Fill the Big Brain - Page 45 — Parallax Forums
Fill the Big Brain
1424345474859
    edited 2011-08-22 19:47
    namochan,
    Welcome to the forum! Sometimes it takes a newcomer to (re)state the obvious! :) But, please, like the rest of us, just sit back and be entertained.
  • Mike GMike G Posts: 2,702
    edited 2011-08-22 20:52
    Welcome namochan, fanfic sums up this thread nicely. Enjoy :)
    edited 2011-08-22 22:00
    :thumb: :thumb:
    Welcome to the forum namochan,
    this is one of thousands of available threads in the parallax forums, Design criteria is all important here,
    what kind of stuff are you into building?
    -Tommy
    edited 2011-08-23 06:49
    Namochan:
    Welcome to the Forum! It's an honor to have your first post in the Big Brain thread.
    You are definitely right about the Borg. ;)
    edited 2011-08-23 07:06
    Big Brain Airport Build
    Part 1 of 3 Parts - Getting Started
    The following is a full step by step summary of how to build a Big Brain Airport for brain owned aircraft projects and robotic aerospace research programs conducted in Micro Space. Refer to other posts for a detailed definition of Micro Space and various programs to be conducted in Micro Space. More on this topic will follow. The Assembly will be divided into three sections, each unique in reaching the final goal, and to facilitate the edit add of a greater volume of material and the add on of numerous assembly illustrating photos.
    This is an automated airport controlled by the Big Brain, now under construction, with Parallax Propeller chips in which various features will be added over time as they are imagined, designed, built, tested and put into use.
    Photo 1 (BUILD1) - the first build photo shows the install of the first airport truss spacer, attached by angle iron. The spacer is a total of 6-inches long. Note the two airport command and control antennae. Clearance above these antennae is set at 1-inch.
    The HYDRA is removed for relocation. It may be reattached to the Propeller Arrays rather than the EXO or become the connection access to a Big Brain Remote Entity. (The Big Brain Remote Entity is currently in the design phase and not posted) The HYDRA may also be dedicated to running the Airport along with other Propeller chip resources.
    __________________________
    NOTE
    You may want to wait until all three parts to the airport build are posted before beginning construction.
    BUILD INSTRUCTIONS PART 1
    STEP 01 Insert the transmitter and receiver into the host board
    STEP 02 Measure the distance from the Vertex Brass Spacer to the antenna top
    STEP 03 Add 1-inch to provide clearance
    STEP 04 Connect three brass 2-inch long spacers and create four sets of 6-inch spacers
    STEP 05 Attach 5/16th angle iron with nuts to each of opposite Vertices on one EXO side
    STEP 06 Position the angle iron as shown in the photo
    STEP 07 Attach the four spacer sets to the angle iron with nuts and tighten
    STEP 08 The truss is now completed
    STEP 09 Position the Transparent Plastic long length left to right
    STEP 10 Position the EXO largest LCD in front
    For reference, this is a view showing the airport clip
    on the right hand side. Note the orientation with
    respect to the EXO. Also note the 7.5-inch length
    of the helicopter has room to spare on the landing
    and take off pad.
    562 x 434 - 109K
    561 x 431 - 119K
    edited 2011-08-23 08:18
    Part 2 of 3 Parts
    This is a Micro Space Airport. The airport adjoins the Big Brain Summit rising a full half foot above the upper-most EXO board. It provides 1-inch clearance for the lower board mounted airport command & control transmitter and receiver antennae. It heightens the EXO to 23 inches.
    Photo 3 (BUILD3) - Airport construction is under way in this photo. The four trusses are completed. You will build these spacer trusses and set a full sheet of transparent green plastic atop all four. At this point, the bolt positions are measured and marked for melting. Note the helicopter has ample space for vertical take off and landing. Sensors may be attached to the perimeter.
    Several features are gained by using Transparent Plastic. Static flight cameras for vertical take off and landing can mount under the airport and image the flight’s landing or take off through the plastic. An experiment will be conducted with the 1st Telescope after the airport is completed to show and film the sequence of a flight mission.
    Photo 2 (BUILD2) - all four trusses are attached with angle iron to four Vertices
    Light sensitive components can mount on the underside of the airport and see through the base and maintain functionality. The base can also act as a mount for other components mounted on the underside. The base can hold a gantry for the launch of other Micro Space Craft. It can also hold electromechanics such as servos. Although just an idea at this time, the airport may robotically transform to host the telescope mounting structure for the 1st Telescope.
    BUILD INSTRUCTIONS PART 2
    STEP 11 Set one full sheet of TP on top of the completed truss
    STEP 12 Measure & mark 1.5-inches from the left of TP
    STEP 13 Measure & mark 2.5-inches from the front
    STEP 14 Proportionally mark the right side of the TP
    STEP 15 Mark the bolt hole positions from the back, in by 2.75-inches
    STEP 16 Mark the remaining bolt proportionally
    STEP 17 Hot solder iron the marked holes
    STEP 18 Remove flashing
    MATERIAL & TOOL LIST
    Needle nose pliers
    Ruler
    Soldering Iron
    Protective Mat
    01 - Sheet 9” x 12” Transparent Plastic
    08 - nuts to fit spacers
    04 - Bolts to fit spacers
    12 - 2-inch length brass spacers
    562 x 433 - 124K
    562 x 434 - 106K
    edited 2011-08-23 08:33
    Part 3 of 3 Parts - the Conclusion
    The Micro Space Airport is a large flat surface (9 x 12-inches) with a span wide enough to launch various helicopters and aerospace vehicles. It handles and hosts the Syma 7.5-inch Micro S107G Helicopter. It’s light weight platform solidly mounts at the top of the Big Brain. It protects all components of the Big Brain and the attached host boards below (from the top down) due to its overlapping nature.
    Photo 4 (BUILD4) - Top down view shows the completed airport with mounting bolts. Note the helicopter has enough space for vertical takeoff and landing. The large pad space serves several purposes, one of which is to provide a large surface resistance to air flow at takeoff and a stable platform so there's no need to hold the craft. This is step inline with the airport automating as many aircraft controls as possible and lessening the degree of human intervention.
    Rules & Regulations
    The aircraft flight zone around and within the vicinity of the Big Brain is restricted to a flying air space at or above the level of the airport, to prevent crashing into the sides of the Big Brain’s EXO.
    Airport Sensor Introduction
    Planning shows that optical devices and various sensors can mount around the perimeter of the airport. Use of an ultrasound PING))) can determine when aircraft take off and land, as well as automatically track their distances and positions during flight. Motion sensors may also be used.
    More Dimensions
    Laterally on each Exo side, there is a 4-inch overlap. To the front and rear - the overall overlap is 2-inches in the front and 2.5-inches in the rear.
    Build Instructions Part 3 - the Conclusion
    STEP 19 Bolt on the TP sheet
    STEP 20 There should be 1-inch antenna clearance to the airport underside
    STEP 21 Minor adjust positions of the landing pad and tighten
    STEP 22 Set aircraft on top. The Airport is now complete
    Notes
    Note the metal clipboard clip is on the bottom right side of the transparent plastic sheet. The clip is used to hold sensors, equipment and routing wires and cables which lead to a lower level.
    This is the completed Big Brain Airport. It does not
    show various sensors that will be installed for more
    autonomous operations or more automatic functions.
    ___________________________
    Routing wires will install using the truss supports and the support offered by the Transparent Plastic's clip. The Airport will hold various sensors. Some sensors will see and detect through TB from underneath while others may locate near the top. The objective is to keep the platform clear of all obstructions for landing aircraft that may be slightly off-center, so some sensors may span out to the sides at the same plane level.
    559 x 407 - 83K
    428 x 558 - 116K
    edited 2011-08-23 08:49
    Big Brain Telescope Software
    for the iPhone
    You'll need an Apple iPhone to run these programs with the Big Brain's 2nd Micro Space Telescope.
    These are found and installed select programs for review and testing (others were deleted) - use with the Big Brain's 2nd Telescope made from the Apple iPhone. Downloads are free at the installed Apple iStore.
    At first glance, programs adjust color, zoom, light and dark, create artificial special effects, manipulate how photos are taken (timed, touched, swiped, etc.), simulate various ISO film, create artificial flash, set image field of view, and other functions. The programs with Zoom are all different. They have various levels of zoom with different resolutions. Over time, these will be reviewed in greater detail.
    452 x 410 - 92K
    529 x 263 - 59K
    edited 2011-08-23 08:55
    Humanoido, you have five posts in a row and the last three within the span of a single hour. I find the edit function helpful for that because it reduces the thread clutter. The downside is that your edits don't update the post time, so your thread won't snap to the top of a sub-forum. But that's not a big deal for posts spaced that closely.
    edited 2011-08-23 09:28
    Big Brain Assimilates Apple iPhone
    The Big Brain has now assimilated the Apple iPhone and for good reason. The list of add on useful functions is very long! Here's some things currently in use that are possible with a tiny iPhone.
    Camera
    Telescope
    Angle
    Theodolite
    V-Cockpit
    Moon Calculator
    Moon Map
    Distant Suns
    SkyORB
    Stars
    Brain Wave Monitor Frequency Calibrator
    Sound Recorder
    LIght Beacon
    Wireless Monitor
    Calculator
    Maps
    Internet Access
    Email
    Photo and Message Sender
    Digital Image Storage Device
    Image Processor
    Phone
    Accelerometer
    Alarm & Timer
    Clock & Calendar
    Paperless Office
    Word Processor
    Numerical Converter
    Sound & Music File Player
    Dictionary
    Sound Processor
    Translator
    Weather
    Beginning List of programs not yet installed
    Programming Languages
    Oscilloscope
    Planetarium
    Panorama Maker
    Voice Recognition
    Music Recognition
    Designer
    Web CAM
    Radio
    Document Scanner
    Bar Code Scanner
    Google Earth
    Books
    Laser
    Etc.
    edited 2011-08-23 09:40
    I think it would take at least five posts to describe and instruct in the building of a Heli-Port onto an Exo-skeleton of that size and nature...
    And what an excellent Heli-Port it is I might add. I think it is a very important addition to the Big Brain,
    as it adds "action and adventure" to something that just crunches numbers and sometime talks to itself... :)
    I know the Big Brain is slated for bigger things, and I do look forward to more innovations and progress.
    Thank you for your time in this Humanoido.
    As an aside, what is meant by "thread clutter"? Also, how important is thread position? I just ask out of curiosity...
    (never mind, those questions might be better in a thread by themselves...)
    -Tommy
    edited 2011-08-23 09:43
    Humanoido wrote:
    The Big Brain has now assimilated the Apple iPhone ...
    By "assimilated", you mean what, exactly? Is there communication between the iPhone and one or more Propeller chips? If so, can you describe the interface for us? What kinds of data are exchanged?
    edited 2011-08-23 10:30
    Phil,
    Obviously, the iPhone has complete integration/assimilation with the right brain via the provided cable and its full support by the iTunes-bellum lobe. Due to issues with the BIG corpus callosum between the left brain and the right brain, at this time, "whole brain" assimilation is limited.
    I'm thinking the "air Brain" (the hellicopter) is limited to manual interfacing for now. Telepathic connections should be available inthe future.
    edited 2011-08-23 16:50
    Humanoido wrote: »
    Oscilloscope
    Planetarium
    Panorama Maker
    Voice Recognition
    Music Recognition
    Designer
    Web CAM
    Radio
    Document Scanner
    Bar Code Scanner
    Google Earth
    Books
    Laser
    Etc.
    My robots are also missing all of these programs. There's just not enough room, even in a BS2E! :)
    edited 2011-08-23 18:33
    Get an iPhone and connect it to your BASIC Stamp - there's plenty of space to run all these programs. If I go to Settings/General/About on this iPhone, I see 65 installed programs filling 6.9 GB with 5.9 GB available. That's more than just program usage - it's everything including many photos, voice & text data, and lots of music too. I think all these new additional programs could be installed.
    With the new OS and folders, this is no longer a limitation: 129 applications (16 apps per page x 9 pages = 144 apps - the 15 stock apps taking up home screen space) does not necessarily = 7 + GB of data. http://forums.macrumors.com/showthread.php?t=567362
    Oscilloscope
    Planetarium
    Panorama Maker
    Voice Recognition
    Music Recognition
    Designer
    Web CAM
    Radio
    Document Scanner
    Bar Code Scanner
    Google Earth
    Books
    Laser
    Etc.
    edited 2011-08-23 18:43
    Actually it's more likely the iPhone could assimilate the entire Big Brain rather than the other way around based on the memory which can store and run programs in two Partitions. It will be interesting to see how this plays out over the next several months.
    Rounding..
    32,000 x 100 = 3,200,000 (a hundred stock Propellers)
    8,000,000,000 (stock iPhone)
    Even if one adds the 32K EEPROM to a 100 Prop array, it's still not enough to equal the iPhone (in memory terms, not in parallel processing power). So combining the iPhone with the Right Brain makes a very powerful combination, and combining the Right Brain with the Left Brain is the right stuff.
    BTW, the iPhone is connected to Propellers through the BWM using sound. Remember when you could hear the data move through modems? This links to frequency signature, records it from the BWM and stores it (reviewed in a post) which is linked from the Props, then feeds the signal to the Right Brain for analysis.
    edited 2011-08-23 18:49
    Humanoido wrote:
    Actually it's more likely the iPhone could assimilate the entire Big Brain rather than the other way around ...
    Given that, is there any longer a point to this thread vis-
    edited 2011-08-23 18:58
    Big Brain Airport Structural Tests
    Three barbell plates were obtained from a weightlifting set to test the structural support capability of the new Airport. Combinations of weigh made with these three plates are .5, .8, 1.3, 1.6 and 2.1 kilograms.
    To initiate the test, plates were set centered on top of the airport pad and the side of the pad was push tested. The time from the initial push to no observed motion was recorded in seconds. If the dampening was less than one second, it was considered negligible.
    At .5 kilo through 1.3 kilo, the transparent plastic platform is very stable. At 1.6 kilo, the Airport is stable though taking on weight significantly more than that the weight of Telescope 1, the helicopter, batteries and sensors combined.
    At 2.1 kilo, the platform was under due stress with the sideways push test and some wobble instability was introduced laterally. It’s determined the maximum structural stability of the airport is in supporting no more than 2.3 kilos.
    The Airport is most satisfactory for supporting the full range of scientific instruments, telescopes, cameras, and various aero Micro Space Craft. It exhibits great stability at .5 kilo and .8 kilo for telescopic mounting.
    At .5 kilo, dampening is at 1 second while .8 kilo is 2 seconds. The dampening of a telescope should not exceed 1 second. The Airport can support a telescope weighing .5 kilo or less with dampening of 1 second or less.
    The Big Brain 1st Telescope weights approximately .1 kilo (currently) which is five times less than the maximum telescope weight allowed.
    With the addition of the weight of the telescope driving Azimuth and Elevation servos, the weight will remain extremely light at about .2 kilo. The Airport will also support Telescope 2 which is slightly lighter than Telescope 1 without adding any lenses. When adding a lens, it is estimated Telescope 2 would weigh about the same as Telescope 1. Both telescope peripherals are suitable for mounting on the Airport.
    (The Meade refracting Telescope 3 is too large and too heavy for the Airport and must set externally to the Big Brain.)
    A large glass lens could increase either 1 or 2 telescope’s weight but again this is of no significance as it remains less than .5 Kg total weight and maintains 1 second or less damping.
    Kilograms Pounds
    .5 * * 1.1
    .8 * * 1.8
    1.3 * 2.9
    1.6 * 3.5
    2.1 * 4.6
    426 x 555 - 82K
    562 x 432 - 73K
    edited 2011-08-24 01:15
    SD Card Added to Big Brain
    1 GB SD & 128K EEPROM memory add on
    This project adds 1 GN memory to the Left Brain (Propeller Side) of the Big Brain project.
    The HYDRA SD Max card also comes equipped with a 128K EEPROM onboard, so driver firmware can be loaded right on the card. http://www.parallax.com/StoreSearchResults/tabid/768/ProductID/505/Default.aspx
    The HYDRA SD Max comes with 1GB SD card pre-formatted FAT16 as well as a complete e-Book (in PDF form) describing how the sample SD card drivers work from the ground up. The manual covers SPI (serial peripheral interface), SD protocol, as well as a complete treatise on DOS FAT16 file systems to get you up and running with SD card media. With this knowledge you will be able to write your own low level drivers or interface your SD cards with the PC. Additionally, a complete SD card driver API is included with source code and examples along with detailed explanations and tutorials in the manual.
    Features:
    • Supports standard SD card media from 64MB to 8GB
    • Design supports IO signals for Write Protect and Insertion Detect
    • Design supports SPI, single wire and parallel SD modes
    • Built in 128K on board EEPROM. Allows firmware to be loaded onto EEPROM rather than HYDRA main board
    • 80+ page tutorial e-book on SPI, SD protocol, FAT16 and the complete development of the API and driver
    http://www.xgamestation.com/view_product.php?id=44
    http://www.xgamestation.com/products/hydra_sdmax/hsdmax_prod_image_01.jpg
    The HYDRA SD Max Storage Card (HYDRA SD MAX) completes the HYDRA system expanding the capabilities of the HYDRA to read and write SD cards via the HYDRA expansion port. The HYDRA SD Max card also comes equiped with a 128K EEPROM onboard, so driver firmware can be loaded right on the card.
    The HYDRA SD Max comes with 1GB SD card pre-formatted FAT16 as well as a complete eBook (in PDF form) describing how the sample SD card drivers work from the ground up. The manual covers SPI (serial peripherial interface), SD protocal, as well as a complete treatise on DOS FAT16 file systems to get you up and running with SD card media. With this knowledge you will be able to write your own low level drivers or interface your SD cards with the PC. Additionally, a complete SD card driver API is included with source code and examples along with detailed explanations and tutorials in the manual.
    The HYDRA SD Max has the following features:
    Supports Standard SD card media from 64MB to 8GB.
    Design supports IO signals for Write Protect, and Insertion Detect.
    Design supports SPI, single wire and parallel SD modes.
    Built in 128K EEPROM on board, so firmware can be loaded onto EEPROM rather than HYDRA main board.
    80+ page tutorial eBook on SPI, SD protocal, FAT16, and the complete development of the API and driver.
    edited 2011-08-24 02:08
    Index Update to Page 67
    The Big Brain Index now includes pages 1 through 67 inclusive, updated through post 1,341.
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain&p=977025&viewfull=1#post977025
    1239 Updates to the Online Index
    1240 New Big Brain Dictionary1241
    Page 63
    1241 First Proceedings of the Propeller Big Brain Anniversary Celebration
    1242 Ttailspin, brain conversation
    1243 Machines Teaching Machines - Left Brain Converses with Right Brain - Brain Machines Talk Together - Machines Learn from Each Other - Machine to Machine AI Intelligence Language Conversation
    1244 Phil Pilgrim
    1245 erco
    1246 publison
    1247 Phil
    1248 NikosG
    1249 Dave Hein
    1250 Humanoido
    1251 Humanoido
    1252 Big Brain Presentation Development
    1253 Humanoido
    1254 BIG Brain in the News, Project of the Month at Dangerous Prototypes
    1255 Historical Brain Wave Machine in 1935
    1256 BIG Brain Assimilates a Parallax Propeller HYDRA
    Another Propeller is added to the collective
    1257 prof_braino, arm, sensor input about environment
    1258 erco, arm
    1259 Sensors & Airport Pad for Aerial Swarming
    1260 Arm, Brain Stub, Basic Stub
    Page 64
    1261 Right Brain Goes Multi-Lingual
    Talk with Right Brain in Four Languages
    1262 Big Brain's BWM and the Brain Wave Machine of 1936
    1263 The Real Father of Neuroscience - Please step forward
    1264 ElectricAye, Pure Robotic Conversation
    1265 Pure Robotic Conversation
    1266 Humans Take the Turing Test - Is it machine or human?
    1267 The Ultimate List of AI Conversational Programs
    Over 7,000 AI bots ready to chat with you!
    1268 128K EEPROM Added to Big Brain
    1269 Phil
    1270 Publison
    1271 Duane Degn, Blade mSR RTF helicopter
    1272 Ratronic, blade mcx2 helicopter
    1273 Humanoido, Blade mCX BNF by BLADE
    1274 Humanoido, Blade mSR RTF by BLADE
    1275 Extreme 512K SRAM Added to Big Brain
    1276 Hacking the Brain & Brain Bots
    1277 Prof_Braino, bug brains book chibots
    1278 Ratronic, helicopter payload weight
    1279 Circadian Rhythm Clock
    1280 Humanoido
    Page 65
    1281 Duane Degn, helicopter
    1282 erco, spinster helical, camera for helicopter
    1283 ratronic, helicopter
    1284 RonP CX2 its larger than a mCX but could handle a small camera helicopter
    1285 Eyecam 2.4GHz Color Micro Wireless Video Camera NTSC
    1286 RonP mCX or mCX2 helicopter
    1287 ratronic helicopter
    1288 Duane Degn mcx helicopter
    1289 RonP weight of mCX and mCX2 helicopter
    1290 ratronic helicopter differences
    1291 Humanoido
    1292 Helicopter Camera & Orientation
    1293 Duane Degn heicopter camera mCX2 mCX pan & tilt
    1294 Reducing Breadboard Capacitance in High Speed Propeller Circuits
    Hack your Overclocked Brain Breadboards
    1295 Humanoido
    1296 ratronic helicopter application
    1297 Big Brain AIRPORT Becoming a Reality
    1298 Humanoido
    1299 Ttailspin
    1300 Humanoido
    Page 66
    1301 Big Brain Airport - Flying the S107G - Part 1 Introduction - a precursor to Propeller control
    1302 Apple iPhone joins Big Brain's Propeller BWM
    Use iphone to generate notes as calibration waveforms
    1303 Big Brain Airport - First Mission
    Airport Peripheral Begins to Take Shape
    1304 Big Brain Airport - Budget Control
    1305 Big Brain Begins Micro Space Program - Introducing Micro Space
    1306 Humanoido
    1307 Humanoido
    1308 Humanoido
    1309 Phil
    1310 Big Brain Robotic Space Telescope - Propellers Slated for Telescope Interface - Moon Photo
    1311 Second Big Brain Robotic Telescope - Telescopes as Propeller peripheral devices
    1312 Right Brain Left Brain Experiment
    1313 Big Brain's First Telescope
    1314 iPhone Digital Telescope for the Big Brain
    1315 First Telescope Image from Big Brain's 1st Camera, Moon
    1316 Mike G
    1317 Propeller PIR Motion Sensor for Flight Recorder
    1318 Big Brain Automated Telescope Control
    1319 Big Brain Telescope Mount Design
    Creating a Propeller Altazimuth Big Brain
    1320 Telescope Control Panel Defined
    Both BASIC Stamp & Propeller compete for the position
    Page 67
    1321 namochan
    1322 Phil
    1323 Mike G
    1324 Ttailspin
    1325 Humanoido
    1326 Big Brain Airport Build - Part 1 of 3 Parts - Getting Started
    1327 Big Brain Airport Build - Part 2 of 3 Parts
    1328 Big Brain Airport Build - Part 3 of 3 Parts - the Conclusion
    1329 Big Brain Telescope Software for the iPhone
    1330 Martin_H
    1331 Big Brain Assimilates Apple iPhone
    1332 Ttailspin
    1333 Phil
    1334 Mindrobots left right brain air brain telepathic
    1335 erco
    1336 Humanoido, iphone
    1337 Humanoido, iphone compare
    1338 Phil
    1339 Big Brain Airport Structural Tests
    1340 SD Card Added to Big Brain - 1 GB SD & 128K EEPROM memory add on
    1341 Index Update to Page 67
    1342
    edited 2011-08-24 02:37
    Ganzfweld Phenomena Tricks the Brain
    Can Sensory Deprivation Delude the Machine Brain?
    How will sensor deprivation affect the Big Brain and other machine brains? Being deprived of sensor input can lead to misjudgment and lack of ability in machines. It can limit and curtail functionality and end up in systems that do less, loss of judgement, and potentially gross manifestations.
    A sensor laden machine can lead to one that is feature rich in ability. Is there a machine deprivation? Yes. Is there a Ganzfweld Phenomena in machine brains? It can happen. Will the machine brain invent and fabricate to compensate for sensory deprivation? It's likely to happen. A machine brain algorithm could expand severely limited existing data by extrapolating between insufficient data points with an outcome of borderline delusion.
    At first this might sound like a bad practical joke. Begin by tuning a radio to a station playing static. Then lie down on a couch and tape a pair of halved ping pong ballsover your eyes. Within minutes you should begin to experience a bizzare set of sensory distortions.
    Some people see horses prancing in the clouds or hear the voice of a dead relative. It turns out that the mind is addicted to sensation so that when there’s little to sense (that’s the purpose of ping pong balls and static) your brain ends up inventing its own...
    http://dbem.ws/ganzfeld.html
    "The ganzfeld procedure is a mild sensory isolation technique that was first introduced into experimental psychology during the 1930s and subsequently adapted by parapsychologists to test for the existence of psi--anomalous processes of information or energy transfer such as telepathy or other forms of extrasensory perception that are currently unexplained in terms of known physical or biological mechanisms. Parapsychologists developed the ganzfeld procedure, in part, because they had become dissatisfied the card-guessing methods for testing ESP pioneered by J. B. Rhine at Duke University in the 1930s. In particular, they believed that the repetitive forced-choice procedure in which a participant repeatedly attempts to select the correct "target" symbol from a set of fixed-alternatives failed to capture the circumstances that characterize reported instances of psi in everyday life."
    edited 2011-08-24 07:04
    We all can use Google to find the info and links you've posted in this thread. What we really want to see posted are your own experiences: photos, videos, schematics, and source code for your projects -- not someone else's.
    No offense Phil, but speak for yourself. The internet is too big and life is too short for me to hunt down everything interesting on my own. It's fun to see what Humanoido posts, regardless of whether who did it.
    Does it hurt anyone that Humanoido documents his research in this thread? Does it affect anything in any way? I realize that it might affect you as a moderator, if you have to read every post; can you leave it to someone else?
    edited 2011-08-24 09:20
    prof_braino,
    First of all, I'm not a moderator; my cat Browser is, and he uses his mod authority sparingly -- mainly because he can't read. :) Second, you don't need to worry about offending me.
    Anyway, you're probably right, and maybe I should just leave well enough alone, although I'm not sure I can. To me, the subtext of all this "research" is more of a smokescreen for a lack of substantial work on the titled project than anything that will move the project forward. We're all guilty of avoidance behavior from time to time, but this thread seems to celebrate it. If it were completely harmless, I'd ignore it. But the danger I see is that a newcomer might happen by and, without a critical read, think that the things talked about in the context of a Propeller "brain" have actually been accomplished and, from that, form a misleading opinion about its capabilities. I've been hoping that my occasional jabs would prod the chef to provide more meat and less bun. It doesn't seem to be working.
    edited 2011-08-24 11:03
    Humanoido wrote: »
    Believe me, I will be the LAST guy on the iPhone bandwagon. I'm counter-trend. Whatever there's an APP for, I run in the opposite direction.
    God forbid Parallax comes up with an iPhone app to wirelessly program a Basic Stamp; that's the last you see/hear of me! I'll retreat to a cave with my old vacuum-tube based Heathkit CW gear and morse-code away my golden years.
    edited 2011-08-24 11:59
    I love how this candle burns so brightly from both ends...
    One end burns with future progress, and the other end burns with protecting the progress that is...
    This thread is an incredible study in humans interfacing with new ideas,
    It was a hoot to read from the lets build robots forum, The reactions range from
    "Grogg not understand Big Brain, want smash Big Brain" to "Hey, I get what you are trying to do, can I help"
    and nearly every reaction in between. What an amazing study all by itself...
    I would not worry to much about a newcomer not catching on quickly,
    Because "critical read" is exactly what is required to absorb nearly 1500 posts,
    And not even Browser can stop someone from starting in the middle of the candle, and that very someone expecting results.
    My advice to the newcomer is to start at the start... :nerd:
    And in case you are a newcomer starting in the middle. This is a work in progress,
    and much of the content is from contributions from many good folks around here.
    Feel free to contribute, one way or the other...
    I believe much of the pursuit of this thread is in "Multi-Core" operations and how they can be implemented whether real or imagined.
    Whether or not an iphone gets connected is still to be determined, and the bulk of that task most likely being done by others.
    It bothers some folks that this very thing has not already been done, And the flame of future progress burns brightly...
    We did get a weight bench/Heli-Port,(you are a brave man humanoido.)
    And that is much beef for to fill a bun... for now... :)
    -Tommy
    P.S. erco, I can picture the crossed plywood swords you use to guard the entrance... :)
    edited 2011-08-24 13:23
    Humanoido wrote: »
    Could you share that APP with us? I can't seem to find it.
    edited 2011-08-25 06:31
    After one year and 1347 posts, I could not fully reproduce anything discussed in this thread.
    Community, is there a quantifiable point where it is appropriate to request proof of Big Brain functionality?
    edited 2011-08-25 10:18
    Phil: Thank you for your critique. Different people seem to have different needs and interests. My projects and the way I share them seem to be interesting to some people, but unsatisfying to others. Sorry.
    edited 2011-08-25 11:02
    @Mike G,
    As a member of this community, you are always entitled to ask for further information on performance of a project. That's how people find out whether a particular project is useful for them. Some projects are very well documented to where they can be easily and reliably duplicated. Some projects have very well defined goals and do a good job of essentially teaching how to reach those goals. Some projects have pretty pictures. Some projects have great descriptions. Some projects don't seem to have any of these things. You have to decide what you need, spend time with the project descriptions and other threads that help and inspire you, and pass over the ones that don't.
    edited 2011-08-25 11:07
    Point taken. Thanks Mike Green.
This discussion has been closed.
