%    100%    100%    100%    100%    0%
    326000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    327000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    328000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    329000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    330000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    331000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    332000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    333000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    334000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    335000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    336000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    337000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    338000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    339000000        (11)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    340000000        (12)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    341000000        (12)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    342000000        (12)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    343000000        (12)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    344000000        (12)   0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    100%    0%
    345000000        (12)   0%      0%      0%      0%      0%      0%      97%     100%    100%    100%    100%    0%
    346000000        (12)   0%      0%      0%      0%      0%      0%      93%     100%    100%    100%    100%    0%
    347000000        (12)   0%      0%      0%      0%      0%      0%      59%     100%    100%    100%    100%    0%
    348000000        (12)   0%      0%      0%      0%      0%      0%      1%      100%    100%    100%    100%    0%
    349000000        (12)   0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    0%
    350000000        (12)   0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    0%
  • roglohrogloh Posts: 5,910
    edited 2022-07-17 07:15
    Here's one of the previously worst performing devices on the 96MB board running with sysclk/3 reads (in 4 bit mode -still need to test with 8 bits using both devices). Run up to 350MHz.
    Enter the base pin number for your PSRAM (0,4,8...52) [32]: 32
    Enter the chip enable pin number for your PSRAM [42]: 45
    Enter the clock pin number for your PSRAM [40]: 40
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 42
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 43
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 44
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 46
    Enter an additional CE/CLK P2 pin to drive high (0-55), or a higher value to exit [56]: 47
    Enter a starting frequency to test in MHz (100-350) : [300] 320
    Enter the ending frequency to test in MHz (320-350) : [350] 350
    Testing P2 from 320000000 - 350000000 Hz
    320000000        (11)   0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    0%
    321000000        (11)   0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    0%
    322000000        (11)   0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    100%    0%
    323000000        (11)   0%      0%      0%      0%      0%      0%      0%      96%     100%    100%    100%    0%
    324000000        (11)   0%      0%      0%      0%      0%      0%      0%      78%     100%    100%    100%    0%
    325000000        (11)   0%      0%      0%      0%      0%      0%      0%      41%     100%    100%    100%    0%
    326000000        (11)   0%      0%      0%      0%      0%      0%      0%      1%      100%    100%    100%    0%
    327000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    328000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    329000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    330000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    331000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    332000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    333000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    334000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    335000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    336000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    337000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    338000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      95%     100%    100%    0%
    339000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      84%     100%    100%    0%
    340000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      60%     100%    100%    0%
    341000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      7%      100%    100%    0%
    342000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    343000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    344000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    345000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    346000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    347000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    348000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      99%     100%    0%
    349000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      34%     100%    0%
    350000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    0%
    And here's its pair that makes up the 8 bits:
    Enter the base pin number for your PSRAM (0,4,8...52) [40]: 36
    Enter the chip enable pin number for your PSRAM [57]: 45
    Enter the clock pin number for your PSRAM [56]: 41
    Enter a starting frequency to test in MHz (100-350) : [100] 320
    Enter the ending frequency to test in MHz (320-350) : [320] 350
    320000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    321000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    322000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    323000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    324000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    325000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    326000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    100%    0%
    329000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      99%     100%    100%    0%
    330000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      99%     100%    100%    0%
    331000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      76%     100%    100%    0%
    332000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      21%     100%    100%    0%
    333000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    334000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    335000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    336000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    337000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    338000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    339000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    340000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    341000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    348000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    349000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    350000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      100%    100%    0%
    This is what it got before at sysclk/2 read rate (in a combined 8 bit mode, so not a perfect comparison, but still)
    320000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      11%     81%     100%    0%
    321000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      9%      80%     100%    0%
    322000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      7%      78%     100%    0%
    323000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      6%      75%     100%    0%
    324000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      2%      74%     100%    0%
    325000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      2%      65%     100%    0%
    326000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      65%     100%    0%
    327000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      55%     99%     0%
    328000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      45%     99%     0%
    329000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      53%     99%     0%
    330000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      45%     97%     0%
    331000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      40%     97%     0%
    332000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      45%     97%     0%
    333000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      1%      41%     96%     0%
    334000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      44%     90%     0%
    335000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      45%     94%     0%
    336000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      38%     87%     0%
    337000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      2%      38%     85%     1%
    338000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      35%     78%     0%
    339000000        (11)   0%      0%      0%      0%      0%      0%      0%      0%      0%      37%     76%     0%
    340000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      28%     78%     1%
    341000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      30%     72%     0%
    342000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      1%      39%     68%     0%
    343000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      37%     68%     2%
    344000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      31%     55%     1%
    345000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      33%     58%     4%
    346000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      34%     60%     3%
    347000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      21%     62%     5%
    348000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      8%      50%     9%
    349000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      9%      48%     19%
    350000000        (12)   0%      0%      0%      0%      0%      0%      0%      0%      0%      7%      48%     24%
    edited 2022-07-17 07:48
    So based on the above results @Wuerfel_21 , there may now be some scope to get NeoYume running faster with the 96MB board with sysclk/3 read rates instead of sysclk/4. You can keep my driver as is writing at sysclk/2 and just need to change your own read code a little. I think you can theoretically shave 13+n P2 clocks off the read latency for each burst transfer of n bytes this way in an 8 bit PSRAM setup with sysclk/3 reads vs sysclk/4 which should help. It does cost two more instructions though (if you can do something in the waitx time like a mergeb) so I guess it's 9+n in reality.
    The key is to use clock pulse mode instead of transition mode, and you need to setup the clock phase correctly at the beginning of the read request. My code does this, yours will be slightly different due to how you do your tri-state waits and delays but the two wxpins and the waitx delay at the beginning are needed and the clock count is now half of what it was before. You might be able to do something useful instead of the waitx perhaps but you'll probably need two instructions between both wxpins to be sure it transitions by 1 clock before resetting the duty cycle. divideby3 = $20003, nco_slower = $2aaaaaab
            wxpin   #1, #PSRAM_CLK_PIN ' adjust timing to one P2 clock per update for precise adjustment
            drvl    #PSRAM_CE_PIN
            drvl    #PSRAM_DATA_PINS
            wxpin   divideby3, #PSRAM_CLK_PIN
            waitx   #0
            xinit   ximm8, pattern
            wypin   #15, #PSRAM_CLK_PIN ' enough clocks for address phase, delay and 1 byte transfer
            xcont   #0, #0
            xcont   #6, #0
            fltl    #PSRAM_DATA_PINS
            wrpin   registered, #PSRAM_DATA_PINS
            setq    nco_fast
            xcont   #DELAY, #0
            xcont   #6, #0
            setq    nco_slower
            xcont   xread2, #0                          ' read data
            waitxfi                                     ' wait until streamer is done
            drvh    #PSRAM_CE_PIN
    edited 2022-07-17 10:22
    Got NeoYume working with sysclk/3. :smile:
    Here were the changes I made...based on my (older) version of this emulator. Run a diff between the two files to see what I did so you can update your own code for the 96MB board, Ada.
    Also the magic required numbers in config.spin2 with this change were PSRAM_WAIT = 5, PSRAM_DELAY = 14, although other nearby DELAY values might also work too at sysclk/3 rates. PSRAM_WAIT=5 makes more sense to me because there are 5 actual PSRAM clock cycles needed after the 8 nibble address transfer before the read data begins. It's multiplied by either 2 or 3 for sysclk/2 or sysclk/3 rates because the streamer has switched back to nco_fast (sysclk/1) at this point so you need to scale it back to real P2 clocks. Then a delay of 14 P2 clock cycles is added before reading begins to account for the total pipeline and board delays encounted by the read operation. It all works out.
    UPDATE: PSRAM_DELAY = 15 and PSRAM_DELAY=16 also work, so you might pick the middle one of 15. The values of 13 and 17 didn't work for me.
    UPDATE2: not sure if I am just imagining it but a couple of times the input control felt a tad laggy perhaps in a couple of places with lots of screen activity when running sysclk/3. Nothing visibly noticeable though.
  • Sounds good, will have to look into it later
    edited 2022-07-18 07:35
    @rogloh said:
    Right now I'm looking at adding support for sysclk/4 reads and writes in my driver. I think its probably doable for the 4 bit and hopefully might also still fit the 8 bit PSRAM driver, but the 16 bit driver is a worry as there is very little space left for the extra instructions (just 2 LUTRAM longs which I think I wanted for pik33's locked video read list feature IIRC). So that driver might end up having different capabilities which isn't ideal.
    Looks like it fits in the 16 bit driver as well, and even leaving me with one LUTRAM long to spare. Luxury! :smile: I initially had two LUTRAM longs free, and if I used the optimization I found previously for pik33 locked request list feature, that actually frees another 2. The sysclk/3 change itself takes 4 instructions but also saves one elsewhere in the clock calculation. So it looks like we are good to put this feature into all PSRAM drivers. It also needs one more COGRAM long for the duty cycle storage but we had three spare anyway. The other driver variants have more space free and are okay.
    This new feature is useful because it allows people to not overclock the PSRAM, or choose to operate at a slower but working speed if the PSRAM output drive's slew rate is not fast enough due to too much load with multiple banks for example. I'm expecting some good things with Rayman's 96MB board now at very high P2 clock speeds allowing it to continue to operate in those situations with only a moderate performance hit.
    I think I will keep sysclk/2 the default for PSRAM unless overridden, in which case operating at sysclk/3 or sysclk/4 can be selected at startup. Even though it violates the duty cycle requirement I sort of expect sysclk/3 to be safe to use. I imagine this 50% duty cycle restriction mainly applies when you are clocking at sysclk/2, so there is enough high and low time on the clock signal for sample/hold purposes. Because we are essentially just doubling the low time, and keeping the high time the same, I'm thinking we should be good. If there was some type of PLL or something like that inside the device that was timed off each edge to generate some internal clock signal, I'd be more worried about changing the duty cycle to 33:66%, but in this case it appears to work. But people can always fall back to sysclk/4 if they have to, at the expense of some additional performance loss.
    edited 2022-07-18 13:39
    PLLs can be "picky" as of reference input duty cycles when they differ too much from the ideal 50/50, but only when the input clock is used as is (without prescalling), because it tends to "foul" their phase comparators.
    Also it would be very hard (in the sense of needed hardware structures) to keep with input references whose periods could be otherwise schrunked, stretched or totally stopped.
    There are no PLLs at PSRams that deppends-on their clock input pin(s), whichever bit-"flavours" they can have (4, 8, 16...). This includes all the Xccela-Consortium-tagged versions, and all HyperBus derivative devices.
    In relation to their input clock waveforms, for each kind of working cycle (read or write), there is an active border to be followed/observed. The internal state machine relies on an interlocking process, in order to deal with all aspects of defined/required data-transfer operations.
    The absence of any externally-accessible DQS/DM or RWDS signals doesn't mean they don't exist; they're just embodied, and used as an integral part of the request/acknowledge mechanism.
    When present (Hypers and Xccelas), their "data mask" function is just a "free reward"; kind off a "useful remanent" from the time when "protecting" some part of the data-words against overwriting was of utmost importance.
  • evanhevanh Posts: 16,475
    edited 2022-07-21 02:50
    I've been bashing away at doing an educational version of this, ie: Using the streamer for performance databus ops. And doing it in a way that shows any desired setting is possible. But damn, it ain't easy. The dance of aligning the timings of multiple pins at different clock ratios and speeds and specific alignments forces hand coded numbers all over the place. There is such a thing as too tight.
    PS: I did find a simpler solution that eliminates the hand coded lead-in timing by swapping out the SPI clock's Pulse Mode smartpin for PWM Mode and instead rely on CE going low for start of the SPI transaction. But, because of timing limitations around when CE can go low, sysclock/2 becomes inflexible. (Data pins have to stay registered for perfect timing).
    At any rate, it takes advantage of the fact that extraneous clock pulses are ignored prior to CE low and also ignored after the command is completed.
                    dirh    #PSRAM_CLK_PIN      ' start SPI clock pulses, PWM smartpin
                    waitx   #1 + CLK_REGD - DAT_REGD
                    xinit   ##M_CA4, paddr      ' tx Command and Address (byte granular address)
                    drvl    #PSRAM_CE_PIN       ' tightly follows streamer to signal CA start
  • Hi @evahn
    Ain't there any risks for command termination to be misinterpreted by PSram, in the sense one must ensure CE# going high well within CLK = "Low"-period?
  • I've managed to come up with a sequence that mostly now works for sysclk/2 sysclk/3 and sysclk/4 and have now added it to my 4,8,16 bit PSRAM drivers. The only downside is that (only) in the sysclk/4 case the clock is not fully centered in the middle of the sent bit (it's at 3/4 I think) but given that is running much slower and we have more headroom there on writes, I'm not too concerned about that limitation. For the reads you can center the clock with the optimal delay setting.
    Here's the main sequence (including my skipf stuff for bytes/words/long/bursts and optional registered data pin controls). I've also used a method from Ada's code now to wait for tri-stating, doesn't save any cycles but it's probably a little neater to read/understand than my old way. You do need a 2 clock delay slot after the second wxpin before the xinit, which I've used for one of the address setup instructions (in this case a movbyts). You do get a few spots in the sequence where you can run other instructions while the streamer is being operated. I've used them to compute / restore the clock delays. The value of clkdelay is different for sysclk/2, /3 and /4, but can be determined in advance and remains fixed at a given clock divisor for the streamer. I also have my own fine delay on top of this which is a per bank setting.
                                wxpin   #1, clkpin              'increase clock update rate
                                drvl    cspin                   'activate chip select
                                drvl    datapins                'enable data bus
                                wxpin   clkduty, clkpin         'resync clock output
                                movbyts cmdaddr, #%%0123        'reverse bytes in address to match bus order
                                xinit   ximm8, cmdaddr          'stream out command+address
                                wypin   clks, clkpin            'start clock output
                                add     clkdelay, delay         'add configurable fine input delay
                                setq    xfreq1                  'reconfigure with single cycle xfreq (sysclk/1)
                                xcont   clkdelay, #0            'streamer transfers during bus turnaround delay and read latency
                                sub     clkdelay, delay         'restore for next time
                                waitxmt                         'wait until first command has completed before tri-stating
                                fltl    datapins                'safe to float the data bus, address has been sent by now
                                wrpin   regdatabus, datapins    'setup data bus inputs as registered or not for read timing control
                if_z            skipf   #%0100100               'special skip case for read-modify-write(RWM)
        'Bursts Bytes Words Longs  RMW
                                setq    xfreq2                  '   a     b     c     d     e
                                xcont   xrecvdata, #0           '   a     b     c     d     e     transfer data as nibbles
                                call    resume                  '   a     b     c     d     |
                                waitxfi                         '   a     b     c     d     e     wait for streaming to finish
                                wrpin   registered, datapins    '   a     b     c     d     e     restore data pins for next transfer
                _ret_           drvh    cspin                   '   a     b     c     d     |     de-assert chip select and return
    @Yanomani said:
    Hi @evahn
    No problem there. Commands are finished long before CE rises again.
    edited 2022-07-21 03:07
    You're missing a needed lead-in timing alignment. A WAITX (with handcrafted delay) should be placed just in front of the XINIT. I have different values for each sysclock ratio.
    Here's what I was using for a while:
                    dirh    #PSRAM_CLK_PIN      ' start smartpin cycling
                    waitx   #(DELAY_SMART + CLK_REGD - DAT_REGD) +// CLK_RATIO  ' smartpin cycle alignment - clock ratio dependent
                    xinit   ##M_CA1, paddr      ' tx Command and Address (byte granular)
                    wypin   len, #PSRAM_CLK_PIN ' SPI clocks for CA phase, and data phase
    With these hand crafted values:
    '    DELAY_SMART = 0    ' tuned for sysclock/2 SPI clock
        DELAY_SMART = 0    ' tuned for sysclock/3 SPI clock
    '    DELAY_SMART = 3    ' tuned for sysclock/4 SPI clock
    edited 2022-07-21 03:39
    However, I gave up on that approach because it proved problematic, not dissimilar to the PWM approach above, where one of the four sysclock/2 combinations could not be aligned. EDIT: The combination with data pins unregistered, clock pin registered.
    PS: I'm back to pursuing the wordier approach of using XINIT then SETQ+XCONT for initiating CA phase in place of the lead-in WAITX. It still needs the handcrafted alignment encoded in the first XINIT but it's not timing limited like the other approaches.
                    xinit   ##M_LEADIN, #0      ' lead-in timing, at sysclock/1, includes smartpin cycle alignment
                    setq    ##($8000_0000 +/ CLK_RATIO)    ' streamer transfer ratio
                    xcont   ##M_CA1, paddr      ' tx Command and Address (byte granular address)
    edited 2022-07-21 03:44
    Strange, mainly because PSRams do rely on the raising edge of CLK, in order to properlly identify the command termination itself, but the timing diagrams seen to be a little misleading, to say the least;
    (data from APS6404L-3SQR devices datasheet, page 10)
    • As for Write to be considered as properlly terminated, CE# "Can Be" de-asserted (High-going) as short as 3nS after the "Rising Edge" of the Last CLK, which effectivelly "clocks" (sic) the last data item, towards PSRam inner "guts";
    • As for Read to be considered as properlly terminated, CE# "Can Be" de-asserted (High-going) as short as 3nS after the "Rising Edge" of the Last CLK, which effectivelly "signs" the completion of the Read operation, but the data transfer of the last nibble towards the I/O buffers. will depend on the forthcoming "Low-going Edge" of that same CLK pulse, so there's an observation/warning at the same item/page: "For a memory controller to correctly latch the last piece of data prior to read termination, it is recommended to provide a longer CE# hold time (tCHD > tACLK+tCLK) for a sufficient data window".
    Its kind of a "Brain Salad Surgery", perpetraded by some drunk surgeon, and lacking all "nice sound effects"...
    To be "Crystal Clear" (and in the sake of any minor sanity, still resting inside my own brain): Command Termination not only means the end of current operation (in progress), but also means PSRam's internal state machine will not try to continue the ongoing operation, "internally", e.g., understanding a burst as crossing actual row address limits.
    Ouch... :smile:
    edited 2022-07-21 04:04
    Huh, maybe combine both: Use the flexible streamer approach plus the PWM as clock approach to eliminate the hand crafted alignment ... something like:
                    xcont   ##M_CA4, paddr      ' tx Command and Address (byte granular address)
    "as short as 3nS" is the operative words there. You can happily make it much longer and not care about the end-of-command timing.
    edited 2022-07-21 04:15
    You're absolutely right, provided the last CLK-signal "completely-stops" after its forthcoming "Low Going" edge.
    Any reasonable "rebound" (in the sense of total voltage excursion), either due to an undamppened reflexion (or even excessive ground bounce) would put such "command termination"-interpretation at risk, which could, in turn, cause some malfunction, be it due to "incomplete (or even totally skipped) self-refresh cycles, or beyound "normal" inter-command "minimum innactivity" (CE# tCPH >= 18nS) limits.
    edited 2022-07-21 04:24
    The clock doesn't actually need to stop (at any time). It is ignored once the command is completed. No further commands will be accepted until CE cycles high and back low. One command per CE cycle.
    edited 2022-07-21 04:33
    If the actual drivers are currently lefting "Page Boundary Crossing" enabled, that statement does not apply, since the PSRam will be ever prepared for a "possible and eventual" RBX-event (that means it'll do each and every "internal housekeeping" needed), as if the commands would really continue.
    Sure, it'll only affects Read ad Write operations at the main memory array. but that's enough to cause havoc.
    edited 2022-07-21 04:40
    Oh, you might have a point, I'd not thought about writing data to the RAM. I've mostly been concerned with the fixed length commands in my testing.
    Yes, using PWM as clock would then need precise CE timing for command termination on RAM block writes. That might be possible given that writes are currently pretty uncomplicated.
    edited 2022-07-21 04:56
    I've been "eating" those datasheets, without any good spice (for them to taste any better) almost since the first 4-bitters appeared, too long ago (SRAMSUN, et al.)... :smile:
    (my connection went "weird", so I'm complementing, based on your latest edition)
    Reads would also kind of "need" them, because those tiny monsters seem to have two fifos; that's the reason for needing a CLK "slow-down" (84MHz, at the datasheet, which would translate to ~12nS of "extra" low-time between the last CLK full-cycle from the first "block", and the first High-going CLK pulse of the next one, but them, up to 2048 consecutive bytes can be I/O'lled (sic) with only one Command/Address sequence (and, sure, would need propper calculations, so as to don't causing havoc with self-refresh timing).
    O.S. the "extra" ~12nS would be the time needed to MUX the secondary Fifo, as it could be the primary-one, then the primary would became the secondary, and so on...
    This is kind of new territory too. Previous approaches were all using exact number of clock pulses so CE termination wasn't thought about at all.
    No need, because my movbyts performs the 2 clock cycle wait function. It would be a wasted WAIT #0 otherwise, which is what I started with, so I can put a useful instruction there to save a couple of clocks. This works for sysclk/2 and sysclk/3 with both registered data and clock pins (which is what I'm using in my driver at this point in the address phase). Sysclk/4 does slightly offset the clock phase by an extra P2 clock though as I mentioned, and I'm unconcerned about that. You can select unregistered data in the lsb of my provisioned bank delay, but that occurs after tri-stating. There is no unregistered clock selection for this driver (like we had for the experimental sysclk/1 HyperRAM stuff). That can fix the sysclk/4 but introduces more selection logic and cycles to switch on/off dynamically.
    edited 2022-07-21 05:18
    Hmm, not looking simple. WAITXFI is ~4..6 sysclocks too late to use for bashing CE on time.
    edited 2022-07-21 05:26
    Pure luck - that those fell that way. EDIT: I guess at sysclock/4 it's leaning to your advantage because 3 of the 4 alignments will work.
    edited 2022-07-21 05:23
    Here is my write timing at 4MHz so my logic analyzer can capture it. It's showing address + data phase to write a byte in nibble mode PSRAM. Reads start out the same and then switch to input mode later. Turns out the rising clock actually is 1/4 into the bit, not 3/4 in sysclk/4 mode as I had initially thought.
    Sysclk/2 (clock is centered)
    Sysclk/3 (rising clock is 2/3 into bit)
    Sysclk/4 (rising clock is 1/4 into bit).
  • Here's the test code I used for the above:
    CON
        _clkfreq = 4000000
        BAUD = 115200
        PSRAM_DATA_PINS = 8 + (3<<6)
        PSRAM_CLK_PIN = 12
        PSRAM_CE_PIN = 13
        SYSCLK_DIV1 = $80000000
        SYSCLK_DIV2 = $40000000
        SYSCLK_DIV3 = $2AAAAAAB
        SYSCLK_DIV4 = $20000000
    OBJ
        uart:"SmartSerial"
        f:"ers_fmt"
    PUB main()
        asm
            wrpin #0, #PSRAM_CE_PIN
            drvh #PSRAM_CE_PIN
            fltl #PSRAM_CLK_PIN
            wrpin ##%100_000_000_01_00100_0, #PSRAM_CLK_PIN  ' pulse mode registered clock pin
            drvl #PSRAM_CLK_PIN
            wrpin  ##%100_000_000_00_00000_0, #PSRAM_DATA_PINS  ' registered data bus pins
        endasm
        write_test(2)
        write_test(3)
        write_test(4)
        repeat
    PUB write_test(divisor) | divider, nco, wrclks, cmdaddr, ximm8, xsendimm, hubdata
        case divisor
            2: divider := $10002
               nco := SYSCLK_DIV2
            3: divider := $20003
               nco := SYSCLK_DIV3
            4: divider := $20004
               nco := SYSCLK_DIV4
            other: return
        asm
            setxfrq nco
        endasm
        wrclks := 8+2        ' byte write as 2 nibbles after 8 nibble address phase
        cmdaddr := $af25af35 ' address+cmd pattern
        ximm8 := $6091_0008  ' 8 nibble immediate transfers
        xsendimm := $6090_0002  ' 2 nibble immediate transfers
        hubdata := $d4        ' data pattern
        repeat 1
            asm
                wxpin   #1, #PSRAM_CLK_PIN      ' adjust timing to one P2 clock per update for fast adjustment
                drvl    #PSRAM_CE_PIN           ' activate chip select
                drvl    #PSRAM_DATA_PINS        ' enable the data bus
                wxpin   divider, #PSRAM_CLK_PIN ' restart pulse mode divider
                waitx   #0                      ' delay
                xinit   ximm8, cmdaddr          ' send 8 nibbles of address and command via LUT translation
                wypin   wrclks, #PSRAM_CLK_PIN  ' start memory clock output
                xcont   xsendimm, hubdata       ' send immediate data as nibbles
                waitxfi                         ' wait for streamer to end
                fltl    #PSRAM_DATA_PINS        ' tri-state DATA bus
                drvh    #PSRAM_CE_PIN           ' de-assert chip select
            endasm
            waitms(500)
    Ah, that's only one of the four combinations of clock/data pin registration.
