Propeller GUI touchscreen and full color display - Page 22 — Parallax Forums
11819202224
  • Igor_RastIgor_Rast Posts: 357
    edited 2013-03-20 07:40
    I added the pull ups(10k) to the 8-15 bus , changed enable 3 to enable 1 of the 138. E3-high , E2- Low. E1 - Load . Pulled High by 10k resistor ,
    Droped the code as is inside , but its not working yet.
    Think it got something to do with the latches , not fully understanding whats happening in the latch code you written , still struggeling with it :p
    a latch wasnt set good before in your code that I got ealier , I changed it back but forgot where it was
    latchvalue |= 1011_0000
    latchvalue &= 1011_0101
    why 8 bits , the latch uses 4 . is it data of botch latches at the same time, Or is it the toggle back data , So low is the first 4 , high is the other 4 . Not realy getting it yet :p
    But the leds of the latch 1 show me that . there is more than 1 of the outputs thats low during the data transfer , But if I remember it should only be the LOW 245 , that should be low , the rest high right ??
    at the second latch also , I only see the Display_RS blink low back high ,only once . It should to it more often , or its happening verry quicly that I cant see it , I can see the other leds blinking ( CS. and clock . so
    UPDATE:
    Testing out , first thing I came along
    PUB Main |i
        outa[RD_pin]~~
        outa[WR_pin]~~
        outa[WR_pin]~~
        'outa[LOAD_pin]~~      ' connect load to enable 1 or 2, active low!!
        dira[11..0]~~
        latchALLhigh
        waitcnt(clkfreq*5 + cnt)
       ' Start_SSD1963
        repeat
    latchALLhigh Doesnt set all output off the 2 latches High, So thats problem number 1
    Another question .
    PRI Lcd_Write_Com(adresslong)
        LCD_RS_Low
        LCD_write_bus(adresslong)
        LCD_RS_High
    PRI Lcd_Write_Data(adresslong)
        LCD_CS_Low
    Lcd_Write_Com - RS=LOW . CS=LOW??
    Lcd_Write_Data RS = High ?? CS=Low
    the RS and CS are both on the same 74hc75 meaning , they both are set at the same time ,
    and assuming that PRI LCD_RS_Low and PRI LCD_CS_Low both toggle just 1 pin at the time respectivly RS(Q0) & CS(Q1), the other 3 are turned the opposite of the toggled pin , . ( CS is or with clock , so, at lcd side the cs wil go low when clock goes low )
    they work echother back .
    at Lcd_Write_Com LCD_RS_Low will make CS high , thats not what we needed right ??
    or does the (latchvalue |= %0001_0000) 2 x 4 bits , take care of not touching the state of the other pins when toggled and leaves them like they were set. Still not understanding that part
    I see this is happening at the end of the ini too
    LCD_RS_High
    LCD_CS_High
    maybe the problem ?
    maybe we could just use a new pin to toggle one of them , still got p22 up free . plus 12+13.
    EDIT . AGAIn :p
    PRI Start_SSD1963
        HUB2LCD_ACTIVE
        LCD_Reset_High    'RS + CS also on 74hc75 , are the held high ??? all latch outputs High ?
        pause1ms(5)
        LCD_Reset_Low      'RS + CS also on 74hc75 , are the held high , while only Reset goes LOW ?
        pause1ms(5)
        LCD_Reset_High
        LCD_CS_High       'RS + Reset also on 74hc75 , should we combine the 2 to toggle at the same time ?
        LCD_WR_High           ' WR is another pin so thats no problem
        pause1ms(5)
    If the latching thig was working not disturbing the other pins than it would work out fine , but now the simple way I hade the code before I m not sure which state the pins should be , because the changing effecting the others , think ill have to dig in that latching.
  • average joeaverage joe Posts: 795
    edited 2013-03-20 09:03
    There's probably lots of issues with the code I posted. Not much time but..
    Latchvalue is both latches, latch 1 is least significant nibble.
    the AND / OR of latchvalue is to not disturb other bits. I prefer to keep CS, RS separate. Only enable/disable CS at the beginning and end of transfers. The pin will toggle when D/WR is toggled anyway.
    Like I said, I'm sure there's problems. Should be close though...
    edited 2013-03-20 13:02
    Ok . Im started thinking all those loose wires runnig around on the breadbord is causing it not to work ,
    Ive just use aa new pin for the RS, and LCD reset . ( only cs is stil on the lach , ) count disabled for the momen
    changed the bank selecting to the old working one , but still no action on the display .
    So im gonna dig in the data sheets to look exactly what the ini data is saying ,
    else Im out of clue,s the rest looks to be working fine , but doesnt :p
    :frown:
    eventualy I think i will be breaking up this board to connect the lcd to the prop at the simples possible way , without any other circuit , just to get the INI done , and make sure theres nothing wrong with it , cause im seriously doubting that now
    bye any chance you already made that code ??
    CON
      _clkmode      = xtal1 + pll16x                        ' use crystal x 16
      _xinfreq      = 5_000_000                             ' 5Mhz crystal
      _1ms      = 1_000_000 /     1_000                     ' Divisor for 1 ms
    CON
        load_pin = 8
        clock_pin = 9
        RD_pin = 10
        WR_pin = 11
        Display_RS_PIN = 12
        Display_Reset_PIN = 13
        CS_PIN = 22
        ' Selector
      LATCH1 = 5
      LATCH2 = 6
      'latch 1
      DispRS  = 0
      DispCS  = 1
      DispRST = 2
      'latch 2
      RamCSlow  = 0
      RamCShigh = 1
      Low245    = 2
      High245   = 3
    VAR byte latchvalue             'latch1 {Count, Display_/Reset, Display_/CS, Display_RS  }
                                    'latch2 {/High 245, /Low 245, Ram/CShigh, Ram/CSlow}
    PUB Main |i
      outa[RD_pin]~~
      outa[WR_pin]~~         'exclusive for SRAM WR Pin .. LCD Shares Clock_pin with Counters
      outa[clock_pin]~       '  Clock Counters/LCD CS
      outa[Display_RS_PIN]~~
      outa[Display_Reset_PIN]~
      outa[CS_PIN]~~
      dira[CS_PIN]~~
      dira[13..0]~~
      LCD_CS_Low
      'LCD_CS_High
     ' latchALLhigh
      waitcnt(clkfreq*2 + cnt)
       ' UpperHUB2RAM_ACTIVE
       ' LowerHUB2RAM_ACTIVE
       ' RAM2LCD_ACTIVE
       'HUB2LCD_ACTIVE
        'LCD_CS_High
       ' waitcnt(clkfreq*5 + cnt)
      Start_SSD1963
      repeat
    PUB UpperHUB2RAM_ACTIVE   {set 245L (D0..D7)  LOW }   { needs to be fixed }
    latchvalue |= 0101_0000
    latchvalue &= 0101_1111
    SetLatch(2)
                                    'latch1{CLOCK_EN, Display_/Reset, Display_/CS, Display_RS  }
                                    'latch2 {High 245, Low 245, RamCShigh, RamCSlow}
    PUB LowerHUB2RAM_ACTIVE   {set 245H (D08..D15)  LOW } { needs to be fixed }
    latchvalue |= 1010_0000
    latchvalue &= 1010_1111
    SetLatch(2)
                                    'latch1 {CLOCK_EN, Display_/Reset, Display_/CS, Display_RS  }
    PUB RAM2LCD_ACTIVE   {8Bit Mode}       'probably not needed anymore. HUB2LCD_ACtive replacing it
    latchvalue |= 1100_0000
    latchvalue &= 1100_1101
    SetLatch(2)
    'RD_LOW
    PRI SetLatch(n) ' n is latch 1 or 2, value is new nibble to set
       if n == 1
         SendLatch(latchvalue &$F , Latch1)
       elseif n== 2
         SendLatch(((latchvalue >> 4) &$F), Latch2)
       elseif n==3
    PRI SendLatch(d,s)
        outa[3..0] := d
        outa[6..4] := s
        outa[load_pin]~
        outa[load_pin]~~
    PUB HUB2LCD_ACTIVE   {8Bit Mode}
        Bus4bit (11)
        Selector138 (6)
        outa[load_pin]~
        outa[load_pin]~~
    'latchvalue |= 1011_0000
    'latchvalue &= 1011_0101
    'RD_HIGH
    '----------------------------------------TEMP PUB TILL LATCH FIXED ---------------------------------------
    PUB Selector138 (load_n)
        outa[6..4]:= load_n
    PUB Bus4bit(data)
      outa[3..0] := data
    PUB pause1ms(period) | clkcycles
    '' Pause execution for period (in units of 1 ms).
      clkcycles := ((clkfreq / _1ms * period) - 4296) #> 381     ' Calculate 1 ms time unit
      waitcnt(clkcycles + cnt)                                   ' Wait for designated time
    PRI SetCounter (address)   | i
        repeat i from 4 to 0
          outa[6..4] := i
          outa[load_pin]~
          outa[3..0]:= address >> (4 * i)
          outa[clock_pin]~
          outa[clock_pin]~~
        outa[load_pin]~~
    PRI LatchAllHigh   {Display }
        Bus4bit (15)                     { 1.1.1.1 - High 245, Low 245, RamCShigh, RamCSlow}
        Selector138 (5)
        outa[load_pin]~
        outa[load_pin]~~
        Selector138 (6)
        outa[load_pin]~
        outa[load_pin]~~
        'latchvalue := $FF
        'SetLatch(3)
    PRI LatchAlllow   {Display }
        Bus4bit (0)                     { 1.1.1.1 - High 245, Low 245, RamCShigh, RamCSlow}
        Selector138 (5)
        outa[load_pin]~
        outa[load_pin]~~
    PRI RD_LOW
      outa[RD_pin]~
    PRI RD_High
      outa[RD_pin]~~
    PRI Bus8bit(data)
      outa[7..0] := data
    PRI LCD_RS_High
     ' latchvalue |= %0001_0000
    PRI LCD_RS_Low
      'latchvalue &= %1110_1111
    PRI LCD_CS_High
        outa[CS_PIN]~~
     ' latchvalue |= %0010_0000
     '   Bus4bit (15)    { 1.1.1.1: Notused output, Display_/Reset, Display_/CS, Display_RS  }
     '   Selector138 (5)
     '   outa[load_pin]~
     '   outa[load_pin]~~
    PRI LCD_CS_Low
        outa[CS_PIN]~~
     ' latchvalue &= %1101_1111
     '   Bus4bit (13)    { 1.1.0.1: Notused output, Display_/Reset, Display_/CS, Display_RS  }
     '   Selector138 (5)
     '   outa[load_pin]~
     '   outa[load_pin]~~
    PRI LCD_RESET_High
     ' latchvalue |= %0100_0000
      outa[Display_Reset_PIN]~~
    PRI LCD_RESET_Low
      'latchvalue &= %1011_1111
    PRI LCD_WR_Low
        outa[clock_pin]~
    PRI LCD_WR_High
        outa[clock_pin]~~
        LCD_RS_Low
        LCD_RS_High
        LCD_write_bus(adresslong)                               ' send out the data
    PRI Displaycmd(c,d) ' instruction in one method
        Lcd_Write_Com(c) ' send out a word
        Lcd_Write_Data(d)
    PRI LCD_write_bus(lcdbyte)
        bus8bit(lcdbyte)
        LCD_WR_Low
        pause1ms(5)
        LCD_WR_High
    '' DISPLAY SETTINGS
    DAT
       VDP        long  271
       HDP        long  479
       HT         long  531
       HPS        long  43
       LPS        long  8
       VT         long  288
       VPS        long  12
       FPS        long  4
       HPW        long  10
       VPW        long  10
    PRI Start_SSD1963
        HUB2LCD_ACTIVE
        pause1ms(5)
        pause1ms(5)
        LCD_Reset_High
        LCD_CS_High     ' WR aleady pull it Hi (OR-logic) 'RS + Reset also on 74hc75 , should we combine the 2 to toggle at the same time ?
        pause1ms(5)
        LCD_CS_Low
        Lcd_Write_Com ($E2)       '($00E2)                             ' //PLL multiplier, set PLL clock to 120M
        Lcd_Write_Data($2d)       '($0023)                             ' //N=0x36 for 6.5M, 0x23 for 10M crystal ' $21??
        Lcd_Write_Data($02)       '($0002)                             '
        Lcd_Write_Data($04)       '($0054)                             ' dummy byte?
        Lcd_Write_Com ($E0)       '($00E0)                             ' // PLL enable
        Lcd_Write_Data($01)       '($0001)                             ' set pll             '
        pause1ms(1)                                      '
        Lcd_Write_Com ($E0)       '($00E0)                             ' pll                         '
        Lcd_Write_Data($03)       '($0003)                             ' lock
        pause1ms(5)
        Lcd_Write_Com ($01)       '($0001)                             ' // software reset
        pause1ms(5)
        Lcd_Write_Com ($E6)       '($00E6)                             ' //PLL setting for PCLK, depends on resolution
        Lcd_Write_Data($00)       '($0003)                             '
        Lcd_Write_Data($FF)       '($00ff)                             '
        Lcd_Write_Data($BE)       '($00ff)                             '
        Lcd_Write_Com ($B0)       '($00B0)                              ' //LCD SPECIFICATION
        Lcd_Write_Data($20)       '($0000)                             '
        Lcd_Write_Data($00)       '($0000)                             '
        Lcd_Write_Data($01)      '((HDP>>8)&$00FF)                    ' //Set HDP 'hps??
        Lcd_Write_Data($DF)       '(HDP&$00FF)
        Lcd_Write_Data($01)      '((VDP>>8)&$00FF)                    ' //Set VDP 'vps??
        Lcd_Write_Data($15)       '(VDP&$00FF)
        pause1ms(5)
        Lcd_Write_Com ($B4)                 '($00B4)                             ' //HSYNC
        Lcd_Write_Data($02)       '((HT>>8)&$00FF)                     ' //Set HT
        Lcd_Write_Data($13)            '(HT&$00FF)
        Lcd_Write_Data($00)      '((HPS>>8)&$00FF)                    ' //Set HPS
        Lcd_Write_Data($2B)           '(HPS&$00FF)
        Lcd_Write_Data($0A)                 '(HPW)                               ' //Set HPW
        Lcd_Write_Data($00)      '((LPS>>8)&$00FF)                    ' //Set HPS
        Lcd_Write_Data($08)           '(LPS&$00FF)                         '
        Lcd_Write_Com ($B6)                 '($00B6)                             ' //VSYNC
        Lcd_Write_Data($01)       '((VT>>8)&$00FF)                     ' //Set VT
        Lcd_Write_Data($20)            '(VT&$00FF)
        Lcd_Write_Data($00)      '((VPS>>8)&$00FF)                    ' //Set VPS
        Lcd_Write_Data($0C)           '(VPS&$00FF)
        Lcd_Write_Data($0A)                 '(VPW)                               ' //Set VPW
        Lcd_Write_Data($00)      '((FPS>>8)&$00FF)                    ' //Set FPS
        Lcd_Write_Data($04)           '(FPS&$00FF)                         '
        Lcd_Write_Com ($36)       '($0036)                              ' //rotation
        Lcd_Write_Data($00)       '($0021)                              ' 3 is 180
        Lcd_Write_Com ($F0)       '($00F0)                             ' //pixel data interface
        Lcd_Write_Data($03)       '($0003)                             ' 16 bit / 565
        pause1ms(5)
        Lcd_Write_Com ($29)       '($0029)                              ' //display on
        Lcd_Write_Com ($BE)       '($00BE)                              ' //SET PWM FOR B/L
        Lcd_Write_Data($06)       '
        Lcd_Write_Data($F0)       '
        Lcd_Write_Com ($D0)       '($00d0)                              ' //dynamic backlight
        Lcd_Write_Data($0D)       '($000d)
    '''''''''''''''''''''LCD RESET ---- GPIO0-----------------------------------------------------
       waitcnt(clkfreq /4 + cnt)'  pause1ms(50)
        Lcd_Write_Com ($B8)       '($00B8)                             '
        Lcd_Write_Data($00)       '($0000)                             ' //GPIO3=input, GPIO[2:0]=output
        Lcd_Write_Data($01)       '($00B8)                             '//GPIO0 normal
        Lcd_Write_Com ($BA)       '($0007)                             ' //
        Lcd_Write_Data(00)       '($0001)                             ' //
       waitcnt(clkfreq /4 + cnt)'  pause1ms(5)
        Lcd_Write_Com ($29)
        Lcd_Write_Com ($2C)       '($002c) start image transfer
        'LCD_RS_High               ' LCD_RS_High
        'LCD_CS_High
    All dedicated pins for control , . the R4 resistor from the lcd , is now grounded . to not have it be sensitive to my touching it , j1 , bridged . what about the PWM line , J2? leave it , or does it have to be bridged too ?
    But now I have a completly black screen .And still no Inni
    when the lcd is just powerd On , but theres no code send to it yet , and the resistor removed , meaning dynamic backlight . do you get a black screen with power on the lcd . or is it already lid.
    Any way to check if the controller is still alive ?
    the data in the inni i also figure I better write it in number , because not having a 16bus code ,
    so ((HDP>>8)&$00FF) went to be first $01 theb $DF . should fix that
    edited 2013-03-21 12:51
    Ok using the code below i have exluded as much as possible , pinn to pin to the propeller , and nothing
    So im assuming the LCD got to be broken orso ??
    contacting the suplier to see what he got to say
    Seeing anything wrong in de code, ive copied all the settings from the LCD.c to it correctly I think .
    Running out of options to test . any idea ???
    CON
    CON
        CS_PIN = 10
        WR_pin = 11
        RS_PIN = 12
        REST_PIN = 13
    PUB Main |i
      outa[CS_PIN]~~
      outa[RS_PIN]~~
      outa[REST_PIN]~
      outa[7..0]~~
      dira[CS_PIN]~~
      dira[7..0]~~
      LCD_CS_Low
      Start_SSD1963
      repeat
    PRI Bus8bit(data)
      outa[7..0] := data
    PRI LCD_RS_High
      outa[RS_PIN]~~
    PRI LCD_CS_High
        outa[CS_PIN]~~
    PRI LCD_RESET_High
      outa[REST_PIN]~~
    PRI LCD_WR_High
        outa[WR_PIN]~~
    PRI LCD_RS_Low
      outa[RS_PIN]~
    PRI LCD_CS_Low
        outa[CS_PIN]~
    PRI LCD_RESET_Low
      outa[REST_PIN]~
    PRI LCD_WR_Low
        outa[WR_PIN]~
        LCD_RS_Low
        LCD_RS_High
        Lcd_Write_Data(d)
        bus8bit(lcdbyte)
        LCD_WR_Low
        pause1ms(1)
        LCD_WR_High
    '' DISPLAY SETTINGS
    DAT
       VDP        long  271
       HDP        long  479
       HT         long  531
       HPS        long  43
       LPS        long  8
       VT         long  288
       VPS        long  12
       FPS        long  4
       HPW        long  10
       VPW        long  10
    PRI Start_SSD1963
        pause1ms(10)
        pause1ms(10)
        LCD_Reset_High
        pause1ms(10)
        Lcd_Write_Data($2D)       '($0023)                             ' //N=0x36 for 6.5M, 0x23 for 10M crystal ' $21??
        pause1ms(1)
        pause1ms(5)
        pause1ms(5)
        pause1ms(5)
        pause1ms(5)
         pause1ms(5)
        Lcd_Write_Data($00)       '($0001)                             ' //
        pause1ms(5)
        Lcd_Write_Com ($2C)
        LCD_CS_High
    UPDATE :
    Assuming the SSD1963 is dead. I contacted the supplier . and im getting a new one shiped :p
    So there will be another 2 weeks of doing nothing with it
    edited 2013-04-19 08:32
    Seems like the LCD module wasnt dead after all . Started a new thread on it
    edited 2013-06-21 16:33
    I've been exploring FPGA chips. I bought a range of boards, from simple CPLDs to higher end FPGAs. They all have advantages and disadvantages. I've ended up looking at this one http://www.ebay.com.au/itm/Altera-CycloneII-EP2C5T144-FPGA-Board-Altera-USB-Blaster-JTAG-programmer-/111015813741?pt=LH_DefaultDomain_15&hash=item19d90ee26d and the board alone is cheaper again - about $25.
    The board can be flipped over and plugged into female DIL headers sockets, so you can treat it as a large socketable chip with 112 pins.
    I have schematics working on the screen so you can draw a schematic and turn it into something in the chip within a minute or so. There are two headers on the board for programming - quick volatile programming and slower permanent programming.
    Over on Seed studios they keep changing their prices of PCBs, and right now the sweet spot for price per sq cm seems to be 10x10cm. So I have been working on a hybrid board with a propeller, FPGA and some ram suitable for a touchscreen.
    Some things are not on the board - the regulators and download circuit, and the touchscreen socket. But this can all be plugged together in various ways to do other things too - eg a propeller with heaps of sram via an 8 bit wide bus.
    This is an attempt to use the propeller and fpga to their strengths. The propeller can do SD card access and I2C and SPI, and the fpga can handle the interface to the ram and touchscreen so very few other chips will be needed. Hopefully no other chips!
    1024 x 819 - 138K
    edited 2013-07-02 12:29
    I was wondering if you got the LCD + touchscreen working with the SRAM tru CPLDś
    Had not done anything with it in a wile , was a bit too busy , but still wanted to get things working :P
    edited 2013-07-03 10:31
    I've done some work on synthesizing the support chips into a CPLD. I chose Xlinx -XC2C64-7QG100C. These are 1v6 core and 1v6 or 3v3 interface with 64 I/Os. Digikey @3.05. Also using different SRAM. IS62WV51216BLL-55TLI Digikey @$9.06 These are surface mount so adapters were needed (and the expensive part). I have verified they work, although it's only partially tested. Breadboard required dropping the clock frequency significantly... Hopefully I'll be able to print some boards soon! That should allow me to bring the clock frequency back up. I can share source code if anyone is interested. I've been meaning to release this for a while now, just been busy with moving and my new job!
    914 x 656 - 518K
    1024 x 514 - 83K
    edited 2013-07-03 13:57
    Looks great over there man
    I still have to dig in that hole CPLD programming thing still , but count me in
    Wondering if you are willing to sell me one of the boards , not sure if you already made them , or still need to .
    maybe populated , or i will order the parts myself no problem there ,
    and sure am intrested in the source code , Think now its about the right time for you to start a github , so you can get some nice things going with your work as backbone :P
    Looking forward
    I was wondering , what happend to the second prop ? wasnt it also part of your design
    In my effort to let the hole world run on the propeller over here :p im running short of everything
    an extra prop to take over a few of those tasks would make it a more than fantastic ting
    edited 2013-07-05 17:58
    I still have not printed boards for this design. I have some optimizations I plan on making that I have not had time to implement. I'm hoping to have this done by December but everything is taking longer than expected, so we'll see. I plan on making fully populated boards available when finished. As soon as something is ready, I'll be posting here. Just thought I'd give you guys a sneek-peek!
    edited 2013-07-06 05:06
    Awch . dec is indeed a long time , espesialy if your super busy
    but mind sharing the code you have that works ,
    I already orderd the parts , so I think I will be making my own board over here , need that second prop to :p
    nos sure if thats still possible , but still want to try .
    any help would be greatly apriciated
    edited 2013-07-08 13:43
    Here's the full source code!
    edited 2013-08-11 07:26
    Mind giving a hint in the programs used to open these source files
    Cant find any spin file in them either , or is that only for the xlin ?
    would love to try to get it working some time in the future , I have bought the chips .nou i need to understand it all before I can make the board that works :P
    edited 2013-08-11 20:11
    ISE design tools > Webpack
    Found here:
    http://www.xilinx.com/support/download/index.html/content/xilinx/en/downloadNav/design-tools.html
    You will need to register to gain access but it's free.
    edited 2013-10-20 15:53
    The current design uses two parallel sram chips and five 161 counters to move pixels quickly from ram to the display in order to do things like fast text where fonts are stored as bitmaps.
    I wonder if this can be done another way? I've been looking at the 23LC1024 sram chips. These have a burst mode where once it is all set up, just toggling the clock pin on the chip will send out data. That saves on having counters. The chips also have a quad mode, so you can transfer 4 bits at a time. So for dumping out 16 bits at a time (one pixel is 16 bits), that would be four 23LC1024 chips.
    Moving the data from the propeller into the ram chips needs some way of multiplexing 4 propeller pins, and isolating those pins when the data is being moved from ram to the display. Two 4052 chips (or 74HC4052) should work. There might be other solutions with other chips too.
    Overall, I think this would use a lot less propeller pins, less peripheral chips and a smaller board size.
    Thoughts would be most appreciated!
    edited 2013-10-20 18:30
    This could certainly work. It would be very interesting to see how well this could translate to the FLASH chips I was planning on using. Multiplexing the pins could save a lot of pins, although I assume we would need to dump the draw commands to SRAM first?
  • RinksCustomsRinksCustoms Posts: 531
    edited 2013-10-20 18:51
    considerations to the operating frequencies involved? with the buffers/mux's? nice design.
    Side query if i may - Can you program the LCD to reverse/flip the displayed data as indicated in the datasheet of the SSD1289? I believe it's the Driver Output Control register 0x01h, bits 9,11,14 depending on mounting method. ie- you could use it as a HUD in your car.
    edited 2013-10-20 19:08
    I'm pretty sure there is a command for that. But if not, it is pretty easy to feed data through a cog and change a bitmap into anything you want. We have code to take 24 bit RGB bitmap data and turn it into 16 bit data so flipping could be done too.
    Actually, if we did build something with 4 bit serial sram chips, some preprocessing of images might be needed anyway. eg - to conserve precious propeller pins, have the concept of 'fast' prop pins which are real pins, and 'slow' pins which are on the I2C bus and a MCP23017 or two. So you would logically use fast pins to do things like clock the ram chip, and to clock the /wr pin on the display. But things like changing ram chips, ie the /cs pins could be slow pins. So for dumping data from a bitmap on an SD card out to the ram chips, it might make more sense to send all the data in blocks, first to one ram chip, then do the next one. So maybe you read a few kilobytes of a bitmap into hub ram off the SD card, then have a little bit of pasm code to mask out each nibble and send it out to the ram chips in the most time efficient way.
    The original propeller demo board has 8 pins for VGA, so many of my boards have 8 prop pins devoted to the display, whether it is TV or VGA. So maybe there is a cunning solution that can talk to a touchscreen using just 8 propeller pins (and then some slow I2C pins as needed). Something like 4 pins for data, one for the /wr pin on the touchscreen, one for the sram clock (join all the clocks together), and that is 6 pins so 2 spare for whatever is the most efficient solution. And things like the sram /cs pins, the touchscreen reset pin, the control pins for the 4052 chips and maybe the touchscreen RS pin are all slow pins off the MCP23017. In software, setup is slow, but dumping data is fast, and that is what you want for updating text and for moving sprites around.
    Back of an envelope design and count down from prop pin 31 - 2 pins for programming, 2 for I2C, 2 for audio, 2 for keyboard, 8 for display (combo touchscreen, VGA and TV), 4 for SD card, and 4 to run the finger sensor SPI on the display. That leaves 8 propeller pins free and free propeller pins are always a Good Thing :)
    So the chips would be propeller, eeprom, MCP23017 I2C expander, 4 sram chips, two 4052 chips.
    Need to read the sram chip data sheet more - can you set up a sram chip ready for burst mode, then deselect it by making its /cs pin high, then talk to other chips on the same 4 pins bus to set them all up for burst mode, then select all /cs pins low and start clocking?
    The more I think about this, the more I think we have to give it a try!
    edited 2013-10-20 20:57
    Just wired up a prop to the display, after all data pins were connected, i have ONE free prop pin left lol (not touching the SDA/SCL for EEPROM. I think you guys are on the right track with additional interface IC's). -but then I bet you already came to that conclusion. I'm not aiming to have 30+FPS, 2-8FPS would be sufficient for my project, which is why i'm omitting the SRAMs if i can.
    BTW - where the heck is Prop2? Or how about just a Prop P8X64A? We could really use more than 32 pins -j/k -not really
    edited 2013-10-20 21:20
    I like the idea James. You are on the right path. I wish I had time to work on this!
    FYI, just wired up the slave serial port on the expansion and realized the pins are flipped on the DB-9 connection I ordered. Had to install on the underside of board. Might want to check your library?
    edited 2013-10-20 23:55
    Oops. My bad. Sorry.
    Agree. Conceptually, I like to think of a Prop plus two MCP23017 chips as a P8X64A.
    edited 2013-10-21 00:10
    Dr_Acula wrote: »
    No worries! I just thought I'd let you know to check the library.
    edited 2013-10-21 22:18
    SD card speed improvement idea - has anyone actually tried 4bit bus mode? Obviously on some older cards this mode would be useless, but on the HC,XC, & Ultra spec cards, 4bit bus mode can transfer up to 100+MB/s. Couldn't the prop do this in a bit banged PASM driver even at like 4MB/s on a multi page read?
    I've seen this thread http://forums.parallax.com/showthread.php/129698-SDCARD-in-4-bit-mode
    t
    his one is a good read with coffee http://electronics.stackexchange.com/questions/10675/is-it-possible-to-use-4-pin-mode-for-an-sd-card-with-a-microcontroller-instead-o
    I
    suppose with needing CRC16 the end solution would be something like an FPGA dumping data from an ULTRA I SD card in 4bit mode down a 16bit bus to a bank of SRAMS, then out to the LCD, but I bet the FPS could be significant.
    EDIT: "Belay that Belay!" -Johnny Dep (I just came across this - http://forums.parallax.com/showthread.php/143639-RAID-of-SD-cards)
    edited 2013-10-22 00:38
    Great idea! The reason we haven't looked at this is that the design with parallel sram uses up pretty much all the propeller pins. But with serial sram there are lots of pins free, and faster SD access would be a really cool use for those pins. Hmm - if those ultra spec speeds really are possible, for some applications maybe we don't need the ram chips at all?!
    edited 2013-10-22 13:28
    Was doing a bit more reading on SD specs. It seems that with the U1 class its SD ver 3.0 which says that for the ultra speed cards to be put in 1v8 mode and can then be clocked to over 200MHz. Might it be worth it to get a decent USB SD reader and have the prop integrated with it that way or is this just a silly idea due top the prop being only able to use USB @115200 baud? It would free up a few pins I think but then you have to deal with USB stack overhead I suppose.
    Please forgive me if it seems as if I'm standing on your feet, I'm more just curious than anything. It does seem like you have covered your bases on this subject.
    edited 2013-10-23 03:24
    t
    I
    From what I understand, the problem with using 4bit mode is the CRC16. IIRC the computation would actually reduce throughput, or possibly a SLIGHT performance increase. In my mind, the best way to get around this would be to do CRC16 in CPLD/FPGA. It's trivial to implement in hardware, but software is slow. To start, something like this might be helpful? http://www.ebay.com/itm/like/251289219686?lpid=82
    This is the chip I'm working with currently.
    A side note, I feel bad I have not had time to work on this project lately. I have a schematic and sample layout for my earlier post with the CPLD. Just need to finish routing. Without power supply, the board comes out about the same size as the 3.2" display. It's all surface mount though.
    *Edit. Sorry, I'm actually using the 64, not the 256 (although I do have a 256 on adapter board). The 64 is minimum to replace all the Shift-registers. Both chips are VQFP-100 and have 64 i/o.
    edited 2013-10-23 04:12
    Attached is a schematic idea using the 23LC1024 serial ram chips in quad mode.
    I've designed it using 8 propeller pins as then one can use the same 8 pins to drive a VGA display. P26 and P27 are for a keyboard and for a touchscreen they are not connected but it means one can have a board that could run VGA and Keyboard or you could run a touchscreen, just by installing different components.
    P24-P25 are audio. P16-P23 are display. P12-P15 = SD card. P8-P11 are the touchscreen SPI interface to detect the finger position. P0-P7 are free.
    In the parallel ram design we were multiplexing the finger position SPI interface in and out very quickly. It seemed to work, but this design has dedicated propeller pins.
    Speed - moving bitmaps from SD to Sram is limited by the SD card speed so the sram in serial mode is the same speed (or 4x, given it is a quad interface).
    Dumping data out from the sram to the display is as fast as the propeller can go - toggle clock, toggle the touchscreen /wr line, repeat, and do that in pasm.
    One slightly complicated bit is setting up the display. Would need to move data into the ram chips, then clock once on the clock to output all 16 bits at the same time, then toggle the /wr line on the display. So the setup would involve lots of writes to address zero, then moving the data out.
    I count 8 chips. Four ram chips, two 244 chips and two 374 chips. One could replace the two 374 chips with one 595 chip but the 595 would be slower.
    The board layout is ending up a lot smaller than the parallel solution. There are a lot less traces and so chips can end up closer to each other.
    There are other solutions, including MCP23017 chips on the I2C bus. Or you could use P0-P7 and save some chips, but I am inclined to leave some propeller pins unused and bring them out to a header for any purpose you want (eg using 4 for another serial sram so you can run big C programs).
    One could make a good case for saying that if one is building the touchscreen version, one does not need a real keyboard, so therefore P26 and P27 are not being used, so therefore these two pins are spare too. And thus if there are 10 pins instead of 8 to talk to the touchscreen, that could well save some of the chips. I'll think about that some more.
    edited 2013-10-23 05:17
    That is a VERY nice design! I bet it will still be able to run packman at decent FPS. Most existing code should run with a slightly modified driver!!!
    I like the separate latch chips. You could breakout the remaining 4 pins on each for GPIO use. That gives you 8 propeller pins and 8 GPIO's!!!
    I bet the 4 chip SRAM design routes much better than 2 chip ;)
    edited 2013-10-23 21:49
    had a look at this page while waiting for the Mrs after work in the parking lot of Walmart:
    circuitsathome.com/category/mcu/arduino/usb-shield
    Mind you it's written for arduino, but probably not difficult to implement on something much faster like the Prop since simple ide is here amongst other C IDE's for prop. Particularly the ability to interface to USB mass storage like a TB HDD (high res data logging for months?)
    Sticking to the SD card, how wild is this?
    WiFi SD card?!
    edited 2013-10-27 15:55
    Id wish the same thing :p , came to take a peep
    @ agerage joe , what happend to the CPLD design , did you find it not working out ? , just curious
    I havent had a slightest chance to continue with the touchscreen , i had the lcd it in my hand today when cleaning and thouth let me take a look at the tread ,
    and you guys are like up on it again :p
    damm we have to make this work ,
    I had to stop with my previous attempts cause i was getting all sorts of noise on my growing beadbord design
    and thouth a pcb would be a best thing to go for , but havent had a chance to make one yet ,
    Ive been fixing my toolsets and expect to be having a small etching station at home , so i can experiment with different designs easier ,
    but the time is just not at my side. i did buy all the parts needed to buld a CPLD design with 2 props , and a wiznet , but nothing of a schematic or pcb yet , to be continued :p
    Guys ???
    Cause we all love to do what we are doing here but barly get the time to dive in , shouldednt we kinda setup a design that we all work on
    and cut it up in a few sections orso , cause now we all do something different , and still were trying , Lets go for an opensource design that we all work on .
    we start with some specs that it need to have ,and go from there till an end design ,
    I think kicad to make the schematic / partslist / pcb is the best software, opensource and free for anybody , so we all can open the same/latest files of the project and work from there
    we will have to agree with one design , (maybe one with a slight extro orso) to make it work
    Should include ( i Think )
    * 2 propellers ( or 1 ?)
    * full communication between the 2 propellers
    * LCD
    * Touchscreen
    * CPLD design or counters etc. + SRAM
    * sd card
    * wiznet W5200 ( This is what i want, this thins workings as a server is just awesome)
    Github uploads so we can all agree what design changes are made , or make a fork :p
    should work i guess . what you guys think ?
