Discussing SD Drivers (depreciated fsrw) - Page 8 — Parallax Forums
1234568
  • Cluso99 wrote: »
    And of course there is the SD pasm code that was running in late 2017 on the FPGA and was the precursor to what went into the ROM :sunglasses:
    https://forums.parallax.com/discussion/167839/p2-sd-card-boot-code-for-rom
    Remember I had different versions of Tachyon running on the P2 FPGA om my DE2-115 board in 2015 with multiple SD cards and FAT32.
    I was even using it in a project based on the P2 BeMicro CV-A9 FPGA early in 2016, in the faint hope that P2 silicon would soon be available :):(
    The TAQOZ ROM code does this same high-speed multiblock read that I do in TAQOZ RELOADED where I read in excess of 3MB/s at 300MHz.
    Here is where I ask TAQOZ to "print DISK" information:
    TAQOZ# .DISK ---  CARD: SANDISK   SD SC64G REV$80 #35190404 DATE:2018 /10
                       *** OCR ***
        VALUE........................... $C0FF_8000
        RANGE........................... 2.7V to 3.6V
                       *** CSD ***
        CARD TYPE....................... SDHC
        LATENCY......................... 1ms+1400 clocks
        SPEED........................... 50MHz
        CLASSES......................... 0 1 0 1 1 0 1 1 0 1 0 1
        BLKLEN.......................... 512
        SIZE............................ 62,367MB
        Iread Vmin...................... 10ma
        Iread Vmax...................... 25ma
        Iwrite Vmin..................... 60ma
        Iwrite Vmax..................... 35ma
                     *** SPEEDS ***
        LATENCY......................... 486us,253us,727us,637us,253us,1459us,771us,351us,
        SECTOR.......................... 387us,408us,428us,439us,409us,1608us,473us,454us,
        BLOCKS.......................... 3,151kB/s @300MHz
                       *** MBR ***
        PARTITION....................... 0 00 INACTIVE
        FILE SYSTEM..................... FAT32 LBA
        CHS START....................... 1023,254,63
        CHS END......................... 0,0,0
        FIRST SECTOR.................... $0000_8000
        TOTAL SECTORS................... 124,702,720 = 63,847MB
    00170: 0000_0000 0000_0001 0002_0000 506F_7250     '............ProP'
                      *** FAT32 ***
        OEM............................. TAQOZ P2
        Byte/Sect....................... 512
        Sect/Clust...................... 64 = 32KB
        FATs............................ 2
        Media........................... F8
        Sect/Track...................... $003F
        Heads........................... $00FF
        Hidden Sectors.................. 32,768 = 16MB
        Sect/Part....................... 124,702,720 = 63,847MB
        Sect/FAT........................ 15,222 = 7MB
        Flags........................... 0
        Ver............................. 00 00
        ROOT Cluster.................... $0000_0002 SECTOR: $0000_F70C
        INFO Sector..................... $0001 = $0000_8001
        Backup Sector................... $0006 = $0000_8006
        res............................. 00 00 00 00 00 00 00 00 00 00 00 00
        Drive#.......................... 128
        Ext sig......................... $29 OK!
        Part Serial#.................... $6269_0201 #1651048961
        Volume Name..................... P2 CARD    FAT32    ok
    TAQOZ#
  • Ahle2 wrote: »
    Dave,
    How is p2gcc coming along? I would love program the P2 in C++ with all the bells and whistles (but I would only use a subset that is known to perform well on MCU's of course)
    /Johannes
    @ntosme2 was working on a GCC port for P2 last year and had some success but it has gone quiet and I think he needed more help/work to progress further... this thread is the one discussing it.
    https://forums.parallax.com/discussion/comment/1478650/#Comment_1478650
    Cluso99 wrote: »
                       *** OCR ***
                       *** CSD ***
                     *** SPEEDS ***
                       *** MBR ***
                      *** FAT32 ***
    TAQOZ#
    I'm sure if we look back at P2HOT we'll see things running on it too :)
  • msrobots wrote: »
    One thing I really liked with @lonesock's SD SPI driver is the read ahead and write behind feature.
    Sadly I lost all my files for the RAISD project (4 SDs on one quickstart) thru a messed up Windows Update, I had managed to use @lonesocks SD SPI block driver inside @Kye's Fat_Engine, and both (Fsrw and Fat_Engine) could do transfers around 1,200 kbytes/second on a P1 with 80 Mhz.
    Hey Mike,
    Its been a while & saw an email notification on this thread. I still happened to have your old codes with me. Not sure if it helps but let me zip them up & forward to you via email.
  • I have archives upon archives. I'm not sure which was the lastest but this is 2.6
  • RaymanRayman Posts: 16,234
    edited 2020-05-26 14:26
    I'm pretty sure FSRW 2.6 for P1 is in OBEX...
  • Here's what I have, sorry it's a bit of a mess.
    Jonathan
    edited 2020-05-26 15:41
    @lonesock You're still here! That's great. Feel free to take over my part in the FSRW for P2 project.
    There are a lot of improvements that can be made. Things like "release" and timeout and read-ahead, write-behind for example...
    It works well enough for what I need, but there's a lot that could be done to make it better.
  • Well, I still exist, but unfortunately I haven't had much time for prop development. [8^(
    I do pop into the forum every once in a while to try to keep tabs on the P2's progress, but I am certainly not well versed enough in the P2 internals to do the kind of code dev that would be considered elegant. I will try to get back in, but I don't know when that will be, sorry!
    thanks,
    Jonathan
  • evanhevanh Posts: 17,167
    edited 2021-10-29 12:12
    Got the demo fixed up enough to work in both Pnut and FlexSpin. It had seriously failed syntax in modern Pnut. Lots of fixes all round. Also streamlined the bashed code to get both reliable operation and more speed.
    It consistently times-out on first of the 20 mount attempts. Haven't tried to determine why. Otherwise seems reliable at reading. The demo doesn't do any writing so that's not tested at all.
    PS: I only just started looking at it - https://forums.parallax.com/discussion/comment/1530713/#Comment_1530713
    EDIT: Oops, file missing from the zip ... fixed. :)
    EDIT2: bashed bug fixed
    EDIT3: "fast_bashed" with +1 to trailing SPI clock pulses
    EDIT4: "fast_bashed" ACMD41 fixed
    edited 2021-10-28 12:21
    Oh, bother, while fast_bashed works with both compilers, the initial cleaned up bashed compiles but doesn't fully work with Pnut. Hmm, quite a lot of little changes between the two as well as the major streamlining ...
    EDIT: Solved! One last syntax fix, which I'd also dealt with in fast_bashed. All the REP instructions had to be changed from REP #label to REP @label. Interestingly, it doesn't create any errors or warnings in Pnut, and of course # works without issue in FlexSpin.
  • JonnyMacJonnyMac Posts: 9,787
    edited 2021-10-28 16:31
    Question about your use of waitct() here (from the sdspi_fast_bashed) object.
        org
            getct   t
        end
        starttime := t
        repeat 3
            t := cmd(0, 0)
            pinh(cs)               ' Deselect the card to terminate a command.
            waitct(100)
    In this case it would wait for that specific value (100) in the system counter. Am I missing something?
  • Jon,
    waitct() must be an object, not the the built-in waitcnt().. right?
  • Doh..spin 2
  • Yeah, it's called waitct() in Spin2. The supporting method is called getct() in Spin2.
    edited 2021-10-29 00:08
    getct() retrieves the absolute counter value but waitct() is specifying an interval to pause for. So waitct() method compiles directly to the single instruction WAITX. Or at least it does in FlexSpin on Prop2.
    Lol, I see that's still got the GETCT assembly in there. The original FSRW code was ported long before Spin2 was fully developed. Methods like getct() weren't part of Spin2 early on.
    edited 2021-10-29 01:39
    I had a look around the forum last night and found Rayman's effort that includes a helper cog for the bit-bashing - https://forums.parallax.com/discussion/171619/fsrw-usd-card-read-write-for-p2-with-2-4-mb-s-read-speed/p1
    A quick patch to his "sdspi_asm_mb.spin2" for my debug method and it worked with my edition of FSRW and test3 demo code. And I immediately noted it doesn't have that initial timeout I mentioned above. So maybe a good time to investigate ...
    EDIT: Grr, another difference between Pnut and FlexSpin: Can't directly reference a child object's variables in Pnut. Only methods and constants apparently.
    EDIT2: Testing with a second SD card I've found I've trimmed off too many of the trailing SPI clock pulses. I'm pretty certain I'd made it the required 8 pulses but one extra is needed to make a Sandisk Extreme happy. See attachments above.
  • ...waitct() is specifying an interval to pause for...
    In Chip's Spin2, waitct() is waiting for a target value to be matched or passed.
    This is from the Spin2 interpreter:
    ' a: POLLCT(tick)                       (15 longs)
    ' b: WAITCT(tick)
    pwct            getct   w               'a m    a: POLLCT(tick)
                    cmpm    w,x     wc      'a m    m: WAITCT(tick)
            if_c    jmp     #pwct           '| m
            _ret_   popa    x               '| m    (continued in op_rel)
    Still, I thought I should check, so I wrote this little test snippet:
      repeat
        t := getct()
        waitct(100)
        t := getct() - t - 40
        term.dec(x++)
        term.tx(term.TAB)
        term.dec(t)
        term.tx(13)
        waitms(1000)
    And got this result:
    0       40
    1       40
    2       40
    3       40
    4       40
    5       40
    6       40
    7       40
    8       40
    9       40
    10      40
    11      40
    12      40
    13      40
    14      40
    15      40
    16      40
    17      40
    18      40
    19      40
    20      2132448384
    21      40
    22      40
    It looks like those are appropriate deltas reported. I haven't actually done much reading of the spin docs myself. The spin code is pre-written here so I just fixed what was getting errors. My focus is the assembly generally.
    edited 2021-10-29 06:48
    Regarding that interpreter snippet, x isn't defined there. The docs says x should be 100 but the behaviour suggests it is a snap of CT+100.
    edited 2021-10-29 10:49
    Oh, I see where you were looking now Jon. You'd followed me in looking at the mount process. I've now replaced all the waitct() lines with waitus() or waitms(). The CT timing wasn't really suited to an arbitrary clock frequency anyway.
    Well, I seem to have found the key difference between the two low level mounting methods. The parameter for ACMD41 was different. I've copied the parameter from sdspi_asm_mb.spin2 into sdspi_fast_bashed.spin2 which has stopped the timeouts. :)
    Ha, doing a bit of reading, it looks like what was happening was the dodgy ACMD41 was requesting the card change signalling voltage. but such an operation needs a following CMD11 in sequence to execute the voltage switch. Since the CMD11 never gets sent the card presumably fails to respond to what comes next. Hence the timeout.
    edited 2021-10-29 13:10
    A small tweak to FSRW code and I've got pread() going almost as fast as FastBlocksRead(). pread() was doing a seemingly unneeded block copy for each and every read block.
    Both methods are now heavily limited by a block request delay, imposed by the SD card, that I suspect always occurs when initiating a read. The seemingly obvious way to improve it is to change from using the single-block command, CMD17, to using the multi-block command, CMD18. I think that'll be next on my list of to-do's.
  • I appreciate you doing this, Evan. I always use FSRW in my P1 projects -- having it for the P2 will be helpful.
    Nice challenge. And get to learn about SD cards at the same time.
    Think I've blundered earlier with the 8 trailing clock pulses too. I had thought they were literally just a tail, there was something in the PDF about that. But in reality it looks like they're the 16-bit CRC clocks. Even when CRC is disabled, the 16 bit spaces for it still exist.
    edited 2021-10-29 15:33
    Oooo, nearly 5 MB/s overclocked SPI. It work! :)
    Hehe, and that's not even the Sandisk.
    edited 2021-10-29 16:20
    I'm struggling to see any real difference between "Default Speed" and "High Speed". It seems to be identical except for the obvious higher rate. I've found the setting process, issue CMD6 with value $80000001 for the parameter. There is optional extra bits for changing the drive strength and current limit but I doubt that's needed nor recommended.
    The timings are tighter but that's a natural side effect of upping the clock rate anyway. Nothing else changes as far as I can see.
    PS: My above overclocking is basically in High Speed mode already. Just not set as such in the mode register.
  • Wuerfel_21Wuerfel_21 Posts: 5,831
    edited 2021-10-29 18:08
    High Speed mode is just that - the card advertises that you may clock it faster and then you just do that. Or just don't bother checking, pretty much all cards can handle high speed (and often can be overclocked beyond that to 100 MHz - UHS-capable cards generally can because why wouldn't they? Though at that point I'd make sure you're actually computing CRCs)
    hmmm ...
