Holy moly! I've been away for a bit but wow, thanks everybody for the out pouring!
@"Christof Eb." said:
Hi @proppy !
this is a nice effort, thank you!
I wonder, if some example of an inline section of propeller asm would be helpful. I think, most people will want to start with rather tiny routines embedded in some other high level code to have maximum speed there.
Christof
Hi @"Christof Eb." . Let me look into it. Honestly, bridging that gap might be pretty helpful for Spin2 at the very least.
@pilot0315 said:
@proppy
I too will be headed to the print shop.
Thank you for this effort.
When do you think the examples and maybe some videos will be on github??
Martin
Hi @pilot0315.
The examples should be on the github for all the examples in the manual. I started doing TikTok for the videos. Right now it's just text videos but the idea is to get some TikTok videos of the terminal/explaining code via TikTok Live. It allows me to clip stuff so I could make videos as well as run Live code cast. https://www.tiktok.com/@p2assembly
@pilot0315 said:
@proppy
I assume that I can bleed some of this over to Pasm??
Thank you and Evan.
Martin
Mostly, the only differences are in the way the cogs work between them, smart pins, hub access speed, etc. I may circle around
Thanks I will go back to github and look again. Found them on github. Tried the first one to print and then add. On propeller tool and on spin tools. Neither gives me anything. Checked the baudrate and even changed it 115200 just for giggles and got nothing.
Using p2 eval rev b and c. Will try one of my edge devices and let you know.
I checked the copy paste line by line.
Martin
Martin
I had upgraded the example a bit ago. A few folks pointed out the same. I added jmp #$ and tested on a few setups other than FlexProp, which originally had zero issues. Let me know, at this point I'm just making vids so things have slowed down a bit and it's mostly just edits on the manual itself and including the suggestions. Thank you so much!
@pilot0315 said:
@proppy
Sorry to bother you.
Martin
BTW. The book you wrote as I keep reading I really understand that is the great part.
It's not a bother at all really. I have been told I need to make sure things work across the board before. And thank you for the compliment.
I tried the code under Spin Tools IDE, it works. I also tried it under FlexProp and it seemed to work as well. I am using the P2 edge setup. Is your Parallax Serial Terminal set to 2000000 by chance? The baud rate in the code is set to 2_000_000. The terminal should be set the same. I included a screenshot.
Feel free to include screenshots. Also, can you describe your setup? Win, Linux, Mac? Emulator like WINE?
EDIT: Also can you try the following? It has a waitx after the smartpin startup. I set the baud rate to 115_200, a much lower rate, just to test something I thought of.:
@evanh
Thank you
Hi @pilot0315.
@proppy
Martin
Thanks @proppy
Martin I will let you know.
@proppy
'print_character.spin2
CON
_CLKFREQ = 180_000_000
BAUD_RATE = 2_000_000
TRANSMISSION_PIN = 62
BIT_PERIOD = (_CLKFREQ / BAUD_RATE)
BAUD_MODE = (BIT_PERIOD << 16) | (8 - 1)
DAT
org 0
asmclk
dirl #TRANSMISSION_PIN
wrpin ##(P_ASYNC_TX | P_OE), #TRANSMISSION_PIN
wxpin ##BAUD_MODE, #TRANSMISSION_PIN
dirh #TRANSMISSION_PIN
wypin #1, #TRANSMISSION_PIN
mov character, #"A"
wypin character, #TRANSMISSION_PIN
endprog
jmp #$
character res 1
String:
'send_string.spin2
both files say last month.
Tried in Pnut53 get lost hardware.
Tested with Pnut 53 examples no issues.
Tried also on Propeller tool and blank screen as well as Spin Tools ide.
Tested all with existing code and they work.
Martin
CON _CLKFREQ = 180_000_000 TRANSMISSION_PIN = 62 BAUD_RATE = 115_200 BAUD_MODE = ((_CLKFREQ / BAUD_RATE) << 16) | (8 - 1) DAT org 0 asmclk dirl #TRANSMISSION_PIN wrpin ##(P_ASYNC_TX | P_OE), #TRANSMISSION_PIN wxpin ##BAUD_MODE, #TRANSMISSION_PIN dirh #TRANSMISSION_PIN waitx ##10_000_000 wypin #"A", #TRANSMISSION_PIN jmp #$
