A good deal
Did you know?
http://www.futurlec.com/P8X32_Controller.shtml
Does the curiosity killed the cat?
Nyamekye,
Uff
is useful only for testing
Did the curiosity kill the cat?
Extra parts to be purchased.
Jim
Notice the top of the page says "Coming soon" but next to the ORDER button it says "Available now". I emailed Futurlec asking them if the board is in-fact available now and for details regarding the EEPROM (if-any).
David
I couldn't see the Prop anywhere so I had to download (downThemAll) all the individual catalog PDF pages and kept searching through them until I found this one.
Can you read Thai? Nah, didn't think so, but it definitely has a 24LC256 EEPROM (why would you think otherwise).
*Peter*
I like the very last sentence.
*Peter*
Properties MCU P8X32A.
• the MCU 32 BIT, 8 COG MULTIPROCESSOR, RUN 80MHz.
• DIP TYPE 40 PIN, 32 PIN I / O PORT.
• working pressure 2.7-3.6 VDC, I / O can SOURCE / SINK flow is 40 mA at 3.3 VDC.
• RAM storage within CODE 32KBYTE, speed of operation of the MCU 20 MIPS / COG.
• In case INPUT PORT been used as a pressure not exceeding 2.7 - 3.6 V (for board ETBASE.
PX32 V1.0 receive no more than 3.3 V).
PORT KEY BOARD (PS2) Form used to MINI DIN JACK KEY BOARD PC.
PORT MOUSE (PS2) MINI DIN JACK using a Mouse to the PC.
PORT RS232 using a 5 PIN WAFER the PORT RS232.
PORT VGA D-SUB 15 PIN Form used to display VGA.
PORT TV (AV) to use a RCA JACK TV channel in AV.
PORT MIC to use a 2 PIN WAFER with MICROPHONE.
PHONE JACK Use a PORT HEADPHONE AUDIO OUT to the expansion.
PORT I / O 8 PIN Form 10 PIN HEADER, with the I / O that does not exceed 3.3 V.
> Properties Board ET-BASE PX32 V1.0 • Use MCU P8X32A, 40 PIN DIP TYPE, X 'TAL 5 MHz internal PLL can be RUN 80 MHz.
Rubber • EEPROM 24LC256 (32KBYTE) used for storage CODE PROGRAM.
• POWER SUPPLY 6 - 12 VDC with a IC SWITCHING LM2575 and LM3940 for 5 VDC for 3.3 V.
• Board size 6.2 X 8.1 CM. Standard ET-BASE.
• Set includes ET-BASE PX32 V1.0.
1st Board ET-BASE PX32 V1.0,.
2nd disc CD-ROM program guide. Sample program on RUN WINDOWS XP / VISTA,.
3rd Line Download ET-RS232 5 PIN TO DB 9 PIN.
• PORT to use ON BOARD.
ET-BASE PX32 V1.0 for single board that can be used with various devices.
For example, many of the port VGA, PORT on TV (AV), PORT KEY BOARD PC/PS2,.
PORT MOUSE PC/PS2, PORT RS232, PORT MIC, PORT HEADPHONE.
Board that you can write programs on a PC and then to Download application.
Immediately.
ET-BASE PX32 V1.0 using MCU 40 PIN DIP size P8X32A number of companies.
PARALLAX that high by more than a BASIC STAMP MCU 32.
BIT, 8 COG MULTIPROCESSOR MCU as a number 8 in a single Chip.
Development program using SOFTWARE TOOL "PROPELLER" based on.
WINDOWS XP / VISTA is a SOFTWARE program that can write, COMPILE CODE.
DOWNLOAD CODE and through PORT RS232 (in case if no PORT RS232.
On the PC to use the PORT USB can be set using ET-USB/RS232 MINI.
Go to the PORT RS232) to write the English language "SPIN".
This allows developers to write applications easily and quickly and with LIBRARY VGA, TV,.
KEYBOARD, RS232, MOUSE can be used to work. Do not write own.
If you still have a legacy RS232 port, that is...
Good Investigation work ..
I love this bit .
John
'Necessity is the mother of invention'
Those who can, do.Those who can’t, teach.
I noticed that is says it has a MAX232. Hopefully it is just the generic "description", but it is really a MAX3232. Will the MAX232(5V chip) work well with the propeller anyway?
Doug
Maybe this isn't a schematic but the image from the ETT catalog is nice and clear in case you hadn't realized it. With a picture like that I could just about draw a schematic for it but why bother because we have enough info already.
*Peter*
Thanks for posting the picture; I missed that one. Now I can see the ten pin header with eight GPIO ports brought out. Yup I think we know enough about this puppy by now. BTW Futurlec still never replied to my email - even after a second transmission. Dead channel.
Regards, David
http://forums.parallax.com/forums/default.aspx?f=25&m=293571
Maybe a family resemblance?
"They may have computers, and other weapons of mass destruction." - Janet Reno
