Propeller Remote Compiler v1 *released* - Page 2 — Parallax Forums
2
    edited 2009-05-23 22:09
    Perfect! That sounds like the piece of the puzzle I'm looking for.
    Thanks!
    OBC
    New to the Propeller?
    edited 2009-05-25 05:12
    Just got it working with the portable Apache server.
    (Couldn't have gotten this far without Harrison)
    I'm smoothing out wrinkles and laying out some documentation if others want to try this.
    I'll post some code within a day or so.
    That's it.. No more Propplug/USB connection required..
    All you'll need is an Ethernet connection, SD, and a copy of PropDOS.
    OBC
    Post Edited (Oldbitcollector) : 5/25/2009 5:31:37 AM GMT
  • BradCBradC Posts: 2,601
    edited 2009-05-25 05:57
    Oldbitcollector said...
    That just seems a bit (humourously) awry to me.. read it like this.
    You no longer need a $25 USB/Serial converter to program your propeller. You now need an SD card (consuming 5 pins), an ethernet MAC (consuming more SPI pins), associated magnetics, an RJ45 cable, a spare ethernet socket to connect it to, and a PC to run the software (which you can access over a network) to enable you to compile your software, plus a TV and Keyboard to enable you to edit it.
    It just made me laugh, that's all [noparse]:)[/noparse]
    Disclaimer for the humour impaired : This was not meant as any form of criticism either direct or implied, it's a joke joyce. (Minimum three month subscription at $10 per month applies, see box for details)
    "VOOM"?!? Mate, this bird wouldn't "voom" if you put four million volts through it! 'E's bleedin' demised!
    edited 2009-05-25 06:07
    He'll be here all week, ladies and gentlemen! Try the veal, don't forget to tip your waitress.
    Heh..
    Yeah, It does read like a "crazy-man" doesn't it. [noparse]:)[/noparse]
    Love it!
    OBC
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-05-25 11:21
    BradC,
    You still don't get it.
    Think of this as step 1, proof of concept.
    Steps 2 to n will be demontrating how a SOAP api will interact with the Prop.
    This is an intelligence amplifier for the Prop, allowing Desktop or Mainframe interactions with a microprocessor.
    SOAP transactions have been clocked at multiple transactions per second at my Wachovia lab.
    Always
    JMH
    Post Edited (James Michael Huselton) : 5/25/2009 11:44:50 AM GMT
    edited 2009-05-25 11:49
    A test case involving SOAP transactions per second is published here: weblogs.java.net/blog/kohsuke/archive/2007/02/jaxws_ri_21_ben.html
    A simple tutorial and code examples: www.codeproject.com/KB/webservices/webservice_tungDbProxy.aspx?fid=435799&df=90&mpp=25&noise=3&sort=Position&view=Quick&select=2125978
    JMH
    Post Edited (James Michael Huselton) : 5/25/2009 11:57:24 AM GMT
  • hippyhippy Posts: 1,981
    edited 2009-05-25 11:51
    James Michael Huselton said...
    BradC, You still don't get it.
    I think he does, it's just the humour in the notion - "I've gone off grid and now generate my own electricity, saving me a fortune, and you can do the same; all you need is a nuclear power plant in your back yard".
    Then again, seeing your wink.gif maybe it's me that's not getting it.
    edited 2009-05-25 11:56
    BradC,
    No, no.. I do get it, honest... I made several comments to mitigate my post from the humour impaired, but you appear to have safely negotiated all those and made it through the woods, missing all the trees and made it through to the other side [noparse]:)[/noparse]
    edited 2009-05-25 12:01
    I want everyone to proceed with developing compilers, memory access, tools, etc.
    But this is a parallel path that MAY provide some additional methods to our toolkit.
    As Scotty said, "I think this is exciting!".
    OBC and I are just experimenting. No need to feel threatened.
    Check my posting history. Enough humor there to negate my "humor impaired" stigma.
    p.s. I hope that you realize that you and Hippy are programming sky gods and I hope to be like you when I grow up.
    JMH
    Post Edited (James Michael Huselton) : 5/25/2009 1:39:19 PM GMT
    edited 2009-05-25 15:54
    He gets it.. and so do I. No one needs feel threatened.
    This whole project wouldn't have been possible without Mpark (editor), BradC (BSTC), and Harrison (TCP/IP & http client code) -- All I did was start glueing resources togeher. [noparse]:)[/noparse]
    OBC
    edited 2009-05-25 16:04
    Yep. And I thank you for picking up the ball and running with it.
    JMH
    edited 2009-05-26 03:52
    Everything is posted to the top thread...
    (At least what I'll share for now... Come to UPEW to see the rest.)
    If you get your own copy up and running, please post to the thread.
    I'm curious how my instructions will pan out.
    OBC
    edited 2009-05-26 04:16
    Can't promise it will stay up, but if you want to try it from my Apache server
    running on my development box, it's IP address is: 71.50.219.78
    Set it in the remote_compiler.spin and it should work.
    At the moment is has the standard object set from the Propeller Tool loaded,
    so if you want to use TV_TEXT, etc in your OBJ it will work.
    OBC
    Post Edited (Oldbitcollector) : 5/26/2009 5:04:50 AM GMT
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2009-05-26 04:31
    Can promise it will stay up,
    That must be a really special server. hop.gif Can I please have a few smile.gif
    edited 2009-05-26 05:04
    Bah! Typo.. fixed..
    Just found an issue with ED. I can't seem to get it to load copied .spin files
    from my windows machine. Must be some translation issues.. Tracking it down.
    No issues with creating files on the prop and bringing them into Windows.
    OBC
  • hinvhinv Posts: 1,256
    edited 2009-05-26 05:08
    Pretty soon you will have a network operating system for it so you can fetch binaries and files off the internet and run them on your proputer!
    edited 2009-05-26 05:12
    OBC, fantastic job!
    JMH
    edited 2009-05-26 05:18
    I'd lay odds it's a Unicode issue. I'd be _very_ surprised if your propeller editor can cope with UTF-16 files [noparse]:)[/noparse]
    edited 2009-05-26 18:03
    hinv said...
    Shhhhh! You're giving away part of my "evil" plan.. [noparse]:)[/noparse]
    OBC
    edited 2009-05-27 00:30
    Quick update on .spin file compatibility using ED.
    For some (yet unknown) reason ED isn't handling .spin files without saving them as text files. Works find if you convert them first.. Still looking into this.
    OBC
  • mparkmpark Posts: 1,336
    edited 2009-05-27 00:44
    Is this not a Unicode issue as Brad surmised? Exactly how are you saving or converting to a text file?
    If you compare an offending .spin file to its corresponding text file, is the former about twice as big as the latter?
    edited 2009-05-27 01:35
    mpark said...
    That's the process I'm in right now.. It looks like .spin files have a 0 character every other letter. I've managed to fix that here easily enough. Now I'm hunting down an extra CR.
    When I'm finished you should be able to open ".spin" files (a bit more slowly than .txt) and then save them out as .txt with ED.
    OBC
    edited 2009-05-27 02:15
    Revised version of ED for this project is attached to the top of thread.
    Now detects & imports .spin files on load (recommend calling them .spn)
    The translation of .spin takes a little longer, (as expected) but works fine.
    OBC
  • BADHABITBADHABIT Posts: 138
    edited 2009-05-30 07:43
    I have been thinking about this concept and what its usefulness could be.· rolleyes.gif
    It would be a great thing if the prop tool was online with ppl collaborating.·The objects w/in the IDE could be, and ideally·would be added to regularly and well categorized with the eventual goal of creating visual building blocks able to be layered together with timing separations and variable creation - maybe even a chip picture with radio/checkboxes around it that would enable one to control i/o, its timing and/or frequency.
    Because of the Propeller's easy object integration and the huge mental powers shocked.gif that could potentially be brought to bear from this multi-talented community the creation of an infinite quantity of resources (bit of a stretch, but it sounds good) could be created for simple program assembly and an even·more rapid development phase than what is currently possible.
    Maybe cloud computing is an apt term for this project. Not·because of an old cliche and·its conotations, but because that is where our heads are. (behind our propellers)· tongue.gif
    BH
    edited 2009-05-30 08:33
    BADHABIT: Since Parallax would not open it up, others such as BradC (BST), mpark (Homespun), Praxis and others have made alternatives. Now the horse has bolted, I think it is too late for Parallax, even though they have just been inspired to make an update to PropTool.
    · Home of the MultiBladeProps: TriBladeProp, SixBladeProp, website (Multiple propeller pcbs)
    · Emulators: Micros eg Altair, and Terminals eg VT100 (Index)
    edited 2009-05-30 21:04
    Indeed, but it appears to be a perfect community project in a community that has an immense knowledge backing along with the capability to physically assemble the beast. Almost everyone here has a specialty in one of the many classes of function with a varying degree of knowledge and capability, ranging from expert to not so expert, in many of the other functions that tie in to their specialiity. It is with this backing that this project could go forward.
    If·the Fathers of the underlying technology have not the desire to see this to it's ultimate completion, then it is up to the community behind it to take up where they cannot/will not/have not(et al..), in order for the community to reach it's ultimate capacity in bringing to life the ultimate. I would suspect it is not true and they do wish for there to be the maximum capabilities for their creations as well as allowing them to do, and have done,·what can be did or done while spending the least amount of time·and go far beyond what any other has done or gone,·and the continued going on of the doing and going as long as doing and going on are things that need to be done.
    Already it has been proved by them that they are willing to lend resources·and technical vision to many other esteemed undertakings, so·one shouldn't go so far as to say that they have no desire to extend their product/s, but it just may not seem like an econimcally sound idea to throw extensive rNd monies at something that they are not sure if everyone wants.
    P.S. I honestly think that here is·no manly undertaking that this community could not do or exceed at,- from damn building to atom splitting. If the community were to continue to thrive and continue in it's endeavours, that would be Parallax' ongoing legacy.
  • jazzedjazzed Posts: 11,803
    edited 2009-05-30 22:35
    @BH, I've started some "graphical" tools this year. When I read "Visual Building Blocks" some how dragging lines from one box to another comes to mind. I've seen a "C builder" program that makes widgets for "if, else" etc... statements. I'm not sure how useful this kind of thing is for anyone beyond the "what's an if statement?" phase though. Maybe you can give more concrete examples of thing you would like to see?
    It seems this part of the discussion belongs in another thread.
    --Steve
    Propalyzer: Propeller PC Logic Analyzer
    http://forums.parallax.com/showthread.php?p=788230
    edited 2009-05-31 06:41
    Im not really sure how it would evolve, and perhaps this portion of the discussion begs for a·new thread, but I think that eventually it may be possible to create. I'm only talking about it·in this one·because this is where the foundation has been lain. There is another thread that JMH started where the idea was created, so it could have gone there too. I'm not sure if this is anywhere near his original idea, but it is where that idea led me.
    I'm not thinking·so much visual like VB where you drag boxes around and make buttons and such(although that functionality for gui making would be insane), but perhaps short segments of code that do one thing or another, then a block that ties them together. In my mind it is something like an object exchange that is more of a library exchange. The library would have anything from full blown objects to small grabbable snippets that could be dropped into place. Users would still need to know the underlying language, but implementation would be faster. Such an arrangement would enable users to quickly develop their code with a minimum of typing and know that the code that was plugged in is going to work as efficiently as possible in the situation. Usually visual type things add bloat and sluggishness, but I think that if it evolves from plug in code to plug in units much of that inefficiency that usually comes with that could be avoided.
    edited 2009-05-31 10:05
    Cluso99 said...
    I'm not quite sure I'd see it like that. Parallax have a very firm position on releasing their PC based code. What Parallax did to enable my work was release the source code for the bootloader and interpreter.
    Now I can't see the view "it's too late for Parallax" as whichever way things go, they win. Parallax sells hardware, and the software we have developed all helps enable people to use their hardware.
  • heaterheater Posts: 3,370
    edited 2009-05-31 10:27
    BADHABIT said...
    I would suspect it is not true and they do wish for there to be the maximum capabilities for their creations as well as allowing them to do, and have done, what can be did or done while spending the least amount of time and go far beyond what any other has done or gone, and the continued going on of the doing and going as long as doing and going on are things that need to be done.
    Err, what? I think I agree with you but this is giving me headache[noparse]:)[/noparse]
