PropTouch Propeller Platform Handheld Kit — Parallax Forums
jazzedjazzed Posts: 11,803
edited 2011-04-22 10:22 in Propeller 1
I've been working on this design for a while and am getting ready to shoot boards.
The design uses a Propeller Platform short board for the micro. It is designed for a specific Propeller board, but could easily accept any Propeller Platform short board with a compatible assembly. I may create boards which would include other micros at some point.
Shown is a package with LCD (262K colors and separate Graphics RAM) in a modified Bud Industries HB3430 enclosure. Depending on interest I will pay to have BUD industries modify the enclosure for a finished look.
The LCD could be replaced with some other Propeller Platform module: that is, you don't have to have an LCD, it could be another board. The LCD with touch-screen is available from Mouser/Digikey. There are other LCDs which could be used with a special Propeller Platform module.
The motherboard has components listed in the Enclosure Stackup as well as footprints for 2 quad-SPI Flash chips (fast access and non-volatile storage). I expect that the Flash chips could be programmed with code or data taken from the SD card and 262K color mode on LCD. Catalina, PropellerJVM, or other language such as XBASIC (when ready) that can fetch/execute code from external memory would benefit from speedup provided by this temporary storage. An optional SRAM module can be used with 65K color mode on the LCD (number of colors available depends on the number of propeller pins in use).
The motherboard has a switch that lets you select USB or AA battery power. A jumper on the motherboard will allow using power provided by a Propeller Platform board if necessary.
There is room for a small 4 button membrane switch below the LCD.
I'm hoping to have kits for this and SpinSocket32 modules available for UPEW.
If you are interested in this project, please comment. If there is no interest, it will go on the shelf.
I'll have a prototype to show at UPEW, but it would also be useful to know how many kits i should make. The assembled boards will be fairly cheap as is the enclosure - I have some Propeller Platform boards that fit in the stackup and they will be available for you to add your hardware.
Stackup:
Motherboard module shows outline of enclosure and expansion modules:
Optional Flash/EEPROM module 1.2" x 0.8"
Optional IO Expander module 1.2" x 1.3". Also a compatible connector for cables is available.
Optional SRAM/Flash/EEPROM module 1.2" x 1.7":
Here is a picture of the cable connector shell for expansion ports. I may be able to squeeze a Flash cartridge into one ... we'll see.
Also attached but not shown in line is picture of a 1.2" x 1.3" SRAM module.
    edited 2011-04-11 10:59
    Looks really good - nice work.
    edited 2011-04-11 11:03
    Awesome work!
    My hat is off to you for using an existing design (The Propeller Platform Board) and incorporating it into your work! This earns you ***** stars from this direction!
    Would you mind doing a detailed submission to Propellerpowered.com?
    OBC
  • jazzedjazzed Posts: 11,803
    edited 2011-04-11 11:21
    Thanks guys.
    @OBC. I see a submit a new project page on PropellerPowered.com. Can I edit the entry if necessary?
  • nohabnohab Posts: 96
    edited 2011-04-11 11:43
    If it could be possible to squeze in a XBee board as well, I would be more than interested!!
    edited 2011-04-11 12:03
    Jazzed,
    'Looks like an elegant design: well-conceived and nicely executed! Congrats!
    edited 2011-04-11 12:47
    nohab wrote: »
    I'm not sure. The problem is the number of free pins. The LCD does have an SPI interface which would free pins for xbee or other add-ons, so I might be able to make an optional configuration with that, but it won't be very fast.
    Jazzed,
    Thanks Phil. Wish me luck finishing this before UPEW.
  • Nick McClickNick McClick Posts: 1,003
    edited 2011-04-11 14:57
    I'd definitely get one, looks very, very cool! Nice enclosure and it's not too large.
    edited 2011-04-11 16:50
    I'm totally in for one. Very nice work.
    edited 2011-04-11 16:52
    Fantastic. You sure packed lot of goodies into it. I'd be interested :)
    edited 2011-04-11 17:08
    I've changed the motherboard design so that the LCD can be optionally driven by a SPI interface via jumper headers. This allows up to 19 free cartridge pins (with SPI LCD but not headphones and flash). With all standard motherboard design features enabled using LCD SPI, 7 pins would still be available.
    So, to recap the operational modes and Cartridge "cart" pin availability, you can have:
    1. Motherboard only with SD card (no LCD, headphones, on-board Flash): 24 free cart pins.
    2. Motherboard with SD card and SPI LCD (no headphones or on-board Flash): 19 free cart pins.
    3. Motherboard only with SD card and on-board Flash (no LCD or headphones): 14 free cart pins.
    4. Motherboard only with SD card, on-board Flash, headphone connected, (no LCD): 13 free cart pins.
    5. Motherboard with all features and SPI (slow) 262K color LCD: 7 free cart pins.
    6. Motherboard with all features and Parallel 262K color LCD: no free cart pins.
    7. Motherboard with all features and Parallel 65K color LCD: no free cart pins, up to 256KB fast SPI SRAM.
    The optional onboard flash is 2MB fast access byte wide quad-SPI similar to SpinSocket-Flash and Rayman's FlashPoint. I forgot to mention the LCD has it's own Graphics RAM, so Propeller HUB RAM is available for your application.
    One of the configurations above should allow a cart with X-bee or some other interfaces.
    If I had room for a gyro and an accelerometer on the motherboard I would include it.
    As it stands now, a gyro/accelerometer cart is a good expansion candidate.
    1024 x 580 - 66K
    edited 2011-04-11 18:04
    jazzed wrote: »
    [*]Motherboard with SD card and SPI LCD (no headphones or on-board Flash): 19 free cart pins.
    This rocks! I'd be interested in a #2
    I won't be at UPEW, but I am planning on UPEC
    Any ballpark on price?
    edited 2011-04-11 18:35
    Oooooo..I like, I like :-)
    Would be pretty in other colors too.
    I keep scouring ebay for cheap LCDs in cases the right
    size to be useful for uC projects... I found some small
    picture viewers but they were just too tiny to fit much inside.
    Plus none had touch screens.
    edited 2011-04-11 18:39
    @prof_braino, Prices not set yet. I'll set prices after I've fully tested the 7 configuration possibilities.
    @Holly, try this in the attachment. It's the Varitronix 1.72" SPI LCD with touch screen in an HB3641 case, I plan to make a Propeller PCB for this too (separate power or Lipo battery/charger). A pair would make nice set of "digital eyes" for robot expressions.
    1024 x 989 - 63K
    edited 2011-04-11 18:52
    jazzed, that one looks great also.
    I see what you mean about the eyes thing.
    That would work very well.
    I bet if we just knew the right people in China to talk to we
    could get large runs of something like this at a bargain price.
    I have been building up a list of salesmen and tech people
    in China for 2 years now and it is starting to pay off. I get
    at least one email a week with some kind of great offer.
    edited 2011-04-12 00:41
    Nice work Steve. Congratulations.
  • schillschill Posts: 741
    edited 2011-04-12 05:26
    Looks nice. I won't be at UPEW (I thought I'd make it but I can't) but I will be at UPEC and UPENE. Any chance the prototype will make it to UPEC? Or maybe it will be available by then :) .
    edited 2011-04-12 11:56
    schill wrote: »
    Hopefully kits will be ready by UPEC. I'm shooting for having several demo units ready by UPEW.
    Thanks to everyone for all the input and kind words. Several boards are on order and I should have the motherboard for testing within a week.
  • David BetzDavid Betz Posts: 14,526
    edited 2011-04-12 12:37
    Very nice but can I get my PropTouch engraved with a personalized message on the back? :-)
  • edited 2011-04-12 14:08
    Put me on the list, please. I will take one of the first batch if possible.
    rocketbrand at gmail dot com
    I think Walter the Robot just got his new control panel and I got a new palm pilot.
  • edited 2011-04-12 15:17
    Well, maybe I take that back...
    So all I did was go to Bud Industries and browse their enclosures... Well, then I had to do the usual round of mouser and sparkfun and 4D systems and look at LCD's. Here it is 4 hours later, I have 20 sketches on napkins, 13 (potential) parts lists and you have officially created a monster. I think I might just have to make one of these bad boys myself! Small joystick, x-bee, bluetooth. Tax return is coming in... Kari wants an iPad... Leaves me an opening to order parts...
    I GOTTA START DESIGNING SOME PCBS!!
    Yup, you have officially created a monster... Such a cool idea and project. Maybe we should all make our own version and have some kinda show and tell later!
    edited 2011-04-12 15:55
    Small joystick ....
    I have one of these I thought might work with the tiny enclosure and 1.72" LCD shown below:
    http://www.mouser.com/Search/ProductDetail.aspx?R=254TA103B50Avirtualkey67110000virtualkey774-254TA103B50A
    The one I got is pretty stiff. The version with the longer actuator is probably better.
    I have to say that I've bought many enclosures looking for the right thing on this project.
    Finding the right LCD/enclosure combo is difficult.
  • MacTuxLinMacTuxLin Posts: 821
    edited 2011-04-13 01:49
    Hey, very cool device Jazzed!! How much is it?
    jazzed wrote: »
    Hmm...nice.
  • jaegjaeg Posts: 156
    edited 2011-04-14 13:28
    This is nice! I tried making something similar once but this looks much better
    edited 2011-04-14 16:58
    jaeg wrote: »
    Thanks. I should have motherboards tomorrow afternoon for testing. Most of the parts are already here in my office.
  • RavenkallenRavenkallen Posts: 1,057
    edited 2011-04-15 20:16
    Whoa.... That does look cool. You never cease to put out these amazing things. Great job:)... I just wish i had more money:(
    edited 2011-04-16 10:52
    Whoa.... That does look cool. ...
    Thanks @Ravenkallen.
    Here's a status update for anyone following along.
    Got 2 motherboard prototypes yesterday. There are no show stoppers so far.
    The power sections are working so far and I can program a Propeller on either USB or battery power.
    USB powered VDD is 3.37V with about 20mVpp ripple (small load).
    2AA powered VDD is 3.36V with about 8mVpp ripple (small load).
    LCD backlight voltage is about 19VDC with similar ripple (no load yet).
    I really like the fact that my power switch behaves like a on/off switch when only one type of power is connected. It is also a power source select when both USB and battery are connected. Since the power switch does have an intermediate unconnected state, it also behaves like a reset button :)
    The Propeller Platform board-to-board connector system works but I'll probably change the footprint to require the dual-entry female plugs rather than allowing for the through-hole connectors for manufacturability. It's possible that this is a better stacking solution all around since it would allow boards to have only the the female plugs and be stacked like pancakes with any interboard clearance on un-soldered long male headers - the number of boards stacked depends on how long are the male headers.
    I'm impressed with the Hirose ST series connector solution. I'm certain that small dongle cartridges can be made now that I have samples of the cable shell. My footprint on the motherboard works, but needs a little tuning to ensure easy placement. This connector solution is not as cheap as some others, but it allows full access to 32 propeller pins with a spare for LCD parallel bus configuration .
    There are some dirty laundry items like small mechanical alignment issues and a few schematic errors, so a respin is required.
    More to come ...
    --Steve
    edited 2011-04-16 17:59
    Discovered some cheap cases on eBay for protecting iPhone and Nokkia etc phones. These could be useful.
    edited 2011-04-17 11:57
    This looks really cool. I like the fact that you have found a case that fits it. If the price is in my budget, I may just get one.
    edited 2011-04-18 15:59
    The case needs some modifications for the LCD and other parts. The motherboard provides mounting for the Propeller Platform boards and provides other features. The only Propeller Platform perfect fit for now is Parallax kit, but it has limits. No enclosure will ever give 100% flexibility.
    Quick update.
    I got the LCD lit up yesterday and have been doing some preliminary battery life testing with the LCD back-light on. The back-light is by far the highest current consumer in the "system" so if that's not usable, nothing is. Based on *current* results it appears the project remains viable.
    Fortunately, my back-light circuit is connected to the LCD PWM output which is configurable. The PWM can be set to suck the most energy of course but that's not recommended at all :) Nine PWM settings give usable LCD back-light results from dim to bright (my maximum $F0).
    (All this data is with the LCD active. That is: the LCD is not in standby/sleep mode. On standby, the LCD is practically not connected.)
    With my maximum LCD PWM setting I have been running on 2 fresh Duracell AA batteries for the last 6+ hours and there is still lots of power left relatively speaking. I'll do similar testing with 2 rechargable NiMH AA batteries later.
    It should be noted that the power supply/other components pass the "teenager test" - that is, no high pitch squeals are detected :)
    653 x 503 - 12K
    434 x 517 - 17K
    edited 2011-04-19 09:31
    Good news!
    The 2AA batteries lasted 12 hours with the LCD backlight turned continuously on to "maximum" brightness.
    Obviously the LCD backlight will not be on continuously on battery power and standby modes take very little energy. A battery monitor is included on the board, so power management could make 2 AA's last a very long time.
    Next up: get some pictures on that LCD.
