New P2 module - Page 13 — Parallax Forums
New P2 module
1789101113»
  • evanhevanh Posts: 16,642
    Took me 1.5 years to get it going. Can't quite fathom how that happened.
    But then, Tony and I spent even longer on the XORO32 analysis. We started on that before 2017 I think. I remember that date because I upgraded from a dual-core PC to 8-core early in 2017. It was fun making use of that many cores in parallel for the first time.
  • TonyB_TonyB_ Posts: 2,219
    I joined this forum by chance in April 2017 as TonyB. I forgot my password a couple of months later but my free email service had been shut down so I've been TonyB_ ever since. I can't believe it's been eight years.
    @TonyB_ said:
    I joined this forum by chance ...
    Any memory the events of that chance? For me, it was a post on the Pixaxe forum by another user saying the Propeller had 8 cores. I immediately wanted to look at the architecture.
  • RaymanRayman Posts: 15,506
    edited 2025-08-17 12:53
    @evanh Don't you have one of these modules?
    Have you tried the FlexProp uSD driver with it?
    The ones here, supposedly identical, have this strange thing where need to run FSRW before the FlexProp uSD interface works...
    Wondering if you see the same thing...
    edited 2025-08-18 05:12
    I'm not at home right now so can't test anything but yep I do have an original Knivd built module.
    I've not booted the SD with it though. I assume that's part of the process here. Or does this behaviour happen with serial boot too?
    Booting from flash and then trying to access uSD…
    Got it. And this is specifically MegaYume by the sounds of it.
    Think it’s anything using Flexprop driver
