Shop Learn
Smartpin Diagram (now with %P..P bit mode table) - Page 5 — Parallax Forums
123578
  • cgraceycgracey Posts: 13,403
    evanh wrote: »
    I prefer Smartpin over Smartcell.
    I've always called it "smart pin", as an adjective, rather than "smartpin", which is a registered trademark.
  • evanhevanh Posts: 10,419
    Thanks. I know Chip has used the term in both contexts but I'd like to see "Smartpin" be used for only one meaning. The docs generally support my interpretation even if not explicitly declared.
    edited 2020-04-17 00:13
    Oh. is that the problem. ... does a google ... LOL, so many of them. There is lots of different trademarks of that name. I doubt that's a concern, they aren't copyright claims.
    And Smartcell is a company name. So that's no better.
  • RaymanRayman Posts: 11,840
    Maybe OUT should be OUTA/B ....
    Same for IN
    edited 2020-04-17 00:16
    I figured that is why Chip always puts it as two words...
    But we don’t have to
    Rayman wrote: »
    Same for IN
    No, OUTA and OUTB covers 32 pins each. Likewise for INA and INB.
    Ok, Maybe IN[n] for even and IN[n+1] for odd?
    What modes use the feedback signal?
    edited 2020-04-17 00:26
    Rayman wrote: »
    Every entry containing "Input" in the "PinA Output" column of the Pad IO Modes table.
    Symbol name "INPUT" in Chip's block diagram.
    edited 2020-04-17 00:35
    Rayman wrote: »
    Extraneous, IN and IN[n] are the same. EDIT: Okay, I guess that is technically better since it does show the two IN's in the block diagram are distinct paths.
    EDIT2: You'll be doing it for every label if go down that path though.
    Maybe I’ll draw a horizontal line to separate the pins and label one n and the lower one n+1
    I could define the range of n that way too
    Yep, just as long as it's clear that the top one is all even numbered pins and the bottom one is all odd numbered pins.
    edited 2020-04-17 02:12
    An alternative is pack the diagram down to one pin and somehow detail the odd/even differences.
    In Chip's schematic for the whole custom pin cell he's used the symbols PA and PB. There is no odd/even naming because there is no difference other than being a pin pair. In the odd # pin PB is the even # pin, and in the even # pin PB is the odd # pin.
    Really, the main difference between odd and even pins is how "Other" is treated.
    I think the smartpin is different between odd and even too right? I think usb mode has only one being in charge...
    Good question. I haven't tried to comprehend any of the USB capabilities.
    Ok, added even/odd barrier. Maybe this is the final version?
    1384 x 1594 - 221K
    edited 2020-04-17 14:46
    I think we should say something about USB... I'm not exactly sure how even and odd are connected in this mode, but the even pin is D- (master Brain) and the odd pin is D+ (slave Passive).
    Added this to Smart Pin sections
    1386 x 1595 - 228K
    Is HDMI in here somewhere as well?
    Chip will need to comment on whether USB has a difference in the smartpins or if it's just the PinA/B pairing that makes the diff.
    TDMS encoding for DVI/HDMI is done in the CMOD hardware, which is a stage of the streamers.
    Ok, thanks. I'll consider this done for now then.
    edited 2020-04-17 21:27
    Oh, you know how I've said "PI" and "Input" are practically the same signal in Chip's block diagram. Lets just make it so in ours. This means that my "Feedback" is the same as the logic input crossing the dotted line. ie: They can be made the same and it'll look clearer what the feedback is and also match up with the Pad IO Modes sheet.
          [%%%%%%%%%%%%%]  |   ||  :               v  |
          [    Logic    ]  |   ||  :          [%%%%%%%%%%%%%]
          [    Drive    ]  |   ||  :   Enable [             ]
          [             ]<-+------------------[    Logic    ]
    ------[   (%P...P)  ]      ||  :   Output [    Output   ]
          [%%%%%%%%%%%%%]      ||  :          [    (%TT)    ]
                ^              ||  :          [  (%MMMMM_0) ]
                |              ||  :      OUT [             ]
          [  Comparator ]<=====//  :      |     -1  -2  -3
          [             ]   |      :      |      v   v   v
     PinB [  Pin Input  ]   |      :      |   [%%%%%%%%%%%%%]
    ----->[   (%P...P)  ]   |      :       -->[ Logic Input ]
     PinA [             ]   |      :          [   (A_B_F)   ]
          [ Sigma-Delta ]  Input   :          [%%%%%%%%%%%%%]
          [     ADC     ]          :             ^   ^   ^
                                   :            +1  +2  +3
    Ok, here it is like that. Not calling it done this time.... That seems to be bad luck..
    1330 x 1596 - 226K
    edited 2020-04-17 22:20
    Oh, bugger, maybe I've put you wrong. It seemed a good idea for a short while. The problem with this new diagram arrangement is it makes it look like the ADC bitstream can reach the feedback when it really can't. That's the one actual difference between Chip's INPUT and the Input I've got there.
    Do we care? It looks tidy right now.
    EDIT: Maybe I should have a go at breaking that block up ... It'll bloat quite a lot I think ...
    Okay, done a halfway job of splitting up the Pin Input block. It corrects that "Input" detail. And I've dumped the block name in favour of full mode list instead.
                : Custom I/O Pad Ring :                       :               : Synthesised Core Logic :
                                                              :                             CogDAC (Streamers/Cogs)
                                                              :          [%%%%%%%%%%%%%]<============================= cog0
                                                              :          [             ]<============================= cog1
                           [%%%%%%%%%%%%%]                    :          [   DAC bus   ]<============================= cog2
                    |      [  Flash DAC  ]<=====++=======================[   select    ]<============================= cog3
                    |<-----[   Network   ]      ||            :          [             ]<============================= cog4
                    |      [   (%P...P)  ]      ||            :          [   (%P...P)  ]<============================= cog5
                    |      [             ]<-    ||            :          [             ]<============================= cog6
                    |      [%%%%%%%%%%%%%]  |   ||            :          [             ]<============================= cog7
                    |      [%%%%%%%%%%%%%]  |   ||            :               |   ------------------------------------- RND
                    |      [ Logic Drive ]<-+--------------   :        BitDAC |  | Other    ||
    [%%%%%%%%]      |<-----[   (%P...P)  ]      ||         |  :               |  v          ||SmartDAC
    [Physical]      |      [%%%%%%%%%%%%%]      ||       | |  :   Enable [             ]<------------------------------ OUT
    [ Even # ]------+            ^              ||       |  -------------[    Logic    ]    ||
    [ Pin Pad]      |            |              ||       |    :   Output [    Output   ]<---------------------------+-- DIR
    [%%%%%%%%]      |                        |  ||            :   |      [    (%TT)    ]    ||    [%%%%%%%%%%%%]    |
                    |                        |  ||            :   |      [  (%MMMMM_0) ]    \\====[            ]    |
                    |                        |  ||            :   |  OUT [             ]          [   Even #   ]<---
                    |      [%%%%%%%%%%%%%]   |  || CompDAC    :   |   ---[             ]<---------[  Smartpin  ]
                    | PinB [  Comparator ]<=====//            :   |  |   [%%%%%%%%%%%%%] SmartOUT [ (%MMMMM_0) ]
                  -------->[   & Logic   ]   |                :   |  |                            [            ]
                 |  | PinA [  & Schmitt  ]   |                :   |  |                            [  (X reg)===]<==== WXPIN
                 |  +----->[  (%P...P)   ]---+                :   |  |     -1  -2  -3             [  (Y reg)===]<==== WYPIN
                 |  |      [             ]   |"Input"         :   |  |      |   |   |             [  (Z reg)===]====> RDPIN
                 |  |      [%%%%%%%%%%%%%]   |                :   |  |      v   v   v             [            ]
                 |  |                        |                :   |  |   [%%%%%%%%%%%%%]      A   [            ]
                 |  |                        |    [%%%%%%%%]  :   |   -->[ Logic Input ]--------->[---o----o---]-------> IN
                 |  |      [%%%%%%%%%%%%%]    --->[   Mux  ]  :   |      [   (A_B_F)   ]      B   [  (M == 0)  ]
                 |  | PinA [ Sigma-Delta ]        [(%P...P)]------------>[             ]--------->[            ]
                 |  +----->[     ADC     ]------->[        ]  :   |      [%%%%%%%%%%%%%]          [            ]<------ ACK
                 |  |      [  (%P...P)   ]        [%%%%%%%%]  :   |         ^   ^   ^             [   USB D-   ]
                 |  |      [%%%%%%%%%%%%%]                    :   |         |   |   |             [   brain    ]
                 |  |                                         :   |        +1  +2  +3             [%%%%%%%%%%%%]
                 |  |                                         :   |                         CogDAC (Streamers/Cogs)
                 |  |                                         :   |      [%%%%%%%%%%%%%]<============================= cog0
                 |  |                                         :   |      [             ]<============================= cog1
                 |  |      [%%%%%%%%%%%%%]                    :   |      [   DAC bus   ]<============================= cog2
                 |<--------[   Network   ]      ||            :   |      [             ]<============================= cog4
                 |  |      [   (%P...P)  ]      ||            :   |      [   (%P...P)  ]<============================= cog5
                 |  |      [             ]<-    ||            :   |      [             ]<============================= cog6
                 |  |      [%%%%%%%%%%%%%]  |   ||            :   |      [             ]<============================= cog7
                 |  |      [ Logic Drive ]<-+--------------   :         Other |  |BitDAC    || SmartDAC
    [%%%%%%%%]   |<--------[   (%P...P)  ]      ||         |  :               v  |          ||
    [Physical]   |  |      [%%%%%%%%%%%%%]      ||       | |  :   Enable [             ]<------------------------------ OUT
    [ Odd #  ]---+  |            ^              ||       |  -------------[    Logic    ]    ||
    [ Pin Pad]   |  |            |              ||       |    :   Output [    Output   ]<---------------------------+-- DIR
    [%%%%%%%%]   |  |                        |  ||            :          [    (%TT)    ]    ||    [%%%%%%%%%%%%]    |
                 |  |                        |  ||            :          [  (%MMMMM_0) ]    \\====[            ]    |
                 |  |                        |  ||            :      OUT [             ]          [   Odd #    ]<---
                 |  |      [%%%%%%%%%%%%%]   |  || CompDAC    :       ---[             ]<---------[  Smartpin  ]
                 |  | PinB [  Comparator ]<=====//            :      |   [%%%%%%%%%%%%%] SmartOUT [ (%MMMMM_0) ]
                 |   ----->[   & Logic   ]   |                :      |                            [            ]
                 |    PinA [  & Schmitt  ]   |                :      |                            [  (X reg)===]<==== WXPIN
                 +-------->[  (%P...P)   ]---+                :      |     -1  -2  -3             [  (Y reg)===]<==== WYPIN
                 |         [             ]   |"Input"         :      |      |   |   |             [  (Z reg)===]====> RDPIN
                 |         [%%%%%%%%%%%%%]   |                :      |      v   v   v             [            ]
                 |                           |                :      |   [%%%%%%%%%%%%%]      A   [            ]
                 |                           |    [%%%%%%%%]  :       -->[ Logic Input ]--------->[---o----o---]-------> IN
                 |         [%%%%%%%%%%%%%]    --->[   Mux  ]  :          [   (A_B_F)   ]      B   [  (M == 0)  ]
                  -------->[     ADC     ]------->[        ]  :          [%%%%%%%%%%%%%]          [            ]<------ ACK
                           [  (%P...P)   ]        [%%%%%%%%]  :             ^   ^   ^             [   USB D+   ]
                           [%%%%%%%%%%%%%]                    :             |   |   |             [  passive   ]
                                                              :            +1  +2  +3             [%%%%%%%%%%%%]
    Note I've made the ADC pin connection correct for Rev C silicon. Rev A and B would have both PinA and PinB connected.
    Maybe "Logic Input" can be "Logic Mux"?
    edited 2020-04-18 00:38
    Okay, yeah, could go with function list there too "Mux & Deglitch"
    What do you mean by function list?
    Is it doing more than selecting one of several inputs?
    edited 2020-04-18 01:08
    smartpi
    evanh wrote: »
    In an even/odd pair, all the USB smart pin logic is in the even pin. The odd pin just has conduit for control from the even pin. The even pin controls HHH and LLL modes for both pins in the pair.
