I am now in Italy just like you, in Cortina for the Olympic curling HF camera's.
I try you explanations, but do not work.
I find strange, I get it working on an emulation win 11 pro on my mac with latest updates on win11.
But it didn't work on my i7 HP win 11 pro laptop....
It's been a long time since I've seen Windows really block something...
But, back then think the trick was to copy onto removeable media, maybe from a different computer, first.
Windows does seem to track things that are downloaded from the web. But, once coming in from removeable media, like USB drive, think it loses track...
@Ltech Good find! Was thinking that all settings were in registry, but seems they are in this file instead...
Wonder if that's the issue for @JoshW as well...
Maybe this happens when trying to go from a very old version to a new version?
Imagining that the very first thing Spin Tools IDE does is try to open and process this file...
In User map I have ".spin-tools" hidden file.
When removed, the last version is running
I'm glad you found the cause of the problem, although it's surprising because the file contains the IDE settings and loading errors shouldn't prevent the application from opening. The settings should anyway have a default. I tried to set the file as hidden but it works, seems it can't be updated but the IDE works.
I'll do some tests to see if I can reproduce somehow. Any chance you have a backup to examine ?
I was trying to help Josh yesterday (he's my colleague). He said he didn't see .spin-tools in his user folder, but I wonder if his Win11 OS shows hidden files or not. I will ask him next time we speak.
I changed the warning and error colors a bit, should be better, at least on the right-side bar.
I think I'll start working on the color theme configuration.
I found a place where I missed to add an error dialog, that would explain why the application closes silently when there is an error reading the preferences. Should also help with other issues.
Changes:
Fixed terminal window redraw
Fixed scope and logic debug windows with arbitrary number of samples
Added missing internal error dialog
Slightly revised warning and error highlighting colors
Just a note about the java runtime: Spin Tools uses its own private runtime, it doesn't use the system-wide runtime (it doesn't need to have one installed at all).
warning color at edge of edit window easy to see now
terminal bottom line printing as expected
The next time you're looking at the Find/Replace dialog, could you add the start point option as on the Find/Replace option in Propeller Tool? It should default to cursor, of course, but I find it convenient to switch to top when I want to locate a global variable definition. Thanks.
There is a bit of a misalignment in the hotkeys versus the bookmark, i.e., bookmark #1 uses [Ctrl]+[0].
Request: Would it be possible to add a Go To fly-out menu to the right-click context menu of the edit window?
For my own use I've found these settings best for the Code Navigation and Hover Doc modifiers
If nothing is selected they seem to operate automatically. Is this the intent?
Request: Would it be possible to show the value of a constant another object using the Hover Doc feature? The Code Navigation feature will take me to a child object, so I'm hoping showing constant values for child objects as well.
Ah... yes, I must have mixed up the indexes...
Yes, I think there are no problems adding it.
Yes, if nothing is selected the mouse click on a navigable keyword goes to the definition and the doc popup opens, it can be a bit annoying.
That should work, unless I'm missing something:
You can hover on both the object or the constant name and should display the value.
You showed P2 code. At the moment I'm in the middle of a largish (~3800 lines in main app) P1 project. Navigation to the constant definition in the child object does work on the P1. Maybe this is an issue of # versus . in the object#constant expression.
Just to confirm, Hover Doc works for constants defined within the P1 file that is the active edit window.
Don't know... I like the doc hover without modifiers.
Ahhh... yes, I forgot the separator for P1 constants. Will fix it.
Another one of those "For your consideration..." quality-of-life things. I make use of bookmarks and was thrilled when you added them to Spin Tools. That said, the markers in the line numbers sidebar are tiny, as as they use anti aliased colors, they're difficult to read on a high-res monitor that's not gigantic. The Propeller Tool bookmarks are bigger, but a little clunky. Feeling a bit arty, I made an alternative set that use the I think are easier to read, and a little nicer looking than the Propeller Tool version.
This is all three, side-by-side: Propeller Tool, Spin Tools (current), JM Spin Tools suggestion
Edited Saturday at 7:35PM Pacific Time -- corrected 7 glyph.
Hey Macca,
Guess I have to talk to myt IT staf.
Find it !
The most recently used file list can break Prop Tool. Wonder if that is what is going on here…
It might be a hidden file…
Show hidden files is just an option in the explorer menu…
Released version 0.53.1
This is a bugfix release:
Changes:
Thank you, Marco!
Hello, @macca
Thank you so much for your hard work — I’m happy to report that I am back to being able to use your great tool.
I installed the most recent release and followed the instructions for unzipping the files using the CMD window, and that resolved the issue.
I truly appreciate the time and effort you put into supporting the community.
Thanks again,
Joshua W
Thank you Marco.
😄 Agreed. Maybe force a checkmark to enable?
Deleted by JM
Released version 0.53.2
Some fixes and a couple of small additions:
That's working well for me, thank you
Thank you very much, Marco! Everything is working nicely.
