New SD mode P2 accessory board - Page 20 — Parallax Forums
1171820222336
  • evanhevanh Posts: 17,011
    edited 2024-10-17 02:37
    @rogloh said:
    ... Caching may not help streaming writes much one the buffer fills up and you are still writing.
    Oi! Clear your head!
    A: We know there is plenty of waiting time happening. There is lots of opportunity for improvement here.
    B: The data written is not a large amount at all.
    C: Even if filled part way through the cache would still make a difference if it was helping at all.
  • roglohrogloh Posts: 6,210
    edited 2024-10-17 03:31
    A. we probably need to see a breakdown of the timing gaps, to know what is being held up. Is the gap just while the card is busy writing, or a delay while the COG is executing FATFS logic, or a gap while cluster map table is being read/updated/processed etc. etc
    B. The data written could be huge if streaming. I'm talking during things like video capture where it keeps on writing for hundreds of MB to several GB.
    C. Yes. It could help a bit if some work can be done during the gaps between clusters is already occurring due to FATFS code slowdowns and if you'll be stuck waiting then anyway. Some internal cache write backs could perhaps continue during this time.
    These delays seem massive though compared to your underlying performance with 4 bit IO. What are we seeing like a 5x slowdown or so?
    edited 2024-10-17 04:01
    I've done the testing already. The most recent data lengths were 2MB, 4MB, 8MB and 16MB. Repeated. EDIT: Err, just the 2 and 4, buffer sizes were 2kB, 4kB, 8kB and 16kB. So not large write lengths at all. https://forums.parallax.com/discussion/comment/1562497/#Comment_1562497
    Behaviour stayed consistent with earlier measurements of the same. In those earlier measurements I logged each timing interval from fwrite() to fwrite() plus every filesystem break in between. So we have the breakdown of the earlier runs already. And there's little evidence anything has changed with caching enabled.
    Yes, they are massive, imho. The waiting gaps should vanish entirely if the caching was doing its job. For some reason it isn't happening.
    Maybe UHS is still needed, which seems unlikely given it allowed me to engage the cache setting.
    Maybe I haven't done all the needed steps and it's not actually engaging at all. I tend to only read enough of the docs to make it happen and stop after that. There could be steps I've missed.
    Maybe other features, like command queuing, is required in combination. I've never tried to implement such before and have no comprehension of what it would take. My gut feel is queuing will take a lot RAM on the host for a starters. And add notable overhead to manage it.
  • Ok, well hopefully we'll be able to figure it out in time as we discover more. Would be neat to be able to take advantage of all the work you've done.
    Yep, I'll keep plugging at it.
    I'll do some more reading and if that turns up nothing I'll get stuck into, attempting to at least, streamlining the fatfs filesystem code.
    edited 2024-10-17 04:27
    Two runs with only the Cache mode toggled. 512kB file length, 64 kB buffer size. Second one is with caching enabled.
    PS:There is natural variation between runs in both settings. I picked a common result around 4000 kB/s. Min/Max are something like 3700/4700 kB/s.
     CID decode:  ManID=1B   OEMID=SM  Name=ED2S5
      Ver=3.0   Serial=49C16906   Date=2023-2
     SD Card Init Successful
     RD0 330376  RD800 331491  RD801 331771 mount sd: OK
     RDf740 332489  WRf740 332819  RD85a 339094  WR85a 339952  WR7fda 345652  RDf740 350838  Buffer = 64 kB,  RD85a 351750  WR43f80+40 352061  WR43fc0+40 358425  WR44000+40 367821  WR44040+40 372460  WR44080+40 378297  WR440c0+40 387651  WR44100+40 392286  WR44140+40 398122  WR44180+40 407499  WR441c0+40 412137  WR44200+40 417975  WR44240+40 427364  WR44280+40 431999  WR442c0+40 437836  WR44300+40 447232  WR44340+40 451870  WR85a 457678  WR7fda 466687  RDf740 470555  WRf740 471438  WR801 475789  SYNC 475880  Written 512 kB at 3998 kB/s,  RDf740 480039  RD43f80+40 480913  RD85a 482087  RD43fc0+40 482453  RD44000+40 484025  RD44040+40 485242  RD44080+40 486815  RD440c0+40 488018  RD44100+40 489605  RD44140+40 490809  RD44180+40 492381  RD441c0+40 493600  RD44200+40 495173  RD44240+40 496375  RD44280+40 497962  RD442c0+40 499167  RD44300+40 500738  RD44340+40 501956  Verified,  RD43f80+40 503784  RD43fc0+40 504990  RD44000+40 506198  RD44040+40 507414  RD44080+40 508624  RD440c0+40 509827  RD44100+40 511050  RD44140+40 512254  RD44180+40 513462  RD441c0+40 514680  RD44200+40 515891  RD44240+40 517096  RD44280+40 518319  RD442c0+40 519523  RD44300+40 520730  RD44340+40 521949  Read 512 kB at 26417 kB/s
     Cache Extension Enabled
     RD0 291810  RD800 293090  RD801 293369 mount sd: OK
     RDf740 294085  WRf740 294415  RD85a 300656  WR85a 301514  WR7fda 307192  RDf740 312355  Buffer = 64 kB,  RD85a 313267  WR43f80+40 313578  WR43fc0+40 319924  WR44000+40 329037  WR44040+40 333656  WR44080+40 339472  WR440c0+40 348663  WR44100+40 353282  WR44140+40 359101  WR44180+40 368319  WR441c0+40 372938  WR44200+40 378754  WR44240+40 387961  WR44280+40 392580  WR442c0+40 398399  WR44300+40 407634  WR44340+40 412252  WR85a 418038  WR7fda 426870  RDf740 430700  WRf740 431575  WR801 435895  SYNC 435986  Written 512 kB at 4009 kB/s,  RDf740 441192  RD43f80+40 442065  RD85a 443192  RD43fc0+40 443549  RD44000+40 445073  RD44040+40 446244  RD44080+40 447770  RD440c0+40 448926  RD44100+40 450466  RD44140+40 451624  RD44180+40 453148  RD441c0+40 454319  RD44200+40 455845  RD44240+40 457001  RD44280+40 458541  RD442c0+40 459699  RD44300+40 461223  RD44340+40 462394  Verified,  RD43f80+40 464176  RD43fc0+40 465334  RD44000+40 466494  RD44040+40 467664  RD44080+40 468827  RD440c0+40 469982  RD44100+40 471158  RD44140+40 472315  RD44180+40 473475  RD441c0+40 474646  RD44200+40 475808  RD44240+40 476964  RD44280+40 478139  RD442c0+40 479297  RD44300+40 480457  RD44340+40 481628  Read 512 kB at 27495 kB/s
    And again but using 4 kB buffer size, file length reduced to 128 kB for reading sanity:
     RD0 382233  RD800 383349  RD801 383628 mount sd: OK
     RDf740 384090  WRf740 384420  RD85a 388721  WR85a 389613  WR7fda 394127  RDf740 398128  Buffer = 4 kB,  RD85a 399031  WR43f80+8 399333  WR43f88+8 403617  WR43f90+8 407387  WR43f98+8 411203  WR43fa0+8 415944  WR43fa8+8 420793  WR43fb0+8 425656  WR43fb8+8 430529  WR43fc0+8 435416  WR43fc8+8 440347  WR43fd0+8 445290  WR43fd8+8 450246  WR43fe0+8 455726  WR43fe8+8 461316  WR43ff0+8 466919  WR43ff8+8 472537  WR44000+8 478167  WR44008+8 483844  WR44010+8 489533  WR44018+8 498146  WR44020+8 501705  WR44028+8 505375  WR44030+8 509057  WR44038+8 512754  WR44040+8 516463  WR44048+8 520219  WR44050+8 523988  WR44058+8 527804  WR44060+8 532543  WR44068+8 537391  WR44070+8 542252  WR44078+8 547125  WR85a 551986  WR7fda 557273  RDf740 561515  WRf740 562383  WR801 565954  SYNC 566045  Written 128 kB at 750 kB/s,  RDf740 569862  RD43f80+8 570733  RD43f88+8 571190  RD43f90+8 571648  RD43f98+8 572105  RD43fa0+8 572575  RD43fa8+8 573045  RD43fb0+8 573515  RD43fb8+8 573985  RD85a 574435  RD43fc0+8 574738  RD43fc8+8 575211  RD43fd0+8 575685  RD43fd8+8 576158  RD43fe0+8 576614  RD43fe8+8 577070  RD43ff0+8 577526  RD43ff8+8 577982  RD44000+8 578444  RD44008+8 578903  RD44010+8 579363  RD44018+8 579822  RD44020+8 580219  RD44028+8 580615  RD44030+8 581012  RD44038+8 581408  RD44040+8 581809  RD44048+8 582209  RD44050+8 582608  RD44058+8 583006  RD44060+8 583401  RD44068+8 583796  RD44070+8 584191  RD44078+8 584586  Verified,  RD43f80+8 585051  RD43f88+8 585485  RD43f90+8 585920  RD43f98+8 586355  RD43fa0+8 586801  RD43fa8+8 587248  RD43fb0+8 587695  RD43fb8+8 588142  RD43fc0+8 588594  RD43fc8+8 589044  RD43fd0+8 589495  RD43fd8+8 589945  RD43fe0+8 590378  RD43fe8+8 590811  RD43ff0+8 591244  RD43ff8+8 591677  RD44000+8 592115  RD44008+8 592552  RD44010+8 592988  RD44018+8 593424  RD44020+8 593798  RD44028+8 594171  RD44030+8 594545  RD44038+8 594918  RD44040+8 595296  RD44048+8 595672  RD44050+8 596048  RD44058+8 596424  RD44060+8 596796  RD44068+8 597168  RD44070+8 597539  RD44078+8 597911  Read 128 kB at 9664 kB/s
     RD0 394150  RD800 395444  RD801 395724 mount sd: OK
     RDf740 396186  WRf740 396519  RD85a 402743  WR85a 403562  WR7fda 409889  RDf740 415701  Buffer = 4 kB,  RD85a 416605  WR43f80+8 416909  WR43f88+8 423067  WR43f90+8 428744  WR43f98+8 434434  WR43fa0+8 443017  WR43fa8+8 446576  WR43fb0+8 450246  WR43fb8+8 453930  WR43fc0+8 457628  WR43fc8+8 461336  WR43fd0+8 465092  WR43fd8+8 468861  WR43fe0+8 472676  WR43fe8+8 477416  WR43ff0+8 482266  WR43ff8+8 487129  WR44000+8 492004  WR44008+8 496891  WR44010+8 501822  WR44018+8 506766  WR44020+8 511722  WR44028+8 517202  WR44030+8 522793  WR44038+8 528399  WR44040+8 534017  WR44048+8 539646  WR44050+8 545323  WR44058+8 551012  WR44060+8 559589  WR44068+8 563148  WR44070+8 566818  WR44078+8 570503  WR85a 574175  WR7fda 578177  RDf740 581163  WRf740 582033  WR801 584352  SYNC 584443  Written 128 kB at 749 kB/s,  RDf740 587637  RD43f80+8 588507  RD43f88+8 588966  RD43f90+8 589425  RD43f98+8 589884  RD43fa0+8 590342  RD43fa8+8 590796  RD43fb0+8 591249  RD43fb8+8 591703  RD85a 592133  RD43fc0+8 592436  RD43fc8+8 592893  RD43fd0+8 593350  RD43fd8+8 593807  RD43fe0+8 594264  RD43fe8+8 594733  RD43ff0+8 595202  RD43ff8+8 595672  RD44000+8 596143  RD44008+8 596616  RD44010+8 597089  RD44018+8 597562  RD44020+8 598035  RD44028+8 598490  RD44030+8 598947  RD44038+8 599402  RD44040+8 599860  RD44048+8 600319  RD44050+8 600778  RD44058+8 601237  RD44060+8 601696  RD44068+8 602090  RD44070+8 602485  RD44078+8 602879  Verified,  RD43f80+8 603341  RD43f88+8 603777  RD43f90+8 604213  RD43f98+8 604648  RD43fa0+8 605084  RD43fa8+8 605514  RD43fb0+8 605945  RD43fb8+8 606376  RD43fc0+8 606808  RD43fc8+8 607242  RD43fd0+8 607675  RD43fd8+8 608109  RD43fe0+8 608543  RD43fe8+8 608989  RD43ff0+8 609436  RD43ff8+8 609882  RD44000+8 610330  RD44008+8 610780  RD44010+8 611230  RD44018+8 611680  RD44020+8 612129  RD44028+8 612562  RD44030+8 612994  RD44038+8 613427  RD44040+8 613861  RD44048+8 614297  RD44050+8 614733  RD44058+8 615168  RD44060+8 615604  RD44068+8 615976  RD44070+8 616347  RD44078+8 616718  Read 128 kB at 9303 kB/s
    edited 2024-10-17 04:48
    Compare without the timing log. Same order as above. Shows that write performance is barely impacted by the logging.
    EDIT: Repeated runs of the first case below looks like the average might be 100 kB/s higher, ie: Min/Max is sitting between 3800/4800 kB/s and I'm getting more above 4000. EDIT: I've actually had 3600 kB/s now so the more testing done the wider the min/max extremes seem to get. Not seeing significant change between settings though.
    mount sd: OK
     Buffer = 64 kB,  Written 512 kB at 4012 kB/s,  Verified,  Read 512 kB at 28915 kB/s
    mount sd: OK
     Buffer = 64 kB,  Written 512 kB at 4022 kB/s,  Verified,  Read 512 kB at 30048 kB/s
    mount sd: OK
     Buffer = 4 kB,  Written 128 kB at 771 kB/s,  Verified,  Read 128 kB at 12779 kB/s
    mount sd: OK
     Buffer = 4 kB,  Written 128 kB at 775 kB/s,  Verified,  Read 128 kB at 11811 kB/s
  • Be good to chart this data somehow. Maybe total # of real payload sectors written on y axis, by time (p2 clocks) on x axis and you'll then see gaps and the resulting slope gives the overall rate.
    We're just looking for the Busy gaps really. Do they change with cache enabled? The rest is just confirming the methods aren't spoiling the measurements.
    edited 2024-10-17 11:35
    The Busy's are looking damn near identical. Even the pattern of high-low bumps is the same. I'm declaring the cache as inactive even though the enable bit is set - and verified set.
    SDv6 spec Section 4.16.2.4 Application Performance Measurement Conditions has a list of steps for how to measure performance to spec. It includes enabling the cache then using command queue together as a pair.
    I get the feeling that the caching system is only accessible via the command queue. Now I wonder if a limited use, ie: 1 deep, of CQ can be effective.
    edited 2024-10-17 12:09
    @rogloh said:
    @evanh said:
    The idea had been that the caching would make it all faster by eliminating the long Busy states. The small singles would be so fast they wouldn't matter much. Alas, that didn't pan out.
    Plus those sorts of extra features are probably somewhat card dependent anyway. Caching may not help streaming writes much one the buffer fills up and you are still writing.
    Oh, you were talking about when a large write is done in the wild. Now I follow.
    If that happens then it won't be because of the small singles. It'll just be the limit of the card, and would also do the same with raw linear writing. So, not the issue we're addressing here.
    PS: I don't want to mess too much with the filesystem software. The potential for introducing subtle and devilish bugs at that level I think is quite high. So if we can get more sustained speed by activating newer SD features then I'm willing to give it a go.
    edited 2024-10-17 12:13
    Yep.
    PS: I don't want to mess too much with the filesystem software. The potential for introducing subtle and devilish bugs at that level I think is quite high. So if we can get more sustained speed by activating more of the advanced SD features I'm willing to give it a go.
    Worth a shot to see what happens with the different SD features, if not just to learn more about it. It's just those FatFS APIs that preallocated the file's clusters during opening that look potentially really good for long sustained writes if they avoid the extra singles. But if it can't speed it up on it's own then it's not as handy. I guess to help more I'd need a breakdown as the to real bulk of the slowness as all I've seen is raw data and it's not always easy to draw conclusions directly.
    edited 2024-10-17 12:32
    The writes in those timing dumps are sequentially ordered clusters all the way. The allocating method seems fine.
    The extra singles intermingled in the dump will be for house keeping in between the fwrites(). The SYNCs were a good example of that. The FS layers are written in a robust manner, ie: They act like each fwrite() consists of an fopen()/fwrite()/fclose() combo to ensure everything is always flushed. It likely also minimises RAM usage, which is very desirable.
    I think using the SD based caching will hide a lot of the extra delays that this approach inflicts. And if this works out, all you need to do when buying an SD card is look for the A2 logo to know it has the required feature set.
  • RaymanRayman Posts: 15,899
    Not exactly sure what was going on, but reinstalled flexprop and seems to work in 1-bit mode with your code now:
       clkfreq = 100000000   clkmode = 0x100090b
    Filesystem = fatfs,  Driver = sdcardx
    mount sd: OK
     Buffer = 16 kB,  Written 4096 kB at 1594 kB/s,  Verified,  Read 4096 kB at 2741
     kB/s
    exit
    Four bit SD mode still doesn't work though...
    Also, that program did format the drive as exFAT. Didn't notice that...
    I've had a shot at using that formatter myself now too. It didn't function. Under Wine, it don't find any drives to format.
    What does the output look like with both DEBUG's defined?
    Still stuck after 4-bit mode:
       clkfreq = 300000000   clkmode = 0x1000efb
    Filesystem = fatfs,  Driver = sdsdcard
     Clock divider for SD card is 4 (75 MHz)
     Set pins: CLK_PIN=44 CMD_PIN=45 DAT_PIN=40 POW_PIN=39 LED_PIN=46
     Card detected ... power cycle of SD card
      power-down threshold = 37   pin state = 1
      power-down slope = 50060 us   pin state = 0
      power-up threshold = 209   pin state = 0
      power-up slope = 1129 us   pin state = 1
     SD clock divider set to sysclock/750.  'rxlag' compensation is 0
    Card idle OK
     OCR register c0ff8000  - Valid SDHC/SDXC Card
    Data Transfer Mode entered - Published RCA 59b40000
    4-bit data interface engaged
    Hmm, yeah, that's getting stuck at the rx_datablocks().
    Try this driver. It's nothing special, just reports the pin states at that point. You should see something like this:
     Card idle OK
     OCR register c0ff8000  - SDHC/SDXC Card
     CLK=0 CMD=1 POW=0 D3=1 d2=1 D1=1 D0=1
    Did you post the gerbers for this board? Maybe I can just have some made?
    edited 2024-10-17 23:06
    It was just the photo and schematic that was posted.
    Grr, I must have a bug still. The driver shouldn't just get stuck like that, irrespective of cause.
    EDIT: Although, a compiler bug is definitely a possibility now too.
    Rayman,
    Post your latest binary here.
  • Even better, a listing (use -l switch)! It's easy to use a diff tool on the listing to see where the differences are
    yes, that too please.
    Still thinking it's something to do with MBR, but who knows.
    I'll have an Ubuntu laptop in a few days...
    edited 2024-10-17 23:29
    It's getting stuck before any data blocks are read at all. The first use of rx_readblocks() is to fetch the SD_STATUS register to print the cache extension availability. Only happens when SD_DEBUG is set.
    The second use is for switching to High-Speed interface mode, which also reports back with the SD_STATUS register. Only happens when CLK_POL = 0.
    If those two are skipped, then the MBR will be attempted.
    edited 2024-10-18 00:08
    DUH!!!! I should have seen that a lot earlier! Rayman, add --fcache=256 to your compile line.
    EDIT: I started talking with Eric about what to do with this. This larger Fcache encroaches on the space needed for the nu-code VM. Eric decided nothing to do and that people wanting to use the VM could live with just using the SPI driver.
    But, even accepting that, it's still a niggle that compiling needs this parameter.
    EDIT2: Yeah, it makes complete sense that both tx_datablock() and rx_datablocks() gave you grief. Those routines both internally copy the data block into cogRAM so they can process the CRC in parallel with the streamer transferring to/from the SD card. That amount of data in cogRAM splatters over FlexC working registers if Fcache isn't expanded to allow for it.
    Awsome. One of my cards didn't work, but another gives this:
    clkfreq = 200000000 clkmode = 0x10009fb
    Clock divider for SD card is 4 (50 MHz)
    mount: OK
    Buffer = 2 kB, Written 2048 kB at 957 kB/s, Verified, Read 2048 kB at 7802 k
    B/s
    Buffer = 2 kB, Written 2048 kB at 976 kB/s, Verified, Read 2048 kB at 7786 k
    B/s
    Buffer = 2 kB, Written 2048 kB at 962 kB/s, Verified, Read 2048 kB at 7763 k
    B/s
    Buffer = 2 kB, Written 2048 kB at 976 kB/s, Verified, Read 2048 kB at 7809 k
    B/s
    Buffer = 4 kB, Written 2048 kB at 1702 kB/s, Verified, Read 2048 kB at 11242
    kB/s
    Buffer = 4 kB, Written 2048 kB at 1741 kB/s, Verified, Read 2048 kB at 11692
    kB/s
    Buffer = 4 kB, Written 2048 kB at 1751 kB/s, Verified, Read 2048 kB at 11762
    kB/s
    Buffer = 4 kB, Written 2048 kB at 1759 kB/s, Verified, Read 2048 kB at 11640
    kB/s
    Buffer = 8 kB, Written 4096 kB at 2869 kB/s, Verified, Read 4096 kB at 15414
    kB/s
    Buffer = 8 kB, Written 4096 kB at 2926 kB/s, Verified, Read 4096 kB at 15543
    kB/s
    Buffer = 8 kB, Written 4096 kB at 2920 kB/s, Verified, Read 4096 kB at 15555
    kB/s
    Buffer = 8 kB, Written 4096 kB at 2872 kB/s, Verified, Read 4096 kB at 15193
    kB/s
    Buffer = 16 kB, Written 4096 kB at 3972 kB/s, Verified, Read 4096 kB at 1839
    1 kB/s
    Buffer = 16 kB, Written 4096 kB at 3958 kB/s, Verified, Read 4096 kB at 1843
    6 kB/s
    Buffer = 16 kB, Written 4096 kB at 4020 kB/s, Verified, Read 4096 kB at 1829
    0 kB/s
    Buffer = 16 kB, Written 4096 kB at 3885 kB/s, Verified, Read 4096 kB at 1814
    3 kB/s
    Buffer = 32 kB, Written 8192 kB at 4724 kB/s, Verified, Read 8192 kB at 2049
    5 kB/s
    Buffer = 32 kB, Written 8192 kB at 4609 kB/s, Verified, Read 8192 kB at 2009
    0 kB/s
    Buffer = 32 kB, Written 8192 kB at 4710 kB/s, Verified, Read 8192 kB at 2042
    2 kB/s
    Buffer = 32 kB, Written 8192 kB at 4682 kB/s, Verified, Read 8192 kB at 2049
    1 kB/s
    Buffer = 64 kB, Written 8192 kB at 6802 kB/s, Verified, Read 8192 kB at 2057
    9 kB/s
    Buffer = 64 kB, Written 8192 kB at 6683 kB/s, Verified, Read 8192 kB at 2057
    6 kB/s
    Buffer = 64 kB, Written 8192 kB at 7018 kB/s, Verified, Read 8192 kB at 2057
    6 kB/s
    Buffer = 64 kB, Written 8192 kB at 6530 kB/s, Verified, Read 8192 kB at 2058
    4 kB/s
    Buffer = 128 kB, Written 16384 kB at 9003 kB/s, Verified, Read 16384 kB at 2
    0668 kB/s
    Buffer = 128 kB, Written 16384 kB at 8934 kB/s, Verified, Read 16384 kB at 2
    0607 kB/s
    Buffer = 128 kB, Written 16384 kB at 8848 kB/s, Verified, Read 16384 kB at 2
    0079 kB/s
    Buffer = 128 kB, Written 16384 kB at 9054 kB/s, Verified, Read 16384 kB at 2
    0666 kB/s
    Buffer = 256 kB, Written 16384 kB at 10582 kB/s, Verified, Read 16384 kB at
    20196 kB/s
    Buffer = 256 kB, Written 16384 kB at 10535 kB/s, Verified, Read 16384 kB at
    20688 kB/s
    Buffer = 256 kB, Written 16384 kB at 10289 kB/s, Verified, Read 16384 kB at
    20243 kB/s
    Buffer = 256 kB, Written 16384 kB at 10844 kB/s, Verified, Read 16384 kB at
    20678 kB/s
    exit
  • Nice one Rayman.
    With a P2 clocking at 50MHz, 20MB/s reads certainly looks like 4bit SD is finally functioning now for you. :smile:
    Yes, pretty awesome
