4.3" Touch LCD Break Out Board. - Page 4 — Parallax Forums
124
    edited 2009-11-21 15:14
    sorry no. The boards are shipped in 24 bit mode. If you want 6 bit mode you need to short the wires as listed they are not shorted when you receive them.
    For myself I plan to use 16bit mode. the colour pins can share with the 16 lower 16 Address and 16 data bits of my RAM module giving me control of the screen and 64MWords of RAM with
    16 pins data/address/colour
    6·lcd control pins
    2 eeprom/touch pins/user interface
    2 latch pins
    5 pins for sd card and flash
    1 pin for power manigment
    24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
    Post Edited (mctrivia) : 11/21/2009 3:23:40 PM GMT
  • James LongJames Long Posts: 1,181
    edited 2009-11-21 20:31
    Sorry for the delays guys.
    It took me a while to figure out how to wire up the breakout board to the platforms I have. I decided on a 40 pin hard drive cable. It has the right pinout, and provided a way to short the wires for the colors. One end is a standard hard drive connector with headers plugged in (used like a pogo pin tester), and the other end was modified to plug into a propeller platform from Gadget Gangster.
    So far this looks like it is going to work OK.
    James L
    James L
    Partner/Designer
    Lil Brother SMT Assembly Services
    Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
    edited 2009-11-21 20:38
    Yes the board was designed around ide. Hence the key pin
  • ForrestForrest Posts: 1,341
    edited 2009-11-21 20:50
    James,
    Could you post a picture of the cable - this sounds interesting.
    Forrest
  • Luis DigitalLuis Digital Posts: 371
    edited 2009-11-21 20:51
    Hello Matthew and James,
    PCBs without components were sent or will be for Monday?
    Thanks.
    edited 2009-11-21 21:35
    James said he was shipping yesterday but I have no confirmation on that.
  • bboy8012bboy8012 Posts: 153
    edited 2009-11-25 04:23
    Any chance I can get one with Touch Screen, mctrivia? Thanks
    edited 2009-11-25 04:56
    I have 72 breakout boards in transit to me at this moment and I will update you when they arrive. Only about 30 of them are spoken for so yes.
    15 breakout boards where shipped directly to customers from James Long.
  • kerrywkerryw Posts: 61
    edited 2009-11-28 19:51
    mctrivia said...
    to connect these to the prop in 6 bit mode compatible with rays paint program you need to use the following pins(pin numbers can be changed in software)
    Pins 16..23
    B0,B2,B4,B6 are shorted
    B1,B3,B5,B7 are shorted
    R0,R2,R4,R6 are shorted
    R1,R3,R5,R7 are shorted
    G0,G2,G4,G6 are shorted
    G1,G3,G5,G7 are shorted
    Hsync
    VSync
    BL=2
    DON=24
    PCLK=25
    DE=26
    PI=27
    SCL= 28
    SDA= 29
    I received my beakout boards and have soldered in the header pins. The above pinouts confused me, as I took it that B0 was Pin 16, B1 Pin 17 etc.·For clarity they·should be:
    Pin - Breakout Board
    16 - VSYNC
    17 - HSYNC
    18 - B0, B2, B4, B6
    19 - B1, B3, B5, B5
    20 - G0, G2, G4, G6
    21 - G1, G3, G5, G7
    22 - R0, R2, R4, R6
    23 - R1, R3, R5, R7
    The touchscreen functionality·is not working for me. I have tried different displays, but no change. PI (Touchscreen IRQ) is always 3.2v, whether the screen is being touched or not. Any suggestions?
    Kerry
    P.S. The screens are nice and bright. Fairly uniform backlighting also. Great find.
    "Heaven help me Marge, I'm just not that smart." - Homer Simpson
    edited 2009-11-28 20:14
    kerryw said...
    I received my beakout boards and have soldered in the header pins. The above pinouts confused me, as I took it that B0 was Pin 16, B1 Pin 17 etc. For clarity they should be:
    16 - VSYNC
    17 - HSYNC
    18 - B0, B2, B4, B6
    19 - B1, B3, B5, B5
    20 - G0, G2, G4, G6
    21 - G1, G3, G5, G7
    22 - R0, R2, R4, R6
    23 - R1, R3, R5, R7
    The touchscreen functionality is not working for me. I have tried different displays, but no change. PI (Touchscreen IRQ) is always 3.2v, whether the screen is being touched or not. Any suggestions?
    Kerry
    Kerry,
    The touchscreen address is different. You must change it in the Spin software.
    In i2c driver change this line:
    TouchAdd = $48 'Address of touchscreen controller
    To
    TouchAdd = $4B 'Address of touchscreen controller
    This change is only for the breakout boards Matt did. This change will not work on Ray's boards.
    James L
    James L
    Partner/Designer
    Post Edited (James Long) : 11/28/2009 8:19:31 PM GMT
    edited 2009-11-28 20:22
    You need to add 3 to the address of touch screen. His code uses 0 and they were assembled with jumpers both in 1 position.
    edited 2009-11-28 20:50
    mctrivia said...
    Excellent, that was it.
    Everything is working now except for one remaining thing.
    I'm using the Parallax Professional Development Board·to make sure everything works.·I·get a stable image UNTIL·I plug a connector from the breakout board to pin 20 on the dev board. This is the G0, G2, G4 etc. line. As soon as I plug that connector in the screen gets corrupted. The correct image is sorta there, but the·line 'PSB Paint'·is duplicated on the bottom of the screen but with a magenta background. It is stable, but obviously incorrect. Both the vsync and hsync pins on the breakout board look clean, definitely no solder bridges there. Soooo close [noparse]:)[/noparse].
    Kerry
    edited 2009-11-28 21:05
    with nothing connected you should get 0ohm between G0,G2,G4,G6 and any other pin.
    edited 2009-11-28 23:47
    kerryw said...
    mctrivia said...
    I'm using the Parallax Professional Development Board to make sure everything works. I get a stable image UNTIL I plug a connector from the breakout board to pin 20 on the dev board. This is the G0, G2, G4 etc. line. As soon as I plug that connector in the screen gets corrupted. The correct image is sorta there, but the line 'PSB Paint' is duplicated on the bottom of the screen but with a magenta background. It is stable, but obviously incorrect. Both the vsync and hsync pins on the breakout board look clean, definitely no solder bridges there. Soooo close [noparse]:)[/noparse].
    Kerry
    Kerry,
    I found if you run all the gnd pins to the same place the screen looked as if the vsync doesn't work. There is one ground that must be run to a separate place....but I can't remember which one. I think it is the gnd for the touchscreen side of the board.
    I would run the screen grounds to one place....and the board grounds to another.
    James L
    James L
    Partner/Designer
    edited 2009-11-29 01:40
    Kerry,
    James L
    It looks like you were on to something James. I just connected the remaining VSS pins on the breakout board to ground and that seems to have resolved the issue. Thank you.
    Kerry
    Post Edited (kerryw) : 11/29/2009 1:48:03 AM GMT
    edited 2009-11-29 17:45
    kerryw said...
    Kerry
    Kerry,
    I think this has to do with the touchscreen circuitry. The touchscreen is more of an analog circuit, with the screen being digital. When you combine the two, it appears there is noise introduced into the digital feed.
    I hope I helped. I found the strange vsync problem just by chance, and fixed it by using a different ground pin for the touchscreen circuitry.
    James L
    James L
    Partner/Designer
    edited 2009-12-01 01:29
    I have had one customer to whom I shipped directly have some inductors cracked on a couple of his boards.
    If anyone receives any boards with broken or otherwise damaged parts, please let me know.
    It was my fault the parts were damaged. I personally packaged them....so I am responsible.
    James L
    James L
    Partner/Designer
    edited 2009-12-01 14:54
    Good news there in. Will start testing tonight and ship the first batch tomorow
    edited 2009-12-02 08:00
    here is a close up of the breakout boards. if you look close you will see some solder bridges. the pins bridged are all the same signal so there is no problem.
    I really need to get a ring flash and tripod. it is hard to focus a macro lens when holding it in your hand.
    24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
    1936 x 1296 - 2M
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2009-12-02 08:12
    Looks awesome. Can't wait to get it [noparse]:)[/noparse]
    UC Berkeley '12 EECS
    CalSol: Berkeley Solar Car team
    www.calsol.berkeley.edu
    edited 2009-12-02 08:16
    here is an entire panel with a quarter for size reference. Can you tell where the quarter comes from?
    3466 x 2328 - 2M
    edited 2009-12-02 08:18
    FlyingFishFinger won't be long now. I hope to have them all shipped out by saturday. I will be shipping a bunch every day until they are all done.
    edited 2009-12-02 08:56
    Haha thanks, no rush.
    The web tells me it's Canadia from around 1912...right?
    Although that motif was common, so I'm taking your word that it's actually quarter...cents and dimes seemed to have it too [noparse]:)[/noparse]
    Where'd you get it?
    Raf
    KJ6AWU
    Post Edited (FlyingFishFinger) : 12/2/2009 9:01:38 AM GMT
    edited 2009-12-02 09:01
    You are close. it is a 1913 Canadian Quarter. a penie is about half the size.
    I collect quarters. I have almost every year from as far back as 1886.
    Started when on my paper route I was paid by an old lady in old coins.
    edited 2009-12-04 04:27
    After all it was worth waiting so long, and make the investment. LCDs look good with a clear and pretty picture. (I have to throw away my camera smile.gif ).
    Solder the connector was easy, not super easy, but easy and clean.
    I'm using Digi-Key Part Number TB62752AFUGCT-ND (Backlight)
    Very cheap compared to the Digi-Key Part Number LT3593ES6 # TRMPBFCT-ND
    (Note: not pin compatible and I realized some changes.)
    When I have time I will try the AR1020-I/SS-ND (TOUCH SCREEN CTRLR)
    It is also very cheap, hope it works.
    (Note: not pin compatible, not compatible with existing software and must be mounted separately.)
    I hope Matt and Ray have a look, you can save a lot, and also undercut.
    Thank you all.
    1797 x 1702 - 361K
    edited 2009-12-04 04:43
    impressive soldering job especially since pcb was not designed for those specific parts. if I need to make more I will look into changing to use those parts.
    edited 2009-12-08 01:50
    Mctrivia,
    Have you started sending out the breakout boards?
    edited 2009-12-08 01:53
    At post office right now. About 60% done will be done by wednesday
  • RaymanRayman Posts: 15,298
    edited 2009-12-08 01:54
    Luis Digital said...
    Thank you all.
    Glad you found some cheaper parts!· It's way too late for me, but I'm sure there'll be others drawing up new boards soon...
    I don't recall the backlight chip being too expensive, but do remember a stiff price for the touchscreen chip...
    My Prop Info&Apps: ·http://www.rayslogic.com/propeller/propeller.htm
    edited 2009-12-12 09:47
    mctrivia,
    Will your 4.3 inch Touchscreen LCD break out board somehow interface with your RAM expansion module http://forums.parallax.com/showthread.php?p=853438
