Hybrid Robot Power Plant => Oversize Boe-Bot — Parallax Forums
edited 2010-03-15 04:07 in Robotics
Copy the code below the dotted line and paste it into the same forum posting in the new forum, replacing the old one.
IMPORTANT: Be sure to do a 'Preview Post' first to make sure it's what you want!
Project Purpose:
_
To develop an outdoor robot power system which can deliver many more amp-hours of energy than batteries, using a gas engine and a modified automobile alternator._The initial purpose was not to build a robot, but to prototype a Hybrid Power Plant that I_could use on an over-the-snow robot. A battery would merely support surges in current demand, like a big capacitor. It wouldn't be there to provide power for anything more than half of a minute. This could lighten my load and extend operating time, particularly for a GPS autonomous robotic project.
_
After building the_Hybrid Power Plant_and running some tests on_it with_real loads I_decided to put some motors on it and test it out_on an R/C robot requiring_much more current. This additional step turned out to be a_big eye-opener, and gave me another purpose to the project - to test the system on a robot.__
_
Mechanical Design:
_
Coupling an alternator to a small gas engine requires that the shafts be perfectly aligned. Small "spider couplings" provide_for up to_1 degree of angular misalignment, and 0.01" of horizontal offset. To_align the engine and alternator I decided to make this a machining project (I had tried other ways before, and failed!). Using belts and pulleys would be out of the question due to_the introduction_of more moving parts, increased system slop and noise, and danger of moving parts.
_
The Hybrid Power Plant would_was built by mounting the engine and alternator on their own plates, using a 3/4" aluminum_rod as an additional alignment (and to double as_handles)._Although the alternator had two mounting holes, I opted not to use these since they_were_offset at different z-axis places. Instead, I machined the front of the alternator flat and drilled/tapped four holes in known locations. These holes allowed me to attach it to its mounting plate and perfectly identify the center shaft. The Honda mini 4-stroke engine (GX35) really needed a clutch - the power curve is way up in the RPMs and it generates little torque until 3,500 RPM. Staton-Inc makes a $60 clutch that has perfect mounting holes, enabling it to be mounted to a plate. I also attached_the back and bottom of the engine to four more mounting locations on the base plate._The thought was that by mounting the engine to some sizeable chunks of aluminum I would smooth out vibration_by closely coupling it to a mass.
_
The parts are all 3/8" 6061 aluminum, anodized clear. If you want to copy this design, you can download my drawings below (I have provided them in DXF format). You will need to scroll down to find them since I'm only given five (5) attachments per post._
_
The_Hybrid Power Plant_now looked like this:
_
_
Electronic Design:
_
Going back to my_purpose, the initial idea was that I'd only build and test a portable Hybrid Power Plant_- I didn't plan on actually using this sytem on a robot._Therefore, my electronics_intiaially_consisted of the following:
  • Alternator_current/voltage regulation_Although I chose a "regulated 1-wire output" alternator from a 1992 Toyota pickup, I determined the regulator_caused some problems for this little engine. It_was difficult to overcome initial_resistance to get the alternator RPMs up_4-6,000 where it produces a lot of power. The alternator was opened up and the voltage regulator was bypassed, bringing the field current outside for my own limiting. This_eliminated all resistance and allowed it to turn really freely._The voltage regulator_design we came up with allows me to limit field current with external resistors, and charge the battery with a shut-off feature if 14.5V is attained (or other voltages,_as set by a potentiometer). This_provided a regulated voltage for motors and other loads, a battery charger, and_15-20 amps of current should I need it. A schematic is below:
_
_
  • Throttle control / RPM measurement The amount of current generated relates closely to engine RPM. The higher the engine throttle, the more power! The initial_system_uses an SX28AC/SS (on an SX28 Proto Board)_to count magneto pulses, and a servo to manage the throttle._Having measured_current at different RPMs, the goal was to set the engine at known RPMs and known current output._Controlling these variables would ensure that I'm not overcharging the battery (max charge is 5A) and generating more power than I need._Through_this process I_destroyed many pants and shirts with acid from overcharging batteries. If I was to generate lots of current, I'd have to use what I couldn't put in the battery. With lots of help from a key friend, the following circuit was developed:
The following SX/B code is an open-loop, potentiometer-controlled servo throttle for the above schematic. This example doesn't count magneto pulses at the same time. I've got both pieces of code working independently, but have yet to integrate them using the SX's RTCC/ISR features.
' Potentiometer Throttle Control
DEVICE_________ SX28, OSCXT2, TURBO, STACKX, OPTIONX
FREQ___________ 4_000_000
' I/O Pins
Servo__________ PIN_RA.1_ OUTPUT
RCCircuit______ PIN_RC.3_ INPUT
' Constants
' Variables
ServoVal_______VAR_______ WORD
analog________ VAR_______ WORD
_ PROGRAM Start
Start:
__ LOW RC.3
__ PAUSE 5
__ RCTIME RC.3, 0, analog
__ ServoVal = analog/2
__ ServoVal = ServoVal+130
__ PULSOUT Servo, ServoVal__ __'__ PAUSE 20
__ PAUSE 20
__ GOTO Start
_
  • Car Headlights / HB-25s and_12V_Motors for a Load_To test out the system I needed a big load. I used two 50W high-beam headlights, two massive 12V Groschopp Planetary Gear motors, and_two HB-25s to control the motors._The HB-25s were connected to the SX28CA/SS Proto Board for control (nothing important here - just a PULSOUT pin, value)._I_tested the system out with some big loads, and it worked great._It ran for an hour, keeping the battery charged and headlights on high-beam. I quickly learned that an entire power management system would have control over engine RPM and alternator field resistance. I probably wouldn't care much about the battery since it would always be charged. I'd only generate current_if I was using the power._I was using about 15-20A at 12V. This is what my load looked like:
The Oversized Boe-Bot
_
I was satisfied that the Hybrid Power Plant would perform really well, and I was ready to shelf it so I could design a robot around the concept. However, the same friend who helped me with the electronics pointed out that I could further prove out the concept if I simply mounted wheels to the Hybrid Power Plant. It made sense considering I hadn't been able to test the motors with a load. Then I wound up with this:
_
_
_
I switched the HB-25s straight over to R/C function and added a transmitter. I set the engine throttle with a potentimeter/servo (SX/B code below) and didn't bother counting magneto pulses. Away we went! Videos are posted in the next message._Under R/C control the whole system works great. I'm certain the Hybrid Power Plant could be used on an outdoor robot. The videos show the first pilot run when I had 16_Ohms of resistance in the alternator field, but now there's only 8_Ohms and it runs much faster._It'll lay down scratch, slide around corners and reverse at full throttle (I completely destroyed an HB-25 doing this, by the way).
_
The oversized Boe-Bot runs better_backwards due to weight distribution. Since the Hybrid Power Plant was never supposed to roll, this is something I'll fix on the next project._Moving the battery around lets it run better in the Boe-Bot's "normal" direction_with the motors up front._
_
_
Safety First
_
I nearly had several accidents with this whole project. I think they're worth sharing so we can all keep our hobbies for the rest of our lives. First, I had to develop and prototype the magneto RPM circuit with the engine running on my desk, inside the office. It was necessary to attach an SX-Key, a PC and let the system run to develop the code and to tweak the signal conditioning circuit from the magneto. This really shouldn't have been done indoors due to CO poisoning (and noise). I kept doors and windows open, but it was a bad idea and I knew it at the time. Nothing bad happened to me, but I wouldn't do it that way again. Other bad things happen from running an engine on my desk. Once my laptop mysteriously shut down due to vibration. Next time I'll run the engine outside and use several serial cables (this is the same way we used to test BASIC Stamp projects on R/C airplanes, such as the dual-engine synchronizers).__
_
Another time I was a bit unaware of the power I was generating. I had connected the battery to the alternator and increased the throttle to a high RPM. I then disconnected the battery and easily dumped 100A into the voltage/current regulator circuit. The_electronics truly exploded and caught fire - I didn't know if I should have_reached for the fire extinguisher or tried to cut the engine first. I_decided to cut the engine_first._Meanwhile I_exploded capacitors, LEDs and a 25 Ohm/1 W_aluminum housing resistor. The trajectory of all components was away from me. Could have been avoided by keeping the battery connected.
_
I also experimented with some smaller spider couplings to connect the alternator to the engine. Though they were rated for much higher RPMs than I was using, a small misalignment sent_some parts into the air._I wasn't standing_along the axial line of rotation, so I didn't get hit. Before any schoolchildren get to see this I'll need_to build a shield around the coupling.
_
I was prepared for_most of the accidents, but didn't quite anticipate the fire on my desk.__
_
Credits
_
My friend John from Tigerbotics provided_tons of help on the whole project, especially the electronics. Without his assistance I'd still be using a hacksaw to cut aluminum,_trying to understand the "how" instead of "why" and be somewhat frustrated. Since I can't help him with his projects the same way,_my intent with posting the whole project is that others could benefit the same way. __
Post Edited (Ken Gracey (Parallax)) : 10/26/2006 9:48:51 PM GMT
Image Attachment :
thumb.aspx?a=9984&ImageID=4453
_ 129KB (image/pjpeg)This image has been viewed 14105 time(s).
Image Attachment :
thumb.aspx?a=9985&ImageID=4454
_ 11KB (image/gif)This image has been viewed 14657 time(s).
Image Attachment :
thumb.aspx?a=9986&ImageID=4455
_ 19KB (image/gif)This image has been viewed 14294 time(s).
Image Attachment :
thumb.aspx?a=9987&ImageID=4456
_ 67KB (image/pjpeg)This image has been viewed 13923 time(s).
Image Attachment :
thumb.aspx?a=9988&ImageID=4457
_ 113KB (image/pjpeg)This image has been viewed 13992 time(s).
«13
  • Steve JoblinSteve Joblin Posts: 784
    edited 2006-10-26 21:25
    Awsome!!! One thing missing... video!· have any movies of this in action?
    edited 2006-10-26 21:27
    Hang on - there's more. I'm running into some trouble uploading videos and design files. It's going to take me an hour to be done.
    edited 2006-10-26 21:31
    Video #1 is attached.
    edited 2006-10-26 21:34
    Video #2 is attached.
    edited 2006-10-26 21:49
    DXF drawings are attached. Use them as you see appropriate.
  • BeanBean Posts: 8,129
    edited 2006-10-26 22:48
    Ken,
    You were quite brave (or something else) to run that in the garage with the car in there too!!!
    Bean.
    Cheap used 4-digit LED display with driver IC·www.hc4led.com
    Low power SD Data Logger www.sddatalogger.com
    SX-Video Display Modules www.sxvm.com
    "People who are willing to trade their freedom for·security deserve neither and will lose both." Benjamin Franklin
  • stamptrolstamptrol Posts: 1,731
    edited 2006-10-26 22:59
    Ken,
    Very nice !!! Always great to see someone push the envelop a bit.
    Regarding the spider-type coupling, most small gen-sets (up to maybe 10KW) mount the alternator rotor right on the engine shaft (with either a female Morse taper or a rigid solid coupling) without a front bearing in the alternator. The frame of the alternator then is only holding the stator windings and maybe a small steady bearing on the outboard end of the alternator. Reduces the pain of getting things lined up and vibration free.
    Really fine work all around!
    Tom
    Tom Sisk
    http://www.siskconsult.com
    edited 2006-10-26 23:05
    Tom,
    I'm not sure I understand the mounting connections you're describing. Could I trouble you to draw me a little picture?
    Update: I understand now. The shafts provide alignment on a single bearing system. I've seen the couplings from Northern Supply designed to connect pumps to engines - they're a single piece. I got it now.
    Post Edited (Ken Gracey (Parallax)) : 10/26/2006 11:28:43 PM GMT
    edited 2006-10-27 12:44
    Ken,
    No problem; BTW, not meant as criticism of the design!
    I used the same set up back about 1980 to build an eddy-current coupling to drive the main hoist drum on a crane. Just used the rotor out of an alternator mounted to the shaft of a motor that ran at constant speed.
    After several less than wonderful attempts at alignment, a machinist at the university's shops put me onto the idea of the rotor being mounted only to the motor shaft. He just used a piece of 3" shafting, about 6" long, bored out to the motor shaft size on one end and the rotor shaft size on the other.
    I'm also going to find a picture of a LeTourneau tree-crusher I used to maintain. Your machine's layout looks remarkably like the crusher....except it had an 8-cylinder diesel driving about a 300 KW generator, 125 HP DC traction motors on each of the 3 wheels ......and weighed in at 35 Tons, and stood 15 feet high. The company also had a bigger one at 75 Tons but I didn't have to work on that one.
    Cheers
    Tom Sisk
    edited 2006-10-27 13:07
    · Ken,
    ·· Attached are three shots of the LeTourneau tree crusher. Photos are by David M. Moehing, Mississippi U, www-forestryimages.org.Used with permission.
    · This what your Boe-bot can grow into!
    Cheers,
    Tom Sisk
    Tom Sisk
    768 x 512 - 127K
    768 x 512 - 144K
    768 x 512 - 132K
  • John R.John R. Posts: 1,376
    edited 2006-10-27 13:27
    Personally, I would have liked to see the hydraulic version you initially planned on smile.gif
    Good work, it looks like you have a strong base to build on.
    John R.
    8 + 8 = 10
  • Tronic (Greece)Tronic (Greece) Posts: 130
    edited 2006-10-27 15:26
    I wonder if its legal (and safe) to leash it on the streets fully automomous, with sensors, cameras, GPS etc... Like a really big boe-bot!· Do you think it will need licence plates? tongue.gif
    Regards Thanos
    Greekbotics: Greek Robotics Forum
    (Translate it using Babelfish)
  • parskoparsko Posts: 501
    edited 2006-10-31 12:31
    Ken,
    You could use two universal joints to couple the altercator and engine, also... Check McMaster-Carr or MSC. But, it is certainly a percent or two more efficient using Stamptrol's idea of mounting direct.
    -Parsko
  • SSteveSSteve Posts: 808
    edited 2006-11-01 02:20
    Ken Gracey (Parallax) said...
    That puppy is loud! I hope you're wearing hearing protection when you're using it indoors. Otherwise you won't have much to protect in a little while.
    OS-X: because making Unix user-friendly was easier than debugging Windows
    links:
    My band's website
    Our album on the iTunes Music Store
  • Justin SaneJustin Sane Posts: 35
    edited 2006-11-07 18:21
    I wonder what's the max of weight load it can pull?
    ·"Imagination is the one weapon in the war against reality."
    -Jules de Gaultier
    edited 2006-11-07 18:40
    Justin,
    That would also be a function of speed... You could gear ratio something down to pull a building if you wanted to, but at the sacrifice of speed.
    The real measure would be how much horse power the hybrid unit could deliver after converting from gas to electric. How energy efficient
    is the conversion? ...and then again, to answer your question, how energy efficient are the drive motors used in combination with the electronics?
    Beau Schwabe
    IC Layout Engineer
    edited 2006-11-08 15:57
    Yeah, I checked out the video, looks like it got the speed.
    This is one cool concept, since it is gas powered robot that can be controlled without any kind of hard mechanism.
    -Jules de Gaultier
  • Brian_BBrian_B Posts: 844
    edited 2007-01-27 22:28
    Ken,
    Just seen this , Where did you get the motors
    Brian
    edited 2007-01-28 01:38
    Hi Brian,
    From eBay, surplus. They were really low-cost ($30 each) and the guy had 14 of them!
    I'm about ready to unleash version 2 of this robot. I've really tidied up the whole system with a mini alternator, no clutch, and less parts everywhere.
    edited 2007-01-28 01:46
    Cool ,can't wait to new version
    Brian
    Post Edited (Brian Beckius) : 1/28/2007 1:57:09 AM GMT
  • HenrymouHenrymou Posts: 128
    edited 2007-01-30 02:15
    COOL! I think that your project is neat-O! Your video is awesome, my parents are impressed with your sleek design. My dad is impressed with your documentation. This is an interesting example of an engineering science fair project, like the one I hope to do for the Synopsis Science Fair! Check out my recently built Seven Segment Decoder-Driver! Good Luck!
    -Henryhttp://forums.parallax.com/showthread.php?p=628728 yeah.gif
    edited 2007-01-30 22:15
    Ah so you did go with the Mini-Cooper alternator. My car still starts, so you didn't salvage it from me. [noparse]:)[/noparse]
    Paul Baker
    edited 2007-02-05 17:23
    This looks like a great 'mule' for around the home totes. Just provide it with R/C remote and it can pull your lawn mower or a cart full of odds and ends.
    I just wish I had the machine shop resources to enlarge my projects. It is amazing how much hardware a microcontroller can actually manage.
    "If you want more fiber, eat the package.· Not enough?· Eat the manual."········
    ···················· Tropical regards,····· G. Herzog [noparse][[/noparse]·黃鶴 ]·in Taiwan
  • bassmasterbassmaster Posts: 181
    edited 2007-02-05 21:37
    I love it, it can double as a generator when the power is out, here in TX I have $400 - $500 electric bills, and have been thinking seriously about soundproofing an area in the garage with a gasoline generator and powering the electric dryer etc with it. I did the math and it will save me 1/2 the cost a month of just the dryer usage. ( we have a family of 5). We are in a Coopt and used only 2500kw last month with the heater at 60 at night and 70 in the day still cost us $300 bucks. Texas electric bills bite! we are the highest cost in the nation.
    Another project I am playing with is a simple $5.00 car 110v AC/DC inverter 75W I got from Ebay and an older trolling motor battery from my bass boat that is just a little weak for tournament fishing. Hooked (no pun) it up to a 12v solar panel, and its been lighting my garage for 2 1/2 months so far.
    Been thinking of daisy chaining the other 4 batterys I have together and getting some more juice, but those big solar panels are expensive.
  • bgthreebgthree Posts: 14
    edited 2007-02-06 01:54
    Ken - that is an AWESOME project - I love the idea.
    Don't know how I didn't see this sooner!
    edited 2007-02-07 06:47
    Use a diesel generator and you may save more. Diesel is intended for constant torque uses and if the fuel is completely filtered for the fuel injectors, you can run a wide variety of oils [noparse][[/noparse]like recycled McDonalds stuff, safflower oil, etc.] Gasoline with alcohol is corrosive and may eat up your machine.
    Having a mobile, self-propelled generator is really a useful application for working with power tools in remote areas.
    A lot of the Japanese gas generators have excellent sound-proofing already. The real problem is ventalation of the CO in an enclosed space.
    edited 2007-03-21 16:28
    Paul Baker (Parallax) said...
    Paul , I orderd a mini cooper alternator. it's not much smaller than the one ken using already , but has a nicer mounting bracket :- )
    Thank's Brian
    www.truckwiz.com
    ·"Imagination is more important than knowledge..." ·· Albert Einstein
    edited 2007-03-21 16:50
    Brian,
    I haven't found an alternator with a mounting system I like, so I'll take a look at the mini Cooper design. For my current hybrid robot (not yet posted, but soon!) I've drilled and tapped the face of the alternator so I could mount it on a plate of aluminum. It's too difficult to figure out the XYZ spatial relationship of the mounting holes of the existing alternators - they're really made for aligning belts instead of shafts.
    I'll be able to share the latest project shortly.
    edited 2007-03-21 17:17
    Heres a link.
    http://www.jegs.com/webapp/wcs/stores/servlet/product2_10001_10002_749983_-1
    post edit: ·This link is for a differnt alt than a mini cooper one
    I'll post a photo of the mini cooper alt. tonight
    Thank's Brian
    www.truckwiz.com
    Post Edited (Brian Beckius) : 3/22/2007 3:52:46 AM GMT
    edited 2007-03-21 22:05
    Heres the mini cooper alt photos
    Thank's Brian
    www.truckwiz.com
