$7 Laser Sensor Bulk Buy - Page 5 — Parallax Forums
1235
    edited 2014-01-13 15:57
    Darn, my hardware store had the 3M tape, so that might not help. I get home and we have a ton of house work to do, so we'll see how much free time I have to work on it.
    edited 2014-01-13 15:59
    OK, Step one find all the parts....................
    556 x 563 - 198K
    edited 2014-01-13 19:04
    I slightly tweaked the alignment and got it working. I can pick up a mirror at 15 feet and the 3M reflector tape reliably at 3 feet and most of the time at 4 feet. Now to find a project to do with it.
    edited 2014-01-16 10:33
    Just got my two EG laser modules today to test.
    http://www.goldmine-elec-products.com/prodinfo.asp?number=G19601
    I can say they run fine at 5 volts with the Hamamatsu receiver.
    Looks like it has a 91 ohm resistor built on. Cool!
    Will let it run over night to see if any smoke lets out.
    edited 2014-01-16 10:43
    Thanks for the feedback, Jim. That's great news, since I ordered 75 of them! Only two for you, Boss? :)
    BTW, I use mine in what I consider "light duty". It's on the mobile robot, continuously on for maybe two minutes at a time. Per the S6986 datasheet, the laser duty cycle is 1/16. Yet Philo said he burned one up without the resistor. I wonder how long these little laser pointer modules would work continuously, for instance if you used them for a break-beam burgular alarm.
    Obviously lasers represent a danger to your eyes. I added a secondary on/off switch to my bot so I can turn the laser & sensor off when I'm programming, don't need the laser sensor, or if the kids are around. Another approach would be to use the controller to switch it on & off as needed. Perfect application for a little relay.
    I'll use that when I make my robot with a high-power green laser to pop black balloons, and use sound feedback to hear the pop and turn the laser off.
    edited 2014-01-16 10:50
    Only two? Well i knew erco would have some in stock if I need them. :)
    And the special already ran out.
    edited 2014-01-16 12:46
    Still working well after two hours.
    Even though the the EG site specs it 3 volt, it is 5 volt tolerant.
    Smaller dot than laser pointers.
    edited 2014-01-16 13:33
    Steady on, or with the sensor? Range still 8-10 feet?
    edited 2014-01-16 14:07
    Connected to sensor, (modulated). 15' with:
    http://www.napaonline.com/Catalog/CatalogItemDetail.aspx/Reflective-Conspicuity-Marking-Strips-TruckLite-Red-White/_/R-LIT98104_0218618121
    edited 2014-01-16 14:08
    Publison wrote: »
    Don't leave me hanging, Jim! 15 feet with ...?
    edited 2014-01-16 14:11
    standard circuit and reflective that I linked to.
    edited 2014-01-16 14:33
    15 feet is great! You're makin' this old dog proud, big Jim. :)
    edited 2014-02-03 04:35
    Yesterday I made some targets out of my 3M tape, one inch dowels, and a wooden base. I then had my robot scan for the them at different distances. I found that the detection range is noticeably shorter when the robot is moving relative to the target. I imagine that there is a required time at a specific intensity to trigger the sensor.
    The 3M tape kinda stinks and I need to buy better tape. But I imagine that increasing the diameter of the target would make the surface slightly flatter and increase the amount of time for the reflection to reach the sensor. Philo used a 40 mm target while my dowels are only 25 mm.
    edited 2014-02-03 08:28
    Since 25mm<1" , I guess you meant a 1" dowel. :)
    Yes, I notice on my ~3" dia soda cans that it's still mainly the center, more "perpendicular to the laser" area that gets sensed. The quality of the retroreflective tape definitely makes a difference.
    Good to hear you're experimenting with these sensors. I want to see what you & others come up with.
    edited 2014-02-03 18:36
    I tried a moving robot with a Campbell's soup can with some 3M tape, and it had a two foot detection distance. The wooden dowel had an eight inch detection distance, so it looks like diameter makes a big difference. This makes sense because the larger the diameter the longer the reflection will hit the detector.
    edited 2014-03-30 14:00
    This took much longer to get done than I expected. The basics were pretty simple, but coupling all the behaviors together was a fair amount of debugging.
    '   File...... LaserTest.BSE
    '   Purpose... The robot finds a target using a laser, grabs and moves it
    '   Author.... Martin Heermance
    '   E-mail.... mheermance@gmail.com
    '   Started... 2014 January 31st
    '   Updated... 2014 March 30th
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' Program Description
    ' This program can be used with a CBA or Boe-bot with a gripper, laser, and edge
    ' sensor to find a target and carry it out of the ring.
    ' Revision History
    ' Pin allocations.
    Buzzer         PIN   8  ' pin for output sound
    Laser          PIN   9  ' pin for laser sensor.
    Ping           PIN  10  ' trigger for SR-04 sensor
    Echo           PIN  11  ' echo pin for SR-04 sensor.
    ServoPal       PIN  12  ' Pin for right servo
    Alarm          PIN  13  ' Pin for the alarm.
    Gripper        PIN  14  ' Pin for gripper servo
    ' Constants
    '--------[Calibration Constants, must be adjusted for your specific robot]------
    GripperOpened   CON     500                   ' PULSOUT pulse width to open gripper servo
    GripperClosed   CON     960                   ' PULSOUT pulse width to close gripper servo
    ' These values need tweaking for each robot's servos.
    SpeedF75L      CON 840  ' Fast forward left
    SpeedF50L      CON 805  ' Med  forward left
    SpeedF25L      CON 775  ' Slow forward left
    Speed000L      CON 750  ' stop left
    SpeedR25L      CON 715  ' slow reverse left
    SpeedR50L      CON 690  ' med reverse left
    SpeedR75L      CON 650  ' fast reverse left
    SpeedF75R      CON 650  ' Fast forward right
    SpeedF50R      CON 690  ' med forward right
    SpeedF25R      CON 725  ' slow forward right
    Speed000R      CON 750  ' Stop right
    SpeedR25R      CON 775  ' slow reverse right
    SpeedR50R      CON 810  ' med reverse right
    SpeedR75R      CON 850  ' Fast reverse right
    ' Standard values from Ping))) example
    Trigger        CON    5 ' trigger pulse = 10 uS
    Scale          CON $200 ' raw x 2.00 = uS
    RawToIn        CON  889 ' 1 / 73.746 (with **)
    RawToCm        CON 2257 ' 1 / 29.034 (with **)
    ' Trigger Ping)))
    IsHigh         CON   1
    IsLow          CON   0
    ' This program is so simple it only needs two variables to
    ' compute and test the distance to the target, and check the
    ' line sensors.
    X              VAR Word
    QTIS           VAR Word   ' Holds the current QTI total
    Duration       VAR Word   ' Holds duration value
    Calibration    VAR Word   ' Holds the calibration value
    GripState      VAR Word   ' Holds current gripper pulse
    ' Execution starts here
    Main:
      ' Pause at start of program to let user set down robot.
      FREQOUT Buzzer, 1000, 2500
      ' Initialize the servoPal
      INPUT ServoPal            ' Make sure ServoPal isn't being driven.
      DO : LOOP UNTIL ServoPal  ' Wait for ServoPAL to power up.
      LOW ServoPal              ' Set pin to an output and hold it low
      PAUSE 100                 ' for 100mS to reset ServoPAL.
      HIGH ServoPal             ' Raise the pin.
      PAUSE 100
      GripState = GripperOpened
      GOSUB Halt                ' stop robot
      DO
        GOSUB ReadAllQTIS
        Calibration = QTIS
        GOSUB FindTarget
        GOSUB Forward
        GripState = GripperClosed
        GOSUB FindEdge
        GOSUB Backward
        GOSUB TurnAround
      LOOP
      END
    FindTarget:
      ' slowly rotate until the laser target finds target
      PULSOUT ServoPal, SpeedF25R
      PULSOUT ServoPal, Speed000L
      PULSOUT ServoPal, 10
      DO
        ' Each iteration refresh the gripper.
        GOSUB PulseGripper
        IF (Laser = IsLow)  THEN
          GOSUB Halt
          RETURN
        ENDIF
      LOOP
    Forward:
      ' slowly move forward to the desired distance to the target
      PULSOUT ServoPal, SpeedF50R
      PULSOUT ServoPal, SpeedF50L
      PULSOUT ServoPal, 20
      DO
        GOSUB PulseGripper
        ' Exit if we're close to the target
        GOSUB PingDistance
        IF (X < 3)  THEN
          GOSUB Halt
          RETURN
        ENDIF
      LOOP
      RETURN
    Backward:
      ' slowly move backward from the target to drop it out ofthe ring
      PULSOUT ServoPal, SpeedR50R
      PULSOUT ServoPal, SpeedR50L
      DO
        GOSUB PulseGripper
        GOSUB PingDistance
        IF (X > 6)  THEN
          GOSUB Halt
          RETURN
        ENDIF
      LOOP
      RETURN
    TurnAround:
      ' Wait one pulse cycle just in case someone just pulsed the ServoPal
      PAUSE 15
      PULSOUT ServoPal, SpeedR75R
      PULSOUT ServoPal, SpeedF75L
      PULSOUT ServoPal, 600
      PAUSE 600
      ' Fall through to Halt
    ' Stop moving
    Halt:
      PULSOUT ServoPal, Speed000R
      RETURN
    ' Called to refresh the gripper servo.
    PulseGripper:
      PULSOUT Gripper, GripState
      PAUSE 20
      RETURN
    ' PingDistance - reads the distance at the current head angle.
    ' Inputs:
    ' Outputs:
    '   X - distance in inches.
    PingDistance:
      Ping = IsLow                                ' make trigger 0-1-0
      PULSOUT Ping, Trigger                       ' activate sensor
      PULSIN  Echo, IsHigh, X                     ' measure echo pulse
      X = X */ Scale                              ' convert to uS
      X = X / 2                                   ' remove return trip
      X = X ** RawToIn                            ' convert to inches
      RETURN
    FindEdge:
      ' slowly move forward to the edge
      PULSOUT ServoPal, SpeedF75R
      PAUSE 100
      DO
        GOSUB PulseGripper
        GOSUB ReadAllQTIS
        ' EXIT IF we've crossed the edge
        IF (QTIS > (Calibration + 400)) THEN
          GOSUB Halt
          RETURN
        ENDIF
      LOOP
      RETURN
    ' Get calibration value for the QTIS
    ReadAllQTIS:
      QTIS = 0
      FOR X = 0 TO 3
        GOSUB ReadQTI
        QTIS = QTIS + Duration
      NEXT
      RETURN
    ' Read a single QTI
    ReadQTI:
      HIGH X                      ' Discharge QTI cap
      PAUSE 1                     ' Wait 1 ms
      RCTIME X, 1, Duration       ' Read sensor value
      RETURN
    edited 2014-03-30 15:50
    Nicely done Martin!
    Are you still using the 3M tekk 03440 tape? I could not get it to work consistently on a round surface also.
    I am stalled on my project trying to source a cheap plastic lens that I can drill a hole to fit the laser into. Dollar store has tuned up nothing.
    McMaster may be another place to shop.
    Jim
    edited 2014-03-30 16:53
    Thanks! I'm still using the 3M tape which is not good. I think mylar or that tape from eBay would be better, but I wanted to just get something working with what I had on hand. All the concepts and code will work if I have better tape and a bigger ring.
    I'm not using a lens for the laser as my module has a built-in lens that works fine. I just keep the laser and sensor close together and it seems to work.
    edited 2014-03-30 18:59
    Sweet, Martin! You're making Philo and me proud! http://www.philohome.com/picker/picker.htm
    Not sure about that short range. I get 8-10 feet easy, no lens. Did you try a different laser yet?
    Jim, didn't you get long range with no lens using the goldmine laser?
    edited 2014-03-30 19:23
    Erco, I haven't used a different laser because I'm certain the problem is the 3M tape. With a mirror I get a fifteen foot range, easy peasy, so I just need better reflector tape. This was still a fun project even with the bad reflector tape. Plus the Boe-bot running around with a laser on it is cool.
    I could see many uses for the laser and targets. Cat and mouse robots, or navigation markers all seem possible.
    edited 2014-03-31 12:44
    Yes I got ~15 feet on flat surface with this reflector. But wrapped around a pill bottle, I do not get the same results. Will try a soda can tonight and report back.
    Wish I can find my camera!
    Jim
    edited 2014-08-05 10:47
    Erco, got any more available?
    edited 2014-08-06 13:38
    Sure do, in fact I've also been hoarding ElecGoldmine lasers and retroreflective tape. I'll be offering a package of those together on Ebay soon so people can make their own sensor. I'm debating whether or not to get PCBs made for a complete kit.
    You need some?
    edited 2014-08-06 14:03
    You need some?
    Yea,
    Give me a couple of days.
    I'm changing an alternator, and packing the truck for the Boston Expo.
    I'm in for of 10 these and 10 on the Solarbotics purchase.
    Be back Monday.
    edited 2014-08-06 18:18
    Publison wrote: »
    I'm changing an alternator...
    As Sigmund Freud noted, the alternator must want to change itself.
    OK, your my "ten" guy. No rush, your credit's good, Jim.
    edited 2014-08-06 19:03
    I'm sure you're capable of designing your own board, but if you'd like me to alter the design in post #107, let me know and I can either send you the gerber files or the DipTrace files.
    OSH Park is great for small boards but if your board is going to be the size of a laser, you might want to go with one of the inexpensive fab houses like Itead Studio. I don't recall if you've had custom PCBs made? IMO, it's a lot of fun.
    I think the 0.05" sockets would work well with the senors. I doubt 0.05" headers are hard to fine, but if needed, I'm sure I could find the source I used again.
  • LevLev Posts: 182
    edited 2014-08-09 16:19
    Hi Erco,
    I saw your laser sensors in action today at the Boston Expo on Martin's BoeBot. Do you have any more available? I would be delighted with 10, but happy with any number.
    Rich
    edited 2014-08-09 16:31
    Sure Rich, ten is fine. You want lasers & reflectors too?
    Please PM me for Paypal info. $7 per sensor plus a buck for mailing.
    Nice to hear the Expo is going well and Martin made it. What kind of laser demo did he do?
    edited 2014-08-09 16:51
    Martin did the same demo in Post #137. I gave him a strip of my NAPA DOT reflective tape, and the demo was highly repeatable, much better than the 3M reflector tape.
    I was impressed with his demo in person.
    edited 2014-08-09 19:25
    Publison wrote: »
    Thanks again for the better tape. I'm going to see if I can make a few more targets and video tape another demo on the kitchen floor.
