Fill the Big Brain - Page 13 — Parallax Forums
Fill the Big Brain
1101113151659
    edited 2011-03-10 00:16
    cde wrote: »
    I imagine this would depend on the kind of data processing the AI would need to do. A quick guess could be done using fixed point, and a more precise, but slower calculation could involve the floating point module you mentioned. One aspect of AI you might also want to look into is competition, that is to have a pool competing programs in a Propeller with a "judge" somehow rewarding the most correct/efficient program based on an evaluator relevant to the task -- a bit like Tierra/Avida.
    cde, I can understand that, since the Propeller has the best of both worlds, we can access either FP or INT depending on the task required. On the topic of AI, there are several things that would be fantastic to accomplish. I call this my wishful thinking list.
    Wishful Thinking:
    • converse with the Brain behind a closed door and not know if it was human or machine
    • create a life form that is self aware
    • the Brain is inquisitive about the world and has the ability to learn
    • the Brain has the ability to solve new problems
  • cdecde Posts: 37
    edited 2011-03-10 10:56
    Humanoido wrote: »
    [*] the Brain has the ability to solve new problems
    Humanoido, please forgive me as the following may sound dismissive of your work -- it is merely constructive criticism.
    To achieve the goal above you need to implement some kind of evolutionary software -- right now it appears to me your brain is a collection of fixed functions, in the same way the Linux kernel is a collection of drivers and other stuff.
    For example, you implement dreaming, although it might be completely unnecessary for AI. Humans evolved to the point where we are now thanks to competitive/cooperative evolution (coevolution), and I believe you'll have to implement a similar setup. Now having a collection of real robots interacting is costly and slow, this is why I suggested simulated evolution.
    edited 2011-03-11 07:08
    cde wrote: »
    Humanoido, please forgive me as the following may sound dismissive of your work -- it is merely constructive criticism. To achieve the goal above you need to implement some kind of evolutionary software -- right now it appears to me your brain is a collection of fixed functions, in the same way the Linux kernel is a collection of drivers and other stuff.
    cde, this is a valid point and you are correct - right now the big push is to get everything tested and working, not as a whole, but as individual sections. We must learn to crawl before we can walk, and walk before we can run. So what I've done so far is create many boards that can do two main things, 1) run as testing channels and 2) test the main BUS for sending and receiving data. In the final step, software will be more integrated and we will strive to achieve the six objectives of machine intelligence:
    1. self aware
    2. no difference between machine or human conversation
    3. inquisitive
    4. It has the ability to learn
    5. can solve new problems
    6. creative artistic, abstract thinking
    cde wrote: »
    Dreaming could of course be totally unnecessary for AI. It's just something that I wanted to do and I think it's really cool to have an intelligent machine do dreaming.
    Simulations are great and as you mentioned, can cost less with software substituting for the hardware. But generally the simulations are not 100% like the hardware, and I would not want to miss out on the fun and education of designing and putting together all the hardware.
    edited 2011-03-11 07:40
    cde wrote: »
    ...quick guess could be done using fixed point, and a more precise, but slower calculation could involve the floating point module ....
    Float is LESS precise due to rounding errors (when it is assumed that all the psooible digits are MEANINGFUL rather than determining when they become meaningless); fixed point when properly scaled to the needs of the application tend to be one or two orders of magnitude more precise.
    http://en.wikipedia.org/wiki/Floating_point#Accuracy_problems
    http://www.eetimes.com/design/signal-processing-dsp/4017010/Fixed-vs-floating-point-a-surprisingly-hard-choice
    edited 2011-03-11 08:32
    prof_braino, this is a point I had not considered before. Thanks for pointing this out. I found this supporting link which is very interesting.
    http://www.lahey.com/float.htm
    The Perils of Floating Point
    Binary Floating-Point
    Inexactness
    Insignificant Digits
    Crazy Conversions
    Too Many Digits
    Too Much Precision
    Programming with the Perils
    Floating-point arithmetic on digital computers is inherently inexact. The 24 bits (including the hidden bit) of mantissa in a 32-bit floating-point number represent approximately 7 significant decimal digits. Unlike the real number system, which is continuous, a floating-point system has gaps between each number. If a number is not exactly representable, then it must be approximated by one of the nearest representable values.
    Whether integer or floating point, it just shows that there's a use, a time and a place for either or both systems, provided the programmer is well aware of the caveats.
    edited 2011-03-11 08:44
    Six Objectives of Machine Intelligence
    1. Self aware
    2. Problem Solving
    3. Learning
    4. Converse
    5. Inquisitive
    6. Creative
    edited 2011-03-11 08:57
    Humanoido wrote: »
    You may want to consider this statement further. I heard someplace that dreaming is the "information digestion". I don't have the link off hand, but I recall a study that found if humans are not allowed to dream, they get cranky and psycotic. Something about projecting the model from all the participants perspectives.
    edited 2011-03-11 09:04
    Humanoido wrote: »
    ..this supporting link... http://www.lahey.com/float.htm ... ...
    Yes, that's one of the links I was trying to site. The other one was about calculating interest at a major bank; over the course of a year (somthing like billions or trillions of dollars), the fixed point calculation had an error of hundreds of thousands of dolloars, while the floating poing calculation had an error of tens of millions. While both accepable errors, the bank of course wanted the more precise.
    edited 2011-03-11 22:08
    prof_braino, this is a good point that deserves greater in depth response - in psychology class we covered the benefits of dreaming and how dreams are necessary for humans to maintain a balance physically, emotionally, and mentally when awake. So we know dreaming is very important to humans.
    I should probably clarify my response which was too short and too summarized which held the notion that for simple applications with a rudimentary AI, the dreaming would not be necessary. On the other hand, I would like to prove that it is.
    As I see it, AI is divided into two areas, fundamentally simple and more advanced. Simple could involve carrying on a conversation with a human, where the psychology benefits of dreaming may not appear necessary. Yet, we know, the nuances and details of carrying on a conversation with an intelligent life form would, or could, reflect models of psychology. This model demands the psychology of well being, thus necessitating dreaming.
    The advanced AI version would involve more psychology and require dreaming. Either way, simple AI or not, work is already progressing on the dream equation at the first level - the 1st discovery information was also posted.
    A number of web sites extol the benefits of dreaming. Reading these sources will provide new information. Did you know there is a device to help you know you are dreaming so that you can guide yourself while in the dream?
    Personally, I have long known that dreaming can help solve problems. Often times when faced with a tough analysis problem, I can review everything known before sleep and during the night, a dream will happen to give me the solution. This is why I always have paper and pencil at the bed side stand, for jotting down the solution when waking up.
    Will these same benefits be available to an artificial life form? Contemporary thought is yes because in any advanced life form with the elements of forward thinking, creativity, self awareness, and problem solving, the psychology of well being will be involved and this necessitates dreaming.
    edited 2011-03-11 22:32
    Prof_braino, I had heard about that and it may have had some discussion in Computer Math class and given as an assignment. This was also made into a popular concept by one American movie some years ago. In the fiction story, a hacker accessed all the world banks to collect the "odd fractional cent" that was leftover in all the accounts from the floating point calculations. When this compounded, he became a millionaire and then a billionaire! Maybe there was some truth into the basis of the movie relative to a real life situation.
    edited 2011-03-11 22:37
    The Benefits of Dreaming
    The commonality of advanced life forms
    http://www.world-of-lucid-dreaming.com/benefits-of-lucid-dreaming.html
    Improve Your Problem Solving Skills
    Improve Your Creativity
    Face Your Fears
    Improve Your Confidence
    Practice New Skills
    Explore Alternate Realities
    Final Thoughts
    Benefits of dreaming
    http://mythwell.com/en/articles/dream.html
    There are several key benefits of working with dreams: creative problem solving, health improvements and increased peace of mind.
    All benefits have in common that dreams have access to personal information usually not available to the conscious mind. To give a few examples: dreams may show that you're concerned about certain work related challenges even before you start feeling the stress yourself. Dreams can quite literally warn you that you're close to catching a flu because your immune system is running low. With a little luck a dream will even show how to avoid the problem. If you watch your dreams you will notice that you sometimes rehearse situations in your dreams. Such a situation could be an important speech, a new sport, a piano recital, etc. The beauty of it is that when you get more accustomed with your dreamlife, you will also be able to take better advantage of the creative potential of dreams by trying to have dreams that help solve your problems. Weird as this may sound, there are dozens of famous examples of scientific breakthroughts based on dreams. Also much music, poetry and other art originated in dreams. Your dreams can also function as a reliable mirror for yourself, showing your strong and your weak points. By listening to your dreams you will raise your self-knowlegde and in time this will lead to simply being more at ease with yourself.
    6 Ways to Reap the Health Benefits of Dreams
    http://www.care2.com/greenliving/6-ways-to-reap-the-health-benefits-of-dreams.html
    Experts claim that our brains’ midnight shenanigans can give us insight to help heal emotional trauma and stress, improve our sleep, increase happiness and even help figure out problems in our lives. New studies suggest that dreams are part of a healthy emotional coping process–the thoughts that happen when we sleep combine recent events, hidden memories, hopes, and fears into a new mix, forging neural connections that might be impossible to attain while awake.
    Along with basic emotional housekeeping, dreaming can help alleviate depression. In sleep studies of recently divorced women with untreated clinical depression, scientists found that patients who recalled dreams and incorporated the ex-spouse or relationship into their dreams scored better on tests of mood in the morning. And they were much more likely to recover from depression than others who either did not dream about the marriage or could not recall their dreams.
    According to a report at MSNBC, recent brain scan studies show that regions active during dreaming are the same ones responsible for processing memories and emotions when we’re awake. Dreams, the new thinking goes, shape your self-image by helping you work through unresolved emotions from waking life. (For this reason, even unpleasant nightmares can be beneficial.) In fact, for a day or two after a significant life event—and again about a week later—hints of it show up in your dreams, according to a study at Canada’s University of Alberta. “Revisiting events in dreams helps reshape your understanding of them,” says study author Don Kuiken, PhD.
    edited 2011-03-11 22:38
    Six Points of Dreaming
    Paving the way towards AI dreaming
    6 points of dreaming
    http://www.dreammoods.com/dreaminformation/recallingdreams.htm
    1. Your dreaming mind has access to vital information that is not readily available to you when you are awake. Your dreams serve as a window to your subconscious and reveal your secret desires and feelings.
    2. In remembering your dreams, you gain increased knowledge, self-awareness and self-healing. Dreams are an extension of how you perceive yourself. They may be a source of inspiration, wisdom, joy, imagination and overall improved psychological health.
    3. Learning to recall your dreams help you become a more assertive, confident and stronger person. By remembering your dreams, you are expressing and confronting your feelings.
    4. Dreams help guide you through difficult decisions, relationship issues, health concerns, career questions or any life struggle you may be experiencing.
    5. Remembering your dreams help you come to terms with stressful aspects of your lives.
    6. You will learn more about yourself, your aspirations, and your desires through your dreams.
    edited 2011-03-11 22:51
    279 x 244 - 34K
    edited 2011-03-11 23:17
    Multiple Life Permeation
    Fitting life in multiple cogs
    Anyone want to try this? The first step is to run the life 1-cog version in the same chip and then modify it with connections to more cogs.
    http://forums.parallax.com/showthread.php?125194-Call-for-Tiny-Objects-%28Plez!%29-to-go-in-a-Massive-Prop-Computing-Machine
    Heater wrote: I think the game of Life is a perfect idea ...
    It is:
    1. Small and simple for running in COGs.
    2. Could probably run many Life cells in each COG.
    3. Requires decent communication between all those COGs and Props as a two dimensional grid.
    4. Easy to display the results on a video Prop somewhere
    Additional Source
    http://en.wikipedia.org/wiki/Conway%27s_Game_of_Life
    http://forums.parallax.com/showthread.php?124495-Fill-the-Big-Brain/page17
    Dennis Ferron comments on implementing Cellular Automatrons on Multiple Cogs:
    http://forums.parallax.com/showthrea...-sand-in-realt ..this particular algorithm is easy to run in parallel because each "cell" only looks at the cells very close to it, so you can run multiple cogs on it as long as they are more than 4 or 5 pixels away from each other as they work.
    So each cog works from bottom to top, line by line, and it's ok as long as all the cogs move from bottom to top at the same speed and maintain some separation between them. Problems ensue if a cog gets bogged down and a cog "below" it catches up to the line it's on. The thing with dividing the screen into buckets is that it's difficult to handle the edge cases where two buckets touch, and if you ignore the boundaries and just let cogs move sand in and out of each other's buckets, then there is still the possibility that another cog will be writing sand into your bucket area while you are trying to put a grain in the same spot.
    So instead of buckets I thought I'd just have all the cogs scan the whole screen, but dynamically insert waits after each line so that the cogs all remain exactly 1/6 of the screen away from each other as they scan. If one cog is getting a little bogged down (happens if there is a lot of sand) the others would all have to slow down too, to maintain an equal distance.
    There are still caveats with that; for instance a hole at the bottom of a sand dune can only "bubble up" to the top as fast as the scan speed of a single cog doing the sim no matter how many other cogs are used. Having more cogs doesn't make holes bubble up any faster, but it allows more holes to bubble up at once.
    edited 2011-03-14 01:23
    Brain Monolith Discovery Emergence
    The Matrix Monolith emerges from within
    CONTACT!
    We've explored the algorithm to create Life and molded the Brain into a potentially powerful platform of multiple propellers and peripherals. We've explored and added software, and stretched the "never traveled before" pathways into mind bending dream worlds and a new Universe.
    But what exactly lurks inside the deepest realm of the Brain? Does it contain pure machine circuits and silicon derived electrons and no more, or is there a machine intelligence that can be pulled from within, even provoked into existence?
    You may have fascination and pure shock & puzzlement when observing the slowly emerging Brain Monolith from a place deep with the Brain's inner Cog. Like an inner sanctum of a chromatic spacial realm waiting to unfold, this is a mind blowing Propeller variant of the Contact Demo, established with the tools of Spin and PASM by Virand.
    Emergence of the Brain Monolith is made possible by a real time
    Matrix based on the contact pattern XAX-2313, embedded within the
    Brain.
    Set up and fully functional, this
    operating iBrain is seen loaded
    and running a level one Matrix in
    one Brain channel. This is not a
    static screen, i.e. it moves and
    scrolls in real time as variations
    of multitudes of components
    appear!
    The demonstration of the Brain's emerging monolith is one of fascination. You need to see it in real time to appreciate the uniqueness of what can exist inside the Brain, and see it unfold in real time! The code to make this happen generates data, in the words of the programmer, "Ex Nihilo," using magic math, in full color dimensional rendering. Wizard Virand masterminded the code for the HYDRA while guru Jeff (OBC) converted the code to the Parallax Demo Board platform. The Demo Board code easily ports to PPPBs. Follow the active links to download both versions.
    As the colorful monolith emerges, an unlimited number of inner circuits from within scroll past, emerging, and ebbing. Like the tidal flow (in the beginning..) of a new world, this remarkable machine Matrix unfolds. What we see is the basis Contact Pattern "XAX-2313."
    Program: 1,198 Longs
    Variable: 243 Longs
    "The Matrix Monolith is capable of extruding millions of of previously unforeseeable matrix components in a muti-processor system."
    Discovery Thread
    http://forums.parallax.com/showthread.php?100033-Miscellaneous-Demo%28s%29/page2
    Downloads
    spin.gifaVA_MatrixCircuit_001.spin For the Parallax Demo Board
    http://forums.parallax.com/attachment.php?attachmentid=55170&d=1218965916
    spin.gifaVA_MatrixCircuit_001.spin For the HYDRA
    Requires tv.spin and graphics.spin objects
    457 x 542 - 79K
    216 x 507 - 22K
    edited 2011-03-14 05:56
    Brain Dreaming from 2D to 3D
    New ELICA LOGO opens up a new realm
    Adding 3D to dimensional LOGO Brain Dreaming is an idea conjured up by Ralphw who appears to not only have experience in the field of LOGO programming but is well researched with LOGO derivative languages.
    Planets circle a giant sun, with a backdrop of stars. Note the planet immediately to the left of the big sun, undergoing occultation at the solar limb. Dreams have no boundaries or limits -
    you can travel the solar system, exit the galaxy, discover new words and life! All these
    worlds are yours with 3D LOGO ELICA. This cosmic phenomena was created with ELICA,
    a LOGO derivative language. The latest ELICA results include 3D motion.
    ____________________________
    Constellation of stars
    http://www.elica.net/site/museum/Constellations.jpg
    Shinkansen Gravity Well
    http://www.elica.net/site/museum/Math%20Shinkansen.jpg
    Global Planetary XRAY
    http://www.elica.net/site/museum/X-Ray%20Plane.jpg
    This hot breaking news comes from Ralphw, who cites the virtues of great programming opportunities with a new type of LOGO programming language. "It's possible, but I would probably start with Elica, which is a LOGO-inspired language which supports 3-d graphics inherently." Ralph notes the 3D scene generation has a long history in computer science, particularly the AI circles, starting with the "Blocks Wolrd."
    While 3D Elica does not run INSIDE the Propeller chip, it can do the next best thing - run under control of a Propeller chip. The idea is to load up ELICA on a tiny PC Netbook and control it with the Propeller Brain. The Propeller can pass parameters to the Netbook and ELICA can replicate the intended results. The two can share resources including the large color screen and RAM, plus the ATOM processor.
    [FONT=Arial,Helvetica]In addition to the flat triangular turtle Elica provides entirely Logo-defined space and spherical turtles, as well as a rich 3D graphics library.[/FONT] [FONT=Arial,Helvetica]Mathematical visualization of curves, surfaces and solids is flexible as users are not bound to predefined sets.[/FONT] [FONT=Arial,Helvetica]This facilitates a deeper understanding the basic principles of geometry, design, programming and logic.
    Here's a programming example to make a 3D pyramid in color.
    run "graphix
    screen [720x400 [rgb 200 200 255]]
    make "steps 10
    make "size 5
    make "time 0
    make "piramidSize 8
    make "ballRepetitions 300
    make "ballVertical :piramidSize - 1
    make "ballHorizontal 0
    make "colers list 230 99 10
    to changeColor
        make (word "c_l :ballVertical "_p :ballHorizontal ".color) rgb random :colers random :colers random :colers
        regenerateimage (word "c_l :ballVertical "_p :ballHorizontal)
    end
    make "angleStep 180 / :steps
    make "circleRadius ((sqrt 2)*(:size/2))
    to move :sx :sy :sz :currAngle
        make "b1 :ball.center
        make "b2 vector :b1.x+:sx*:size :b1.y+:sy*:size :b1.z+:sz*:size
        make "circleStartX :b1.x + :sx*:sz*:circleRadius + :sx*:size/2
        make "circleStartY :b1.y + :sy*:sz*:circleRadius + :sy*:size/2
        make "circleStartZ :b1.z + :sz*:sz*:circleRadius + :sz*:size/2
        repeat :steps[
            make "xTemp :circleStartX + :sx*:sx*(1 + (cos :currAngle))*:circleRadius
            make "yTemp :circleStartY + :sy*:sy*(1 + (cos :currAngle))*:circleRadius
            make "zTemp :circleStartZ - (1 - (sin :currAngle))*:circleRadius
            make "currAngle :currAngle - (:sx+:sy)*:angleStep
            make "ball.center vector :xTemp :yTemp :zTemp
            regenerateimage "ball
            make "time :time+1/2
            lookat vector cos 45+30*sin :time sin 45+30*sin :time 0.3+0.1*sin :time/2 vector 0 0 -0.5 vector 0 0 1 1 200
        make "ball.center :b2
        make "ballVertical :ballVertical - :sx - :sy
        make "ballHorizontal :ballHorizontal + :sy
        changeColor
    end
    to moveRightDown
        move    0 1 -1    135
    end
    to moveRightUp
        move    -1 0 1    -45
    end
    to moveLeftDown
        move    1 0 -1    135
    end
    to moveLeftUp
        move 0 -1 1    -45
    end
    make "currLevel 0
    make "currCube 0
    make "pict0 texture "'\sample0.jpg'
    repeat :piramidSize [
        repeat (:piramidSize - :currLevel)[
            make (word "c_l :currLevel "_p :currCube) custom (cube     vector ((:piramidSize - 1 - :currLevel - :currCube)*:size)  (:currCube*:size) (0+:currLevel * :size) :size) (set
                "mode 2
                "texture :pict0
                "texture.scale 10
                "light "true
                "hollow "false
                "color (rgb 255 255 255 50)
            make "currCube :currCube + 1
        make "currLevel :currLevel + 1
        make "currCube 0
    make "ball custom sphere vector (0.5*:size) (0.5*:size) (:piramidSize *:size + 1) 2 (set "mode 2 "light "true "color rgb 80 80 80 "shininess 10)
    repeat :ballRepetitions  [
        make "maxRight :piramidSize - 1 - :ballVertical
        if :ballVertical = piramidSize - 1 [make "mVertical 1]
            [if :ballVertical = 0 [make "mVertical 2]
                [make "mVertical random [1 2]]]
        if :mVertical = 2 [
            if :ballHorizontal = 0 [make "mHorizontal 1]
                [if :ballHorizontal = :maxRight [make "mHorizontal 2]
                    [make "mHorizontal random [1 2]]
        ][make "mHorizontal  random [1 2]]
        if :mVertical = 1 [
            if :mHorizontal = 1[moveRightDown][moveLeftDown]
            if :mHorizontal = 1[moveRightUp][moveLeftUp]
    [/FONT]
    Discovery Link
    http://www.elica.net/site/about/about.html
    Download ELICA
    http://www.elica.net/site/..%5Cdownload%5C5.6%5CElica56Setup.zip
    574 x 507 - 18K
    edited 2011-03-16 03:40
    Propeller Brain Neural Design Moves Forward
    The building of neurons
    Intro to building Neurons and Neural Nets in the Propeller iBrain
    This is a simple working
    neural net created with
    BrainBox
    Modeling neurons from the human brain can be a daunting task. New breakthroughs
    in Propeller technology elevate the possible level of the numbers of neurons in the
    giant electrical iBrain.
    _____________________________________________________
    Neuron Modeling
    Work is progressing at the early stages in working with a neural programming model that can run wide-band (or channel) in a multi-propeller system.
    Cog Permeability
    In the progressing software modeling, the neurons are simulated by numerous divisional neuronic spin code segments. This has Cog permeability.
    Distribution Injection
    There is a means by which the Neurons can be injected across Propellers and this has entered a test phasing.
    Neural Allotment
    The model for each neuron is given a finite size. Everything the neuron must do in the iBrain must fit into this constraint.
    Flowing in Numbers
    We already addressed the creation of an artificial electrical Synapse, which is the assist medium for the flow of an actuated neuron response.
    Test Density
    Experimental test densities of neurons have reached the 21,000 level.
    Neuron Expansion
    It's important to think in terms of expanding the number of neurons. Resources are now purchased to elevated the neuron density to over 100,000.
    Comparative Density with Human Brain
    Consider that the human brain has 100 billion neurons and one can see the concern for pumping up density of machine neurons.
    Expanding Neural Densities
    While this is just the birth of an idea, it is possible to algorithmically define a neural extension for multiplicity. This is a future field to explore.
    The Progression of Work
    I have written a white paper and while the subject matter is being published, the project will continue to phase develop the algorithm.
    Associative Background
    The brain and spinal cord are made up of many cells, including neurons and glial cells.
    Neurons
    Neurons are cells that send and receive electro-chemical signals to and from the brain and nervous system. There are about 100 billion neurons in the brain. There are many more glial cells; they provide support functions for the neurons, and are far more numerous than neurons
    Types of Neurons
    There are many types of neurons. They vary in size from 4 microns (.004 mm) to 100 microns (.1 mm) in diameter. Their length varies from a fraction of an inch to several feet
    Neuron Function & Speed
    Neurons are nerve cells that transmit nerve signals to and from the brain at up to 200 mph. The neuron consists of a cell body (or soma) with branching dendrites (signal receivers) and a projection called an axon, which conduct the nerve signal.
    Synapse
    The Synapse is the gap between the axon terminal and the receiving cell. A typical neuron has about 1,000 to 10,000 synapses (that is, it communicates with 1,000-10,000 other neurons, muscle cells, glands, etc.).
    Axon
    The axon is a long extension of a nerve cell that takes information away from the cell body.
    Nerves
    Bundles of axons are known as nerves or within the CNS (central nervous system), as nerve tracts or pathways.
    Axon Inter-relationships
    At the other end of the axon, the axon terminals transmit the electro-chemical signal across a synapse. The word "neuron" was coined by the German scientist Heinrich Wilhelm Gottfried von Waldeyer-Hartz in 1891.
    Dendrites
    Dendrites bring information to the cell body. Dendrites branch from the cell body and receive messages.
    Myelin
    Myelin coats and insulates the axon (except for periodic breaks called nodes of Ranvier), increasing transmission speed along the axon. Myelin is manufactured by Schwann's cells, and consists of 70-80% lipids (fat) and 20-30% protein.
    SOMA
    The cell body is named soma and contains the neuron's nucleus, with DNA and typical nuclear organelles.
    Programming
    Here is simple pseudo code for an artificial neuron Threshold Logic Unit TLU. It works with true or false Boolean input and expunges a single Boolean output when triggered.
    [B]class[/B] TLU [B]defined as:[/B]
      [B]data member[/B] threshold [B]:[/B] number
      [B]data member[/B] weights [B]: list of[/B] numbers [B]of size[/B] X
      [B]function member[/B] fire( inputs [B]: list of[/B] booleans [B]of size[/B] X ) [B]:[/B] boolean [B]defined as:[/B]
       [B]variable[/B] T [B]:[/B] number
       T [B]←[/B] 0
       [B]for each[/B] i [B]in[/B] 1 [B]to[/B] X [B]:[/B]
        [B]if[/B] inputs(i) [B]is[/B] true [B]:[/B]
         T [B]←[/B] T + weights(i)
        [B]end if[/B]
       [B]end for each[/B]
       [B]if[/B] T > threshold [B]:[/B]
        [B]return[/B] true
       [B]else:[/B]
        [B]return[/B] false
       [B]end if[/B]
      [B]end function[/B]
     [B]end class[/B]
    Discovery Links
    http://vv.carleton.ca/~neil/neural/neuron-b.html
    A Program for
    Making a Neural
    Net
    Introduction of BrainBox
    http://neil.fraser.name/software/brainbox/ Models of neurons in the iBrain are made and explored using a program called BrainBox.
    BrainBox is for coding up neural nets. The neural networks made are fully functional in real time.
    BrainBox is a Windows program (3.1 or 95/98) that allows one to graphically build and execute neural networks. Use the mouse to drop neurons, drag links from one neuron to another, adjust the weights, and watch what happens when the network executes. There is no automated learning; you are in complete control. Take a look at BrainBox's demo files to see what it can do.
    Note: BrainBox is tested and working on a WinXP computer here at the iBrain lab.
    Download BrainBox [538k zip]. The download archive contains BrainBox's setup program, along with sample files, and source code.
    Samples
    http://neil.fraser.name/software/brainbox/bboxdemo/
    77 x 68 - 2K
    160 x 144 - 7K
  • doggiedocdoggiedoc Posts: 2,249
    edited 2011-03-16 04:12
    Humanoido, this level of detail has me wondering if you don't have a background in neuroanatomy. Also, did you see this link in post #1? :D
    Paul
    edited 2011-03-16 05:24
    doggiedoc wrote: »
    Humanoido, this level of detail has me wondering if you don't have a background in neuroanatomy. Also, did you see this link in post #1? :D Paul
    Thanks for the link, Paul. There are always cautionary caveats that humans should heed with the development of artificial intelligence technology, lest some unusual unforeseen circumstances may result.
    It seems like yesterday when we had the cybernetics lab upstairs. I was working alone on a cybernetic android and developing a new speech chip for VOTRAX. We needed to hold a meeting and I went downstairs, not shutting off the equipment.
    The four of us were downstairs talking and suddenly someone was talking upstairs. But no one was there! I remember the chilling feeling that coldly shot across my spine! Who was in the lab? I was almost afraid to go up there alone in the dark and welcomed a couple of colleagues to accompany me!
    As fate will have it, the cybernetic "organism" started talking on its own.. probably a power surge causing a boot and it sort of randomly became alive. My colleagues were convinced it had become a life form and congratulated me for achieving life - but I had to explain - I simply had no explanation for the random state causing it to speech out like that.
    It's something I will never forget! The story made it to an international magazine when the ten year project was published. Reminiscing, perhaps it was simple circuit failure.. or a symbolic metaphor of insightful vision towards the ebbing birth of new life in the Universe.
    edited 2011-03-16 10:19
    Humanoido wrote: »
    That must have been freeaky!! Good times!
    edited 2011-03-16 11:01
    Brain Artificial Intelligence through Gaming
    Tic Tac Toe Neural Net
    Design this neural net using BrainBox on your PC and transfer it to the Propeller chip. Here, the game setup of Tic Tac Toe is only using 59 neurons. Imagine what might be possible by increasing the number of neurons in the Propeller chip or by adding Propeller chips to a vast collective. Up to 1,000 neurons can fit into each Propeller. The iBrain can handle a total of 21,000 neurons across the net. We are not talking about playing 355.9 games of Tic Tac Toe but rather developing a much greater intelligence.
    This is Tic Tac Toe on a Neural Net
    A Tiny Intelligence
    Back in the year 2007, I did a take on Artificial Intelligence with the Penguin Robot and a version of Tic Tac Toe that ran on the Parallax BASIC Stamp 2px. It ushered in Stamp AI through the thinking thought processes with gaming, on a tiny brain board residing on top of Penguin's chassis. This little brain was the forerunner of what we are working on today. If you have an original Penguin, or the new Penguin REVB, you can still download and experience the challenge of interacting with this tiny intelligence.
    http://forums.parallax.com/showthread.php?98922-PENGUIN-ROBOT-Artificial-Intelligence-the-Code
    A Powerful Game
    Note: it plays the best game of Tic Tac Toe and you can never beat Penguin. You can only tie the game. But Penguin has a weird sense of humor and when he wins, he laughs in Penguinese using the Virtual Sound Chip built into the software. If you enter the cheat code, the tiny intelligence will cheat! Feel free to explore this precursory open source adventure.
    Setup for Penguin Tic Tac Toe uses the Debug Screen. This game
    was eventually tied and it was a Cat's Game.
    Neural Net Tic Tac Toe
    Today, Tic Tac Toe is incorporated into the basis of an embedded neural net. All you need to do is design it with BrainBox or run the sample program. As you can see in the program, there are two boards for one game beset by the propagation of neurons.
    A single player of this Tic Tac Toe can challenge
    the Neural Net. A challenging Neural Net takes
    about 166 neurons which is almost three times
    as many neurons compared to the setup of a
    two humans game. 126.5 games fit into our large
    Propeller Neural Net model. This is sufficient
    for the beginning of artificial life based on
    fundamental rules.
    How it Works
    [TTT-1.BBX 10KB] Download here
    This neural network can play the game of Tic-Tac-Toe against a human. The computer's moves are very good, but not infallible; it is possible to trap the computer and win the game. For information about how to use the Tic-Tac-Toe game, see the documentation for the two-player version of the game: TTT-2.
    Rules of the Net
    When playing this game, make your move then wait for the computer to play before making your next move. The functionality is the same as the two-player version, including the Clear All, Who goes first Error neurons.
    The computer follows three simple rules when playing:
    1. Play any move that will result in an instant victory.
    2. Play any move that will block the human from victory in the next turn.
    3. If nothing urgent is detected, then play the center or a corner or a side (in that order of preference)
    This is a game played against the Neural Net. The human's board is on the
    left and has the winning combination. The Neural Net's board is on the right.
    The first play gave the advantage according the win rules of Tic Tac Toe.
    Discovery Link
    For more information about building Neural Nets with your Bare hands and BrainBox, follow the discovery link. http://neil.fraser.name/software/brainbox/
    423 x 315 - 29K
    480 x 409 - 114K
    edited 2011-03-16 11:18
    Here's a link that provides a hint of what 21,000 neurons can accomplish:
    edited 2011-03-16 12:05
    Here's a link that provides a hint of what 21,000 neurons can accomplish: -Phil
    Thanks Phil, it's a very good reference and shows the power of animal neurons in numbers. It's a nice comparison if you have ANIMAL neurons. It's probable we can cut much or all of the nerve overhead with a machine neuron model. For example, Sponge and Trichoplax are fully functional creatures, yet they have no nerve cells and as a result, their requirement for quantities of neurons is nill. Plus, a robot does not need 11,000 neurons to emulate the basic thinking intelligence of a pond snail. Probably all that's needed is a prop and a good spin program. This also raises some good points and challenges the neuron model algorithm as applied in artificial life form machines. Do we really want to emulate humans and animals?
    BTW, did you notice, if the number of neurons are proportional to intelligence, Hump Back Whales are twice as intelligent as humans, coming in with 200 billion or more compared to 100 billion for humans.. It makes you wonder what new worlds they're spinning deep in the ocean.
    edited 2011-03-16 18:34
    I wonder how well a California sea slug plays tic tac toe.
    edited 2011-03-16 19:05
    I'm sure that if it didn't have to forage for food, find a mate, elude predators, or pose for National Geographic, it could play -- and win -- 355.9 games at a time.
    edited 2011-03-17 03:58
    Brain Research
    Sea Slugs Computer Modeling
    Going downward on the evolutionary scale, are there lessons to be learned from the lowly Sea Slug? Apparently so..
    Cyberslug Cyberbranchaea Program
    Control Panel
    "An animated model reproduces aspects of optimal foraging decisions. Prey are created with specific nutritional and defensive qualities, given specific odors, and placed in the field. Predator hunger increases with time between feeding. The predator's hedonic evaluation of odors may be inspected at any time by clicking the odor. The predator and prey are shrunken images of Pleurobranchaea and its noxious real prey, Flabellina sp."
    Download the Cyber Slug Program
    http://www.life.uiuc.edu/slugcity/CyberSlug.exe
    Busy as a Bee
    We all agree the Sea Slug is a very busy banty little critter, contending with additional elements of commensalism, symbiosis, adapting solar power, mutualism, parasitism, bioilluminism, managing Lessepsian Migration, crawling, joy swimming in Opisthobranchia, spiraling, mantel flapping in Chromodoris, regulating tortion and detortion, and managing eggs and larval culturing. All those things are not necessary in the iBrain, which has other purposes. Perhaps looking at Slug research could be beneficial in some other way.
    Slug Research
    Dr. Rhanor Gillette's research group [Department of Molecular and Integrative Physiology, Center of Biophysics and Computational Biology, University of Illinois at Urbana-Champaign] has a website called Slug City at http://www.life.uiuc.edu/r-gillette/.
    Cyber Slug Program
    If you go to the Models page on that site you can download a copy of their Optimal Foraging Simulation program for the cyberslug Cyberbranchaea. The name is a play on the name of the real carnivorous slug they have studied, Pleurobranchaea californica.
    The Sea Slug Analog Computer!
    http://www.life.illinois.edu/slugcity/cyberslug.html
    This simple analog computer uses voltage levels to simulate stimuli strength and
    the feeding or avoidance responses. Potentiometers can be set to desired levels of
    virtual hunger, pain, and food-scent. One observes lamp brightness corresponding
    to feeding or avoidance behavior. The circuit behaves qualitatively like
    Pleurobranchaea, with proper handling of behavior throughout the hunger
    continuum.
    For more information, the Sea Slug Forum is helpful.
    http://www.seaslugforum.net/
    404 x 362 - 37K
    235 x 436 - 38K
    658 x 125 - 11K
    edited 2011-03-17 06:29
    Brain Ear 1st Experiments
    Mic sound input for analysis
    The idea of a simple Brain amplification ear came from Chip's code. The audio input from the microphone circuit on a PPDB is fed to the earphone output which in turn is fed to the primary audio amplifier. Two ears on opposing Brain sides can hear in stereo.
    Mic to Headphones
    spin.gifmicrophone_to_headphones.spin
    http://forums.parallax.com/showthread.php?85703-Demo-board-audio-examples&p=587464
    This program uses the Propeller Demo Board, Rev C. The microphone is digitized and the samples are played on the headphones. Here's a program that runs on the new Propeller Demo Board, Rev C. It digitizes the microphone to selectable resolutions and then outputs the samples to the headphones. It uses one COG. The COG's CTRA is used for analog-to-digital conversion and its CTRB is used for digital-to-analog conversion.
    Envelope Detector
    spin.gif Also in use is this demo which uses an envelope detector from the mic input to generate a bar graph output on the board's LEDs. Concocted by Phil for the Propeller Demo Board, it's a simple audio volume level indicator. http://forums.parallax.com/showthread.php?118061-Simple-audio-volume-level-demo
    edited 2011-03-18 15:41
    Brain Life
    Utilize BrainBox Neural Net to Establish Life
    Inventing Life
    The Game of Life was invented by John Horton Conway, a British mathematician, and described by Martin Gardner in his Mathematical Games in Scientific American in 1970 (Scientific American 223(4), October, 1970, pp 120-123).
    Entering a New World
    A world ... consisting of locations which may or may not be occupied by life. And time ... as many steps as you like. And a very simple set of rules ...
    • At each step, life persists in any location where it is also present in two or three of the eight neighboring locations, and otherwise disappears (from loneliness or overcrowding). Life is born in any empty location for which there is life in three of the eight neighboring locations.
    Post 382 had discussion about using BrainBox to create neural nets. This code allows the placement and linking establishment of neurons to design and formulate a Neural Net. After exploring the code, a new implement of Life was discovered and is presented here.
    Why is Life So Interesting?
    Life is one of the simplest examples of what is sometimes called "emergent complexity" or "self-organizing systems." This subject area has captured the attention of scientists and mathematicians in diverse fields. It is the study of how elaborate patterns and behaviors can emerge from very simple rules. It helps us understand, for example, how the petals on a rose or the stripes on a zebra can arise from a tissue of living cells growing together. It can even help us understand the diversity of life that has evolved on earth.
    Watch Life evolve within the confines of the Neural Net. Neurons
    in Life6T run within the BrainBox.
    Life evolutionary view during a Life6 run
    Discovery Links
    For more information about Life, check post 333 on page 17
    For more information about BrainBox
    Game of Life on a 6x6 grid
    Life6
    http://neil.fraser.name/software/brainbox/bboxdemo/life6.htm
    Glider
    slowly moves diagonally across the grid requiring four generations to move by one pixel. This is the pattern displayed when Life6 is loaded."Life6 implements a 6x6 square grid of Life using a neural network. Each pixel of the grid is made up of three neurons in a triangular group.
    The lower two determine if the pixel will be alive or dead (death has priority) in the next generation. The top neuron reflects the current state of the pixel. Each Life generation takes two execution steps. To change the grid's pattern one may have to single step the net once so that the top neurons are the active ones, then their states may be toggled.
    An interesting side-effect of the two-step generation is that a second Life pattern can be run concurrent with the first, without any interference between the two -- as long as they are half a generation out of phase. The second pattern doesn't slow down the network at all because every neuron must compute its state each step anyway."
    6x6 Life Torus
    [LIFE6T.BBX 8KB]
    Life6T Game of Life wrapped toroidally
    http://neil.fraser.name/software/brainbox/bboxdemo/life6t.htm
    "Life6T is the same as Life6 with the addition of wrap-around links to make the 6x6 playing field toroidal. This means that Gliders (among other patterns) will circulate forever. For information about Life and how to use it, see the documentation for Life6. An interesting property of Life6T's toroidal nature is that the left-most or right-most column of 'pixels' can be dragged to the opposite side, and the resulting pattern will be identical. The same applies for moving rows from the top to the bottom or vice-versa."
    What Life is and is Not
    In the article written about John Conway's Life, Martin Gardner refers to it in his interpretation as a game. Note that Life is not really a game. According to the Scientific American Article, it is an implementation of a cellular automata that John H. Conway chose to call "Life." It simulates the birth, death, etc., of organisms based on certain rules.
    The Infinitely Programmable Computer
    Despite the name of the game, when John Conway developed the system he called Life he wasn't aiming to simulate life at all. All the same, the game's lifelike nature, with its endless complexities and unpredictable nature, has captured imaginations all over the world. Conway's original aim was entirely mathematical - he was trying to find a so-called universal system, that is, a system capable of carrying out arbitrary computations - a sort of infinitely programmable computer.
    Explore Online Life Applet
    http://www.bitstorm.org/gameoflife/
    http://www.bitstorm.org/gameoflife/standalone/manual/
    http://www.ibiblio.org/lifepatterns/
    Single Stepping or X10
    Here's a Life applet that allows setting the initial condition
    and either single stepping or stepping by ten.
    http://serendip.brynmawr.edu/complexity/life.html
    Lexicon Discoveries Made Within Life
    http://www.bitstorm.org/gameoflife/lexicon/
    Many things are discovered while Life is unfolding,
    such as vast spaceships,diamonds, volcanoes and
    hundreds of other elements!
    original Life Lexicon is available at Silver's website
    More Information
    From Life in Postscript
    http://www.tjhsst.edu/~edanaher/pslife/
    John Conway Hoped for Greater Simplicity
    http://plus.maths.org/content/games-life-and-game-life
    Life is not as simple as Conway had hoped, but is, he says, "a sort of pleasant failure". In one way von Neumann's system was simpler, as the state of a cell only depended on itself and its four crosswise neighbours, whereas Life involves all eight neighbours. Ideally, Conway was looking for a system that was "astonishingly simple", one that only involved one dimension - cellular automata in a line rather than in a plane. With a two-dimensional system "you have to hold the state of position (x,y) at time t. It would be much better if we could reduce the complexity of the space we are operating in", he says.
    showthread.php?129592-Penguin-Robot&p=977061#post977061]
    427 x 396 - 136K
    389 x 373 - 86K
    edited 2011-03-19 02:03
    Brain Progress Report March 2010
    Investigations continue with the Giant Brain in various scientific fields
    pertinent to the future of AI Brain operations and the establishment of
    life plus all incorporated related fields.
    Overview
    This is a large plate of impending agenda based on large elements of
    time, labor development, ongoing research and design, and now
    testing of modules. In the next phase, many of these modules will be
    interconnected in the internal Brain web of neural nets.
    Simulations
    More simulations and try-outs will take take place, offline from the brain,
    to establish new neural designs and try out new ideas to see if they are
    fully workable.
    Brain Direction
    The idea is to build up a collection and references of working sources that
    can contribute functional sections with algorithms to the Brain project.
    Some will schedule for tryout and end up for reference only while others
    will become highly useful.
    Continuing Directions
    The following fields of development will continue
    • Brain Channeling was highly successful
    • Adding processors went well
    • Adding programming languages will increase
    • Apps incorporating TV & computer
    • Modeling, Sketching, Simulation
    Development Trends
    Current development trends include continuation of wiring (the largest
    project ever undertaken with a Brain of this magnitude), sketching
    the schematic for the new designs based on earlier testing, research,
    and Brain Channeling. Programming languages are also added so in
    the final analysis this will become multi-lingual programming code
    Brain. It is intended to program the brain will a variety of languages
    simultaneously.
    Directly Related Background Projects
    In the background are other ongoing related projects - the design of
    a new cybernetics laboratory equipped with useful test equipment. This
    will suffice the current and near future levels of ongoing Brain research &
    development including the construction of full scale humanoids,
    advanced robotics, & a step toward increasingly powerful Brain technology.
    It will require international moving.
    Brain Neural Net Day
    The upcoming Brain Neural Net Day will be observed and the lab will close
    for about 2 weeks and vacated during this time period. No activity or posts will
    occur during this time span. This is most likely still a few weeks away. It is not
    certain exactly when the observance will occur.
    Possible Future Trending
    • Addition of a PC with ATOM core processor
    • Direct connect or wireless
    • Blue tooth
    • RF wireless
    • Internet
    • IR modes
    • VGA EXT
    edited 2011-03-19 03:37
    Brain Dreaming Suggestions
    Information Digestion
    In a nutshell, dreaming is considered information digestion.
    (Thanks to Prof_Braino for this coinage)
    Artificial Intelligence coding can be complicated or capable of
    "processing" large amounts of data even though great strides will
    be taken for some degree of simplification. The process of AI will
    require time for processing data. This "making sense of the
    real world," even in psychological organizations, could be
    directed to the benefits of dreaming.
    How digestion takes place is directly dependent on the
    AI and dreaming algorithms. This incorporates the AI modules.
    Refer to the Six Objectives of Machine Intelligence outlined in
    Post 364.
    The objective of dreaming is not to just show pretty random
    unfolding pictures but rather couple the dream world to that of
    sorting, organizing and making sense of the real world.
    In a kind of data crunching, or uncrunching if you will, dreaming
    will contribute to the silicon life form's well being in fundamentally
    useful ways.
    It's likely that not one second of waking or sleeping time will be
    wasted in this kind of ongoing life analysis. The brain will likely
    always think, even during nights of lessened power and dreaming..
This discussion has been closed.
