For Scribbler users! Check this out. — Parallax Forums
RobofreakRobofreak Posts: 93
edited 2008-01-07 02:57 in Robotics
Hello, people with Scribblers. I have made this (I think) cool·program. Took me a while... It's a light follower / object avoider program, that when the center CDS cell sees a certain light level, goes into darkness seeking mode. When in dark seeking mode, and it sees a certain darkness level, it goes back into light follower mode, all while avoiding objects and stalls. So it transitions a few times, then goes into just object avoiding mode. Does that for a while, then goes back into dark / light follower mode. Then repeats everything over and over again...·Just upload it to your Scribbler, and it should work. Takes about 4 - 5 seconds to load. But before you do, you should recalibrate your light sensors with the Scribbler GUI recalibrate program. I did it, and I had to adjust the settings a bit... Tell me what you think afterwards please! (Also, you might want to check back every so often, because I keep finding ways to make my program better.)
P.S. Make sure you have fresh batteries! And read the directions, either at the beginning of the program, or the attached·Word file below. They're not long, just 3 small steps. burger.gif
Program last updated: 11/10/07, 3:00 p.m.
Austin Bowen,
Robo-freak.com
"One must watch out for mechanics. They start out with a sewing machine, and end up with the atomic bomb"
Post Edited (Robofreak) : 11/10/2007 7:59:15 PM GMT
  • WhitWhit Posts: 4,194
    edited 2007-11-07 04:17
    Thanks! Nice site too...
    Whit+
    edited 2007-11-08 04:20
    Thanks for the updated code!
    Whit+
  • RobofreakRobofreak Posts: 93
    edited 2007-11-08 18:24
    Sure! Anytime. Um, you might want to check back every so often, if you want to. I keep finding ways to make the program better, more flexible.
    Austin Bowen,
    Robo-freak.com
  • LightRustLightRust Posts: 1
    I'm going to check your program out and get back to you
