Spin Tools IDE - Page 29 — Parallax Forums
Spin Tools IDE
1232425262729»
  • maccamacca Posts: 944
    @JonnyMac said:
    I've seen a few oddities with the Spin Tools internal terminal, too, so I tend to open and use PST. I tried your string in both. In my case all characters seem to print, but there is some extra cruft at the end of the string using the Spin Tools terminal.
    I'm not sure, could be tx pin floating when the cogs are terminated ?
    Seems that weird things happens if I don't call txflush at the end, or don't add an endless repeat to keep the main cog running (using your jm_fullduplexserial library).
    @macca If you do any updates to the Spin Tools terminal would you consider adding the ability to turn off the flashing cursor?
    The cursor is draw when the line input box is disabled, but yes I can add a setting.
    Unfortunately PST doesn't have a cursor control code, ANSI/VT-100 have escapes to set the cursor blinking or hide and show.
  • @macca said:
    @lab_ges said:
    Hi @macca
    I have been noticing for a while that certain ASCII characters seemed to be missing when using the SPIN Tools terminal, specifically most of the RIGHT brackets i.e. ") > }" as well as "\"
    It may be something in my setup but the characters are there using spin Tools with PST, as shown on the screen prints, I have combined, below.
    Had these rendering issues in the past and I have changed the terminal rendering code to prevent that, in version 0.47 if I remember correctly. Are you using the latest version ?
    Opps sorry I meant to say this was on "Spin Tools IDE 0.49.1" which is still the latest version according to your site. It has never been a major problem but thought it was worth mentioning. I am also running on Windows 11 pro if that makes a difference?
    This problem has been arround for several versions at least and I thought that one day it would go away when a new version was released, but it has hung on.
    I find it interesting that @JonnyMac isn't seeing the same thing, though I do note he is missing the\symbol between the square brackets!
    I never see those funny characters at the end or the blinking cursor that JonnyMac sees either, it is like he is seeing the CR LF characters at the end of the line (which can be a handy thing for debugging).
    On on my Spin tool terminal there is actually a backtick type character (like these but not possible to show on the forum) showing instead of the backslash.
    I generated the characters using this simple test code, though I think I actually missed out the space in the screen prints above.
      repeat byte[x] from $20 to $7E             'Full visible ascii range starting at space!
        waitms(50)
        send(byte[x])
      send(13)
      send(10)
    I don't see problems here with Linux and Windows 11.
    Are you using a different font than the default (that on Windows should be Consolas) ?
    @Rayman said:
    @macca Just tested the serial port issue on another computer and it acts the same way...
    Have to close IDE if was in debug mode and serial cable unplugged and replugged.
    That auto device discovery option is selected.
    Ah... I found that on Windows the COM port number doesn't change... I need to adjust some parts of the discovery process.
  • JonnyMacJonnyMac Posts: 9,513
    edited 2025-10-09 14:46
    My fault; I copied the wrong result string from your original post. I duplicated your repeat loop code and it seems to work. Unless there's a specific reason I don't understand, you don't need to cast x as a byte because term.tx() only sends the lower eight bits of what it gets.
    That may have been the case because I'm not able to replicate that now. Sorry for the false alarm.
    Ok, you got me there, I remember playing around with the Parallax2 font at some stage and I must have left it in the options. I changed it back and it now works OK.
    Sorry for the trouble I caused you!
    @JonnyMac > Unless there's a specific reason I don't understand, you don't need to cast x as a byte because term.tx() only sends the lower eight bits of what it gets.
    Thanks for the comment, always useful. In this case the program was just an exercise to get to the cause of the missing characters in the terminal, ultimately I will be creating ethernet packets and I just grabbed some code from my main program and edited it to use for the demo.
  • ke4pjwke4pjw Posts: 1,231
    @macca I had to perform an update on one of my large projects last night. It was my first time really putting Spin Tools IDE through its paces. Wow, what a difference from Propeller Tool. Having the ability to jump straight to the PUB/PRI method or the OBJ file using the window on the right made a tremendous difference in the amount of time required to get things done. What used to be a bunch of searching and scrolling is now just a click away.
    Thank you so much for Spin Tools IDE!
    I suggest to those that can, support Marco!
    --Terry
  • RaymanRayman Posts: 15,804
    @macca
    Was thinking that it'd be nice if the top object stayed top when saved with a different file name.
    Also, maybe better if debug window was cleared when run in non-debug mode?
  • evanhevanh Posts: 16,901
    edited 2025-10-12 19:39
    @Rayman said:
    @macca
    Issue a time-stamp on each run attempt. That's something I keep wanting in my Bash sessions but never sort out myself.
    EDIT: LOL, that was easy, just had to add "date;" ... eg:
    $ filename=sdfat-speedtest;   flexspin -q -l -2 -D_BAUD=2000000  ${filename}.c; date;  loadp2 ${filename}.binary -p /dev/serial/by-id/usb-Parallax_Inc_Propeller_P2-ES_EVAL_P23YOO42-if00-port0 -t -b 2000000
    Mon 13 Oct 2025 08:37:42 NZDT
    ( Entering terminal mode.  Press Ctrl-] or Ctrl-Z to exit. )
       clkfreq = 100000000   clkmode = 0x100090b
      Compiled with FlexC v7.5.1-beta-v7.4.4-15-g89b6ef11
     cluster size = 32768 bytes
    Just an interesting note...
    Spin Tools was letting me get away with an unpaired "}".
    FlexProp wouldn't have it though...
  • wummiwummi Posts: 108
    @macca
    I found many problems in Spin Tools with Pointer operations.
    Chip has an good demo file in PNUT V52: PointerFlexibility.spin2
    I modified this file for PNUT V51a to show you all the problems
    This can not compiled with Spin Tools IDE 0.49.1, PNUT V51a has no problems and generate correct code.
    {Spin2_v51}
    pub go() | ^byte p, byte buff[20]       'declare a byte pointer and a 20-byte buffer
      [p] := @buff                          'point the pointer to the buffer
      p[++].byte := $50                     'write a byte into the buffer, step pointer
      p[++].long := $77777777               'write a long, step pointer
      p[++].word := $BEEF                   'write a word, step pointer
      p[++].byte := $01                     'write a byte, step pointer (.byte is for clarity, not needed)
      p[++].byte := $02                     'write a byte, step pointer
      p[++].byte := $03                     'write a byte, step pointer
      p[++].long := $FFFFFFFF               'write a long, step pointer
      debug(uhex_byte_array_(@buff,20))     'show the buffer
      [--]p.word := $5555                   'back up and write a word
      [++]p.word := $AAAA                   'move ahead and write a word
      p := $22                              'write a byte
      p[-1] := $33                          'write a byte at [-1]
      p++                                   'inc byte
      p[1]--                                'dec byte at [1]
      p~~                                   'set byte
      [--]p.long[-1].[31..28]++             'back up long pointer, increment top nibble of long at [-1]
      [p] += 6
      p.long := $11223344                   'set last 4 bytes
      p[0] /= 4                            'math ops examples
      p[1] *= 4
      p[2] += 4
      p[3] -= 4
      p[0] |= $F0                          'logic ops examples
      p[1] &= $F0
      p[2] <<= 4
      p[3] >>= 2
    @wummi said:
    @macca
    The fixes are already on the github repository for the next release.
    @macca
    I can not find a newer *macos-aarch64.tar.gz on GitHub
    The last Version is from 1. Sept
    edited 2025-10-24 19:39
    It'll be a git pull operation. Then recompile the compiler itself.
    I mean, the source repository is updated with the fixes, the new release will be published in the next few days, I have some more things to do and test.
    @ macca
    debug( lstr(...) ) is not working
    debug(zstr(@"Uwe")) ' works
    debug(lstr(@"Uwe",3)) 'crashes the Spin debugger
    Released version 0.50.0
    A lot of updates with this version.
    Updated the Spin2 interpreter to PNut v52, including the new functions/keywords, the next/quit level addition, DEBUG_END_SESSION and the new commands for the TERM debug window.
    The TERM debug window also have the SCROLL command implemented as suggested by @JonnyMac :
    scroll x1 y1 x2 y2 direction units bgcolor [level]
    Direction would be 0..3 for up, down, right, left, and units would be lines for vertical scrolling and columns for horizontal scrolling. The actual size of a line or column is dependent on the font size. It's a lot of parameters but I think it could be useful in many ways.
    The direction can also be specified as a word up, down, left, right to have a shortcut to scroll the entire window with just scroll up. If bgcolor is omitted it takes the window background color specified in the setup command. Note: this is not (yet) implemented in PNut.
    The outline view now can display background colors like the editor (can be enabled in the preferences):
    And since we are at, there is a new button on top to temporarily toggle the view visibility to have more editing space.
    The Editor preferences has a new option to disable the automatic expansion of the outline tree (sometimes may be a bit annoying).
    The program launchers now are using a fixed list of files to configure the Java runtime, this should prevent the load of old versions when updating to a new release.
    The problems with unplugging and replugging the serial adapter on Windows should be fixed.
    Also should be fixed the issues reported by @wummi with the pointers operations and LSTR.
    The cursor position in the edited files is now saved across sessions, this includes the open tabs and the last recently used files.
    Some other fixes, for a full list of changes:
    https://github.com/maccasoft/spin-tools/compare/0.49.1...0.50.0
    Enjoy!
    Grazie, Marco! Grazie!
    @macca
    thank you for version 0.50, all reported errors are fixed.
    Yesterday i update my iMac to Vers. 26.1, and the Spin-Editor now has a Problem with selected Code.
    When i select Code in one Line, the selected Chars are displayed normal.
    When I select Code in more than one Line, the selected Chars is not shown.
    The selected Code is not shown but can be deleted or copied in the Clipboard.
    If you want I can make screenshots to show this.
    Good!
    Yes, just to have an idea about what happens.
    Also, please try to change some preferences to see if there is something that affect it, like disable the sections background colors (editor preferences), force the light or dark theme (general preferences), or if the MacOS theme affects it.
    edited 2025-11-08 12:10
    I have tried all this already. Nothing helps.
    In the Debug-Output panel are the same problem. Select some Chars in one line are displayed ok. Select more than one line is not displayed inverted. Select all with ^A inverted nothing but all the Debug Lines are in the clipboard after ^C
  • DiverBobDiverBob Posts: 1,124
    Is there a way to port the debug output to a separate terminal window instead of bottom of the main programming view? I thought I saw a discussion on this but can’t find it again.
  • dgatelydgately Posts: 1,641
    edited 2025-11-08 16:06
    I have similar issues on macOS 26.1. Text selection in the editor is not visible beyond a single line. Selection highlighting is only partially visible when drag-selecting. I will try to catch screen grabs to show this issue.
    See the attached video file. In that video, you'll see several attempts to double-click text selection, drag-select text, etc... Although you can copy/paste a selection of text, it does not appear selected.
    EDIT: Added a 2nd video that displays text being selected & copy/pasted, but not highlighted...
    dgately
    edited 2025-11-08 15:54
    @wummi @dgately I did a quick research and looks like an issue with the SWT library:
    https://github.com/eclipse-platform/eclipse.platform.swt/issues/2621
    I guess we need to wait for the fix in 4.38 that is scheduled for release in december.
    No, the window is currently not detachable.
    Good to know... Thanks!
