Propeller II: Emulation of the P2 on FPGA boards (Prop123-A7/A9, DE0-NANO, DE2-115, etc) - Page 13 — Parallax Forums
1101113151624
    edited 2012-12-09 20:52
  • FredBlaisFredBlais Posts: 370
    edited 2012-12-09 21:54
    No. It takes me a day to get a working compilation for a particular device/board combination. Then, I must maintain it as we move forward. I don't think it's worth doing for an FPGA that is three generations old. I wish you had some new Cyclone V board like this:
    http://www.altera.com/products/devkits/altera/kit-cyclone-v-e.html
    That board would be worth doing the work for, as it might enable 100MHz Prop2 emulation.
    Are you working with Xilinx device too? Any chance to see this ported to a newer Xilinx board? We have a lot of new Xilinx stuff at my University.
    edited 2012-12-09 22:05
    FredBlais wrote: »
    I've never used Xilinx FPGA's. I wonder which FPGA's, Altera or Xilinx, provide the most function for the money. Do you think we could just ask them?
  • LeonLeon Posts: 7,620
    edited 2012-12-10 02:13
    I've used both. I've had one of the Digilent Spartan 3 boards for a few years, and I did quite a lot with the Xilinx CPLDs at one time. The Altera tools seem easier to use, and are a lot faster, but Xilinx seem to be ahead technologically. For the average user, I don't think it really matters.
    edited 2012-12-10 02:53
    I have use a few Xilinx parts in designs over the years. To me they seem to be ahead and cheaper comparing LEs. As for the tools, I have not used Altera so cannot comment. I would expect some learning curve even though they both use verilog and vhdl. I have a Spartan 3A board by Avnet and had on my list to get a Spartan 6LX board with a large LE count.
    However, I would not suggest you change Chip, as I donvt think the time to learn would be worth the trouble.
    edited 2012-12-10 09:06
    I don't have as much experience as Leon but I came to the same conclusion. Xilinx silicon is superior,but their software has grown into a glued together mess compared to Quartus II.
    edited 2012-12-10 09:29
    Yes, the Quartus II software feels as if it was designed as a whole, whereas the Xilinx tools seem to consist of lots of different applications linked together by the IDE.
    I first came across FPGAs when I worked for Racal, and one of the early ones was incorporated in our new range of military radios. It was a Xilinx device, of course, and I think it took over 24 hours to build the programming file. I was playing with Lattice CPLDs at home, at the time, and I used one for the glue logic required for a simple 68008 controller board. It replaced about six TTL chips.
  • SRLMSRLM Posts: 5,045
    edited 2012-12-10 11:28
    When I was doing VHDL work with Xilinx, I edited the files with Gedit (simple text editor), and just keep a very small corner of the Xilinx software open for the compile process. It worked very well.
    edited 2012-12-10 12:12
    My DE0-Nano came today.
    I set it up over lunch, everything went easy peasy which was nice change of pace.
    One thing I did see is I need to epoxy a backer board to the Prop-Plug, it likes to bend when standing up unsupported.
    Now to come up with some things to try out.
    C.W.
  • evanhevanh Posts: 15,222
    edited 2012-12-10 17:41
    ... I've read how certain too-big-to-fail banks have massive low-latency connections to the main trading systems at the NYSE and CME. By intercepting asks and bids, they execute meta-trades within milliseconds that front run trades by regular dolts like us, and probably everyone else. That's how they can make money, no matter what the market does. ...
    That's how some can ... it is, of course, legalised theft. As in speculation (gambling) is a game of who can outwit (fluke it) to grab the biggest lot. Problem with this is it's being applied to third-party savings, and it's usually done with no real consent or even knowledge that it's happening.
    Where I live it's investment brokers and managed funds and the likes that partake in the above activities, not banks. These shady outfits do give some hint that things may not always be a rosy outcome but never let you know it could all vanish in the blink of an eye and certainly don't hand out less than rosy looking graphs. And making enquiries about the market activities just yields "it's all good" with no further help. It all seemed very clubby to me. I got out pretty early on. Though, I suspect some of my saving will be doing the rounds even now.
    Banks and governments simply create the money for real - which is another topic altogether.
    edited 2012-12-11 00:16
    Chip has just posted the latest DE0-Nano code and pnut.exe on this thread. It fixes a RDQUAD problem and adds a new SETQUAZ (set quad and zero the cache/instructions)
    http://forums.parallax.com/showthread.php?144478-LMM2-Propeller-2-LMM-experiments-(50-80-LMM2-MIPS-160MHz)&p=1149263&viewfull=1#post1149263
  • SapiehaSapieha Posts: 2,964
    edited 2012-12-11 01:03
    Hi Chip.
    Can Video circuit be used to send continuous stream of 3-4 DAC's Data instead of Video lines that are separated by H,V synchronization
    edited 2012-12-11 05:43
    I just updated the main.zip file with new DE0_Nano and DE2_115 configurations:
    http://forums.parallax.com/showthread.php?144199-Propeller-II-Emulation-of-the-P2-on-DE0-NANO-amp-DE2-115-FPGA-boards&p=1145603&viewfull=1#post1145603
    Yesterday some some forum members discovered a bug in the RDQUAD circuitry which is now fixed.
    edited 2012-12-11 05:44
    Sapieha wrote: »
    Hi Chip.
    You bet! You control everything.
    edited 2012-12-11 05:54
    Hi Chip
    edited 2012-12-11 13:40
    I hate to be a pain but is there any way the DE0-Nano version could put one or more of the LEDs on Propeller pins so they can be used for debugging? I know you currently use all 8 to indicate which COGs are running but since there is only one COG could one or two be connected to Propeller pins? I guess that would even work on the DE2-115 since it only supports six COGs.
    edited 2012-12-11 15:06
    You could wire up LEDs and resistors on a socket plugged onto the connector, and use P2 outputs.
    edited 2012-12-11 15:10
    Leon wrote: »
    Yeah, but I'm a programmer. I don't know how to wire things! :-)
    edited 2012-12-11 15:13
    My reading of the data sheet says they are limited to 2mA or 4mA depending on the configuration, so current limiting the LED's to 4mA is probably a good idea
    mind you, in the real world I really don't think 5mA would hurt the FPGA, but I won't take that chance with my Nano
    Leon wrote: »
    edited 2012-12-11 19:02
    This is exactly why I requested that one or two of the on-board LEDs be wired to Propeller pins. I was nervous about wiring anything up to the DE0-Nano for fear of frying it.
    edited 2012-12-11 19:13
    Good call :-)
    It is easy to current limit the LED's to 2mA, but a lot of LED's won't light up well enough with that little juice.
    I second your request for re-wiring the LED's to some P2 pins.
    Right now I've mostly been using the monitor (EXTREMELY useful) and a logic analyzer when needed.
    David Betz wrote: »
    edited 2012-12-11 19:28
    Good call :-)
    Actually, the monitor is probably what I should be using but I'm used to thinking of LEDs as the perfect debug aids for microcontroller programming. I need to change my mindset for the P2 I guess! :-)
    edited 2012-12-11 19:40
    Can you remind me of the magic incantation required to invoke the monitor?
    edited 2012-12-11 19:53
    	coginit	monitor_pgm,monitor_ptr	'relaunch cog0 with monitor - thanks Chip!
    monitor_pgm	long	$70C			'monitor program address
    monitor_ptr	long	90<<9 + 91		'monitor parameter (conveys tx/rx pins)
    Hand waving, incense, and magic words optional
    David Betz wrote: »
    edited 2012-12-11 20:01
    Thanks Bill!
    edited 2012-12-11 20:30
    I just tried this and it is *way* better than LEDs!
    edited 2012-12-11 20:37
    You are most welcome!
    And it is WAY better, I agree.
    I write my results out to the hub at $2000 in longs before booting back to the monitor.
  • potatoheadpotatohead Posts: 10,255
    edited 2012-12-11 20:56
    When we all get more cogs, just have your program launch a monitor instance on another set of pins and poke at your program while it is running. I've been doing this and it is damn cool. Just use two Prop Plugs and leave them connected. One is for programming and serial I/O back to the developer, the other is connected to a PUTTY window.
    Later, when I've built up some cog drivers, it will be possible to fire off something with the IDE, once it's running, use the monitor to stop a driver cog, edit it's code or parameters, assuming that code is in HUB, then fire it back up! If the code is written to poll and connect, this is a lot like restarting a service or something. Frankly, it would also be possible to recompile the driver, squirt it into the HUB somewhere, then fire it up, completely replacing a portion of a running program!
    Damn cool, if you ask me.
    edited 2012-12-12 02:21
    Well, I picked $4000 but the idea is the same. It works quite well. In fact, C is limping along on the P2 now. Hope to have more news later today.
    edited 2012-12-12 07:30
    Absolutely the specific location is irrelevant (pun intended) but it is the same idea. As you noted, it works a lot better than LED's!
    Congrats about getting C running!
    I look forward to trying it.
    David Betz wrote: »
