New BASIC compiler for Prop1 and Prop2 - Page 9 — Parallax Forums
1679111220
  • Does anyone have a copy of propeller-load.exe, that I could download? I cannot seem to find one here on the forums. It seems I have deleted my previous versions of fastspin, that contained propeller-load.exe.
    Ray
  • Rsadeika wrote: »
    Ray
    propeller-load.exe is part of SimpleIDE. If you have that installed you should have it. So you're thinking this is a problem with proploader.exe? If so, please file a bug report in GitHub. proploader.exe is the program that Parallax is using now so we should make sure it works correctly.
  • I just checked my version of SimpleIDE, and it has proploader.exe, not propeller-load.exe. The version in my SimpleIDE is v1.0-24, and when I ran the test1.binary, with that version, it displays the same clobbered chars.
    Ray
  • Rsadeika wrote: »
    Ray
    Sorry if you've already done this but could you provide your code so I can try to duplicate this problem?
    edited 2018-10-25 12:46
    This is a copy from ProplyBlock, so it should be recent.
    (BTW I found propeller-load in my SimpleIDE folder)
  • The attached zip file contains both, test1.bas and test1.binary.
    Ray
  • Rsadeika wrote: »
    Ray
    Thanks! I'll try to look at this tonight. I'm at work at the moment.
  • I just tested the test1.binary with the propeller-load.exe program, and it looks like the print string is not clobbered. It is showing what is expected. I will run some of my other test... programs with propeller-load.exe to see if anything else runs the way I expect it to.
    Ray
    G:\fastspin\temp>propeller-load -p COM3 -t -r g:/fastspin/programs/test1/test1.binary
    Propeller Version 1 on COM3
    Loading g:/fastspin/programs/test1/test1.binary to hub memory
    1676 bytes sent
    Verifying RAM ... OK
    [ Entering terminal mode. Type ESC or Control-C to exit. ]
    will I see something
  • Rsadeika wrote: »
    Ray
    1676 bytes sent
    In thinking about this it might be that proploader.exe uses a much higher baud rate to download your code and then switches to the target baud rate when the program starts. There may be an issue with that transition. You could try using proploader.exe with "-D fast-loader-baud-rate=115200" to get it to use 115200 for the download as well as terminal mode and see if that solves the problem.
  • Ah, I'm able to reproduce the issue now Ray (thanks for posting your binary). It does seem to be a timing issue related to startup -- propeller-load doesn't show it, but proploader does (presumably proploader is slightly slower at starting to look at the serial port?). Putting a delay in at the beginning, as Ron suggested, seems to fix it for me. A 1 millisecond delay is not enough, but 10 milliseconds does the trick.
    David, thanks for looking at this. I'm not sure if there's any way for proploader to get into its serial port receive routines faster. I suspect we haven't seen this before because regular Spin and even PropGCC CMM are slow enough that there's probably a baked in delay before anything can be printed. But PropGCC LMM can show the problem too. For example:
    #include <stdio.h>
    int main() {
        int i;
        for(i = 0; i < 4; i++) {
            printf("hello, world!\n", i);
        return 0;
    shows some garbage for the first one or two lines when compiled with LMM mode and -Os and run with proploader. The last 2 or 3 lines come out OK.
  • Did you try setting fast-loader-baud-rate to 115200? Does that fix the problem?
  • I just did a test run of my test.temp.binary using the propeller-load.exe. I added the delay that Eric suggested, and the program runs, but the temp and humid values are way out of the normal. At least I got something to shyow on the terminal.
    Ray
    rem test_temp.bas
    ' October 13, 2018
    ' Test of the CM2302 module on the WX Activity Board
    dim cm2302 as class using "DHTnn_Object.spin"
    let mscycles = clkfreq / 1000
    sub pausems(ms)
    	waitcnt(getcnt() + ms * mscycles)
    end sub
    dim temp#,humid#,misc#
    cm2302.StartDHTnn(8,22,@temp#,@humid#,@misc#)
    waitcnt(getcnt() + 10_000_000)
    print "Did I get this far."
    do
    	cm2302.DHTnn_Read()
    	print "Temp ";(9.0/5.0)*temp# + 32.0;"  Humid  ";humid#
    	pausems 3000
    loop
    G:\fastspin\temp>propeller-load -p COM4 -t -r g:/fastspin/programs/test_temp/test_temp.binary
    Propeller Version 1 on COM4
    Loading g:/fastspin/programs/test_temp/test_temp.binary to hub memory
    8908 bytes sent
    Did I get this far.
    Temp 103.46 Humid 1.1093E+09
    Temp 105.26 Humid 1.1096E+09
    Temp 106.88 Humid 1.1098E+09
    Temp 105.80 Humid 1.1097E+09
    Temp 105.08 Humid 1.1096E+09
  • rsutrsut Posts: 45
    edited 2018-10-25 16:51
    Eric
    I think noise maybe part of the problem.
    Try this
    rem test_noise.bas
    ' Declarations
    const pin = 30
    direction(pin) = output
    pausems 5
    'Main
    print "Now watch the cursor carefully"
    do
    	output(pin) = not output(pin)
    	pausems 1000
    loop
    This would indicate that the print channel is still open.
    Given that there is also a problem with the back to back read/write with fsrw, It begs the question as to
    whether the two problems are related.
    Ron
    Regards
    Ron
  • David Betz wrote: »
    Setting fast-loader-baud-rate to 115200 does fix the problem. So it seems it's something in the transition from the fast download speed to the "normal" 115200 that causes the corruption. It may even be an OS issue? Although it seems to happen on both Windows and Linux.
  • ersmith wrote: »
    David Betz wrote: »
    Are you sure it's not just a timing issue? The Propeller program may start sending data before the PC side has changed its baud rate. There may be nothing that can be done about this other than inserting a delay.
  • rsut wrote: »
    Eric
    Try this
    rem test_noise.bas
    ' Declarations
    const pin = 30
    pausems 5
    'Main
    do
    	pausems 1000
    loop
    Ron
    Pin 30 is the serial pin, so if you explicitly toggle it then strange things are going to happen on the terminal. I don't think there's any way around that!
    The back to back read/write problem with fsrw was a bug in the BASIC close function. That'll be fixed in the next release. Is there some other read/write problem you've noticed (when BASIC close is not called)?
    Eric
  • ersmithersmith Posts: 6,231
    edited 2018-10-25 18:37
    David Betz wrote: »
    ersmith wrote: »
    David Betz wrote: »
    Good point, it may be that the only solution is to insert a delay (or to use -D fast-loader-baud-rate=115200). Having a delay at the start of the program is pretty common, so that may not be too bad.
  • ersmith wrote: »
    David Betz wrote: »
    ersmith wrote: »
    David Betz wrote: »
    I'll check with Jeff Martin but it might be friendlier to provide a simple option to disable the "fast loader" other than the cumbersome way of setting the fast loader speed the same as the terminal emulator speed. propeller-load doesn't have this problem because it doesn't have a fast loader.
  • jmgjmg Posts: 15,198
    ersmith wrote: »
    David Betz wrote: »
    Any change in Baud speed, does take time in modern OS.
    If the Prop is alive at that stage, it could easily send-before ready.
    Options would be to delay as discussed (somewhat klunky, but works), or wait on some ready signal from the PC side.
    It may be possible to define an optional char the fast loader can send, when it is speed-changed, to give a simple handshake that acts as a ready signal ?
    David Betz wrote: »
    That's one workaround, but for those wanting to keep fast loader, and friendly, you could also ask Jeff about a user optional ready Char it can send when terminal is 'up' at changed baud speed.
  • Eric
    Ok, that's good to know I just assumed the output port would close after a print and the input port
    would open (they would toggle). I now understand why that would never work.
    No other issues. Looking forward to the next release :smile:
    Ron
  • My setup, for now is, using spin2gui to compile, and from the command line, use the propeller-load.exe to run the program.
    Below is my test_temp program and the values that are being printed are way off. Did something happen to the '#' floating point variable, in the last update of fastspin?
    I also tried using '%' integer variable in place of '#', to see what would happen, still was getting some way off results. I also noticed that by using '%' integer variable, it increased the size of the program by ~4000. I thought it would be the other way around.
    Ray
    rem test_temp.bas
    ' October 13, 2018
    sub pausems(ms)
    end sub
    do
    	cm2302.DHTnn_Read()
    	pausems 3000
    loop
    G:\fastspin\temp>propeller-load -p COM4 -t -r G:/fastspin/programs/test_temp/test_temp.binary
    Loading G:/fastspin/programs/test_temp/test_temp.binary to hub memory
    8852 bytes sent
    Temp 106.52 Humid 1.1098E+09
    Temp 107.06 Humid 1.1098E+09
  • RaymanRayman Posts: 15,899
    I think I'm close to having a decent colorizer for FastBasic in SpinEdit (see attached).
    Been so long since I've used BASIC, I think I need to relearn...
    937 x 910 - 45K
    edited 2018-10-27 17:52
    I think I see some keywords not in documentation's list:
    waitcnt getcnt clkfreq waitpeq waitpne const heapsize new delete chr$
    Also, what is with "mscycles"?
    Do you need to define it to use "pausems"?
    Got my little test program to compile after fixing the way fullduplex serial is used.
    Think the way described in the docs is old, one should use "class" now...
    Does this look OK?
    rem simple program to toggle a pin while outputting characters
    '' create a Spin FullDuplexSerial object
    class fullduplex using "FullDuplexSerial.spin"
    dim ser as fullduplex
    'Going to toggle pin #1 every 1/10 of a second
    const pin = 1
    rem first, wait for user to press a key in serial terminal
    var r = ser.rx()
    'Then, loop forever
    do
      ser.tx("Hello.")
      ser.tx(13)
      pausems 1000
    loop
    That compiles for P1, but for P2 I get this:
    D:\Propeller\Code\SpinEdit\temp>fastspin -2 BasEditTest1.bas
    Propeller Spin/PASM Compiler 'FastSpin' (c) 2011-2018 Total Spectrum Software Inc.
    Version 3.9.7 Compiled on: Oct 21 2018
    BasEditTest1.bas
    |-FullDuplexSerial.spin
    FullDuplexSerial.spin(191) error: syntax error, unexpected identifier `Jmpret'
    FullDuplexSerial.spin(202) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(209) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(213) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(233) error: syntax error, unexpected identifier `Jmpret'
    FullDuplexSerial.spin(256) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(264) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(269) error: syntax error, unexpected ':'
    FullDuplexSerial.spin(271) error: syntax error, unexpected ':'
    Got it to work by replacing fullduplexserial stuff with "print".
    Works on P2. See the CR is automatic now.
    Used p2load, works fine. Can use propellent for P1, I think.
    Wish there was a simple input method to go with "print"... Something like GetChar or something...
  • Rayman wrote: »
    Look for `input$()` in FastSpin-BASIC's doc.
    edited 2018-10-27 18:31
    I see this:
    ### INPUT$
    A predefined string function. `input$(n, h)` reads `n` characters from handle `h`, as created by an `open device as #h` statement.
    The open device thing looks like a pain for something that is supposed to be easy...
    "print" works without any setup...
    Anyway, this sample code seems to work fine on P2:
    'Going to toggle pin #1 every second
    const pin = 1
    'Will show count of how many times toggle
    var c = 0
    'Then, loop forever
    do
      print "Toggled ";c;" times."
      c = c + 1
      pausems 1000
    loop
  • yetiyeti Posts: 819
    edited 2018-10-27 18:36
    If no `h` is specified (just `input$(n)` is used) then the default serial device will be used.
    print input$(80)
    Thanks! that does work for P1.
    For P2, I think there's a bug because I get this:
    error: Unknown symbol _rx
