Automotive/Marine applications
Hi everyone, I just joined.
I have a BS2 Stamp that I mucked around with some time ago and it was
loads of fun. I managed to make a home alarm with outgoing text-
paging alerts, an inbound telephone/dtmf interface, and also
manipulate some X-10 appliances.
Have any of you made any useful Auto/Marine applications?
For my boat I can think of things like manifold heat sensors,
automate the (crappy) fridge thermostat, tank level sensors etc. with
graphical output on the 4-line LCD display, and audio alarms as
required.
Any creative input is most welcome!
required.
how about water speed, wind speed, fuel flow all put in to give you
distance to empty?
or maybe GPS and fuel level, but that's not as much fun.
Heck if you put in a GPS, you could put in a cruse control.
Humidity sensor and cabin ventilation when in port ?
Dave
--- In basicstamps@yahoogroups.com, "ii_awesum" <ii_awesum@y...>
was
with
> required.
> Thanks,
> Mike
sensor mounted on the rudder post that
would determine the amount of left and right rudder rotation from dead center
and send it to a BS2 for
processing. An LCD mounted on the helm would then be used to graphically
indicate the amount of left or right
rudder rotation.
Now if I just knew how to do.
"Dave Mucha " wrote:
> If you are talking creative applications,
> distance to empty?
> Dave
> was
> with
> > required.
> > Thanks,
> > Mike
> To UNSUBSCRIBE, just send mail to:
> from the same email address that you subscribed. Text in the Subject and Body
of the message will be ignored.
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
with a GPS and make and autopilot (an "Iron Mike" as we used to call them).
Several possible ways to to let the stamp know what position the rudder is
in. IR detectors being an easy place to start. There are positional sensor
packages out there too. Are you talking sail or power?
Jonathan
Original Message
To: <basicstamps@yahoogroups.com>
Sent: Saturday, December 07, 2002 9:10 AM
Subject: Re: [noparse][[/noparse]basicstamps] Re: Automotive/Marine applications
> I was thinking of a rudder position indicator. It would take some type of
center and send it to a BS2 for
> rudder rotation.
> > distance to empty?
> > Dave
> > was
> > with
> > > required.
> > > Thanks,
> > > Mike
and Body of the message will be ignored.
used it would have to be able to
withstand the humidity and temperature ranges. Interference from other onboard
systems could also be an issue.
The autopilot would make an interesting project but it would be way beyond my
expertise. If I built an autopilot
I would probably also need to make a system that called 911 after the autopilot
failed.
Like someone previously mentioned, a system that monitors various engine and
temperature parameters would also be
interesting.
I have to tell you that I can think big but in reality do very little when it
comes to electronics.
Jonathan Peakall wrote:
> Funny you mentioned that, I was thinking of using the stamp to interface
> Jonathan
Original Message
> From: "pslive" <pslive@m...>
> > rudder rotation.
> > > distance to empty?
> > > Dave
> > > was
> > > with
> > > > required.
> > > > Thanks,
> > > > Mike
interest here :-).
Rudder (drive) position indicators are also feasable, I already have
a analog trim indicator but that shouldn't be difficult to interface
using an A/D convertor. The Rudder angle would require a retrofit
of a sensor on the tiller arm and I think these sensors are readily
available at marine shops for a modest cost. You can buy a stick on
position indicator that attaches to your steering wheel hub for $35
US or so and I hear are pretty good for reference purposes. Of
course if you want to go electronic...
One other thing that came to mind is an computerised trim tab
control, which can be purchased off the shelf - but for what I
consider a high cost ($400+). I suppose the dual-axis inclinometer
is a costly component.
There are already plenty of GPS and autopilot interfaces readily
available down to the PDA level and for the cost might be more
practical to buy outright. I have a Magellan handheld GPS which
does what I need (heh heh, for now...but I hope to get a PDA based
GPS sometime for the added flexability).
Fuel flow meter, that's something I plan to purchase off the shelf,
and costs $200 US. No interface for this model except to tap into
the flow sensor to collect data. You can get very sophisticated
models that will interface to autopilot, GPS, and chart plotter.
They indicate RPM, fuel consumption, fuel remaining and feed this
data to the other devices which is real sweet but cost prohibitive
at $800+ for my class of boating.
Anyways, enough of my rambling. I'd like to start small with the
level sensors and fridge thermostat. I think the fridge control is
a no-brainer using the temperature sensor and a relay. What type of
sensors are available for level sensing? My water tank is embedded
in the hull
and I only have access to the rear wall of it thru a 5"x8" access
hole. The 2 options I suspect are an external inductive type or
cutting a hole for a rheostat type sensor. Inductive one would be
the cleanest method.
Thanks all!
--- In basicstamps@yahoogroups.com, "Jonathan Peakall"
interface
call them).
rudder is
positional sensor
> Jonathan
Original Message
some type of
from dead
graphically
> > rudder rotation.
give you
> > > distance to empty?
> > > Dave
<ii_awesum@y...>
and it
> > > was
text-
etc.
> > > with
as
> > > > required.
> > > > Thanks,
> > > > Mike
Subject
Subject and
Temp control is easy, I just made a controller for my hot tub. Same basic
thing. I used an inexpensive LM35DZ for the sensor, and it was easy to
interface. Mail me off list if you want details.
It sounds like you want to make a fuel/water level indicator. One of the
classic problems of fuel/water gauges is of course movement. Rheostat/float
sensors are almost usless except at rest. So I was thinking, what about a
pressure sensor on the output of the tank? Should be easy to interface, and
I would think more accurate under working conditions.
Jonathan Peakall
Original Message
Sent: Saturday, December 07, 2002 10:17 AM
Subject: [noparse][[/noparse]basicstamps] Re: Automotive/Marine applications
> I'm power (26' Bayliner Ciera SB). Looks like there's some genuine
> interest here :-).
> in the hull
> Thanks all!
> Mike
> interface
> call them).
> rudder is
> positional sensor
> > Jonathan
Original Message
> some type of
> from dead
> graphically
> > > rudder rotation.
> give you
> > > > distance to empty?
> > > > Dave
> <ii_awesum@y...>
> and it
> > > > was
> text-
> etc.
> > > > with
> as
> > > > > required.
> > > > > Thanks,
> > > > > Mike
> Subject
> Subject and
water temperature indicator connected to a GPS so you can data log
what temperature the water was when you caught the BIG fish.
engine heat temperature
G-force meter to post just how BIG that wave was.
Can counter to see how many beers you have left before you need to
get back to port.
water speed vs. motor RPM to help fine tune the prop ?
air temperature meter to let you know when the temp is changing,
signaling weather changes, barometric sensor ?
galvanometer?
Dave
was
with
> required.
> Thanks,
> Mike
Regarding a low-cost, dual-axis inclinometer, consider using Analog
Devices ADXL202, which is a dual-axis accelerometer, sensitive to tilt
angles. See both the Parallax and Analog Devices web sites for stamp
code, using PWM and not requiring analog-to-digital conversion. The
Analog Devices application notes are quite detailed, with circuit
examples for filtering, optimizing sensitivity, and other useful
information.
Dennis
Original Message
From: ii_awesum <ii_awesum@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8tHOGIY2WaiS0ISvkllAg_H6Xv3ssjIlp6uNXQu1z0sogmHblLzCiA06hB0NmIhoYxmNSGwAUhaB]ii_awesum@y...[/url
Sent: Saturday, December 07, 2002 10:18 AM
To: basicstamps@yahoogroups.com
interest here :-).
<deleted>
<deleted>
pattern on it that indicates exactly how far in its rotation it is -- you
have multiple devices to read this pattern. You can buy or make your own.
Do a search on Yahoo! for "absolute position encoder" and do some research.
Original Message
> rudder rotation.
http://www.ida.net/users/tetonsl/railroad/graycode.htm
and see if that is interesting??
Leroy
flooded lead acid batteries, make a battery desulfator. Premature death
of a lead acid battery (80% +) is attributable to lead sulfates.
Works well on starter and deep discharge batteries.
Merely build up the output stage only of this NFET schematic (R4, C3,
Q1, L1, L2, D1 and C4). Q1=IRL630 or IRFZ44N, C4=2
http://shaka.com/~kalepa/556alternate.gif
Component values are shown in the PFET schematic,
http://shaka.com/~kalepa/schematic.gif
OR in the original article written for Home Power magazine
http://www.humboldt1.com/~michael.welch/desulfator.pdf
But PLEASE do not email the author of the article as he is extremely
busy on another project and has asked folks to direct any questions you
may have to the BBS
http://pub36.ezboard.com/bleadacidbatterydesulfation
or to me
desulfator@y...
I have lots o pulsing programs for the Stamp line to share. Especially
if you use thermistors to monitor temps of the FET and Diode to enable
running at the edge of the performance envelope.
> required.
> Thanks,
> Mike
C4 is 200uF to 6800uF I use 100V rated caps.
Don Denhardt wrote:
> Sure! If you are not getting a 20 to 70 year life span from your
> may have to the BBS
> or to me
> desulfator@y...
> > required.
> > Thanks,
> > Mike
I have a boat that has a fuel tank that is very long and very skinny, so
normal tank level sensors are no good. I made a fuel flow meter using a
standard commercial flow meter (expensive), and an LED display that showed
either flow rate or fuel quantity remaining depending on selected mode.
I had a passing thought that using a fuel flow meter coupled with a speed
sensor (water speed Pitot), that an auto trim system that trims the boat for
the most fuel efficient trim automatically could be done. With rising fuel
prices that we are getting in AUS this could be a good thing!!
Also, y not just make a heading hold autopilot?
Have Fun,
Dwain.
Original Message
Sent: Saturday, December 07, 2002 7:57 AM
Subject: [noparse][[/noparse]basicstamps] Automotive/Marine applications
> required.
> Thanks,
> Mike
degrees, why not just a pot ?
There are multiple places to put it. on the actual shaft of the
rudder, or on the arm that drives it. should be easy to waterproof.
and is MUCH easier to code for than an encoder.
Dave
--- In basicstamps@yahoogroups.com, Rodent <daweasel@s...> wrote:
> One solution is an absolute position encoder. Its an encoder wheel
with a
- you
your own.
research.
Original Message
some type of
dead
graphically
> > rudder rotation.
I worked 30 years as an Engineer in the lead-acid battery industry and I am
amazed that these vastly inflated claims for battery desulfators keep
circulating. Twenty years life for a lead-acid battery in cyclic service
is absolutely ridiculous and 70 years far exceeds the life of the most
advanced NONCYCLIC designs maintained under strictest conditions.
For anyone interested in a better understanding of the care and maintenance
of auto starting and deep-cycle marine batteries I suggest you take a look
at the vast amount of information presented by my friend Bill Darden at
http://www.uuhome.de/william.darden/ .
Those with lingering doubts might want to visit the Usenet newsgroup
sci.chem.electrochem.battery. If your questions there are initially
unanswered it is because everyone there is probably a bit tired of this
topic. Ask for a one-line summary only and the word "snake oil" will
probably be a part of it.
Jim H
rudder post and rudder arms so I could
fasten something to them. If I used a pot, does that mean that for example:
-if the rudder was full left, the pot would be at minimum resistance
-if no rudder (straight), the pot would be one half resistance
-if the rudder was full right, the pot would be at maximum resistance
Then the stamp would compare the resistance(voltage drop) of the pot to a range
of programmed in values for the
various rudder positions and determine how much rudder to display on the LCD?
Sorry to ask such basic questions but I am new at this.
Does anyone have an example of something like this?
> IF you are talking a single flap (rudder) that moves, maybe 180
> Dave
> with a
> - you
> your own.
> research.
Original Message
> some type of
> dead
> graphically
> > > rudder rotation.
maintenance of auto starting and deep-cycle marine batteries I suggest
you get first hand knowledge of the subject. OR talk to folks that have
had successes in this area.
Reading about anyone's opinion that has no first hand knowledge is a
poor substitute. AND like the old saying goes, opinions are like
rectums, everyone has one.
Desulfation pulsing is a hot area of research with many patents filed
over the last 20 years. Those who have insight into unique designs tend
to keep them close to the vest. It seems the primary benefactor has
been industrial applications where this capability has been built in to
industrial charging equipment.
It has only been recently (in the 100 year history of the lead acid
battery) that desulfation by electronic means have been developed.
Desulfation by chemical means (EDTA tetrasodium salt) also works but has
some drawbacks to it.
If everyone in the United States used desulfating pulsers, the lead acid
battery industry would virtually die out in a month.
Gee I wonder why some lead acid battery folks tend to get a little
touchy about the subject?? I am absolutely amazed that folks can have
an opinion about a subject and little or no experience.
On the other hand, if you want to buy a used car the last person you
might get a straight answer from might be the used car salesman.
For myself, I've recovered too many dead batteries, watched the Specific
Gravity rise as the battery was pulsed and brought back to life; seen
many previously dead batteries start cars and load test in the green
once more to have any doubts about the process.
I've heard from many many folks that were ecstatic over how their dead
batteries came back to life after using a pulser based on enhancements
of Mr. Coupers original design.
One of the commercial desulfating pulsers has a website where a few
folks have taken the time to write about their experiences.
http://www.pulsetech.net/
If you click on "Product info" and then "Testimonials" you can read
about what some folks on this forum must believe to be delusional.
On the other foot, if you have a BS2 stamp and would like to try
something new, cobble a pulser together and you just might save yourself
a ton of bucks by not ever having to purchase a new battery again. You
can get all the free batteries you want by merely recovering those that
others have tossed out.
Now there is a difference in pulsers. The enhanced designs we've come
up with are 5 to 10 times more powerful than what you will find in the
commercial market. Soooooooooo I suppose it is possible you might get
poor results using something that had low output.
> Jim H
> Jim H
>it does work so well, why do not the commercial makers of battery chargers
>(for example, Xantrex, who make 3 and 4 stage, expensive, chargers for
>marine deep cycle batteries) not provide pulse charging in their units?
Larry Bradley
Orleans (Ottawa), Ontario, CANADA
enough.
I have no idea why some commercial makers of battery chargers do not
provide this capability.
Some do!
Larry Bradley wrote:
> >I've no idea if pulse charging for desulfation works or not. However, if
> Larry Bradley
the sinusoidal output of the unit.
They may have relied on antiquated information and advise as far as the
treatment of the lead acid battery goes.
Other manufacturers do have pulse charging capability that has
demonstrated a desulfation effect. BUT desulfation is not what they had
in mind when they designed the unit. They used pulse charging to
control the charge going in to the battery. Desulfation was merely a
unplanned benefit.
> Larry Bradley
Morningstar did design the unit to have desulfation capability. At
least that is what their ad implies.
http://www.morningstarcorp.com/our_advantage/index.shtml
> Larry Bradley
noted when pulse charging equipment was developed. Many of the early
patents were part of pulse charging equipment
Dedicated desulfation equipment was developed later.
But you have to remember that the rise time of the pulse is critical to
achieve desulfation results. We use the 50nSec rise time of inductor
mag field collapse to recover batts with.
> Larry Bradley
maintenance, the best site I've found is from those who have a critical
reliance on the lead acid battery
http://www.windsun.com/Batteries/Battery_FAQ.htm
There may be some tidbits concerning starter batteries as well.
Although these folks sell desulfation equipment, nothing will beat or
even come close to a BS2 series desulfation pulser that keeps an eye on
FET and Diode temperatures in order that the pulse width to the FET
keeps the inductors at or near saturation for max pulse out.
> may have to the BBS
> or to me
> desulfator@y...
> > required.
> > Thanks,
> > Mike
of examples in the Stamp manual and Stamps in Class documentation -- all
free for download on Parallax' web site.
Original Message
> The rudders don't even move a full 180 degrees and I do have access to the
example:
range of programmed in values for the
LCD?
think I would rather trust a new battery than a resurrected one if I was out
in the middle of nowhere in my car or on the bike. Besides, its not like
batteries cost thousands of dollars.
Original Message
misinformation put out by battery industry people.
They would rather have you trucking into the battery store every 3 to 5
years purchasing new batteries to enable supporting thier handsome
paychecks.
> > Jim H
dollars. Ever see a 400lb to 800lb 2V cell? I hear from their owners
all the time when their battery bank fails and they have a considerable
investment to save.
If you bother to take the time to cut a failed battery apart you will
find that the lead plates have hardly been used. They are normally
disposed of and the battery industry has a remarkable record of
recycling all the parts, putting them in so called "New" batteries and
selling them to you again.
I fail to see the difference.
Personally, if I am out in the middle of nowhere I'd rather be using a
battery that has a pulser permanently connected to it.
I know it will not fail and leave me stranded.
Rodent wrote:
> A reconditioned battery would be fine for around the house or shop, but I
Original Message
pulse charger I will be first in line to buy one of these fancy chargers.
Until then, a $40 Wal-Mart battery every 4 years or so is fine with me.
If I had a hybrid car with a trunk full of batteries I would think about
sulphation problems -- otherwise no. And batteries do fail for problems
other than sulphation -- vibration, overcharging, etc... will also kill them
and can leave you out in the sticks with no phones and a 100+ mile walk back
to civilization.
Original Message
> Actually there are some batteries whose cost exceeds a thousand
> investment to save.
I
out
Original Message
Specific
