Propeller 2 Assembly Language beginner guide v0.1 — Parallax Forums
proppyproppy Posts: 51
edited 2026-03-05 19:26 in PASM2/Spin2 (P2)
Hello!
I’ve been working on a practical Propeller 2 assembly language manual that walks through real-world examples using smartpins, UART, line editing/input parsing, and SPI flash access. It’s written in P2ASM/Spin2 and meant to be a hands-on reference for embedded development with the P2.
It covers topics like:
UART communication (high-speed async, echo, line input)
Interactive command input with backspace handling
Token parsing and command dispatch
State machines with optimized jump tables
SPI setup and full-duplex communication
Reading JEDEC ID from SPI flash
Streaming flash reads over UART
String handling routines (length, compare, copy, concatenate)
Number ↔ string conversions
And more
The manual is organized with explanations for each example, and every program has commentary describing how it works.
📌 Version: v0.1
📌 Repository: https://github.com/propeller-mcu/propeller2_asm
This is an early release, and I’d really appreciate feedback from the community — especially on:
Example enhancements
Clarity of explanation
Anything that’s confusing or could be improved
I intentionally waited to polish formatting until the content was solid first, so this is about substance over style. If you find it useful, great — and if not, constructive feedback is more than welcome.
Thanks!
  • JonnyMacJonnyMac Posts: 9,835
    Neat. Downloaded and will get it over to the print show (I like to hold books in my hands [showing my age]).
    Though it's old, too, I tried a couple of examples using Propeller Tool. I figured out that I have to download to flash (F11), open the terminal (PST), and then reset the P2. Still I was getting odd behavior from time to time.
    I noticed that some of your examples jump to an end label...
      jmp     #endprog
    In the print JEDEC example that label is right above the variable definitions
      endprog
      spi_command         res 1
      spi_reception       res 1
      uart_transmission   res 1
      hexadecimal_copy    res 1
    I was seeing funny things in the PST window. When I add a line at endprog, everything settled down.
      endprog
        jmp  #$
    Is it possible that the P2 is interpreting the variables as instructions? Or that the cog just runs out? In all of my Spin code, especially code that prints to a terminal, I go into a repeat loop so that the TX pin doesn't shutdown and send garbage to the terminal. Am I missing something?
    Thank you for the feedback! Most likely yes! That's because the jmp literally jumps to endprog. The only thing is, on FlexProp, I don't seem to run into that issue. But possible it may be an issue if using PNut or other software, since it might see those variables and just execute them, basically executing garbage. I do not have PNut but this helps the manual since jmp #$ should work in FlexProp.
  • Letting the program counter just run off is definitely an error. You need to either enter an infinite loop or issue a cogstop. What happens afterwards will (in the case of very short programs) largely depend on stale RAM contents, which might differ based on a number of things. (If you have the debugger enabled, it should set unused memory to zero on startup...)
    ...on FlexProp, I don't seem to run into that issue...
    It's work, I know, but I suggest you ensure your code works with PNut, FlexProp, and Spin Tools. I try to do this with anything I release to the public.
    Oh I don't disagree. I just updated the repository with the fix. Also, you may want to get the pdf again before printing. I refreshed the examples in that as well. For PNut, I may need to dig up a machine and put windows on it, so that part may take a bit but will do this before official v1.0 though. Thank you!
    PNut is not a big program, it will probably run in a VM.
  • ersmithersmith Posts: 6,285
    PNut works reasonably well under Wine. Getting the serial communication to work is a bit fiddly, but you can always compile the binary and then download it with loadp2.
    Oh really? Perfect! Thanks for that. I do have a FreeBSD machine with Wine so i can try it out there.
  • RaymanRayman Posts: 16,449
    Have to wonder if would be better to use Debug rather that hard coded uart…
    I think it's good for people to learn the smartpin stuff at the lower level, at least that was my experience. I would have to test if FlexProp Debug is the same as PNut as well. It may not be a bad idea to add DEBUG as a shortcut at least though! Thank you!
  • evanhevanh Posts: 17,278
    Yes, the UART mode is a good one to actually setup and use.
    That's something I need to add to my wish list of future new hardware - Merge the async and sync serial modes so that a mix of the features can be selected from. Namely providing for clocked start and stop bits. Such a device would've been able to handle I2C and 1-bit SD.
    simclk ... Never seen that mentioned anywhere to do with the Prop2.
    In your various examples of setting up smartpins, it is advised to first always do a DIRL to ensure the smartpin is disabled before configuring. This covers the more real world scenarios where smartpins get reconfigured instead of just an initial config. Often a pin mode needs switched in and out repeatedly.
    edited 2026-02-25 08:30
    The flush routine could actually check the smartpin for completion. Here's an old one of mine:
    'Wait for comport transmitting to complete
    '  input:  (none)
    ' result:  (none)
    'scratch:  (none)
    waittx
                    rqpin   inb, #DIAGTXPIN   wc    'transmiting? (C high == yes)
            if_nc   ret wcz
                    jmp     #waittx
    edited 2026-02-25 08:51
    In the "WAITX vs NOP" topic you mention that instructions execute in one clock cycle. This is incorrect, base instruction execution takes two clock cycles.
    I do wonder where your info is coming from? ChatGPT maybe?
    EDIT: Ah, maybe some of this pertains to very early FPGA development where it was indeed an instruction per clock. That became known as the Prop2-Hot design. Which would probably explain the simclk reference as well.
    For future documenting, anything you find prior to year 2020 can be discarded as not valid for finished Prop2 chips.
    Thank you. Had a lot of help from the forum in my earlier post on how to do it.
    Ah, closer to the beginning of the manual. I can remove this. It is not apart of the P2 chip itself but is it something I saw in a code example.
    '  input:  (none)
    ' result:  (none)
    'scratch:  (none)
    waittx
          if_nc   ret wcz
                  jmp     #waittx
    This seems oddly familiar. I think i might have asked something or seen someone in a forum post about this. I'll check it out.
    Yes actually, I was looking for beginner gotchas. The exact start of the rabbit hole was here, among others:
    https://forums.parallax.com/discussion/167871/who-will-be-prop2s-biggest-competition/p2
  • proppyproppy Posts: 51
    edited 2026-02-25 15:24
    I have made the proposed updates to the document/code so far and put them on the front page of the github.
    The following outstanding points i need to test a bit:
    • Debug rather that hard coded uart…
    • The flush routine could actually check the smartpin for completion.
    • suggest you ensure your code works with PNut, FlexProp, and Spin Tools.
    Thanks everybody for all the help! :)
    These should also work in prop tool…
    Should be identical to Pnut for pure assembly…. And, easier to work with…
    Good point, Ray.
    Adding it to the list! Thank you!
  • @proppy
    I too will be headed to the print shop.
    Thank you for this effort.
    When do you think the examples and maybe some videos will be on github??
    Martin
    I feel smarter already. good sized chunks latch right in my brain, presented in a decent order to see results that encourage continuing. a "real page-turner" so to speak. :)
  • Hi @proppy !
    this is a nice effort, thank you!
    I wonder, if some example of an inline section of propeller asm would be helpful. I think, most people will want to start with rather tiny routines embedded in some other high level code to have maximum speed there.
    Christof
  • RossHRossH Posts: 5,775
    Inline assembly is an absolute minefield for a beginner. It is non-standard extension to most languages, being both compiler and platform dependent. In fact, it may not be implemented at all. Even if it is, each compiler and platform combination will have different (and sometimes not very obvious) restrictions on what can be done, and how to do it.
    The Propeller is unusual in that it has so many instructions that no compiler would ever generate, and so inline assembly may get more use on a Propeller than than on other platforms. So it is certainly worth mentioning the possibility. But even providing a trivial example that would work across all compilers would be difficult, and to go beyond that would probably be more confusing than useful.
    Perhaps include it as an "advanced" topic, with suitable warnings.
    Ross.
    Ross.
    Yes and No!
    Teaching is all about motivation. So the low hanging fruits must be shown!
    Probably the combination with SPIN2 will be the most common. @JonnyMac 's Nuts and Volts text could be linked.
    If MicroPython will support more than one Cog in future, than the combination of inline assembler with that will make sense.
    "Minefield". This is, how inline single assembler instructions mixed with Forth look like in P2XCForth:
    It's fast :)
    edited 2026-05-20 08:36
    Hmmm. I have no idea what that is, but it is certainly not assembler as most people would expect to see it.
    edited 2026-05-20 13:21
    Spin2 has extensive support for inline Pasm2. And for good reason - The language is built for the Prop2 alone. Being able to parameter pass efficiently into registers and have high level local variables also passed into registers makes for simple and efficient interfacing with the assembly code. Performance is then integral rather than relying on mail-boxing to a separate task.
    Flexspin's inline support, with all its supported languages, is providing the same levels of integration as Spin2. Eric has indicated he never intended the feature to be used for more than neat snippets but I'll say it well and truly performs as a serious coding feature. Flexspin did require some tweaking to bring it up to feature parity to, and beyond, Pnut's Spin2. Flexspin does have at least one notable performance advantage over Pnut in the way it handles high level local variables - They are in registers natively, whereas Pnut's implementation has to copy them to registers when calling the "inlined" Pasm2.
    I put "inlined" in quotes there because Pnut always copies the assembled machine code into cogRAM (Register space) and then calls it there.
    PS: And I will say that, in compiled code, ignoring the large general register set that cogRAM affords us is ignoring a big feature of the Propellers.
  • @proppy
    Hey the manual is great. Took it to the printer today. Your explanations are excellent and make it easy to understand. Some time ago @evanh was helping me and you book now helps make that assistance from him make more sense. I assume that I can bleed some of this over to Pasm??
    Thank you and Evan.
    Martin
  • pilot0315pilot0315 Posts: 1,008
    edited 2026-05-22 10:03
    @evanh
    @proppy
    DAQ. In @proppy 's manual section 2.12 I see : BIT_PERIOD = ( _CLKFREQ / BAUD_RATE )
    if my math correct this = 50
    Is this in uSec? Meaning the space between each bit is 50 uS?
    I ran the program listing 2.1 as is direct copy and paste. Got nothing. Two different p2 eval boards tried on spin tools ide and prop tool.
    Martin
    _CLKFREQ is sysclock ticks per second
    BAUD_RATE is the bits per second
    Algebra says that second/second cancels, therefore you're left with sysclock ticks per bit.
