Propeller II: Emulation of the P2 on FPGA boards (Prop123-A7/A9, DE0-NANO, DE2-115, etc) - Page 9 — Parallax Forums
1679111224
    edited 2012-12-05 09:25
    Sapieha wrote: »
    Hi David.
    Up to 3.000.000 at least --- For test possibility's --- Same way PuTTY use it --- no any fast values
    Okay, I'll see what I can do. Thanks for helping to track down the dependency problems!
    edited 2012-12-05 09:26
    4x5n wrote: »
    The ldd command in cygwin should give you a list of the dynamic load libraries an executable needs.
    That works well too. Thanks for the suggestion. Now I have an alternative that doesn't launch a GUI like depends.exe does.
    edited 2012-12-05 09:37
    677 x 342 - 29K
    edited 2012-12-05 09:48
    Thanks!! Let me know if you run into any problems. I have noticed that if I type ^C to get out of the terminal emulator on the Mac, I sometimes get an error. I'll try to track that down later tonight.
    edited 2012-12-05 09:53
    Sapieha wrote: »
    Hi David.
    Now as it function ---> Can You add second line parameter to specify Baud-rate
    While I was waiting for my company IT to resolve my network connectivity problem to my office I added your -b option to select the baud rate. I don't, however, have time to try it. Let me know if it works for you. It uses standard Windows baud rates up to 256K but then lets you enter anything you want. The updated zip file is in message #224.
    edited 2012-12-05 10:01
    David Betz wrote: »
    Ugh... Never mind. There is a bug in the -b option. I'll be back with a fix.
  • SapiehaSapieha Posts: 2,964
    edited 2012-12-05 10:03
    Hi David.
    Look on PIC
    David Betz wrote: »
    Yes, I'll do that later tonight. What baud rates do you want supported?
    729 x 531 - 75K
    edited 2012-12-05 10:04
    David Betz wrote: »
    I'm going to have to fix this later today. I forgot that I need to tell the second-stage loader to use the new baud rate as well. That will require patching the COG image before downloading it. That isn't a big deal but it's more than I can handle in the middle of a work day. Sorry!!
    edited 2012-12-05 10:09
    Hi David.
    No problem --- Thanks
    David Betz wrote: »
    edited 2012-12-05 10:57
    I moved the discussion of p2load to a new topic to avoid flooding this one with any more messages.
  • dMajodMajo Posts: 862
    edited 2012-12-05 11:17
    Hi Chip,
    I am considering the DE2-115.
    In the meantime do you think I can go with mine Cyclone III FPGA Starter Board equipped with the HTG(M) HSMC card? It have more or less the same characteristics of the DE0-NANO (EP3C25: LE 24,624; M9K 66; RamKb 594; 18x18mul 66; PLLs 4; GC nets 20).
    BTW: here you have the HSMC specifications, I haven't verified if the same apply on the DE2-115, but I think so because the HTG(M) daughter-board is the same.
    Regards
    1024 x 768 - 120K
    edited 2012-12-05 11:21
    dMajo wrote: »
    Hi Chip,
    Regards
    I guess you could try loading the DE0-Nano configuration file and see what happens. :-)
    Edit: Maybe that's a bad idea. If your board has outputs where the DE0-Nano expects inputs you might release the magic smoke? I'm not really sure. I guess Chip is the one who will have to answer this.
    edited 2012-12-05 11:25
    Hi dMajo.
    DE0-NANO have Cyclone IV -- Not Cyclone III
    dMajo wrote: »
    Hi Chip,
    Regards
    edited 2012-12-05 13:42
    Hi Chip.
    It is possible that You can add one more directive to PNut.
    ORGHUB XXXXX.
    edited 2012-12-05 13:44
    Sapieha wrote: »
    Hi Chip.
    ORGHUB XXXXX.
    Yes, that would be quite handy!
    edited 2012-12-05 13:56
    Sapieha wrote: »
    Hi Chip.
    ORGHUB XXXXX.
    I thought about that a little more and what would that mean with respect to the output .BIN and .obj files? Would they still start at location zero but have zeros in them up to the lowest ORGHUB address? Or would they start at the lowest ORGHUB address?
    edited 2012-12-05 14:11
    Hi David.
    My thinking was OBJ file --- I use name CODE.HUB --- as OBJ -- are win file type
    BIN file with only 1 COG code I will Chip leave that it is
    > GOOD to made COG blobs for import in other files/Compilers GCC and like as Driver files.
    Fill 0000 between last code and start of ORGHUB xxxxx.
    0E80: some code
    fill with 0000
    ORGHUB xxxxx
    some code
    fill with 0000
    ORGHUB xxxxx
    and so on
    David Betz wrote: »
    edited 2012-12-05 14:17
    Sapieha wrote: »
    Hi David.
    0E80: some code
    fill with 0000
    ORGHUB xxxxx
    some code
    fill with 0000
    ORGHUB xxxxx
    and so on
    In other words, you want the OBJ file to contain a memory image starting at $0 and ending with the last address of code/data to be loaded. Is that right? Since locations $0-$0e7f would overlay the ROM I guess we could make the file start at $0e80 and save some space and load time since writing over the ROM will not accomplish anything.
    edited 2012-12-05 14:22
    Hi David.
    Sorry for misunderstanding.
    BUT First addres to load are 0E80
    0E80: some code
    this place in my explanation
    David Betz wrote: »
    edited 2012-12-05 14:32
    Sapieha wrote: »
    Hi David.
    0E80: some code
    Okay, sorry I misunderstood you. By the way, I got the -b option working but now I think I need to be able to specify separate baud rates for the first-stage loader, the second-stage loader, and the terminal emulator. I found that when I changed the baud rate to 230400, my p2-hello program no longer worked because it has 115200 baud hard-coded into it.
    edited 2012-12-05 14:35
    Hi David.
    Change baud rate in spin file are not big problem --- > If I can specify correct one in loader
    David Betz wrote: »
  • nutsonnutson Posts: 242
    Fun, I have 5 COG's running now, code works both with Dave's loader and with Pnut (probably because the total object size is less than 512 longs)
    DAT
                    org
                    setcog  #1
                    coginit hub1, param
                    setcog  #2
                    coginit hub2, param
                    setcog  #3
                    coginit hub3, param
                    setcog  #4
                    coginit hub4, param
    live            nop
                    nop
                    jmp     #live             'keep COG alive
    hub1            long    $0EC0
    hub2            long    $0EE0
    hub3            long    $0F00
    hub4            long    $0F20
    param           long    0
    DAT
                    org
                    mov     dira,#1         'make P0 an output
    :loop1          mov     count1,#100     'increment the pins 100 times
    :inc1           add     pina,#1
                    djnz    count1,#:inc1
                    reps    #100,#1         'now let's do it faster
                    nop                     '(could do something useful here)
                    add     pina,#1
                    jmp     #:loop1          'repeat (watch P0 on an o'scope)
    count1          res     1
    DAT
                    org
                    mov     dira,#2         'make P1 an output
    :loop2          mov     count2,#100     'increment the pins 100 times
    :inc2           add     pina,#1
                    djnz    count2,#:inc2
                    add     pina,#1
                    jmp     #:loop2          'repeat (watch P0 on an o'scope)
    count2          res     1
    DAT
                    org
                    mov     dira,#4         'make P2 an output
    :loop3          mov     count3,#100     'increment the pins 100 times
    :inc3           add     pina,#1
                    djnz    count3,#:inc3
                    add     pina,#1
                    jmp     #:loop3          'repeat (watch P0 on an o'scope)
    count3          res     1
    DAT
                    org
                    mov     dira,#8         'make P3 an output
    :loop4          mov     count4,#100     'increment the pins 100 times
    :inc4           add     pina,#1
                    djnz    count4,#:inc4
                    add     pina,#1
                    jmp     #:loop4          'repeat (watch P0 on an o'scope)
    count4          res     1
    edited 2012-12-05 14:41
    nutson wrote: »
    DAT
                    org
                    setcog  #1
                    coginit hub1, param
                    setcog  #2
                    coginit hub2, param
                    setcog  #3
                    coginit hub3, param
                    setcog  #4
                    coginit hub4, param
    live            nop
                    nop
    hub1            long    $0EC0
    hub2            long    $0EE0
    hub3            long    $0F00
    hub4            long    $0F20
    param           long    0
    DAT
                    org
    :inc1           add     pina,#1
                    djnz    count1,#:inc1
                    add     pina,#1
    count1          res     1
    DAT
                    org
    :inc2           add     pina,#1
                    djnz    count2,#:inc2
                    add     pina,#1
    count2          res     1
    DAT
                    org
    :inc3           add     pina,#1
                    djnz    count3,#:inc3
                    add     pina,#1
    count3          res     1
    DAT
                    org
    :inc4           add     pina,#1
                    djnz    count4,#:inc4
                    add     pina,#1
    count4          res     1
    Congratulations! You people with the DE2-115 boards have all the fun!
    edited 2012-12-05 14:45
    nutson wrote: »
    DAT
                    org
                    setcog  #1
                    coginit hub1, param
                    setcog  #2
                    coginit hub2, param
                    setcog  #3
                    coginit hub3, param
                    setcog  #4
                    coginit hub4, param
    live            nop
                    nop
    hub1            long    $0e80 + @task1
    hub2            long    $0e80 + @task2
    hub3            long    $0e80 + @task3
    hub4            long    $0e80 + @task4
    param           long    0
    DAT
                    org
    task1           mov     dira,#1         'make P0 an output
    :inc1           add     pina,#1
                    djnz    count1,#:inc1
                    add     pina,#1
    count1          res     1
    DAT
                    org
    task2           mov     dira,#2         'make P1 an output
    :inc2           add     pina,#1
                    djnz    count2,#:inc2
                    add     pina,#1
    count2          res     1
    DAT
                    org
    task3           mov     dira,#4         'make P2 an output
    :inc3           add     pina,#1
                    djnz    count3,#:inc3
                    add     pina,#1
    count3          res     1
    DAT
                    org
    task4           mov     dira,#8         'make P3 an output
    :inc4           add     pina,#1
                    djnz    count4,#:inc4
                    add     pina,#1
    count4          res     1
    Also, you should be able to use labels instead of hard-coded addresses by making changes similar to what I did above.
    Hi David.
    I don't have money to buy that one ---> so no fun for me.
    David Betz wrote: »
    edited 2012-12-05 18:33
    nutson: Congratulations!
    I have not even ordered my DE0-Nano yet! I cannot take the chance of it arriving before I finish some other work - I just know I will get distracted!
  • TubularTubular Posts: 4,774
    edited 2012-12-05 19:39
    I was lucky enough to find a few hours to get a DE0 up and running this morning. It was all very painless (thanks Cluso for the thread and Chip for the photos of pinouts and clear instructions), and big thanks to Parallax for bothering.
    So... I pushed on and now have a very basic SVGA test pattern running (800x600x60Hz, 40MHz pixel clock, 1.5 Altera clocks per pixel). I love this reps instruction.
    I've got to say its all a bit of a throwback to the late 80s for me. We invested in an Altera Aplus system back then, and toured the (relatively small, then) Altera office in Santa Clara. I was also dabbling in 80386 assembler about then. The Altera Aplus software came on floppy disks. I note PNut is about 600kB, and the current Altera programmer wanted almost 1GB of space to install when unpacked.
    The monitor is a really nice, thoughtful idea. Now to order that DE2 from digikey...
    1024 x 768 - 122K
    1024 x 768 - 136K
  • cgraceycgracey Posts: 14,315
    edited 2012-12-05 19:51
    Tubular wrote: »
    At first I couldn't figure out how you got the video running, as it's not documented yet, but then I realized you were bit-banging it! If you've programmed the current Prop's video before, you're going to find Prop2's video circuit much simpler to work with. I need five more of me just to write documentation.
    edited 2012-12-05 20:17
    Yes bit banging is exactly the right way to describe it. But it's getting the job done effortlessly, and I can easily extend the color depth too
    The slow release of instructions actually suits me. A bit like an advent calendar, with a different instruction every day or few days... for a fuller appreciation of what you've implemented
    edited 2012-12-05 20:49
    Hi Tubular.
    Why You don't post code and sch -- so others can experiment and learn from Yours code
    Tubular wrote: »
