Propeller 2 Assembly Language beginner guide v0.1 - Page 2 — Parallax Forums
2
  • @evanh
    Thank you
  • proppyproppy Posts: 52
    edited 2026-05-24 02:40
    Holy moly! I've been away for a bit but wow, thanks everybody for the out pouring!
    @"Christof Eb." said:
    Hi @proppy !
    this is a nice effort, thank you!
    I wonder, if some example of an inline section of propeller asm would be helpful. I think, most people will want to start with rather tiny routines embedded in some other high level code to have maximum speed there.
    Christof
    Hi @"Christof Eb." . Let me look into it. Honestly, bridging that gap might be pretty helpful for Spin2 at the very least.
    @pilot0315 said:
    @proppy
    I too will be headed to the print shop.
    Thank you for this effort.
    When do you think the examples and maybe some videos will be on github??
    Martin
    Hi @pilot0315.
    The examples should be on the github for all the examples in the manual. I started doing TikTok for the videos. Right now it's just text videos but the idea is to get some TikTok videos of the terminal/explaining code via TikTok Live. It allows me to clip stuff so I could make videos as well as run Live code cast.
    https://www.tiktok.com/@p2assembly
    @pilot0315 said:
    @proppy
    I assume that I can bleed some of this over to Pasm??
    Thank you and Evan.
    Martin
    Mostly, the only differences are in the way the cogs work between them, smart pins, hub access speed, etc. I may circle around
  • pilot0315pilot0315 Posts: 1,014
    edited 2026-05-24 04:59
    @proppy
    Thanks I will go back to github and look again. Found them on github. Tried the first one to print and then add. On propeller tool and on spin tools. Neither gives me anything. Checked the baudrate and even changed it 115200 just for giggles and got nothing.
    Using p2 eval rev b and c. Will try one of my edge devices and let you know.
    I checked the copy paste line by line.
    Martin
  • @pilot0315 said:
    @proppy
    Martin
    I had upgraded the example a bit ago. A few folks pointed out the same. I added jmp #$ and tested on a few setups other than FlexProp, which originally had zero issues. Let me know, at this point I'm just making vids so things have slowed down a bit and it's mostly just edits on the manual itself and including the suggestions. Thank you so much!
  • Thanks @proppy
    Martin I will let you know.
  • @proppy
    'print_character.spin2
    CON
    _CLKFREQ = 180_000_000
    BAUD_RATE = 2_000_000
    TRANSMISSION_PIN = 62
    BIT_PERIOD = (_CLKFREQ / BAUD_RATE)
    BAUD_MODE = (BIT_PERIOD << 16) | (8 - 1)
    DAT
    org 0
    asmclk
    dirl #TRANSMISSION_PIN
    wrpin ##(P_ASYNC_TX | P_OE), #TRANSMISSION_PIN
    wxpin ##BAUD_MODE, #TRANSMISSION_PIN
    dirh #TRANSMISSION_PIN
    wypin #1, #TRANSMISSION_PIN
    mov character, #"A"
    wypin character, #TRANSMISSION_PIN
    endprog
    jmp #$
    character res 1
    String:
    'send_string.spin2
    both files say last month.
    Tried in Pnut53 get lost hardware.
    Tested with Pnut 53 examples no issues.
    Tried also on Propeller tool and blank screen as well as Spin Tools ide.
    Tested all with existing code and they work.
    Sorry to bother you.
    Martin
    BTW. The book you wrote as I keep reading I really understand that is the great part.
    edited 2026-05-26 22:15
    @pilot0315 said:
    @proppy
    Martin
    It's not a bother at all really. I have been told I need to make sure things work across the board before. :) And thank you for the compliment.
    I tried the code under Spin Tools IDE, it works. I also tried it under FlexProp and it seemed to work as well. I am using the P2 edge setup. Is your Parallax Serial Terminal set to 2000000 by chance? The baud rate in the code is set to 2_000_000. The terminal should be set the same. I included a screenshot.
    Feel free to include screenshots. :) Also, can you describe your setup? Win, Linux, Mac? Emulator like WINE?
    EDIT: Also can you try the following? It has a waitx after the smartpin startup. I set the baud rate to 115_200, a much lower rate, just to test something I thought of.:
    CON
        BAUD_RATE  = 115_200
        BAUD_MODE = ((_CLKFREQ / BAUD_RATE) << 16) | (8 - 1)
    DAT
            org     0
            asmclk
            waitx ##10_000_000
            wypin  #"A", #TRANSMISSION_PIN
            jmp    #$
    edited 2026-05-28 07:57
    @proppy
    I checked the baud rates for all three GUI. I even changed the baud rate just for fun in the code and the terminals.
    Nothing. Not even gibberish that you would see if the baud rates are not in sync.
    Just nothing.
    I will try with one of my edge boards and let you know.
    The above code works with a P2 eval RevB instantly. I will play and adapt the other code examples and let you know. :)
    Also checked it with the 2_000_000 baud and it works great also. For fun added a loop and I gets forever "A" 's printing.
    Martin.
    Got the printed version in my hand now. Drooling over it. :DB)
    Lastly I inserted the waitx before the wypin #1, #transmission_pin in the multiplication code and it now works also. Must be the smartpin as you said needing time to set up.
    Using Windows 11 pro.
  • @pilot0315 said:
    @proppy
    Yes, correct. I've run into this a few times until i settled on the code in the GitHub. The delay, waitx in the second code, helps because you are dealing with toolchain startup timing, cog scheduling, smart pin enablement and any terminal delays. It might be one of these things or it could be all of them honestly.
    So, "waitx" and "wypin #1, pin" are forcing an active state. They do it in different ways, indirectly(waitx) and directly(wypin). Personally I prefer not to use delays like waitx or nop. But, you'll find when you get to attach other hardware that you'll need said delays. The flash on the P2 edge is one example.
  • @proppy
    Understood. I am 70 and began coding when I was 16. Basic, Fortran, hated Cobol. IBM 1130 and 360 plus some others.
    Got back into it 15 years ago with Parallax. Wonderful help. Now we have toys to play with. Like GPS.
    Always wanted to learn ASM.
    This is the perfect opportunity. I will send you a personal link with more info.
    Martin
    edited 2026-05-29 05:52
    @evanh said:
    In the "WAITX vs NOP" topic you mention that instructions execute in one clock cycle. This is incorrect, base instruction execution takes two clock cycles.
    I do wonder where your info is coming from? ChatGPT maybe?
    EDIT: Ah, maybe some of this pertains to very early FPGA development where it was indeed an instruction per clock. That became known as the Prop2-Hot design. Which would probably explain the simclk reference as well.
    For future documenting, anything you find prior to year 2020 can be discarded as not valid for finished Prop2 chips.
    I read what evanh said and increased the waitx to 40 000 000 it appears to work better. I think this covers for the two clock cycles. Remember reading this somewhere.
  • If the second question about ascii is in the earlier comment please disregard figured it out.
  • @pilot0315 said:
    @proppy
    Martin
    Sounds good. And this started off as kind of a throw it at the wall project. But thanks to you and others I have many more improvements that will help folks. I'm going to add the delay stuff we talked about in an appendix of gotchas. So truly thank you because this will help the next person deciding if they want to learn some p2asm. I use to do z80 and 6502 but honestly p2asm is probably the most relaxing assembly I have ever encountered. Even the cog lock stuff was simple to understand. I'm mostly just getting videos together so I'll be checking this and updating the manual in the coming months. Feel free to post any you think it note worthy to add. Right now it's just about where to place stuff so it remains beginner friendly.
  • RaymanRayman Posts: 16,460
    Flexspin lets you inline assembly on P1
    Just fyi…
    edited 2026-05-31 05:41
    @proppy
    Question, the purpose of the add number2, #"0" to convert to ascii. Where is this referenced in the p2asm manual that you used. Also I have the original and the IRON sheep version. Which are you using?
  • evanhevanh Posts: 17,315
    edited 2026-05-31 08:41
    It won't be. That's just a common trick that coders always use in any language.
    The only detail is what syntax a particular language uses to indicate an array of characters verses a text string. Spin/Pasm only has character arrays, that are called strings in the documentation. But when you want to use any of the few string functions then you'll be up for explicitly adding a null terminator to turn a character array into a string.
    EDIT: Or use the STRING() macro to do the same.
  • @pilot0315 said:
    @proppy
    Just to add to what @evanh mentioned.
    The add number2, #"0" technique isn't something specific to the Propeller 2 manuals. It's a standard ASCII conversion technique used in many assembly languages. The character "0" has ASCII value 48 ($30), so adding it to a digit value from 0–9 converts the number into the corresponding printable ASCII character. That's why it works. I use information from both the official Propeller 2 documentation mostly and forum post, but this particular technique comes from general programming and ASCII knowledge rather than a specific source. For my own personal programming experience the conversion knowledge comes from C/TCL/Tk. This is actually good because if P2ASM happens to be someone's first language then it's a detail that should go in there. Thank you again!
    edited 2026-06-02 02:41
    I now remember this from C++
    @proppy
  • @evanh
    Finally found the waitx in @Proppy's manual Makes sense. Plus seeing the stuff you taught me.
    Now making more sense. You both are making me a genius.
  • @pilot0315 said:
    @evanh
    Hey there @pilot0315 ! I'm just happy it's all working out for you. I'm planning to do an update soon on the github with some of these suggestions. Summer vacation has got me busy. :smiley:
    Yes, good to hear things are working out. I remember an early period of learning where I first worked out the structure of Z80 instructions. How the opcode and associated operands were consecutive ordered bytes. That simple detail was a revelation at the time.
    Of course I didn't yet know the terminology at that stage. It was a live disassembly of memory I was looking at using a fancy debugging tool. I didn't yet even have a reference manual for the CPU.
  • @evanh
    Learning curve. I get it.
    @proppy
    I am going through each of the example code objects and adding the waitx stuff. EAch are working also adding continuous loops and letting the code run to see if it crashes. So far so good I will let you know if I find a bug.
    Also slowly disassembling code like:
    Chip Gracey's
    Reciprocal Counter Demonstration *
    '* - inputs frequency on P0 *
    '* - transmits serial text on P62
    To understand exactly what is going on in the code.
    edited 2026-06-08 05:23
    @proppy
    @evanh
    Question.
    Program 0031_waitct1.spin
    O.k.
    time duration is loaded with #5 meaning 5 seconds based on clkfreq ?
    then we get with getct to place the time at that moment into time out.
    then the addct1 now places the #5 into timeout.
    Question. I assume getct is holding the current time.
    What is confusing me is addct1, (2, 3) and waitct1 (2, 3)
    are these 1,2,3 a first, second and third add and wait that can be designated and are the same but
    different in that I can designate three separate events say that are really named event 1, event 2 and event 3
    If so I am limited to up to three events say in a closed loop ".loop" and can reuse these say in another .loop
    ’waitct1 . spin2
    CON
    _CLKFREQ = 180 _000_000
    BAUD_RATE = 2 _000_000
    BIT_PERIOD = ( _CLKFREQ / BAUD_RATE )
    BAUD_MODE = ( BIT_PERIOD << 16) | (8 - 1)
    DAT
    org 0
    asmclk
    dirl # TRANSMISSION_PIN
    wrpin ##( P_ASYNC_TX | P_OE ), # TRANSMISSION_PIN
    wxpin ## BAUD_MODE , # TRANSMISSION_PIN
    dirh # TRANSMISSION_PIN
    wypin #1, # TRANSMISSION_PIN
    mov counter , #0
    mov delay , ## _CLKFREQ
    mov time_duration , #5
    sleep
    getct timeout
    . loop
    addct1 timeout , delay
    waitct1
    add counter , #1
    cmp counter , time_duration wz
    if_nz jmp #. loop
    .end
    wypin #"#" , # TRANSMISSION_PIN
    endprog
    jmp #$
    timeout res 1
    counter res 1
    delay res 1
    time_duration res 1
    Martin
  • JonnyMacJonnyMac Posts: 9,850
    edited 2026-06-08 06:00
    Shouldn't the first instruction in the sequence to setup the smart pin UART be fltl to release any previous smart pin mode? This is the code from pinstart() in the Spin2 interpreter.
    edited 2026-06-08 11:47
    DIRL does the same job.
    Yep.
    Kind of. After the ADDCT1, timeout holds the tick count of future 1 second trigger. The program loops one second at a time.
    Yep, fetches copy of live value from sysclock tick counter, a hidden special register.
    Yep.
    Yes, can reuse each the moment each has finished.
    I see now... It was late and I read that as drvl.
  • @evanh
    Thanks for the conformation. I must be getting it.
    edited 2026-06-09 07:14
    Oh, more detail: The ADDCTx instruction sets up dedicated special register (one of three), holding the future expiry count (same value as "timeout" holds), and arms the event. The event hardware continuously compares against the sysclock tick counter.
    When compare is equal the CTx event triggers. WAITCTx simply waits for the trigger to happen.
    PS: So, over and above the expiry register, that's two dedicated flip-flops in the hardware. One for running the compare (armed event), and the second for remembering event has triggered.
  • @evanh
    So you have 3 to work with.
    If that is so can you say reuse the three but in different ".loops"
    Or are the three exclusive to the entire asm program.
    Thanks for the explanation
    Also
    I am looking of how to call from spin or spin2 different sections of an asm code.
    Like say this.
    I am running three stepper driver boards. Each uses the same code but on different pins.
    Presently in spin I wrote them as different objects. How does one call different parts of an asm code program say modules. Like if I call say I was calling from fullduplexserial:
    screen.dec .....
    screen.hex ....
    I want to write the stepper drivers and possibly servo drivers in asm and call the different parts.
    Looking through the forums and nothing obvious yet.
    Martin
