HDMI discussion - Page 2 — Parallax Forums
HDMI discussion
2456710
  • evanhevanh Posts: 16,509
    @TonyB_ said:
    Quoting old messages seems to only quote the last replier's response. Nested quotes can be done manually, by quoting the earlier message, replacing > with >> and merging the two quotes, e.g.
    Can be adjusted here - https://forums.parallax.com/profile/quotes
  • roglohrogloh Posts: 5,912
    edited 2024-10-11 04:47
    @Wuerfel_21 ,
    Hey Ada, I think I just found a way to save 2 instructions in the text rendering code. This means we could either do one cursor and keep the flash attribute OR two cursors (one mouse, one text) which would be great.
    scanfunc_text
                                rep     @.endscan,#2            'do twice
                                rfword  color                   'get color + char data
                                getbyte data, color, #0         'get character
                                rczr    data                    'divide by 4
                                rdlut   pixels, data            'read pixels in font
                                movbyts pixels, color           'make pixels in LSB of long valid
    testflash                   bitl    color, #15 wcz          'test (and clear) flashing bit
    flash       if_c            and     pixels, #$ff            'make it all background if flashing
                                decmod  curs_count, #511 wc     'test for cursor, wrap to large num
                if_c            mov     color, curs_color       'choose cursor color for all nibbles
                if_nc           movbyts color, #%01010101       'colours becomes BF_BF_BF_BF
                                mov     data, color             'grab a copy for muxing step next
                                rol     data, #4                'data becomes FB_FB_FB_FB
                                setq    ##$F0FF000F             'mux mask adjusts fg and bg colours
                                muxq    color, data             'color becomes FF_FB_BF_BB
                                movbyts color, pixels           'select pixel colours for char
                                xcont   X_IMM_8X4_LUT, color    'write colour indices into streamer as 8 nibbles
    .endscan                    ret     wcz                     'restore flags
    Note: I used a ## constant here in my original code, which now needs to be stored in COGRAM, otherwise the timing values I counted up before are not valid. I was assuming space for that.
  • Did a little analysis of the P2 clock cycle use in my video driver during pixel doubling with thoughts of whether HDMI is still feasible while streaming out the prior scan line simultaneously, which is what my driver model does.
    Here are the clocks taken by my pixel doubling loop for different colour depths at 640x480. I've focussed on the 24 bit RGB/32 bpp one which is the most resource hungry. Accounting for most of the doubling work it looks like there'd be 2752 cycles free in the active portion. There are a few other things the code might still need to do such as trigger PSRAM reading and mouse sprite stuff but it'd hopefully leave us 2200 cycles for HDMI encode+audio. I also tested the block transfers into the COG and it appears that for reads & writes it takes about approx 25% more cycles than usual when simultaneously streaming longs into the FIFO using a 10:1 sysclk/pixelclock ratio, due to the competition for HUB window bandwidth. I measured ~648 clocks for 512 long transfers vs ~521 when not streaming and budgeted for this additional transfer overhead in the table.
    Main drama is probably where this extra HDMI encoding code can fit. For modes that don't use the 256 entry colour palette I could gain 240 longs there (need to keep 16 free for the text palette and other simpler LUT modes). Whether those 240 longs would be enough for HDMI+audio resampling, not quite sure yet. I could potentially read in some of the HDMI code after doubling and swap it out after but that burns a lot of clocks too.
  • @rogloh said:
    Just tried patching my code so it outputs half the active pixels at half the rate in DVI mode with a setq before the active pixels begin using the divide by 20 value and restored at the end of active portion back to divide by 10 so the other sync timing stuff still all works. Couldn't get an image on screen. Might still be something I'm doing wrong or maybe this repetition only works in immediate mode...? My code is using the streamer.
    Update: just verified this same approach of the extra setq instructions with VGA instead of DVI in my driver does double the pixels on screen so it would appear my patched code is okay. It's just that DVI output doesn't like it. I wonder if the streamer's NCO value still somehow affects the DVI encoder block's timing and messes with it or we have to do some special initial priming for it to work.
    Yeah, this was tested before. Try deploying your 10b capture code, I'd love to see what's actually going on.
    Clever use of MOVBYTS!
    I was assuming that already. It's easier to write it out with ##...
    Disclaimer: I am not 100% on my HDMI code being as optimized as it could be. You may be able to crunch it down some at the expense of cycles.
    Current size seems to be ~128 longs for CRC+encode (96 code, 16 terc symbols) and another ~128 for audio buffer management, resampling and packet building. Take some scanfunc stuff, give some variables, so 256 longs. Maybe more like 200 if you remove the resampler or downgrade to linear interpolation (cubic really uses a lot of code space).
    There's also the 32 long packet buffer, but that can be moved into hub (easier to stream it out from there, too).
    But oh yeah, it's kind of a lot of code. I feel like doing a 1:1 upgrade of p2videodrv might not be in the cards, some features might need to be left on the table for a new driver.
    edited 2024-10-12 02:11
    If I do choose to add HDMI I sort of plan to keep my existing output variant as is (possibly make use of the alternative NCO rate for pixel doubling at some point) and then have a mostly different codebase that gets read in at startup time and this would remove all remnants of PAL/NTSC sync stuff and be dedicated for HDMI output only. Even if rewritten it would try its best to keep the key features of my existing driver and understand the same data structures. Things like PSRAM, text mode, mouse, all colour modes would try to be prioritized.
    If clocks are available I might be able to read in some of the HDMI code on the fly into upper LUT RAM. Last night I realized you actually only have to read the code in, you don't need to copy it back as these longs are only ever used for doubling so they get refreshed automatically by the process on the next line. So that's one bonus.
    If needed I could make a couple of sacrifices that may help, though I'd try to avoid this as both of these are useful. Also doubling/pixel repetition is sort of needed anyway if you ever wanted to output interlaced SDTV over HDMI.
    1) No doubling in 32bpp mode, maybe also in 16bpp mode too. Or even no doubling at all. :(
    2) No 8bpp palette mode support with HDMI. Frees another 240 longs. :(
    I won't like dropping either thing.
    One other idea I had (will have to look into it) is to just do audio processing per scanline and save samples to a buffer. This will lag audio by one frame but let me do a lot of packet encoding work in the mostly wasted vertical blanking time. I recall when I was coding my HDMI TERC stuff way back that was my plan and I thought I'd even checked the budget for that, thinking it was doable. But that was years ago and I may have been wrong, or may have been doing part of the work on the active scan line as well. I can't remember fully.
    UPDATE: looking at my old first attempt code and roughly counting instruction cycles it looks like it took in the vicinity of 2660 cycles just to TERC encode a packet - using crcbit instead of crcnib is obviously not nearly as efficient as your stuff Ada :confounded: , so that won't fly to do in the vertical interval - that burns 218 scan lines of the 525 sent if 525 packets are encoded. I think I'd probably planned to pack 4 stereo audio samples in each packet or something that would have cut down the number of packets being encoded/sent, but knowing what we do now about my TV/Amp pickiness about audio timing it probably wouldn't have worked out too well there anyway.
  • Wuerfel_21Wuerfel_21 Posts: 5,365
    edited 2024-10-12 02:41
    Oh those are both rather important I think.
    The mouse cursor is also a rather nice feature, IMO, should defo keep that.
    mine is at 2006 for CRC+TERC - this includes 76 dummy scanfunc calls at 8 cycles a pop, so 1398 real cycles. The CRC is broken up to meet scanfunc timing, so that could be sped up a bit further.
    Super Off-Topic: 16bpp 320x240 I think will be the nice mode for polygon rendering - can fit one (or squeezing it, two) buffer in Hub RAM comfortably, is a real color space that can do arbitrary gradients, pixel count in range for simple scenes at 60 FPS or complex scenes at 30 FPS (using fillrate estimates from that texture map experiment code I still haven't published).
    Those being (at peak - narrow spans have large-ish overhead - note that my test just fills rectangles, no triangle raster processing)
    • ~26cy/px for RGB gouraud
    • ~26cy/px for raw texture
    • ~37cy/px for texture + mono gouraud (lighting or fog)
    • ~88cy/px for bilinear filtered texture + mono gouraud (lighting or fog)
    (all this for 8bpp index textures with no clamp/repeat, approximate perspective correction and dithering to 16bpp)
    (So if using texture+lighting on 2 render cogs at 320 MHz targeting 60 FPS, a depth complexity of ~3.4 is possible)
    Ultra Off-Topic: My KDE plasma shell and VSCodium crashed while trying to write this post. I don't even...
    edited 2024-10-12 02:50
    Yeah I know, that's the problem. 640x480 8bpp LUT mode fits very nicely in HUB for those without PSRAM, and pixel doubling is good for game emulator/sprite driver COG stuff - although if these COGs did the repetition work into 640 pixel linebuffers, that'd still work. I can still do 40 column text in my code.
    Yep. Mouse sprite for GUI is slick.
    Yeah was looking at your code a moment ago. Scanfunc stuff goes away. It's probably something that fits ok in my budget. Instruction space is the biggest issue IMO but I might be able to read in 240 longs dynamically and that'd take about 300 or so clock cycles.
    edited 2024-10-12 04:46
    One other thing I realized I could do if LUT space is at a premium is to separate the steps of the processing like you did, with CRC stuff first then TERC4 encode. The code for both steps could be read into the LUT at different times before being executed, then you don't need the full instruction space for all HDMI work to fit inside the COG simultaneously. That sort of more fine grained overlay approach should help allow us to keep the 256 entry palette mode with any luck. So the sacrifice might then be that this HDMI driver variant is crashable if its HUBRAM is corrupted. That's not ideal but it's still a reasonable tradeoff to make IMO as most other system code already works that way anyway. Even things like the mouse sprite code could work that way too, and free more COG RAM.
  • TonyB_TonyB_ Posts: 2,209
    edited 2024-10-12 10:31
    Is testing still ongoing or is hardware DVI/HDMI pixel repetition using the streamer definitely not possible?
    Well my first attempt failed. If you'd like to try it go ahead. It'd be great it this was somehow possible, although if it means underflowing the streamer's command buffer for each pixel sent in immediate mode that could be a real problem. Ideally it could work with the FIFO and data sourced from HUB RAM. Once I get my setup with the HDMI capture software all ready again I'll probably try it another time to at least see what is being output. Alternatively this can be investigated with a logic analyzer and a slowly clocked P2 outputting DVI encoded pixels.
  • I don't think there's a difference between command types at that layer. The TMDS encoder appears to just sit inbetween the 32 pin outputs from the streamer and the actual OUTA bus.
  • My only thought was if the streamer was too slow to fill the pipeline initially due to 1/2 NCO rate it could get into some sort of messed up state where all pixels after that were badly encoded and messed up the monitor tracking pixel boundaries or something like that. Perhaps the first pixel is special and needs to be primed first in the buffer then we switch the NCO rate to half speed. But it was only a guess and has no Verilog analysis or real evidence base to it. Theory only.
    edited 2024-10-12 13:32
    No rush, just asking as I don't have the Eval DVI board.
    Different bpp settings might either work or not equally, but perhaps the one most likely to work is RFLONG -> RGB24, i.e. 1 long per pixel.
    FIFO filling shouldn't be a problem as that happens at one long per clock. 1/2 NCO rate means it takes twice as long before FIFO is refilled due to half speed reading from the FIFO.
    Ok, I might have been trying with text (which is 4bpp)
  • I wonder is there is some weird pipeline related problem where streamer rate changes at a different time than the serializer reload. Maybe cut the blanking intervals in half and run everything at 1/20? I think that would prevent HDMI audio though.
  • @rogloh scanfunc text proof-of-concept
    (Haven't actually checked if the audio is still working...)
    Good idea, run streamer at sysclk/20 all the time to test pixel repetition and worry about HDMI audio later.
    edited 2024-10-12 20:38
    Well done! I knew you'd do this :smile: A nice little challenge wasn't it.
    Without freeing two more instructions by retiming everything, the second (mouse) text cursor could be made a choice to have at setup time or even dynamically. So whenever you disable the text flashing option on the screen you gain the second cursor instead. That could work out nicely actually. It just means that any text based UI's that need a mouse cursor would have no flashing text. Can't recall if the old Borland/Turbo C style IDEs used flashing text much - I don't think they did as they might have used brighter background colours which disabled flashing.
    EDIT: if you do a second mouse cursor I think it needs to be the second one applied to fully cover the solid block over the text and any text cursor so some co-ordinate or code reordering may be required, if this is dynamic.
    So with flashing enabled:
    do flashing text
    do cursor 1 = text
    With flashing disabled:
    do cursor 2 = text
    do cursor 1 = mouse
  • RaymanRayman Posts: 15,244
    @Wuerfel_21 What are you up to here?
    Doubling horizontal pixels so can show QVGA at VGA resolution?
    She has basically taken my text rendering code and has integrated into her HDMI driver. This capture above is 80 column text at VGA 640x480 resolution being output over HDMI (and in theory audio will work with this too). I think the font is double high if she used my p2font16 or could be something shrunk from the P1 font. 15 rows x 32 pix font = 480 lines or the capture interface was expecting interlaced material and showing one field stretched. But that's unimportant for now.
    edited 2024-10-12 23:16
    Hey I just managed to use my capture code from a couple of weeks back to capture my video driver outputting RGB24 with NCO at sysclk/20 rate in active part of the scan line. Interestingly my TM decoder program barfed on the clock. Looks like the clock is not continuing to be output at the 5 high/5 low levels after this switchover. I think the individual bits are being doubled or something...strange transition from 10 to 16 to 20 bits for the clock (I will have to examine this further by getting my program to output more details than just skipping over the bad data).
    Yes this the sort of issue I was wondering about too - you put it more succinctly.
           301    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           302    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           303    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           304    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           305    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           306    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           307    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           308    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           309  * Invalid bit count of 16 ignored
           310  * Invalid bit count of 20 ignored
           311  * Invalid bit count of 20 ignored
           312  * Invalid bit count of 20 ignored
           313  * Invalid bit count of 20 ignored
           314  * Invalid bit count of 20 ignored
           315  * Invalid bit count of 20 ignored
           316  * Invalid bit count of 20 ignored
    At the end of the active portion back to the normal NCO rate it also does this... and goes via 14 clock bits back to 10.
           626  * Invalid bit count of 20 ignored
           627  * Invalid bit count of 20 ignored
           628  * Invalid bit count of 20 ignored
           629  * Invalid bit count of 14 ignored
           630    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           631    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           632    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           633    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
    edited 2024-10-12 23:33
    Ok doesn't look good - here's the TMDS data when it switches NCO rates. Look at the clock bits
    Decoding TMDS using channel bits:
        Sample    Interval Type                             Red(ch2)    Green(ch1)  Blue(ch0)     Clock       RRGGBB  TMDS/CTS  128*Fs FsClk  FifoSize Action
           309    Data:->  RGB (00_00_00)                   0000000100000000  0000000100000000  0000000100000000    0000000000011111  000000
           310    Data:->  RGB (11_11_41)                   00000011111111110000  00000011111111110000  00000001111111000000    00000000000111111111  111141
           311    Data:->  RGB (EF_EF_95)                   00000001000000001111  00000001000000001111  00000001111110001100    00000000000111111111  efef95
           312    Data:->  RGB (11_11_C9)                   00000011111111110000  00000011111111110000  00000011111110111000    00000000000111111111  1111c9
           313    Data:->  RGB (EF_EF_1C)                   00000001000000001111  00000001000000001111  00000001111100001011    00000000000111111111  efef1c
           314    Data:->  RGB (11_11_BE)                   00000011111111110000  00000011111111110000  00000001000011000000    00000000000111111111  1111be
           315    Data:->  RGB (EF_EF_6A)                   00000001000000001111  00000001000000001111  00000001000010001100    00000000000111111111  efef6a
           316    Data:->  RGB (11_11_D9)                   00000011111111110000  00000011111111110000  00000001111101001000    00000000000111111111  1111d9
           317    Data:->  RGB (EF_EF_1C)                   00000001000000001111  00000001000000001111  00000011000111110100    00000000000111111111  efef1c
           318    Data:->  RGB (FE_FE_51)                   00000001000000000000  00000001000000000000  00000001000111001111    00000000000111111111  fefe51
           319    Data:->  RGB (11_11_94)                   00000011111111110000  00000011111111110000  00000001000110001100    00000000000111111111  111194
    Here's it switching the NCO back
           146    Data:->  RGB (EF_AB_BE)                   00000001000000001111  00000011000000110011  00000010111110010101    00000000000111111111  efabbe
           147    Data:->  RGB (11_44_6A)                   00000011111111110000  00000001111111000011  00000010111111011001    00000000000111111111  11446a
           148    Data:->  RGB (EF_BA_D9)                   00000001000000001111  00000011000000111100  00000010000000011101    00000000000111111111  efbad9
           149    Data:->  RGB (C0_C5_2C)                   11010101000000  11010101000011  10101010110001    00000111111111  c0c52c
           150    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           151    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           152    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           153    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
    edited 2024-10-12 23:35
    Yes, font is rendered at double height. (and it is p2font16, just because that's already in interleaved format). Just because that was easier to hook up. It is re-doing it every line, it's just that the line counter is set up for 2x scaling. I did verify audio on my ASUS monitor, but that's the least picky out of my available sinks. Try it on your Pioneer to be sure.
  • This is what it should look like between the transitions (at normal NCO rate the whole time). I'm sending a test pattern that increments the blue channel by 4 each pixel.
           534    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           535    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           536    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           537    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           538    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           539    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           540    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           541    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
           542    Data:->  RGB (00_00_00)                   0100000000  0100000000  0100000000    0000011111  000000
           543    Data:->  RGB (00_00_04)                   1111111111  1111111111  0111111100    0000011111  000004
           544    Data:->  RGB (00_00_08)                   0100000000  0100000000  0111111000    0000011111  000008
           545    Data:->  RGB (00_00_0C)                   1111111111  1111111111  1111111011    0000011111  00000c
           546    Data:->  RGB (00_00_10)                   0100000000  0100000000  0111110000    0000011111  000010
           547    Data:->  RGB (00_00_14)                   1111111111  1111111111  0100001100    0000011111  000014
           548    Data:->  RGB (00_00_18)                   0100000000  0100000000  0100001000    0000011111  000018
    and
          1176    Data:->  RGB (00_09_E8)                   0100000000  0100000111  1000001101    0000011111  0009e8
          1177    Data:->  RGB (00_09_EC)                   1111111111  1111111000  1011110001    0000011111  0009ec
          1178    Data:->  RGB (00_09_F0)                   0100000000  0100000111  1000000101    0000011111  0009f0
          1179    Data:->  RGB (00_09_F4)                   1111111111  0100000111  1011111001    0000011111  0009f4
          1180    Data:->  RGB (00_09_F8)                   0100000000  1111111000  1011111101    0000011111  0009f8
          1181    Data:->  RGB (00_09_FC)                   0100000000  0100000111  1000000001    0000011111  0009fc
          1182    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1183    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1184    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1185    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1186    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1187    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
          1188    Ctrl:->  Blanking  VH=3       +V  +H      1101010100  1101010100  1010101011    0000011111  fdfd02
    edited 2024-10-12 23:40
    Oh wow, something's really broken in there. 11/9 duty clock, how come? I guess it sources it from the NCO counter somewhere? In that verilog snippet the serializer had its own counter, why not use that?
    So for a very theoretical P2 rev D, this should really be fixed in some way (+ add harware TERC4 modulation - possibly as %xxxxxxxx_xxxxxxxx_RRRRGGGG_BBBB010x ?)
  • The NCO switching is very simple with setq... here's my hacked up code with xxx and yyy being the two NCO rates I hacked in.
                if_z            call    #borderregion           'and go back to border generation
                                setq    xxx
                                xcont   m_rf, palselect         'generate the visible line
                                sub     regionsize, #1 wz       'decrement the region's size count
                if_z            call    #newregion              'when 0, reload another region
                                call    videomode               'create the next video scan line
                                setq    yyy
                                xcont   m_bs, hsync0            'generate horizontal FP blanking
    edited 2024-10-12 23:45
    Yeah TERC4 encode would be nice, plus HW pixel replication for DVI. Once you open up another rev the requests will start flying though.
    I think that Verilog might be from Rev A, the channel command formats didn't quite line up as I expected, or I was misreading it.
  • Oh, you think there was significant change there from A to B?
  • Yeah the whole streamer was rewritten IIRC.
  • From the old rev A doc:
