HDMI discussion - Page 5 — Parallax Forums
HDMI discussion
1235710
  • Wuerfel_21Wuerfel_21 Posts: 5,795
    edited 2024-10-17 16:25
    Well if it's just the first version, don't worry too hard about the edge cases~
    @rogloh said:
    Sounds good too. Seems weird to put a lot of audio burden in the video COG but HDMI and audio is coupled somewhat closely together. The other way to go is to have some sort of pull model where the HDMI pulls out audio samples at its own rate from some small FIFO and the audio source needs to monitor this FIFO's fill/drain levels and feed it with samples. Might create more jitter this way though as it would need to adapt its output rate slightly to keep the level from draining/filling too quickly. Probably messy to manage the buffer.
    No mess if the generator agrees on the overall sample rate (as with the mailbox system) or times itself to the FIFO. In such a system the video cog would also be responsible for the analog audio outputs, so it really becomes an audio+video cog. An interesting idea regarding this: If 32kHz is used, the 640/854/etc x 480 HDMI timing can be fudged (by creating a few extra VBlank lines) such that the line frequency is also 32kHz, matching the audio exactly. This would be super useful for doing multichannel, since otherwise you'd sometimes need to process and encode 2 packets per line.
  • In prep for HDMI audio I tightened up the original text processing loop a bit and split it up for polling audio which was getting too slow if I tried to do it in the inner critical REP loop itself. There is a nice natural split position half way though the output as I already needed to deal with half the number of characters in double wide mode. So I now do either one iteration of the outer loop for double wide chars or two iterations for normal wide and I tidied up my skipf mask at the end of the loop in the process saving a couple of instructions. This new code is working in both double and normal width text mode. New relevant snippet shown below.
    I'm now working on something similar in the graphics processing/pixel doubling code which also needs to poll audio without bogging down too much. I believe I can shrink the number of outer loop iterations a lot by always maximizing the available LUT space for transfers using a few conditional altd instructions before some setq2's. May take a few more instructions which I didn't have room for before but should be hundreds less cycles overall, especially for 24bpp mode which is the troublesome one. Moving to something like 36x3=108 clocks of housekeeping overhead vs 28x16=448 before. This is a useful savings if achievable.
                if_nz           setd    textloop, #18           '18 instructions executed for normal text
                if_z            setd    textloop, #24           '24 instructions executed for double wide text
                                wrnz    temp1                   'double = 0, normal = 1
                                mov     a, #%11000 wc           'reset starting lookup index
                if_nz           setbyte a, #%11101110, #2       'skip pixel doubled code when normal wide chars
    textloop                    rep     #0-0, #COLS/2           '1940 clocks for 40 double wide chars, 2920 for 80 chars
                                skipf   a                       'skip 2 of the next 5 instructions
                                xor     a, #%11110              'flip skip sequence for next time
                                rdlut   d, pb                   'read pair of characters/colours
                                getword c, d, #1                'select first word in long (skipf)
                                getword c, d, #0                'select second word in long (skipf)
                                sub     pb, #1                  'decrement LUT read index (skipf)
                                getbyte b, c, #0                'extract font offset for char
                                shr     b, #2                   'divide by 4
                                add     b, #$110                'add to font base
                                rdlut   pixels, b               'determine font lookup address
                                movbyts pixels, c               'get font for character's scanline
    testflash                   bitl    c, #15 wcz              'test (and clear) flashing bit
    flash       if_c            and     pixels, #$ff            'make it all background if flashing
                                movbyts c, #%01010101           'colours becomes BF_BF_BF_BF
                                mov     b, c                    'grab a copy for muxing step next
                                rol     b, #4                   'b becomes FB_FB_FB_FB
                                setq    F0FF000F                'mux mask adjusts fg and bg colours
                                muxq    c, b                    'c becomes FF_FB_BF_BB
        ' wide  normal
                                setword pixels, pixels, #1      '  *      |     replicate low words in long
                                mergew  pixels                  '  *      |     ...to then double pixels
                                mov     b, c                    '  *      |     save a copy before we lose colours
                                movbyts c, pixels               '  *      *     compute 4 lower colours of char
                                ror     pixels, #8              '  *      |     get upper 8 pixels
                                movbyts b, pixels               '  *      |     compute 4 higher colours of char
                                wrlut   b, ptrb--               '  *      |     save it to LUT RAM
                                wrlut   c, ptrb--               '  *      *     save it to LUT RAM
                                call    #audio_poll_repo
                                djnf    temp1, #textloop
  • roglohrogloh Posts: 6,246
    edited 2024-10-19 04:33
    Just modified my pixel doubling code to take advantage of a reduced housekeeping loop size and fixed that 24bit mode critical inner loop and now call the audio poller a few times during this workload. I timestamped the 24bpp doubling work and other line maintenance during the active portion and it is now down to using up ~3750 clocks of the 6400 budget. This should now leave enough for the audio & TERC4 workload I'd hope. :)
    Had a nightmare bug to figure out until I changed this
        _ret_                   pop     ptra
    back to this
                                pop     ptra
                                ret
    Getting rusty in my old age.
    Other colour modes are busted right now with pixel doubling but they should require less cycles so I'm not too concerned about measuring those at this stage.
    UPDATE: fixed some other depths of doubling:
    16bpp uses ~3130
    8bpp uses ~1600
    4bpp uses ~1445
    2bpp uses ~630
    1bpp uses ~375
    UPDATE2: The trick now will be getting all the extra HDMI specific sync logic/streamer code to fit, replacing what I already do for DVI, and creating a suitable init sequence for the new stuff. Down to 43 free COGRAM longs. :scream:
        _ret_                   pop     ptra
    back to this
                                pop     ptra
                                ret
    Yea, that one should really be added to the hardware errata list. Though I don't remember what kind of glitch this causes (is it just popping once and using it for both the RET and the POP?)
    16bpp uses ~3130
    8bpp uses ~1600
    4bpp uses ~1445
    2bpp uses ~630
    1bpp uses ~375
    :+1: As said, more love is needed for 16bpp mode.
  • @Wuerfel_21 said:
        _ret_                   pop     ptra
    back to this
                                pop     ptra
                                ret
    It's a feature, the GETPC feature:
    https://forums.parallax.com/discussion/comment/1426230/#Comment_1426230
    If line freq is 32kHz then exactly three 96kHz samples per line, presumably. Do most/all HDMI sinks support 96kHz?
    P.S. I have acres of whitespace to scroll past whenever I edit one of my posts.
    edited 2024-10-19 18:38
    @TonyB_ said:
    @Wuerfel_21 said:
        _ret_                   pop     ptra
    back to this
                                pop     ptra
                                ret
    That's one way of putting it. Though a relative LOC instruction does the same thing.
    I don't think so. The only required formats are 32/44.1/48kHz stereo. AVRs probably all take 96, TVs maybe, PC monitors probably not (my ASUS PA248QV doesn't even say anything about audio in the spec sheet other than "Speaker: Yes").
    Though for stereo 96kHz the line rate matching is not so much of an issue, since you can fit up to 4 samples in one packet for stereo. For multichannel you can only fit 1 (there's always 8 channels even if you're, e.g. only doing 4.0 or 5.1)
    Side note that's somewhat on-topic: The HDMI/CEA spec for surround channel mapping is apparently kinda broken?
    So:
    • 5.1 is an inherently compromised layout. The surround speakers are more to the side than to the rear (+/- 110° from center per ITU spec). This makes sense, most people have their sofa up against a wall and physically can't have proper rear speakers. This does mean there's a gaping 140° hole in the back and the front/rear speakers aren't symmetrical, but that's a fair compromise.
    • This means there are two variations on "4.0 surround": The classic "quadro" square layout and the 30°/110° 5.1 layout minus the center speaker. These are not equivalent. (The square layout is mathematically superior, but not as practical to actually set up)
    • (tangent: 7.1 has no formal spec! Though 135° azimuths are an ok guess? 150° is ideal to be opposite from the front L/Rs - something something energy vectors)
    • HDMI InfoFrames are based on CEA-861 (also probably used by DisplayPort audio?)
    • old versions of CEA-861 seem to ignore the above facts and feature this mindboggling graphic
    • (in that, FL+FR+RL+RR is 4.0 (code 0x08), FC is added for 5.0 (code 0x0A) and RLC/RRC are added for 7.0 (code 0x10) - has anyone ever needed discrete FLC/FRC channels? - note that the ITU spec azimuth for FL/FR is only +/-30° out from center!!)
    • in later versions of CEA-861, they realize the error of their ways and updated the figure and the channel names (though they missed some in the tables! Terrible find-and-replace job!)
    • LS/RS are now explicitly the 5.1 +/-110° surrounds. This includes the 4.0 layout (code 0x08).
    • This means there's no standard CEA/HDMI channel layout that isn't weirdly lopsided! Which, considering that more modern systems really treat the discrete channels more as suggestions than something to directly send to a speaker... is no good for making these suggestions.
    • Even in Dolby Atmos proprietary lala-land, which is supposedly speaker independent, there are still 5.1-derived "bed" channels! AAAAAAA! This is where anything that isn't a 3D object goes. The bed channels can be 7.1.4 or something like that, which is less bad, but urrrgh why~ (another fun Atmos fact: almost no receiver with the extra amp channels can take them as discrete analog or PCM input channels! 7.1's the limit! There is software for mastering Atmos, but guess what, the master bitstream format they output also isn't compatible with actual Atmos AVRs (you are supposed to use a "dumb" 12 channel interface for monitoring)... The conversion to the consumer bitstream (still apparently some iteration on ye-olde AC3) is apparently "handled by the distribution service". ??????? What distribution service? What if you just want to post a file to a normal-donkey website????)
    • This entire headache had already been solved by Ambisonics and related research in the 70s before any of this happened - you don't record speaker channels, you record the 3-dimensional soundfield, approximated by n-th order spherical harmonics and then the hardware at the very end turns it into speaker channels - and guess what format is predominantly used for 360° VR videos...
    Sorry for the unprompted rant, but if an idiot like me who's read a few papers and specs can spot something obviously amiss...
    Huh?
    edited 2024-10-20 03:51
    Running into a potential issue coding up stuff for HDMI data island packet transfers. Can the streamer handle two back to back commands using the HUB RAM from different source addresses without introducing a gap?
    I'd like to do something like the following snippet...
        rdfast  #0, ptrb ' setup FIFO source address for fifo data, to pre-fill it
        xcont   xhub32, #0  ' send 32 longs from hub
        rdfast  #0, next ' setup next source address for fifo data
        xcont   xhub32, #0  ' send another 32 longs from hub from second address
    xhub32 long X_RFLONG_32P_4DAC8 | 32
    My question is, will the second rdfast mess up the first? Will it corrupt the streaming in progress? I don't want to wait for the FIFO to empty before setting up the next transfer as is done by setting bit31 in the D field because that will resync me to to point when the first transfer is complete and I have other things I wish to do in this time. I basically want to issue both streamer instructions closely together and essentially buy myself ~640 clocks for other work I can go do in this time.
    I'm pretty much guessing this approach above isn't going to be possible given the FIFO prefill time.
    Normally FBLOCK can be used to setup the next address in advance when doing multiple FIFO transfers with wrapping etc but this seems to be for 64 byte block transfers and I'm sending 32 longs. Perhaps if I align the data it still could be possible to use somehow? Will FBLOCK also work with the streamer?
    In theory I could send 64 longs in one streamer command, but the second packet data (clock regen) is pre-encoded (static) which introduces complexities during VSYNC where it needs to be encoded differently.
  • Yes, this is what FBLOCK is explicitly for. It works on 64 byte blocks, so 32 longs means you need D=2. For smooth changeover, all your buffers must be whole blocks apart and long-aligned. I don't even think you need the 2nd streamer instruction, you can just do one 64 long command.
    edited 2024-10-20 04:04
    Um yeah it's worth an attempt. I hope it works correctly in conjunction with the streamer as I've only used it before without the streamer.
    The issue with coupling is the VSYNC encode version of the clock regen packet that immediately follows audio is different. I guess I can encode the audio packet to a different address on the scanline before vsync starts and do that until the second last line of vsync - just messy to check all the different scan lines for different work. Also in some cases I don't send a clock regen packet and would prefer to send a NULL pkt instead.
  • evanhevanh Posts: 17,070
    I just stuck to plain stereo. 5.1 and the likes always seemed a mess. The subs always seemed to pump out a monotonous throb and nothing else.
    edited 2024-10-20 11:54
    I might have just managed to get some sort of HDMI implementation to barely fit inside my P2 video driver. :smile: Worked on the tricky sync code today and found I could use skipf to an advantage here. I have 1 COGRAM long left right now but I think I can potentially free about 4 more when I get desperate. In addition I have kept the VGA's VSYNC pin toggle code in place (5 pin mode) done at VSYNC time so maybe there is hope for VGA+HDMI simultaneously depending on what else is required there in the runtime code, if anything. This code compiles but is untested and probably has bugs.
    Still need to add into the small amount of spare LUTRAM a couple more things to complete this to my satisfaction for testing:
    1) audio volume control (mostly just a couple of multiplies - hopefully 16 bit only)
    2) chain loading some more code after the TERC4 packet encoding stage which will do some audio polling to the end of the scan line. Am anticipating that I'll probably need to latch a timestamp from the start of the scan line so the code knows when to stop before the end the scan line and return for next hsync to be prepared. Right now that polling code after everything on the line has been done and the COG is just sitting idle probably won't fit the space.
    For now I will probably need to align the horizontal sync to the start of the island data and keep it within the first 64 pixels once the data island begins. It's tricky to have it change anywhere in the middle of the back porch following the island as this adds more streamer commands and COGRAM storage.
    In theory this code has the ability to send out two Infoframes on the last VSYNC scan line (or whatever packet is encoded by the client into HUB RAM). It's slightly messy because the driver could either decide to send a null packet or a clock regeneration packet prior to these two Infroframes, so the setup code would have to copy this extra packet data into two HUB locations to have the packets ready and stored contiguously for both packet send options, but this should be doable.
    Later on if interlacing support is added (480i/576i) then all pixels will have to be doubled by default and even quadrupled if the resolution drops to 320 or 360 pixels via my horizontal double wide option flag configured per region. This will take up more code space but my plan for that is to move the doubling/quadrupling code into LUTRAM overlays, which can then be read in to either double or quadruple pixels as needed. Doing this also frees some extra COGRAM space, ~32 longs IIRC, which can be helpful for also changing the text mode implementation to optionally pixel quadruple, as well any extra vsync changes for interlaced timing.
    ' Subroutines
        ' active   vsync   blank
    blank_vsync                 skipf   skipfmask_vsync         '
                                cmp     pa, #1 wz               '            *              z=1 if pa=1 (last sync line)
    blank                       skipf   skipfmask_vblank        '            |       *
    hsync                       skipf   skipfmask_active        '            |       |
                                xzero   m_hfp, hsync0           '   *        *       *      send shortended fp before preample
                                cmpsub  hdmi_regen_counter, hdmi_regen_period wc
        '   *        *       *      check if time to send regen pkt (c=1)
                                xcont   m_imm8, preamble        '   *        |       *      send preamble before island
                                xcont   m_imm8, preamble_vsync  '   |        *       |      send preamble before island (vsync line)
                                rdfast  #2, audio_pktbuf        '   *        |       *      prepare encoded audio pkt
                                wrlong  status, statusaddr      '   *        *       *      update clients with scan status
                if_c            fblock  #0, aclk_pktbuf         '   *        |       *      send aclk pkt (normal encode)
                if_nc           fblock  #0, null_pktbuf         '   *        |       *      send null when no regen packet ready
                if_c            fblock  #0, aclkv_pktbuf        '   |        *       |      send aclk pkt (vsync encoded)
                if_nc           fblock  #0, nullv_pktbuf        '   |        *       |      send null when no regen packet ready
                                xcont   m_imm2, dataguard       '   *        |       *      send leading guard band
                                xcont   m_imm2, dataguard_vsync '   |        *       |      send leading guard band (vsync)
    alt0                        xcont   m_hubpkt, #0            '   *        *       *      send two packets
                if_z            xcont   m_hubpkt, #0            '   |        *       |      send two more packets
                                setq2   #256-1                  '   *        |       |      read large palette for this scan line
                                rdlong  0, paletteaddr          '   *        |       |
                                xcont   m_imm2, dataguard       '   *        |       *      trailing guard band
                _ret_           xcont   m_hbp, hsync0           '   *        |       |      send shortened back porch before preamble+gb
                                xcont   m_imm2, dataguard_vsync '            *       |      trailing guard band sync encoded
                                xcont   m_hbp2, hsync0          '            *       *      only control, no pre+gb for blank/sync lines
                if_z            altd    alt0, #m_vi2            '            *       |      shrink vsync vis line for extra 64 pixel pkts
                                xcont   m_vi, hsync0            '            *       *      generate blank line pixels
                                call    #\loadencoder           '            *       *      encode next audio pkt & poll audio
               _ret_            djnz    pa, #blank_vsync        '            *       |      repeat
               _ret_            djnz    pa, #blank              '                    *      repeat
    skipfmask_vsync             long    %111100010011010100110 'check this mask
    skipfmask_vblank            long    %10010110111010110000100010 'check this mask
    skipfmask_active            long    %0000000010101100001000
    'hub RAM addresses of packet buffers stored here
    audio_pktbuf                long    0
    aclk_pktbuf                 long    0
    aclkv_pktbuf                long    0
    null_pktbuf                 long    0
    nullv_pktbuf                long    0
    avi_pktbuf                  long    0 ' dual pkt buf here audio+video infoframes, always sent on last vsync line
    m_hubpkt                    long    X_RFLONG_32P_4DAC8 | X_PINS_ON | 64
    m_imm8                      long    X_IMM_1X32_4DAC8 | X_PINS_ON | 8
    m_imm2                      long    X_IMM_1X32_4DAC8 | X_PINS_ON | 2
    preamble                    long    %0010101011_0010101011_1101010100_10        'preamble pattern when vsync is inactive (assumes hsync inactive)
    preamble_vsync              long    %0010101011_0010101011_0101010100_10        'preamble pattern when vsync is active (assumes hsync inactive)
    dataguard                   long    %0100110011_0100110011_1010001110_10
    dataguard_vsync             long    %0100110011_0100110011_0101100011_10
    video_guard                 long    %1011001100_0100110011_1011001100_10
    video_preamble              long    %1101010100_0010101011_1101010100_10
  • As previously discovered, the preamble doesn't have to be exactly 8 pixels, it just needs to be at least 8 pixels. So you can remove some complexity by turning the entire front porch into a preamble. (This checks out with the conformance document I found)
    I mean it is a mess :) Though if the sub sounds like that, level/crossover is probably set weirdly. (possibly because someone didn't understand that "small speaker" in the settings means "really small speaker" and any real speaker (yes even if bought at ALDI) should be set to "large" and that leads to setting the crossover so low that the sub only gets LFE and very low sub-bass). Of course nothing stops one from getting properly big speakers (as one would use for a good stereo setup), hook up 4 or 5 of those and just not having a sub at all. I actually really like the ProLogic style phase-amplitude matrix systems for music, nicely spreads the sound all around the room, a lot more like listening on headphones than normal stereo speakers.
    edited 2024-10-20 14:43
    Ok, just wasn't sure about doing that. I do plan to make the first bit of the data packet align with the hsync, so the preamble would be certainly remain part of the front porch.
    I had another thought about how to tidy things up a bit. If I keep one buffer area in HUB RAM with the following sequence of contiguous 32 pixel packets it should save longs as I can compute 128 byte offsets to select different output packets. No need to keep lots of addresses in COGRAM and I can just have a single InfoFrame update too which is simpler. I would just need to send the Null or Clock regen packet as the first of the pair (reverse the order). Am going to look into this. It may improve things quite a bit.
    Static Null packet (normal)
    Static Clock regen packet(normal)
    Static Null packet (vsync)
    Static Clock regen packet (vsync)
    Audio encoded packet (either vsync or normal encoded by software)
    InfoFrame packet 1 (only ever sent on vsync line, contents can vary with client COG's changes)
    InfoFrame packet 2 (ditto)
    (etc...)
    Update: now I have 5 free COGRAM longs after this change. :smile: Here's the updated code:
    blank_vsync                 cmp     pa, #1 wz               '                           z=1 if pa=1 (last sync line)
                                skipf   skipfmask_vsync         '                           do vsync line
    blank                       skipf   skipfmask_vblank        '            |              do other blanking line
    hsync                       skipf   skipfmask_active        '            |       |      do active line
                                xzero   m_hfp, hsync0           '   *        *       *      send shortened fp before preample
        '   *        *       *      c=1 if time to send a clock regen pkt
                                mov     pb, pktbuf              '   *        *       *      setup base packet buffer address
                                add     pb, #256                '   |        *       |      offset to send in vsync line
                if_c            add     pb, #128                '   *        *       *      offset to send clock regen pkt (c=1)
                                rdfast  #2, pb                  '   *        *       *
                                fblock  #0, pktbuf_audio        '   *        *       *      setup next packet start address
    'hub RAM address of packet buffers stored here contiguously in this sequence.  Must be aligned to 64 byte boundary.
    ' null
    ' audio clock regen
    ' null (vsync)
    ' audio clock regen (vsync)
    ' audio packet sample (both)
    ' avi infoframe(s) (only vsync encoded)
    pktbuf                      long    0
    pktbuf_audio                long    0
    edited 2024-10-22 06:30
    Almost there with the code for HDMI but still cranking on packet setup during init and sync polarity stuff. That gets messy to deal with and is prone to error.
    Confidence is high right now that this should fit both P2 timing wise and COG/LUT RAM wise. Something should work at least once bugs are sorted.
    I'm going to load the 256 entry palette and mouse sprite code into LUT RAM during HSYNC time when 2 packets are sent out (64 pixels = 640 P2 clocks). Then during horizontal back porch I can run the mouse sprite which takes about 480 clocks to execute. This will be nice and delayed and should give the prior issued external memory access from the previous scan line plenty of time to complete to be ready to overlay the sprite over this returned pixel data. Essentially the back porch will need to be setup with at least 48 pixels in order to have time to execute this sprite code before the video guard is sent.
    This seems reasonable and normal 640x480 mode at 25.2MHz uses the following pixel timing for blanking:
    HFP=16, HSYNC=96, HBP=48. We can move the extra 32 pixels from HSYNC into BP to ensure we have sufficient time for a mouse sprite to be rendered. My setup code can probably just reallocate any excess HSYNC size that exceeds 64 pixels into the HBP. This simplifies the multi-packet encoding.
    27MHz HDMI (widescreen 720x480) typically uses different timing like this:
    HFP=16, HSYNC=62 HBP=60. This timing can be modified to send 16, 64 and 58 pixels instead which should still be sufficient for a mouse sprite. Any time HSYNC is configured with less than 64 pixels, the missing amount can simply be stolen from the HBP.
    The HFP needs to be at least 8+2 pixels to send a preamble and data guard band but my code (currently) expects a non-zero control portion of around 2 pixels for this as well (16 clocks). This time is useful for figuring out the packets to go out and to preload the FIFO for streaming these packets. So realistically the HFP should be reduced no less than 12 pixels for the code to work, though the default of 16 is fine, and I think it needs at least 14 in order to sync correctly anyway.
    This means that blanking can't really be reduced further than about 14+64+48 or so, and using 128 total horizontal blanking pixels is probably safer. You could probably then achieve (1360+128)(768+3?)30fps on a P2 @ 344MHz on some low refresh rate display device that can accept the absolute minimum of blanking. Higher resolutions = lower frame rates. 1280x720p24 is probably achievable at ~254MHz with 750 vertical total lines being sent and the reduced horizontal blanking, although is an uncommon display resolution and refresh combination. Even @pik33 's 1024x576p special favourite resolution could potentially even be done sending out 1152x625x50Hz at a blistering P2 speed of 360MHz if a display accepts this timing.
    Separately to all this, I was thinking about an alternative way to pass in audio sample data if a spare pin can't be used as a repo. If we use the repo pin idea with the HDMI pins we have to give up the bitDAC IO on the pins and probably drive the TMDS data at voltage levels outside the spec (which typically works but I don't like it that much). The alternative way could just use a single HUB memory location instead of a more complicated FIFO in order to keep the resource use low and an ATN could be signalled to interested COGs.
    Right now my driver doesn't really make good use of ATN so an audio COG could potentially write stereo 16 bit data into a known memory address and then issue a COGATN. The polling code could be altered from this code...
    audio_poll_repo
                  cmp audio_inbuf_level,#4 wc
    .pptchd if_c  testp #0-0 wc ' TESTP is a D-only instr
            if_c  altd audio_inbuf_level,.inbuf_incr
    .pptchs if_c  rdpin 0-0,#0-0
                  ret wcz
    .inbuf_incr   long audio_inbuffer + (1<<9)
    to the following code below. It just requires one more COG long to hold the HUBRAM audio sample address and some suitable setup amongst COGs to share this common address. Not quite as easy as the Repo pin method, but still probably very simple to achieve.
    audio_poll_repo
            if_c  jnatn #exitpoll
    .pptchs if_c  rdlong 0-0,audio_addr
    exitpoll      ret wcz
    UPDATE: I think it's now fully coded unless I've missed something. There will be bugs no doubt but I should be able to start checking/testing very soon.
    Current storage:
    COGRAM - 498 used of 502 total longs
    HDMI encoding overlay - 240 of 240 LUT RAM entries used, though this could be split into two different parts eventually, audio + encode
    Driver setup overlay - 271 of 272 LUT RAM entries used, any more than 272 prevents the loading of the HDMI overlay during init time for packet encoding, though this part could be moved to HUBexec if required.
    edited 2024-10-23 04:00
    It's alive! Well HDMI framed video anyway with my "Chimera" test driver (a hybridised meld of @Wuerfel_21's audio +TERC encoder and my P2 video driver). Audio packets are being encoded yet apparently not being produced but that should be figured out soon.
    Had 4 real bugs to resolve so far to get to this point. All I can say is that the P2 DEBUG stuff and my TMDS decoder program saved the day, and it only took me a few hours instead of potentially days to sort this lot out.
    • had placed an extra push operation after a call, messing up call stack on return and crashing badly
    • inadvertent cut/paste of an instruction in between a setq2 and wrlong, resulting in only single LUT write instead of full packet burst
    • inadvertent cut/paste of another instruction in between an alts and muxq during code rearranging, messing up data guard symbol during sync
    • back porch size calculation error, off by 2 pixels on some lines
    Once those were sorted it now seems to be stable and I can now work with this.
    In other testing last night I discovered the worst case for a 640x480 resolution output was about 7104 clocks to execute the scan line from the start of horizontal blanking in 24 bit pixel doubling mode including audio/TERC4 encoding and up to the final audio poller sample operation before returning and starting the next line. I will probably also need to also add another 134 clocks or so to this if the region changes on the scan line and it might also need a couple of hundred more cycles per extra audio sample included in the audio packets. TBD. But even with those it should still fit the budget of 8000 clocks (6400 active, 1600 blanking). I should know soon.
    edited 2024-10-23 07:07
    Hi @Wuerfel_21 I'm having some problems with your resampling code which I took from your video-nextgen branch on GitHub.
    If I try to get it to lock the output at 48000Hz by setting up the audio_period with that rate in mind computed as (clkfreq+24000)/48000, I get zero for the integer and fractional portions of resample_ratio and no samples are emitted because the resample_phase_int is stuck at 0 and never increases.
    If I manually patch the resample_ratio_int value to a "1" by default at boot I do get samples emitted but it's arriving at 24000Hz (half rate). If I set it to 2, I then get 1/3 the samples per second. Maybe I should set it to some other value... ideally it should be computed but it's not touched when the sample period is found to be one of the known 32/44.1/48kHz rates.
    I also tried a different non-standard sample rates but it doesn't seem to output samples at the correct rate 48kHz rate either, got about 38kHz or something like that IIRC (approx half of what I'd nominated, but can't recall exact number). Will need to retest that specifically again tonight and update this. I might have used a rate that is higher than the 48kHz rate, not lower.
    So is this branch's audio code currently working or broken to your knowledge? I hope I haven't missed something important but I believe I now have the same algorithm coded as yours - virtually copied verbatim but with a couple of minor custom changes - your patch skipping now has a variable controlling it as it executes for LUTRAM as an overlay and I can't patch it as easily. Here are the relevant snippets of interest...
                  mov temp3,#0
    .sploop
                  tjz resample_phase_int,#.dosp
    .feed
                  tjz audio_inbuf_level,#.spdone
           '      debug(UHEX_LONG(audio_inbuffer))
                  mov audio_hist+0,audio_hist+1
                  mov audio_hist+1,audio_hist+2
                  mov audio_hist+2,audio_hist+3
                  mov audio_hist+3,audio_inbuffer+0
                  mov audio_inbuffer+0,audio_inbuffer+1
                  mov audio_inbuffer+1,audio_inbuffer+2
                  mov audio_inbuffer+2,audio_inbuffer+3
                  sub audio_inbuf_level,#1
                getword spleft, audio_hist+3, #1 ' get left sample
                muls    spleft, lvol ' attenuated left sample
                sar     spleft, #15 ' convert left sample to 16 lsbs
                muls    audio_hist+3, rvol ' attenuate right sample
                sar     audio_hist+3, #15 ' convert right sample to 16 lsbs
                setword audio_hist+3, spleft, #1 ' combine both samples
             '    debug(UHEX_LONG(audio_hist))
                  djnz resample_phase_int,#.feed ' always fall through if ratio < 2
    .dosp         ' Create an output sample using cubic resampling
                  'debug(UHEX_LONG(spleft))
                  'debug(UHEX_LONG(spright))
    .... <skipped>
                  decmod resample_antidrift_phase,resample_antidrift_period wc
            if_c  mov resample_phase_frac,#0
            if_nc add resample_phase_frac,resample_ratio_frac wc
                  addx resample_phase_int,resample_ratio_int
                  ' Set sample as valid in header
    .... <skipped>
                  add hdmi_regen_counter,#1
                  incmod temp3,#2-1 wc ' This limits it to encoding 2 samples per scanline, which ought to be enough
                  ' Hacky check to fix sampling jitter:
                  '  Packets where frac->int overflow occurs are only allowed in first packet slot
                  '  This is probably bad and a better way should be found.
                  mov temp1,resample_phase_frac
                  tjz patch_enabled, #.skippatch
    .jptch1 if_nc add temp1,resample_ratio_frac wc ' Check if next frac add or
    .jptch2 if_nc cmp resample_antidrift_phase,#1 wc ' antidrift overflows
    .skippatch
            if_nc jmp #.sploop
    .spdone
                  ' fall straight into packet encoder
    And here's the setup code...I have zeroed all the values at startup.
    ' audio-related, all needs zero-ing before use
    audio_hist                  long    0[4]
    audio_inbuffer              long    0[4]
    audio_inbuf_level           long    0
    resample_ratio_frac         long    0
    resample_ratio_int          long    0
    resample_antidrift_period   long    0
    resample_phase_frac         long    0
    resample_phase_int          long    0
    resample_antidrift_phase    long    0
    spdif_phase                 long    0
    hdmi_regen_counter          long    0
    ... <skipped>
                                ' Setup resampling rate
                                ' If it matches any standard rate we know then we disable resampling
                                rdlong  temp2,#@clkfreq ' grab system clock
                                ' Check 32kHz
                                loc     pa,#\32_000
                                call    #util_check_sr_fuzzy
                if_c            setnib  spdif_status+0,#%0011, #6
                if_c            jmp     #.nctssetup
                                loc     pa,#\44_100
                if_c            setnib  spdif_status+0,#%0000, #6
                                loc     pa,#\48_000
                                call    #util_check_sr_fuzzy ' gets 48k ideal period into temp1
                                setnib  spdif_status+0,#%0010, #6 ' Always set 48k
                                ' Ok, resample whatever it is to 48k
                              ' debug(udec(temp1))
                              ' debug(udec(audio_period))
                                qdiv    temp1, audio_period ' temp1 still has 48kHz period
                                getqx   resample_ratio_int
                                getqy   temp1
                                qfrac   temp1, audio_period
                                getqx   resample_ratio_frac
                                mov     resample_antidrift_period, audio_period ' Always set NC
                                sub     resample_antidrift_period, #1
                                mov     resample_antidrift_phase, resample_antidrift_period ' Init to max valud because DECMOD
    .nctssetup
                if_c            mov     temp1, audio_period ' If not resampling, use input rate
                                ' Disable de-jitter code if not resampling or fractional ratio >= 0.5
                                mov     patch_enabled, #1
                                tjns    resample_ratio_frac,#.no_djkill
                                tjnz    resample_antidrift_period,#.no_djkill
                                mov     patch_enabled, #0
                debug("Disabled de-jitter!")
    .no_djkill
                                ' Setup audio clock regen packet
                                mov     packet_header, #$00_00_00_01 ' Clock packet
                                debug(udec(resample_ratio_int))
                                debug(uhex(resample_ratio_frac))
                             '  debug(udec(temp2))
                                mov     temp3, ##10000
                                mul     temp3, temp1
                                shr     temp3, #1 wc
                                add     temp2, temp3
                                rcl     temp3, #1
                                qdiv    temp2, temp3 ' clkfreq/period (rounded)
                                getqx   temp2 ' gives multiplier that shifts 1280/period into optimal range
                                mul     temp1, temp2 ' CTS value
                                mov     hdmi_regen_period, temp2
                                mul     hdmi_regen_period, #10
                                mul     temp2, ##1280 ' N value
                                debug("N: ",udec_(temp2)," CTS: ",udec_(temp1))
                            '   debug(udec(hdmi_regen_period))
                                ' Pack them into the clown car, honk honk
                                setr    temp3, #packet_data0
                                rep     @.nctspck, #4
                                alti    temp3, #%111_000_000
                                movbyts temp1, #%%0123
                                movbyts temp2, #%%3012
    .nctspck
                                rczr    a wcz
                                mov     packet_extra, ##$FE_FF_FF ' Start bit, hsync
                if_c            setbyte packet_extra, #0, #1        ' positive vsync
                if_nz           setbyte packet_extra, #0, #0        ' negative hsync
                                loc     pb, #\clkpkt
                                call    #terc_encode
                                xor     packet_extra, ##$FF00
                             '  setbyte packet_extra, #$FF, #1 ' VSync version
                                loc     pb,#\clkpktv
                                call    #terc_encode
                                setq    #9-1
                                rdlong  packet_header, ##$80000 ' clear packet data
                                jmp     #fieldloop              'begin outputting video frames
    util_check_sr_fuzzy
    '' Compute period of sample rate in PA into temp1 (using clkfreq in temp2)
    '' Set C if audio_period is close enough
                mov pb,pa
                shr pb,#1
                add pb,temp2
                qdiv pb,pa
                getqx temp1
                mov pb,temp1
                sub pb,audio_period
                abs pb
          _ret_ cmp pb,#1 wc
    util_infoframe_chksum
                setbyte packet_data0+0,#0,#0
                setbyte packet_header+0,#0,#3
                setbyte packet_data0+1,#0,#3
                setbyte packet_data1+1,#0,#3
                setbyte packet_data2+1,#0,#3
                setbyte packet_data3+1,#0,#3
                getbyte temp1,packet_header,#2 ' grab length
                add temp1,#4-1
                mov temp2,#0
    .chklp
                altgb temp1,#packet_header
                getbyte temp3
                sub temp2,temp3
                djnf temp1,#.chklp
              ' debug("infoframe checksum ",uhex_(temp2))
          _ret_ setbyte packet_data0,temp2,#0
  • It should definitely work - just build whatever you copied it out of to verify.
    All zeroes is the correct setting for bypass. The ratio is indeed zero, but the antidrift counter will underflow every time, so it doesn't matter (antidrift is normally used to fix rounding error in the ratio).
    edited 2024-10-23 10:43
    Okay I reset it back to zero and do see some samples generated now - however it seems to be getting into a regime where there's only ever one sample seen per packet and I see an audio packet rate of 31.5kHz based on the number of samples and the number of pixels and 25.2Mpixels/s. Maybe I'm not sampling often enough on the scan line. I sample audio at the following times on the scan line:
    • start of line (0 clocks)
    • half way through text processing and also at end of 80 chars rendered, ~1600 & 3200 clock cycles later
    • (or) in graphics mode per each pixel group doubling iteration of 240 output longs
    • at end of TERC encode ~ 1300-2000 cycles later.
    • then repeatedly in a tight loop until near the end of the scan line when I return for the next line
    Here's what I get: ~31.5kHz rate
    ❯ grep Sample out | more
        Sample    Interval Type                             Red(ch2)    Green(ch1)  Blue(ch0)     Clock       RRGGBB  TMDS/CTS  128*Fs FsClk  FifoSize Action
           587  Sample 0  right = 000000, left = 000000, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=0          0     1     SAMPLE WRITE
          1387  Sample 0  right = 028900, left = 028900, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=1          0     2     SAMPLE WRITE
          2187  Sample 0  right = 03C500, left = 03C500, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=2          0     3     SAMPLE WRITE
          2987  Sample 0  right = 062000, left = 062000, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=3          0     4     SAMPLE WRITE
          3787  Sample 0  right = 073800, left = 073800, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=4          0     5     SAMPLE WRITE
          4587  Sample 0  right = 093000, left = 093000, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=5          0     6     SAMPLE WRITE
          5387  Sample 0  right = 0A0B00, left = 0A0B00, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=6          0     7     SAMPLE WRITE
       1565387  Sample 0  right = F9DF00, left = F9DF00, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=79      2927    -971     SAMPLE WRITE
       1566187  Sample 0  right = F8C700, left = F8C700, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=80      2928    -971     SAMPLE WRITE
       1566987  Sample 0  right = F6CF00, left = F6CF00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=81      2930    -972     SAMPLE WRITE
       1567787  Sample 0  right = F5F400, left = F5F400, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=82      2931    -972     SAMPLE WRITE
       1568587  Sample 0  right = F48900, left = F48900, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=83      2933    -973     SAMPLE WRITE
       1569387  Sample 0  right = F3FE00, left = F3FE00, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=84      2934    -973     SAMPLE WRITE
       1570187  Sample 0  right = F34100, left = F34100, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=85      2936    -974     SAMPLE WRITE
       1570987  Sample 0  right = F30100, left = F30100, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=86      2937    -974     SAMPLE WRITE
       1571787  Sample 0  right = F31100, left = F31100, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=87      2939    -975     SAMPLE WRITE
       1572587  Sample 0  right = F39000, left = F39000, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=88      2941    -976     SAMPLE WRITE
    ❯ grep Sample out | wc
        1967   45231  318232
    edited 2024-10-23 11:08
    Am wondering if it is related to this hacky stuff...if it exits the loop early it might only allow a single sample per audio packet. When I increased the first line incmod value to 3-1 instead of 2-1 it still issued only one sample per line. Maybe this patch is not being skipped and forces an exit due to comparing zero with the #1 value which sets carry and exits.
                  incmod temp3,#3-1 wc ' This limits it to encoding 2 samples per scanline, which ought to be enough
    .skippatch
            if_nc jmp #.sploop
    .spdone
    The logic here seems to not disable this patch if the tjns line is executed which it will be because resample_ratio_frac is never set after startup and it remains at zero.
              ' debug("Disabled de-jitter!")
    .no_djkill
    EDIT: Yep, when I manually disabled the dejitter hack it seems to work now and I get ~2997 samples in 1572229 pixels which is 2997/1572229 * 25.2MHz ~ 48kHz. So that code is not working correctly.
      1569099  Sample 1  right = 0C6F00, left = 0C6F00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=0       2982     7     SAMPLE WRITE
       1569899  Sample 0  right = 0CBE00, left = 0CBE00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=1       2983     7     SAMPLE WRITE
       1570699  Sample 0  right = 0CEE00, left = 0CEE00, flags=CC Pr=1 Cr=1, Pl=1 Cl=1 ParityR=0 ParityL=0 Channel status count=2       2985     6     SAMPLE WRITE
       1570699  Sample 1  right = 0CFE00, left = 0CFE00, flags=88 Pr=1 Cr=0, Pl=1 Cl=0 ParityR=1 ParityL=1 Channel status count=3       2985     7     SAMPLE WRITE
       1571499  Sample 0  right = 0CEE00, left = 0CEE00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=4       2986     7     SAMPLE WRITE
       1572299  Sample 0  right = 0CBE00, left = 0CBE00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=5       2988     6     SAMPLE WRITE
       1572299  Sample 1  right = 0C6F00, left = 0C6F00, flags=00 Pr=0 Cr=0, Pl=0 Cl=0 ParityR=0 ParityL=0 Channel status count=6       2988     7     SAMPLE WRITE
        2997   68921  479514
    edited 2024-10-23 12:41
    AUDIO IS WORKING :):)B)
    Update: looks like we just made it with pixel doubling and audio. When three samples are encoded per scan line it takes 7716 clocks and two samples takes 7492 clocks. I do need to add the optional next region processing code to this which is ~134 more clocks. 7716 + 134 = 7850 out of 8000 clocks per line. Tight.
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_492
    Cog1  temp1 = 7_492
    Cog1  temp1 = 7_492
    Cog1  temp1 = 7_492
    Cog1  temp1 = 7_492
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_716
    Cog1  temp1 = 7_716
    When I forced it to encode 4 samples per audio frame I found it took 7940 clocks which is just enough to fit but would mean only one region would be achievable as there is insufficient time to do region processing. I may be able to move some of that work into the back porch if there is any time left after the mouse stuff but that would be for later. Mouse appears to be completed at 1308 clocks into the scan line (~131 pixels in from start of FP), and we have 1600 clocks in the blanking interval. Doing that could enable up to 4 samples per line for 96kHz audio transmitted on a 31.5kHz video line frequency. Right now the limit would be 31.5 * 3 = 94.5kHz.
    At 27MHz there are more clocks per scan line so 96kHz may work there.
  • Oh.... will have to investigate how that ever worked... it certainly does for me...
    edited 2024-10-23 13:41
    Might work if you declared an uninitialized variable as res 1 instead of long 0 and had something different in HUB RAM at that underlying location which may make the variable a negative value and have it work for you.
  • I am just ????
    Anyways this should fix 'er up:
                tjz resample_antidrift_period,#.yes_djkill
    .yes_djkill mov build_audio:jptch1,#0 ' NOP
                mov build_audio:jptch2,#0 ' NOP
    .no_djkill
  • Oh, no, there's something deeply cursed occurring.
    If I apply the above fix to Tempest 2000 (uses 44.1kHz bypass), the audio timing gets messed up - ?????
  • Okay, so apparently whatever buggy nonsense comes out with the dejitter code wrongfully enabled, my monitor likes, but correct 44.1 output where some samples are delayed (because I enabled debug mode and there's some prints in the MOD player code)? NO, that gets dropouts.
    tl;dr; code posted above is good.
    @rogloh before I merge the new code into mainline on any project, I'll ask you and your prickly picky equipment to sanity check it :)
    I suspect some HDMI monitors might take all sorts of abuse and fill in the gaps during missing audio samples etc as long as they get something at some fixed rate. So you may not have noticed the issue. DEBUG mode would introduce a lot of larger jitter though and probably is noticeable. This bug would simply send some samples constantly at 31.5kHz. It's essentially resampling to 31.5kHz. :smile:
    I tested your fix on your code with my Plasma (using vgatest) as well as in my own driver. Nice zero overhead fix, seems good.
    I meant the whole applications :) as seen above, timing bugs can creep in from the audio driver. Have you built the Tempest 2000 source before? It has a similar branch with the new HDMI driver.
    edited 2024-10-24 02:32
    I haven't seen Tempest 2000 before, no, but in the meantime I'll try full NeoYume with this and report back.
    Update: played NeoYume first level of MSlug - audio survived fine.
    Well that doesn't mean much, there wasn't any change (dejitter enabled either way).
    T2K source is here: https://github.com/Wuerfel21/tempest2k/tree/video-nextgen
