ELEV-8 Quadcopter: ordering, design files, assembly and flight!
Introduction to the ELEV-8 Quadcopter
Open-source, Propeller-powered flight that may make your wildest dreams of flight come true!
December 3, 2011: the first posts in this thread is where we will maintain updated information about the ELEV-8. Expect these posts to be populated in the next couple of days! Parallax is now assembling ELEV-8s and we expect the first shipments to go out in one week.Details will be provided here. Until Nick, Kevin and I get the details up all we have is a pretty picture (below, not the guy on the left who appears seven times).
Things the customer should provide before attempting an ELEV-8 build
The following tools are required to build an ELEV-8:
- 1/4" wrench (box-end or socket)
- 11/32 wrench or nut driver
- #1 Phillips screwdriver
- Soldering iron
- Wire strippers (12-16 AWG)
- Wire cutters (12-16 AWG)
- Needle nose pliers
- Heat gun or lighter for melting heat-shrink tubing
- Scissors
- Safety glasses
The following supplies are also required and not included in the kit:- Solder
- Velcro (for securing R/C receiver to chassis)
The following additional hardware is also required and not included in the kit:Download open-source drawings here to assemble ELEV-8 kit or to build your own
Parallax's ELEV-8 design is distributed under Creative Commons 3.0 so you are free to share, change or use these drawings for any use (including commercial) - no approval from Parallax is required. We have provided all of the common formats people may wish to use including the native SolidWorks files. Each drawing format has its own benefits.For simple browsing, download the SolidWorks eDrawings viewer http://www.edrawingsviewer.com/. With this tool you can easily navigate through the various sub-assemblies with the ability to zoom, rotate and modify views. All of the parts may be made with a laser cutter, bandsaw and drill press.
Single-level BOM with usage, supplier part numbers, costs and notes in XLS format
Shown below is an XLS version of the internal Parallax manufacturing BOM for ELEV-8. You may use this BOM to identify replacement parts you wish to order or to assist with your own builds and modifications. Common suppliers are shown (like McMaster) though Parallax may purchase these components elsewhere for cost savings.This BOM includes Parallax cost for raw materials but excludes any labor time, machine fixturing costs and machine run time.
First prototype flight inside Parallax, assembly examples and miscellaneous clips
These are listed in the order in which they were filmed. The most recent videos are at the bottom.
How to put your ELEV-8 together
These are the files that you will use for Assembling your ELEV-8 Quadcopter. You will want to open "ELEV-8 ASSEMBLY GUIDE", and "ELEV-8 ASSEMBLY DOCUMENT" below. They were made to be used together. The Guide is just as it says, a Guide for assembly. It is not step by step directions for assembly, as they are not needed with the amount of information and detail combined between all of the documentation. When you open the .pdf, go to the menu and select VIEW> READ MODE. This will put the doc in order so that the pages will correlate with the step number in the Guide.
The Turnigy ESC Manual had to be split up into two documents due to it's size. You will use the two pages together to program your ESC's using your Transmitter and Receiver, unless you purchased or already have an ESC Programming Card.
Take a look at the docs, and let me know if you have any questions or comments so that I can make any necessary changes before the Kits are available. I dont want a key piece of information to be left out, so take a look and let me know if you have any questions.
-Nick
Reading these links and watching some videos from others will be very helpful
Content to follow.
Paul
Just to say it...other items that should perhaps be on the "user supplied" list?:
Ken called out this motor accessory pack as a good-to-have item
Loctite
Battery strap
Low battery voltage alarm? Or is this overkill?
Anything else I'm forgetting?
We've all been there...nothing more disappointing than getting a new toy, unwrapping it, putting it together...then figuring out that one part is missing or doesn't fit right.
EDIT: just saw post #2 in this thread. Thanks, Ken.
What kind of flight time are you getting?
I agree, an official list like this would be useful - especially if it involves ordering from places that might take longer to deliver. (In fact, I actually logged in to make the same post.)
I'm putting this one on my X-mas wishlist... ;-)
http://gopro.com/products/?gclid=CPas6O_QhK0CFUOo4AodeAvzSQ
Not sure of the model # Ken and Jason are using.
Ken talks about flying with streaming video in the build/project thread:
http://forums.parallax.com/showthread.php?133372-Ken-Cluso99-W9GFO-JasonD-s-QuadCopter-Build-Log-%28updated-info-ELEV-8-availability%29&p=1058736&viewfull=1#post1058736
The new one (HD Hero2) looks like it'll do higher frame & data rates, which would be cool, but isn't really necessary unless you're filming fast action stuff like sports.
It doesn't do cell balancing, which you'll eventually want to do, and would need a separate (but generally inexpensive) unit for. It does charge 4 batteries at a time though, which is awesome. Up to 3A each. I fly pairs of batteries, so this is perfect for me. I'm willing to bet you could find something similar on HobbyKing that also did balancing, but I haven't looked. This one by Hitec does, but it's more expensive: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXAEGM&P=M
Many battery chargers also require a 12V power supply. Some will use standard A/C wall power, but many don't, so check that too. The ones I linked above do not, so you need something like this to go with them: http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWGU7&P=FR
I ordered one of these a couple days ago. I'll report back on quality once I get it and have time to test it.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17200
