PropPad mini. Bare PCB $5, Serial LCD driver with 7 x 21 chars and 262k Font colors. - Page 2 — Parallax Forums
245
  • tripptripp Posts: 52
    edited 2010-02-06 20:25
    jazzed: do you know any good touchsensor IC?
    Here is the schematic:
    Hires PDF: http://www.xtune.se/images/PropPad/schematic.pdf
    edited 2010-02-07 02:56
    If it is a resistive touchscreen then you would be able to read it like the Propeller would a potentiometer, right? Just a simple capacitor charge circuit. Then it could be read in only one cog.
    Computers are microcontrolled.
    Robots are microcontrolled.
    I am microcontrolled.
    SX Spinning light display·
    http://designedbymemicros.blogspot.com/
  • jazzedjazzed Posts: 11,803
    edited 2010-02-07 06:51
    @tripp, your schematic seems to be missing the LCD control lines RD* WR* RS .... Are there other connections not shown?
    Also I have to assume Propeller RES* is connected correctly.
    microcontrolled said...
    You're basically right. A 4 wire touchscreen is like 4 resistors arranged in a big plus + with one resistor per "arm" ....
    Attached is a drawing that shows some basic Propeller pin connections ... the capacitors are missing in the measurement points.
    P11,12,13,14,15 would be connected the same in every figure.
    In the upper panels, P11 = out and high, P14 = out and low, P15 state = 1 no touch, 0 touch.
    In the lower left panel, P11 is input, P12 = out and high, P13 = out and low, P14 and P15 make the ADC input connections.
    In the lower left panel, P11 is input, P15 = out and high, P14 = out and low, P13 and P12 make the ADC input connections.
    I have no idea if this works, but this is what I'll try. I would like some feedback on it.
    A Propeller ADC is good for about 256 levels, so the resolution may be good enough to work.
    Post Edited (jazzed) : 2/7/2010 6:57:24 AM GMT
    495 x 561 - 19K
    edited 2010-02-07 12:56
    The RES is connected correctly, see updated PDF.
    Are there other connections not shown?: all of·the LCD pins, and some DC/DC step up components for backligt on a 2.4" LCD.
    I've had a busy weekend, but I've had time to assemble one PropPad.
    Link: http://www.xtune.se/product_info.php?products_id=131·price $80
    And for all that have bought a PCB you need to ad a resistor on J2, see picture:
    Or monut a smd powerswith from sparkfun: sku: COM-08769
  • ry.davidry.david Posts: 63
    edited 2010-02-07 13:46
    A dedicated touchscreen ADC has it's advantages though.· Most have a interrupt pin to signal a touch, so you can use the cog for other tasks while checking the pin.·
    edited 2010-02-07 16:23
    Here is a program that could do the capacitor charge read and convert it to coordinates. It is commented for use and should work well. Read the comments for instructions. Try it out and tell me if it works. I have a schematic attached as well, but you would need this circuit on the X and Y, not just the X.
    I am hoping that you do not deside to use an IC, after I wrote the program and all. smile.gif
    edited 2010-02-07 18:33
    Here is an updated touchscreen Propeller ADC drawing (pins reassigned).
    The caps and resistors would be the same as in the counters app note ADC.spin.
    6 pins to read the touchscreen seems a bit much.
    @micro, your code looks very nice. Want to try writing an object like the ADC.spin for my drawing?
    I'm thinking an object would have the following public methods:
    pub start(xi,xo,xg,yi,yo,yg)
    xi = adcpinx
    xo = fbpinx
    xg = xgnd
    yi = adcpiny
    yo = fbpiny
    yg = ygnd
    pub stop
    pub touched
    is touched ... pins set to detect touch mostly
    pub getX
    pub getY
    401 x 400 - 10K
    edited 2010-02-07 19:26
    What makes your schematic better? More accurate? Just wondering, since I'm still not too good on my circuit designing skills. Thanks for the complement on my object. I used the equation for calculating the exact cap time from the "TestRCDecay" object for the Propeller labs. The setting for the CTR registers was also from there, but the rest was my own. I'll look at your circuit.
    edited 2010-02-07 19:40
    @tripp, you still need to add the LCD control lines to your schematic.
    @micro, I guess a few differences are where the input logic 1 level threshold is for a given chip at a given temperature (capacitance changes over temperature and a balanced circuit with two caps mitigates that to a point). Using your approach only 4 Propeller pins would be necessary. I'm thinking that another resistor may also be necessary in the x and y of my drawing. In any event, almost exactly the same layout can be used.
    edited 2010-02-07 21:12
    In my setup only 2 propeller pins would be needed. I'll start experimenting with yours now.
    edited 2010-02-07 22:24
    Actually, I don't believe the axes can always be tied to ground. Look at my first picture which is a lot like yours except it doesn't show the charge capacitor. The axis you're reading needs to behave like the center tap of a variable resistor. If the other side of the "center tap" is tied to ground constantly, the reading will not be very useful. In the picture below you could replace RL with your capacitor.
    The reason for P11 and the extra resistor in my first picture with the 4 drawings is for detecting a touch (pins are different between the two drawings). Detecting touch is important because constantly reading and saving the values won't work. So even with your method, it seems 5 pins are necessary. Of course if you can prove me wrong, it would be a good thing.
  • RossHRossH Posts: 5,642
    edited 2010-02-08 00:56
    Hi tripp,
    I'd order one right now - but the Xtune web site won't let me ship one to Australia cry.gif
    Ross.
    edited 2010-02-08 22:09
    Hi tripp,
    Order placed! Very reasonable shipping cost from Xtune as well.
    I noticed the Xtune board does not include the SD card adaptor, but that the one you used is available from SparcFun - I may use a different one, but can you confirm that this is the one you used: Breakout Board for DOSonCHIP FAT16 FAT32 uSD Module (sku: BOB-08215) ?
    Ross.
  • nicolad76nicolad76 Posts: 164
    edited 2010-02-09 15:04
    Hi,
    I have looked to the connection diagram but I do not see how you connect the display, how many pins do you use?
    Nicola
  • Reset_VectorReset_Vector Posts: 55
    edited 2010-02-12 10:04
    Hi to all
    I've ordered the board & LCD and I'm still waiting for it.
    For the touchscreen, I plain to use the ADS7843 controller, 16 pin SOIC package and serial communication to the propeller.
    As I receive the board, i'll try to make an object for this controller.
    I'll send my work as it was functionnal.
    Thank you tripp for this nice job !
    Tripp : On wich propeller I/O do you connect the LCD ? and can you post a programm to use the LCD ?
    edited 2010-02-17 20:20
    Now the proppad is in stock. http://www.xtune.se/product_info.php?products_id=131
    The Breakout Board for microSD Transflash is: http://www.sparkfun.com/commerce/product_info.php?products_id=544
    Be careful when you·solder the connections to the touchscreen, losen the LCD before.
    edited 2010-02-17 23:05
    Hi Tripp,
    Board arrived! Just had time to fire it up and try Rayman's Serial control driver (with your initialization code mods) - and I can draw circles on the screen! It will take me a while to get to grips with the LCD controller, but I'll post some driver code when I manage to get some time to write some.
    One thing - when I load an image with Rayman's software , only about half of it appears on the screen - i.e. it's shifted right by about half the screen width. Any ideas? Could you post the actual code you used?
    Also, can you tell me how the screen is fixed to the circuit board - my screen is lifting on one end, but I'm afraid to lift it up any further (which I would need to do to try to fix it down permanently).
    Ross.
    edited 2010-02-18 07:09
    RossH said...
    Board arrived!
    Wish I had mine. I suppose it's stuck in US Mail somewhere.
  • Mike HuseltonMike Huselton Posts: 746
    edited 2010-02-18 10:10
    I am serious. When can I have a fully-assembled unit with postage?
    JMH
    edited 2010-02-18 16:07
    RossH: Here is the code i use for displaying images, it uses a 10Mhz crystal so you may need to change the crystal settings in code.
    I get the same result when displaying images in 16-bit try to check the 24-bit radiobutton.
    I cant get circle funktion working, can you post your code?
    Mike: you can now order a fully assembled and tested·unit: http://www.xtune.se/product_info.php?products_id=131
    Edit: the LCD is fitted with double sided tape, just slide a nail under the LCD to get it loose.
    Post Edited (tripp) : 2/18/2010 7:21:52 PM GMT
    edited 2010-02-18 22:25
    tripp,
    Thanks! I didn't think to try 24 bit. I'll try your code out tonight, and also post the code I used (which was just Raymans code but with your initialization changes).
    Ross.
    edited 2010-02-21 07:37
    HI,
    I have the same problem as you for driving the LCD :
    When using Rayman's Serial control driver, with Tripp initialisation code :
    I can draw lines as I need
    the circles are half drawed
    Pixel function don't work
    Background and foreground functions are OK
    for Images only about half of it appears on the screen
    I have tried to modify the initialisation code, but without success
    Does anyone have modified with success the driver ?
    Best regards
    edited 2010-02-24 02:02
    jazzed said...
    hinv said...
    So this has memory like the PSM screen does?
    173KB ... should be fast access with the parallel data bus. Good stuff.
    does it mean I can write/read from that memory to draw to picture I want to display? so easy??? no external memory????
  • CannibalRoboticsCannibalRobotics Posts: 535
    edited 2010-02-24 02:37
    This is very cool. Can you provide a mechanical spec. If a header can be soldered to it to link to a control / communications board, your on your way.
    Excellent work!
    Signature space for rent!
    Send $1 to CannibalRobotics.com.
    edited 2010-02-24 05:14
    nicolad76 ... seems that way. I don't know if we can read though. I got my unit and have started assembling it.
  • MagIO2MagIO2 Posts: 2,243
    edited 2010-02-24 05:50
    The memory is for display only : (320 x 240)resolution x 3colors x 6bit per color / 8 bit per byte = 172800 byte
    But yes, you could also read the memory. But it's better to know what you display, as reading is slower than writing.
    edited 2010-02-24 13:32
    Hi,
    Here is the results of my effoerts to modify the PSM driver to match the ProPad.
    Circles are well drawed, as pixels, lines, but there is a bug with the rectangles.
    I can download images on the screen now !
    I'll post the driver if someone is intersested !!
    Best regards from France
    3008 x 2000 - 978K
    3008 x 2000 - 1000K
    3008 x 2000 - 848K
  • Graham StablerGraham Stabler Posts: 2,510
    edited 2010-02-24 14:23
    Reset_Vector, why do all your images have watermarks for fcoder, are you converting from a strange format? Have you tried picasa, does most things.
    Looks really amazing btw.
    Graham
    edited 2010-02-24 14:44
    Hi MagIO2...thanks for your reply. I just want to understand if I can save some external memory in order to have a kindo of portable device. In that case I do not have a PC to "prepare" the image and send it to the prop but I will have the prop to "draw" the image. Since I expect to refresh the image every 1/2 sec, if I can use the display memory as "video buffer", I will not need to add any external memory.
    Nicola
    edited 2010-02-24 16:18
    Yes, you can use the display-memory as screen buffer. But if you need to re-read what's been written it will get very slow. The transmission is really fast if you can write the whole image at once from upper left to lower right (having windows smaller than the whole display is possible). This is a bulk-write .. you set the address once and then send all the data.
    But random access is expensive. You will see the image generation then. Problem here is:
    1. you have to address each pixel which means to send the address
    2. switching from write to read costs extra cycles, as the display will answer the read one cycle later.
    What kind of image do you draw?
