Open Propeller Project #3: Propeller IDE V0.1 Package Available - Page 13 — Parallax Forums
1101113151629
  • pedwardpedward Posts: 1,642
    edited 2014-02-26 08:31
    JonnyMac wrote: »
    For the love of all that's holy (and sensible), can we stop with the cute names?....
    In case your funny bone is broken, it was all musings.
  • jazzedjazzed Posts: 11,803
    edited 2014-02-26 11:22
    Hi
    I've updated the repository to include a fix from Dennis and some SpinSuggest icon changes. The new icons (attached) are stylized more like the toolbar icons and keep colors consistent with PropellerTool sections which we will have in this program some day.
    301 x 255 - 14K
    edited 2014-02-26 11:32
    jazzed wrote: »
    Hi
    Having all those shapes the same and only differ in color may be an issue for those with color vision issues.
    C.W.
  • dgatelydgately Posts: 1,647
    edited 2014-02-26 11:42
    ctwardell wrote: »
    C.W.
    That's why my example kept the basic shapes, but added the lock-key for PRI and some of the other "feature-ettes" to help distinguish the icons form one another.
    dgately
    edited 2014-02-26 11:44
    ctwardell wrote: »
    C.W.
    Hmm. Ya, I guess you're right. I wonder how the propeller tool background shading looks to people with such issues.
    The Icons are much cleaner without little artsy pieces. Adding words to the icons won't help because they are so small when rendered (if anyone has noticed ???). Will look into adding some text bys some means to make it clear (tool tip/list feature).
    edited 2014-02-26 11:49
    If you could decide on letters to distinguish pub and pri you could use colored letters to provide color clues and be ADA friendly.
    Is a capital P different enough from a lower case p in a simple font?
    edited 2014-02-26 12:09
    How's this for PRI?
    50 x 30 - 1K
    edited 2014-02-26 12:38
    So a colored P, 'lock', C, V, D and the object doesn't need any letter since it has four little blocks? That would work, I think.
    I'm building a new Windows version now through a Nyquil fog........
    edited 2014-02-26 12:44
    I messed with using (OBJ), (CON), etc... in the symbol names. That's more trouble than it's worth.
    At this point, I think if we can stick with the color scheme and have some very simple little decorations things would be fine.
    It's hard to tell how anything will look without running the program though.
    Rick, I don't recommend a fifth of Nyquil :)
    BTW, I found several OBEX programs that ignore case when adding objects. If something isn't showing up in the method list, then the case issues are likely causing the problem. Works great on Windows of course, but that ain't the only platform.
    edited 2014-02-26 12:46
    SPIN_AUTOCOMPLETE works like this:- Press dot (.) in any non-comment area of the source to show OBJ, CON, PUB, PRI, VAR, and DAT references.- Press escape to not add any item listed.- Press dot (.) to add a dot.- Scroll to the item you want and press enter to add that item. Tab to select is not available at the moment. Later, "tab" may be used instead of enter if the cbAuto is a sub-class of QComboBox.
    RE:
    - Press dot (.) to add a dot. <== currently does nothing (I assume you mean that typing the dot key while the 'dot' pop-up menu its is selected?)
    And, not sure if a carriage-return or line-feed should be added after the pop-up menu item is entered. Seems that the cursor going to the next line may not be helpful. In most cases, won't the user want to edit within the same line as they started.
    Example:
    1. User types '.', gets the pop-up menu of auto-choices
    2. User arrows down to a VAR or CON item: (i.e. "someVar")
    3. User types an Enter key
    4. "someVar" is inserted with the cursor placed just after it...
    5. User expects to type something like: " := 123" to complete that line of code
    dgately
    edited 2014-02-26 12:53
    dgately wrote: »
    RE:
    Typing dot, then selecting dot adds a dot.
    dgately wrote: »
    This only happens on Mac :) No idea why.
    edited 2014-02-26 12:56
    jazzed wrote: »
    Oh, pressing dot mean clicking on its pop-up menu item (I get it!)
    Only happens on Mac. Hmm, I'll look into that. Noticed that it does NOT do that when you click on the pop-up menu item, so there's that clue.
    Might need to have the auto-complete code 'swallow' the return key event. Does it get passed on?
    dgately
    edited 2014-02-26 13:54
    Regarding colors.
    PropTool lets you modify the colors. You can change everything color-wise, including doing more color syntax highlighting than is apparent by default.
    Having the icons be color based might be an issue, unless we can tint them based on user chosen colors, since we should allow uses to set the block section colors (just like proptool does), especially for accomadating colorblind folks.
    Maybe if the icons were simple symbols, and the color was applied as either a tint of the icon or as a background behind the icon?
    Roy
  • Don MDon M Posts: 1,654
    edited 2014-02-26 15:24
    jazzed wrote: »
    Hi
    How about just using these simple shapes / colors as you have shown and for those that are "color challenged" just put a 3 letter label in each icon. OBJ, VAR, CON, PUB, PRI, DAT and so on. Then you really don't need to know what the shape or color means.
    Just my .02...
    edited 2014-02-26 15:28
    jazzed wrote: »
    How's this for PRI?
    As in this example you could delete the padlock and just put PRI instead or you could make padlock smaller and put PRI next to it in on the icon...
    edited 2014-02-26 15:39
    Don M wrote: »
    Just my .02...
    Hi Don.
    Unfortunately, the icon rendering is too small for this method to be effective.
    Thanks for your input. I hope what we end up doing will work for you.
    edited 2014-02-26 20:32
    Bug/Issue?
    If for example, your top level file tab has focus and is the only file open, when you go to the lower left panel and click on an object file, it will open that file up in a new tab and give that tab focus. Cool! Works as expected.
    If you go back to your main tab and then click on the same object you just opened, it opens it again in another tab and gives that new tab focus. What?
    If you do the same thing, go back to main tab, click on an object in the lower left window, it opens ANOTHER tab with ANOTHER copy of that object and gives it focus.
    In a short time, you can have many tabs open for the same object.
    Shouldn't proper behavior be to just switch focus to the correct tab if the object file is already open in a tab?
    The top left window behaves inthe same manner when you click on files.
    Last pull of source around 4pmET.
    This has been observed on Windows and Mac.
    edited 2014-02-26 21:03
    What are you doing awake at 4AM?
    The doctor's gonna kill you ... oh wait, that would be crazy.
    mindrobots wrote: »
    Bug/Issue?
    "But you got what you asked for." LOL
    Rick, I noticed that once also but forgot to take a note.
    Here's another one for ya.
    The current terminal doesn't send $d for "Enter" ....
    Also, I've found that some older versions of openspin just don't work in some limited cases. Please make sure to use a recent build.
    There are some issues stacking up, but they aren't really being recorded yet. Maybe it's time.
    edited 2014-02-26 21:14
    I'll let you know if i'm still awake at 4am! It's just past midnight. I'm an old man now so I nap and get up in the middle of the night more than I used to! Talk about issues stacking up!
    I'd offer to help track issues but I'm seriously bad at it but if you want a helper you can fire, let me know.
    I was actually up and going to play with P2 code but my cat kept walking on my keyboard and really messing up my PASM code!
    edited 2014-02-26 21:20
    mindrobots wrote: »
    Hmm, guess I'm asleep at the wheel. Qwerty forehead and all .....
    I was obliquely referring to the "issue tracker" - it's "Virgin Atlantic" right now.
    I'll start porting the terminal stuff tomorrow.
    edited 2014-02-27 11:04
    Hi. I've updated the repository to fix a few things.
    The most visible is probably the duplicate tab file problem Rick mentions.
    Another issue was that the file browser did not work for some spin files.
    Dennis sent me a "block shift" fix, but I haven't included that yet.
    Edit: Fix is now in the repository. Thanks Dennis!
  • fridafrida Posts: 155
    edited 2014-02-28 02:54
    In the FullDuplexSerial.spin, when I choose PUB rxflush or PUB rx I got PUB rxflush highlighted.
    I would like to get the files in the lib directory to be read only, so I do not change them unawares.
  • kinougromitkinougromit Posts: 8
    edited 2014-02-28 03:27
    hi all,
    why not having a real front end and backend for this compiler ...
    so everybody can use their favorite tool either for editing or trying new version of the compiler. A pure command line tool with input & output files ... (like gcc does depending on options) if we need to keep trace of OBJ etc ...
    It will ease the maintenance of such tool IDE and compiler and ensure the multiplateforme thing (even across krosoft versions).
    Thierry.
    edited 2014-02-28 03:44
    hi all,
    Thierry.
    Have you tried OpenSpin? Command line, open source Spin compiler that this tool uses for the backend.
    edited 2014-02-28 03:59
    yes I'm using this in fact on win,osX and linux ... that's why I'm wondering a new ide that reintegrate everything through DLL,so ... ? ...
    edited 2014-02-28 04:56
    kinougromit,
    We do. Currently openspin is a totally separate program and project.
    Nobody is suggesting that be changed.
    But there are advantages to having the ability to use the compiler as a library as well. It can then provide functions to the IDE that provide a lot more information about the source code.
    To start with, what about syntax highlighting?
    Currently the IDE has to some how parse and analyse the source code in order to colour the syntax and background.
    But that is silly, the compiler already has a lexer and parser. Whey not have the IDE use that? It would be much more robust.
    What about "intelisense" or whatever you call it. The compiler can be parsing all the code, whilst you are editing, and through that library API provide all the information you need to put red squiggles under undefined symbols or help with completions. etc etc,
    edited 2014-02-28 05:37
    fair enough, I get it now.
    Then one thing could be what exist in some modelling tools an option to the command line to launch it as regular static file or librairy and provide such means to the IDE. What I feel nice today is the real multiplateform ability ... It is a key factor to work on some research industrial project with Zi propeller.
    T.
    edited 2014-02-28 12:54
    Re: OpenSpin exe & dll stuff
    I was considering making the OpenSpin command line exe use the same DLL setup/interface. So you'd be using the same compiler backend with the IDE as with the command line exe. The only downside (if you can call it that) is that the command line tool would now be two files (exe & dll) instead of just one. Any strong opposition to that?
    edited 2014-02-28 13:08
    Roy Eltham wrote: »
    Roy including .dll (or a .so for linux) for an app is generally a pain.
    Can you generate a .dll as a build option?
    edited 2014-02-28 14:01
    Having two files: openspin.exe & propellercompiler.dll (or so) that live together, side by side, it a pain?
    Almost every app I have installed has an exe and some number of DLLs installed with them side by side, seems like I'm experiencing a lot of pain I wasn't aware of... :)
    I can make it so the openspin.exe is all self contained, and have the dll be produced separately for use with the IDE (or whatever). It's a little more work to do. I just thought it might be desirable to have both things using the exact same backend setup.
