Propeller 1 Wiring — Parallax Forums
Propeller 1 Wiring
Hey y'all - (Did I do that right?)
I am looking for only wiring information on how to wire multiple Prop 1s together and on how to wire in external 512k memory.
Note - I have optoisolators that will be utulized to protect my Propeller chips.
This is not about coding, and its not about advanced circuitry, this is only how to wire multiple Propeller 1 together and how to wire 512k memory chips into each Propeller. Currently looking at 3-5 Propellers and each will have at least 2 512k for additional memory.
If you know how to wire these things please let me know. Any help is greatly appreciated.
  • You can link them with opto's and use RS232 to talk prop to prop
  • What kind of RAM you want to use? 2 times 512K eats a lot of pins.
    Another thing to consider is using a common clock for all propeller, not needed, but would allow for faster communication between them.
    As for programming Catalina C supports external RAM, just check with @RossH what sort of RAM is supported, but on the P1 you might run out of pins.
    Anyways, good luck, it is doable
  • One good resource for multiple props would be the Tetra-Prop, a quad prop array on a board about 2"*2". May take some digging since it showed up a few forum incarnations ago. Possibly also search for some threads for prop to prop comms for the Tetra-Prop.
    Couldn't locate it...
  • Hi
    you might find this interesting..
    https://forums.parallax.com/discussion/110563/triblade-prop-pcb-uses-3-propeller-ics-for-a-single-board-computer-sbc/p2
    from the ever inventive and productive cluso99... (Ray Rodrick)
    http://bluemagic.biz/cluso.htm
    https://www.clusos.com/home/triblade/
    and an OS
    https://forums.parallax.com/discussion/138251/clusos-propeller-os-v1-14-now-with-spin-pasm-compiler-eeprom-read-write/p1
    Also RossH has developed the following..... https://forums.parallax.com/discussion/175349/so-what#latest
    Yes, Catalyst is my OS for the Propeller 1 and Propeller 2. This is an updated list of features that will be in the next Catalyst reference manual:
    Features
    ● Compatible with any Propeller 1 or 2 platform that supports Catalina and has an SD card available (e.g. Hydra, Hybrid, TriBladeProp, RamBlade, DracBlade, C3, P2_EVAL, P2_EDGE);
    ● Support for SPIN or Catalina CMM (Compact Memory Mode) or LMM (Large Memory Mode) programs on any supported Propeller 1 platform;
    ● Support for SMM (SDCARD Memory Mode) and EMM (EEprom Mode) on the Propeller 1, which maximizes the memory available to Catalina CMM and LMM programs on any supported Propeller 1 platform;
    ● Support for Catalina CMM, LMM or NMM (Native Memory Mode) programs on any supported Propeller 2 platform;
    ● Support for Catalina XMM (External Memory Mode) programs on any supported Propeller 1or Propeller 2 platform equipped with external XMM RAM (e.g. Hybrid, TriBladeProp, RamBlade, DracBlade, C3, P2_EVAL, P2_EDGE);
    ● Support for multi-CPU platforms (e.g. TriBladeProp);
    ● Support for serial, TV or VGA Human Machine Interface on any supported Propeller 1 or Propeller 2 platform;
    ● Provides familiar SD card file management commands (e.g. ls, cp, mv, rm, mkdir, rmdir);
    ● Provides the vi full-screen text editor (requires a VT100 compatible terminal emulator if used with a serial HMI);
    ● Supports self-hosted Propeller development (in Pascal, Basic and Lua) on the Propeller 1 and Propeller 2;
    ● Supports self-hosted Propeller development (in C) on the Propeller 2;
    ● Supports Lua scripting – Lua scripts can be executed directly from the command line;
    ● Supports passing command line parameters to both C programs and Lua scripts and to SPIN or SPIN2 programs;
    ● Supports the YModem serial file transfer protocol, for transferring text and binary files between the Propeller and a PC;
    ● Supports auto-execution of command scripts on reboot and script execution from the command-line or from C or Lua;
    Ross.
    to search for these hidden gems I started with
    site:forums.parallax.com tribladeprop
    in the browser searchbar- its much better than using the parallax site navigator/search facility, and finds long lost posts no longer available.
    Dave
  • @"Francis Bauer"
    :D Sorry, I was referring to links in the thread messages.
    Craig
