Automotive/Marine applications — Parallax Forums
edited 2002-12-18 12:19 in General Discussion
Hi everyone, I just joined.
I have a BS2 Stamp that I mucked around with some time ago and it was
loads of fun. I managed to make a home alarm with outgoing text-
paging alerts, an inbound telephone/dtmf interface, and also
manipulate some X-10 appliances.
Have any of you made any useful Auto/Marine applications?
For my boat I can think of things like manifold heat sensors,
automate the (crappy) fridge thermostat, tank level sensors etc. with
graphical output on the 4-line LCD display, and audio alarms as
required.
Any creative input is most welcome!
«134
    edited 2002-12-07 14:17
    If you are talking creative applications,
    how about water speed, wind speed, fuel flow all put in to give you
    distance to empty?
    or maybe GPS and fuel level, but that's not as much fun.
    Heck if you put in a GPS, you could put in a cruse control.
    Humidity sensor and cabin ventilation when in port ?
    Dave
    --- In basicstamps@yahoogroups.com, "ii_awesum" <ii_awesum@y...>
    was
    with
    > required.
    > Thanks,
    > Mike
    edited 2002-12-07 17:10
    I was thinking of a rudder position indicator. It would take some type of
    sensor mounted on the rudder post that
    would determine the amount of left and right rudder rotation from dead center
    and send it to a BS2 for
    processing. An LCD mounted on the helm would then be used to graphically
    indicate the amount of left or right
    rudder rotation.
    Now if I just knew how to do.
    > distance to empty?
    > Dave
    > was
    > with
    > > required.
    > > Thanks,
    > > Mike
    edited 2002-12-07 17:39
    Funny you mentioned that, I was thinking of using the stamp to interface
    with a GPS and make and autopilot (an "Iron Mike" as we used to call them).
    Several possible ways to to let the stamp know what position the rudder is
    in. IR detectors being an easy place to start. There are positional sensor
    packages out there too. Are you talking sail or power?
    Jonathan
    Sent: Saturday, December 07, 2002 9:10 AM
    Subject: Re: [noparse][[/noparse]basicstamps] Re: Automotive/Marine applications
    center and send it to a BS2 for
    > rudder rotation.
    > > distance to empty?
    > > Dave
    > > was
    > > with
    > > > required.
    > > > Thanks,
    > > > Mike
    edited 2002-12-07 18:07
    My rudder application would be for a power boat. What ever type detector was
    used it would have to be able to
    withstand the humidity and temperature ranges. Interference from other onboard
    systems could also be an issue.
    The autopilot would make an interesting project but it would be way beyond my
    expertise. If I built an autopilot
    I would probably also need to make a system that called 911 after the autopilot
    failed.
    Like someone previously mentioned, a system that monitors various engine and
    temperature parameters would also be
    interesting.
    I have to tell you that I can think big but in reality do very little when it
    comes to electronics.
    > Jonathan
    > From: "pslive" <pslive@m...>
    > > rudder rotation.
    > > > distance to empty?
    > > > Dave
    > > > was
    > > > with
    > > > > required.
    > > > > Thanks,
    > > > > Mike
    edited 2002-12-07 18:17
    I'm power (26' Bayliner Ciera SB). Looks like there's some genuine
    interest here :-).
    Rudder (drive) position indicators are also feasable, I already have
    a analog trim indicator but that shouldn't be difficult to interface
    using an A/D convertor. The Rudder angle would require a retrofit
    of a sensor on the tiller arm and I think these sensors are readily
    available at marine shops for a modest cost. You can buy a stick on
    position indicator that attaches to your steering wheel hub for $35
    US or so and I hear are pretty good for reference purposes. Of
    course if you want to go electronic...
    One other thing that came to mind is an computerised trim tab
    control, which can be purchased off the shelf - but for what I
    consider a high cost ($400+). I suppose the dual-axis inclinometer
    is a costly component.
    There are already plenty of GPS and autopilot interfaces readily
    available down to the PDA level and for the cost might be more
    practical to buy outright. I have a Magellan handheld GPS which
    does what I need (heh heh, for now...but I hope to get a PDA based
    GPS sometime for the added flexability).
    Fuel flow meter, that's something I plan to purchase off the shelf,
    and costs $200 US. No interface for this model except to tap into
    the flow sensor to collect data. You can get very sophisticated
    models that will interface to autopilot, GPS, and chart plotter.
    They indicate RPM, fuel consumption, fuel remaining and feed this
    data to the other devices which is real sweet but cost prohibitive
    at $800+ for my class of boating.
    Anyways, enough of my rambling. I'd like to start small with the
    level sensors and fridge thermostat. I think the fridge control is
    a no-brainer using the temperature sensor and a relay. What type of
    sensors are available for level sensing? My water tank is embedded
    in the hull
    and I only have access to the rear wall of it thru a 5"x8" access
    hole. The 2 options I suspect are an external inductive type or
    cutting a hole for a rheostat type sensor. Inductive one would be
    the cleanest method.
    Thanks all!
    --- In basicstamps@yahoogroups.com, "Jonathan Peakall"
    interface
    call them).
    rudder is
    positional sensor
    > Jonathan
    some type of
    from dead
    graphically
    > > rudder rotation.
    give you
    > > > distance to empty?
    > > > Dave
    <ii_awesum@y...>
    and it
    > > > was
    text-
    etc.
    > > > with
    as
    > > > > required.
    > > > > Thanks,
    > > > > Mike
    Subject
    Subject and
    edited 2002-12-07 18:56
    Mike,
    Temp control is easy, I just made a controller for my hot tub. Same basic
    thing. I used an inexpensive LM35DZ for the sensor, and it was easy to
    interface. Mail me off list if you want details.
    It sounds like you want to make a fuel/water level indicator. One of the
    classic problems of fuel/water gauges is of course movement. Rheostat/float
    sensors are almost usless except at rest. So I was thinking, what about a
    pressure sensor on the output of the tank? Should be easy to interface, and
    I would think more accurate under working conditions.
    Jonathan Peakall
    Sent: Saturday, December 07, 2002 10:17 AM
    Subject: [noparse][[/noparse]basicstamps] Re: Automotive/Marine applications
    > interest here :-).
    > in the hull
    > Thanks all!
    > Mike
    > interface
    > call them).
    > rudder is
    > positional sensor
    > > Jonathan
    > some type of
    > from dead
    > graphically
    > > > rudder rotation.
    > give you
    > > > > distance to empty?
    > > > > Dave
    > <ii_awesum@y...>
    > and it
    > > > > was
    > text-
    > etc.
    > > > > with
    > as
    > > > > > required.
    > > > > > Thanks,
    > > > > > Mike
    > Subject
    > Subject and
    edited 2002-12-07 19:10
    Simplier stuff,
    water temperature indicator connected to a GPS so you can data log
    what temperature the water was when you caught the BIG fish.
    engine heat temperature
    G-force meter to post just how BIG that wave was.
    Can counter to see how many beers you have left before you need to
    get back to port.
    water speed vs. motor RPM to help fine tune the prop ?
    air temperature meter to let you know when the temp is changing,
    signaling weather changes, barometric sensor ?
    galvanometer?
    Dave
    was
    with
    > required.
    > Thanks,
    > Mike
    edited 2002-12-07 20:44
    Hi Mike,
    Regarding a low-cost, dual-axis inclinometer, consider using Analog
    Devices ADXL202, which is a dual-axis accelerometer, sensitive to tilt
    angles. See both the Parallax and Analog Devices web sites for stamp
    code, using PWM and not requiring analog-to-digital conversion. The
    Analog Devices application notes are quite detailed, with circuit
    examples for filtering, optimizing sensitivity, and other useful
    information.
    Dennis
    From: ii_awesum <ii_awesum@y...> [noparse]/noparse]mailto:[url=http://forums.parallaxinc.com/group/basicstamps/post?postID=8tHOGIY2WaiS0ISvkllAg_H6Xv3ssjIlp6uNXQu1z0sogmHblLzCiA06hB0NmIhoYxmNSGwAUhaB]ii_awesum@y...[/url
    Sent: Saturday, December 07, 2002 10:18 AM
    interest here :-).
    <deleted>
    <deleted>
    edited 2002-12-07 21:15
    One solution is an absolute position encoder. Its an encoder wheel with a
    pattern on it that indicates exactly how far in its rotation it is -- you
    have multiple devices to read this pattern. You can buy or make your own.
    Do a search on Yahoo! for "absolute position encoder" and do some research.
    > rudder rotation.
    edited 2002-12-07 23:27
    There is a special code used for position sensing of a shaft. Look at:
    http://www.ida.net/users/tetonsl/railroad/graycode.htm
    and see if that is interesting??
    Leroy
    edited 2002-12-08 07:40
    Sure! If you are not getting a 20 to 70 year life span from your
    flooded lead acid batteries, make a battery desulfator. Premature death
    of a lead acid battery (80% +) is attributable to lead sulfates.
    Works well on starter and deep discharge batteries.
    Merely build up the output stage only of this NFET schematic (R4, C3,
    Q1, L1, L2, D1 and C4). Q1=IRL630 or IRFZ44N, C4=2
    http://shaka.com/~kalepa/556alternate.gif
    Component values are shown in the PFET schematic,
    http://shaka.com/~kalepa/schematic.gif
    OR in the original article written for Home Power magazine
    http://www.humboldt1.com/~michael.welch/desulfator.pdf
    But PLEASE do not email the author of the article as he is extremely
    busy on another project and has asked folks to direct any questions you
    may have to the BBS
    http://pub36.ezboard.com/bleadacidbatterydesulfation
    or to me
    desulfator@y...
    I have lots o pulsing programs for the Stamp line to share. Especially
    if you use thermistors to monitor temps of the FET and Diode to enable
    running at the edge of the performance envelope.
    > required.
    > Thanks,
    > Mike
    edited 2002-12-08 07:42
    Oooooooooops got interuppted with emails
    C4 is 200uF to 6800uF I use 100V rated caps.
    > may have to the BBS
    > or to me
    > desulfator@y...
    > > required.
    > > Thanks,
    > > Mike
    edited 2002-12-08 10:52
    Hi Mike,
    I have a boat that has a fuel tank that is very long and very skinny, so
    normal tank level sensors are no good. I made a fuel flow meter using a
    standard commercial flow meter (expensive), and an LED display that showed
    either flow rate or fuel quantity remaining depending on selected mode.
    I had a passing thought that using a fuel flow meter coupled with a speed
    sensor (water speed Pitot), that an auto trim system that trims the boat for
    the most fuel efficient trim automatically could be done. With rising fuel
    prices that we are getting in AUS this could be a good thing!!
    Also, y not just make a heading hold autopilot?
    Have Fun,
    Dwain.
    Sent: Saturday, December 07, 2002 7:57 AM
    Subject: [noparse][[/noparse]basicstamps] Automotive/Marine applications
    > required.
    > Thanks,
    > Mike
    edited 2002-12-08 14:33
    IF you are talking a single flap (rudder) that moves, maybe 180
    degrees, why not just a pot ?
    There are multiple places to put it. on the actual shaft of the
    rudder, or on the arm that drives it. should be easy to waterproof.
    and is MUCH easier to code for than an encoder.
    Dave
    with a
    - you
    your own.
    research.
    some type of
    dead
    graphically
    > > rudder rotation.
    edited 2002-12-08 15:28
    I worked 30 years as an Engineer in the lead-acid battery industry and I am
    amazed that these vastly inflated claims for battery desulfators keep
    circulating. Twenty years life for a lead-acid battery in cyclic service
    is absolutely ridiculous and 70 years far exceeds the life of the most
    advanced NONCYCLIC designs maintained under strictest conditions.
    For anyone interested in a better understanding of the care and maintenance
    of auto starting and deep-cycle marine batteries I suggest you take a look
    at the vast amount of information presented by my friend Bill Darden at
    http://www.uuhome.de/william.darden/ .
    Those with lingering doubts might want to visit the Usenet newsgroup
    sci.chem.electrochem.battery. If your questions there are initially
    unanswered it is because everyone there is probably a bit tired of this
    topic. Ask for a one-line summary only and the word "snake oil" will
    probably be a part of it.
    Jim H
    edited 2002-12-08 16:08
    No wonder -- Snake Oil is two words.
    edited 2002-12-08 17:00
    The rudders don't even move a full 180 degrees and I do have access to the
    rudder post and rudder arms so I could
    fasten something to them. If I used a pot, does that mean that for example:
    -if the rudder was full left, the pot would be at minimum resistance
    -if no rudder (straight), the pot would be one half resistance
    -if the rudder was full right, the pot would be at maximum resistance
    Then the stamp would compare the resistance(voltage drop) of the pot to a range
    of programmed in values for the
    various rudder positions and determine how much rudder to display on the LCD?
    Sorry to ask such basic questions but I am new at this.
    Does anyone have an example of something like this?
    > Dave
    > with a
    > - you
    > your own.
    > research.
    > some type of
    > dead
    > graphically
    > > > rudder rotation.
    edited 2002-12-08 18:38
    maintenance of auto starting and deep-cycle marine batteries I suggest
    you get first hand knowledge of the subject. OR talk to folks that have
    had successes in this area.
    Reading about anyone's opinion that has no first hand knowledge is a
    poor substitute. AND like the old saying goes, opinions are like
    rectums, everyone has one.
    Desulfation pulsing is a hot area of research with many patents filed
    over the last 20 years. Those who have insight into unique designs tend
    to keep them close to the vest. It seems the primary benefactor has
    been industrial applications where this capability has been built in to
    industrial charging equipment.
    It has only been recently (in the 100 year history of the lead acid
    battery) that desulfation by electronic means have been developed.
    Desulfation by chemical means (EDTA tetrasodium salt) also works but has
    some drawbacks to it.
    If everyone in the United States used desulfating pulsers, the lead acid
    battery industry would virtually die out in a month.
    Gee I wonder why some lead acid battery folks tend to get a little
    touchy about the subject?? I am absolutely amazed that folks can have
    an opinion about a subject and little or no experience.
    On the other hand, if you want to buy a used car the last person you
    might get a straight answer from might be the used car salesman.
    For myself, I've recovered too many dead batteries, watched the Specific
    Gravity rise as the battery was pulsed and brought back to life; seen
    many previously dead batteries start cars and load test in the green
    once more to have any doubts about the process.
    I've heard from many many folks that were ecstatic over how their dead
    batteries came back to life after using a pulser based on enhancements
    of Mr. Coupers original design.
    One of the commercial desulfating pulsers has a website where a few
    folks have taken the time to write about their experiences.
    http://www.pulsetech.net/
    If you click on "Product info" and then "Testimonials" you can read
    about what some folks on this forum must believe to be delusional.
    On the other foot, if you have a BS2 stamp and would like to try
    something new, cobble a pulser together and you just might save yourself
    a ton of bucks by not ever having to purchase a new battery again. You
    can get all the free batteries you want by merely recovering those that
    others have tossed out.
    Now there is a difference in pulsers. The enhanced designs we've come
    up with are 5 to 10 times more powerful than what you will find in the
    commercial market. Soooooooooo I suppose it is possible you might get
    poor results using something that had low output.
    > Jim H
    > Jim H
    edited 2002-12-08 18:45
    >I've no idea if pulse charging for desulfation works or not. However, if
    >it does work so well, why do not the commercial makers of battery chargers
    >(for example, Xantrex, who make 3 and 4 stage, expensive, chargers for
    >marine deep cycle batteries) not provide pulse charging in their units?
    Larry Bradley
    Orleans (Ottawa), Ontario, CANADA
    edited 2002-12-08 18:50
    Pulse charging will desulfate if the rise time of the pulse is fast
    enough.
    I have no idea why some commercial makers of battery chargers do not
    provide this capability.
    Some do!
    > Larry Bradley
    edited 2002-12-08 18:59
    I suspect that many of the inverter folks have focused their efforts on
    the sinusoidal output of the unit.
    They may have relied on antiquated information and advise as far as the
    treatment of the lead acid battery goes.
    Other manufacturers do have pulse charging capability that has
    demonstrated a desulfation effect. BUT desulfation is not what they had
    in mind when they designed the unit. They used pulse charging to
    control the charge going in to the battery. Desulfation was merely a
    unplanned benefit.
    > Larry Bradley
    edited 2002-12-08 19:15
    Oooooooooops, I stand corrected!
    Morningstar did design the unit to have desulfation capability. At
    least that is what their ad implies.
    http://www.morningstarcorp.com/our_advantage/index.shtml
    > Larry Bradley
    edited 2002-12-08 19:25
    As a matter of fact, if I am not mistaken, desulfation effect was first
    noted when pulse charging equipment was developed. Many of the early
    patents were part of pulse charging equipment
    Dedicated desulfation equipment was developed later.
    But you have to remember that the rise time of the pulse is critical to
    achieve desulfation results. We use the 50nSec rise time of inductor
    mag field collapse to recover batts with.
    > Larry Bradley
    edited 2002-12-08 19:43
    And if you would like to read about current or updated battery
    maintenance, the best site I've found is from those who have a critical
    reliance on the lead acid battery
    http://www.windsun.com/Batteries/Battery_FAQ.htm
    There may be some tidbits concerning starter batteries as well.
    Although these folks sell desulfation equipment, nothing will beat or
    even come close to a BS2 series desulfation pulser that keeps an eye on
    FET and Diode temperatures in order that the pulse width to the FET
    keeps the inductors at or near saturation for max pulse out.
    > may have to the BBS
    > or to me
    > desulfator@y...
    > > required.
    > > Thanks,
    > > Mike
    edited 2002-12-08 19:55
    You could use the RCTIME command to determine the position of the pot. Lots
    of examples in the Stamp manual and Stamps in Class documentation -- all
    free for download on Parallax' web site.
    example:
    range of programmed in values for the
    LCD?
    edited 2002-12-08 20:00
    A reconditioned battery would be fine for around the house or shop, but I
    think I would rather trust a new battery than a resurrected one if I was out
    in the middle of nowhere in my car or on the bike. Besides, its not like
    batteries cost thousands of dollars.
    edited 2002-12-08 20:03
    Actually the only "Snake Oil" I run into consistantly is the
    misinformation put out by battery industry people.
    They would rather have you trucking into the battery store every 3 to 5
    years purchasing new batteries to enable supporting thier handsome
    paychecks.
    > > Jim H
    edited 2002-12-08 20:15
    Actually there are some batteries whose cost exceeds a thousand
    dollars. Ever see a 400lb to 800lb 2V cell? I hear from their owners
    all the time when their battery bank fails and they have a considerable
    investment to save.
    If you bother to take the time to cut a failed battery apart you will
    find that the lead plates have hardly been used. They are normally
    disposed of and the battery industry has a remarkable record of
    recycling all the parts, putting them in so called "New" batteries and
    selling them to you again.
    I fail to see the difference.
    Personally, if I am out in the middle of nowhere I'd rather be using a
    battery that has a pulser permanently connected to it.
    I know it will not fail and leave me stranded.
    edited 2002-12-08 20:37
    When they build a motorcycle with the room to house a 400lb battery and a
    pulse charger I will be first in line to buy one of these fancy chargers.
    Until then, a $40 Wal-Mart battery every 4 years or so is fine with me.
    If I had a hybrid car with a trunk full of batteries I would think about
    sulphation problems -- otherwise no. And batteries do fail for problems
    other than sulphation -- vibration, overcharging, etc... will also kill them
    and can leave you out in the sticks with no phones and a 100+ mile walk back
    to civilization.
    > investment to save.
    I
    out
    Specific
