New P2 module - Page 15 — Parallax Forums
New P2 module
191011121315»
  • evanhevanh Posts: 16,677
    edited 2025-08-29 09:57
    @Wuerfel_21 said:
    @evanh said:
    The only way to use a SD card, and not be constantly removing it, and also develop new code via serial booting is to have a loader in the EEPROM. Thereby entirely bypassing the ROM's SD boot solution.
    I usually just set the pullup for the long serial window. Forget which one that was. That will never auto-boot anything, but that's usually desireable.
    P59 pull-up forces serial only booting. P59 pull-down forces no serial booting.
    Yeah, I suppose that is an option: Boot from serial as a loader until happy with finished product, then put the loader on the SD card and make it bootable.
  • RaymanRayman Posts: 15,553
    edited 2025-08-29 12:35
    @evanh Looks like that was it...
    FatFS works from boot with this change to line 550 in sdmm.cc:
            //spm_rx |= P_SYNC_RX | P_OE | P_INVERT_OUTPUT | P_HIGH_15K | P_LOW_15K;  // rx smartpin mode, with 15 k pull-up
            spm_rx |= P_SYNC_RX | P_OE | P_INVERT_OUTPUT | P_HIGH_1MA | P_LOW_FLOAT;  //  pull-up
    edited 2025-08-29 14:32
    You do know that's a work-around, right? It overpowers the incorrectly wired R24 pull-down on P58 that should be a pull-up. I expect you to correct the schematic and fix the already made modules in the medium term.
    PS: The only reason, I think, that FSRW works for you is because you're using the broken sdspi_bashed2.spin2 driver that doesn't ever do a card busy check. Which is also why FSRW needs multiple attempts to get anything done.
    edited 2025-08-29 14:51
    @evanh what’s wrong with the work around?
    Not sure how changing the pulldown would affect other parts sharing that pin…
    It ain't gonna be standard issue for a starters. It'll be up to you to add the workaround each time there is an update to includes.
    The pull-down is a mistake. A tad surprisingly, the Parallax board have no resistor at all. So my programmed pull-up is actually needed.
    Everything except the CLK requires a pull-up.
    edited 2025-08-29 15:29
    The fact that the Eval and Edge boards have no pull-up resistor present on P58 means you can remove the Swap's R24 and be reasonably confident of future drivers always handling it.
    @evanh Have to see how that would affect the behavior of the PowerGood1 LED...
    Pull-ups on the LEDs don't matter but I have no idea what the PGOODx pins will do from that regulator. One hopes they go hi-Z when good. My gut reaction is cut those tracks so that P58/P59 no longer reach the regulator chip.
    @evanh Don't think I'll be cutting any traces..
    R24 is in an easy place to remove though. I'll try that.
    Goes without saying that future board production runs should be changed to fix these issues.
